    4. Servicemeldung ccu
    Servicemeldung ccu
    • Peoples
      Peoples last edited by
      Habe es gerade mal bei mir reingepackt und durchlaufen lassen, ich habe keine Fehlermeldungen.
      Was habt ihr denn für ne Javascript-Adapter version?
        4.0.5
        17.12.2018, 23:32:15.699	[info ]: javascript.0 Stop script script.js.System.System_Homematic_Servicemeldungen
        17.12.2018, 23:32:16.252	[info ]: javascript.0 Start javascript script.js.System.System_Homematic_Servicemeldungen
        17.12.2018, 23:32:16.256	[warn ]: javascript.0     at count (script.js.System.System_Homematic_Servicemeldungen:41:22)
        17.12.2018, 23:32:16.256	[warn ]: javascript.0     at script.js.System.System_Homematic_Servicemeldungen:53:9
        17.12.2018, 23:32:16.256	[warn ]: javascript.0     at countService (script.js.System.System_Homematic_Servicemeldungen:52:21)
        17.12.2018, 23:32:16.256	[warn ]: javascript.0     at script.js.System.System_Homematic_Servicemeldungen:115:1
        17.12.2018, 23:32:16.257	[warn ]: javascript.0     at countService (script.js.System.System_Homematic_Servicemeldungen:52:21)
        17.12.2018, 23:32:16.257	[warn ]: javascript.0     at script.js.System.System_Homematic_Servicemeldungen:115:1
        17.12.2018, 23:32:16.257	[warn ]: javascript.0     at script.js.System.System_Homematic_Servicemeldungen:57:22
        17.12.2018, 23:32:16.257	[warn ]: javascript.0     at countService (script.js.System.System_Homematic_Servicemeldungen:56:28)
        17.12.2018, 23:32:16.257	[warn ]: javascript.0     at count (script.js.System.System_Homematic_Servicemeldungen:41:22)
        17.12.2018, 23:32:16.257	[warn ]: javascript.0     at script.js.System.System_Homematic_Servicemeldungen:65:9
        17.12.2018, 23:32:16.257	[warn ]: javascript.0     at countService (script.js.System.System_Homematic_Servicemeldungen:64:20)
        17.12.2018, 23:32:16.257	[info ]: javascript.0 script.js.System.System_Homematic_Servicemeldungen: Homematic-Servicemeldungen:
        17.12.2018, 23:32:16.257	[info ]: javascript.0 script.js.System.System_Homematic_Servicemeldungen: Anzahl Homematic-Servicemeldungen: 0
        17.12.2018, 23:32:16.257	[info ]: javascript.0 script.js.System.System_Homematic_Servicemeldungen: registered 74 subscriptions and 1 schedule
        • Peoples
          Daran wirds liegen, hatte einige Scripte die nicht mehr richtig gelaufen sind. Bin wieder zurück auf stable und seit dem alles wieder gut. Sonst habe ich nichts geändert.
          • totocotonio
            totocotonio last edited by
            woran könnte es denn dann liegen?
            Er geht auf jedanfall nicht mehr.
            • eric2905
              eric2905 last edited by
              @totocotonio:
              woran könnte es denn dann liegen? `
              das hat peoples doch geschrieben:
              @peoples:
              Daran wirds liegen, hatte einige Scripte die nicht mehr richtig gelaufen sind. Bin wieder zurück auf stable und seit dem alles wieder gut. Sonst habe ich nichts geändert. `
              An der JavaScript-Version (4er Version) aus dem Latest-Repository.
              Nachdem er den Downgrade gemacht hat, läuft es wieder.
              Hast Du auch die 4er-Version im Einsatz?
              Gruß,
              Eric
              Von unterwegs getippert
              • totocotonio
                ja ich hatte die 4 Version im Einsatz.
                Jetzt einen Downgrade auf die 3er Version .
                Es wird mir trotzdem noch die 4er angezeigt das sie inst. wäre.
                Jetzt kommen noch mehr Fehlermeldungen :oops:
                • Peoples
                  war bei mir auch so, (downgrade ohne vorheriges löschen ging nicht) ich musst den Adapter komplett löschen, aber sichere vorher lieber mal deine Scripte.
                  Ich bin das alles umgangen indem ich einfach eines meiner alten Komplett Backups widerhergestellt habe.
                  • totocotonio
                    sind die Scripte weg wenn ich den Adapter lösche?
                    hier die Fehler
                    javascript.0	2018-12-22 14:28:14.746	error	at Object. <anonymous>(script.js.common.Service.Stromverbrauch:75:19)
                    javascript.0	2018-12-22 14:28:14.745	error	at entferneDatenpunkt (script.js.common.Service.Stromverbrauch:266:11)
                    javascript.0	2018-12-22 14:28:14.745	error	Error in callback: TypeError: Cannot read property 'indexOf' of undefined
                    javascript.0	2018-12-22 14:27:47.813	error	at Object. <anonymous>(script.js.common.Service.Stromverbrauch:75:19)
                    javascript.0	2018-12-22 14:27:47.813	error	at entferneDatenpunkt (script.js.common.Service.Stromverbrauch:266:11)
                    javascript.0	2018-12-22 14:27:47.813	error	Error in callback: TypeError: Cannot read property 'indexOf' of undefined
                    javascript.0	2018-12-22 14:27:44.252	error	at script.js.common.Service.Servicemeldung_der_ccu:52:9
                    javascript.0	2018-12-22 14:27:44.252	error	at count (script.js.common.Service.Servicemeldung_der_ccu:42:34)
                    javascript.0	2018-12-22 14:27:44.252	error	TypeError: Cannot read property 'split' of undefined
                    javascript.0	2018-12-22 14:27:44.252	error	^
                    javascript.0	2018-12-22 14:27:44.252	error	var Geraet = temptext.split(':');
                    javascript.0	2018-12-22 14:27:44.252	error	script.js.common.Service.Servicemeldung_der_ccu: script.js.common.Service.Servicemeldung_der_ccu:42
                    javascript.0	2018-12-22 14:27:44.252	warn	at script.js.common.Service.Servicemeldung_der_ccu:52:9
                    javascript.0	2018-12-22 14:27:44.251	warn	at count (script.js.common.Service.Servicemeldung_der_ccu:39:22)
                    javascript.0	2018-12-22 14:27:44.251	warn	getState "hm-rpc.2.LEQ0257346.0.UNREACH" not found (3) states[id]=null
                    javascript.0	2018-12-22 14:27:44.251	warn	at script.js.common.Service.Servicemeldung_der_ccu:52:9
                    javascript.0	2018-12-22 14:27:44.249	warn	at count (script.js.common.Service.Servicemeldung_der_ccu:39:22)
                    javascript.0	2018-12-22 14:27:44.248	warn	getState "hm-rpc.2.KEQ0956203.0.UNREACH" not found (3) states[id]=null
                    javascript.0	2018-12-22 14:27:44.248	info	Start javascript script.js.common.Service.Servicemeldung_der_ccu
                    javascript.0	2018-12-22 14:27:37.945	info	Stop script script.js.common.Service.Servicemeldung_der_ccu
                    javascript.0	2018-12-22 14:27:12.930	error	at script.js.common.Service.Servicemeldung_der_ccu:52:9
                    javascript.0	2018-12-22 14:27:12.930	error	at count (script.js.common.Service.Servicemeldung_der_ccu:42:34)
                    javascript.0	2018-12-22 14:27:12.930	error	Error in callback: TypeError: Cannot read property 'split' of undefined
                    javascript.0	2018-12-22 14:27:12.930	warn	at script.js.common.Service.Servicemeldung_der_ccu:52:9
                    javascript.0	2018-12-22 14:27:12.929	warn	at count (script.js.common.Service.Servicemeldung_der_ccu:39:22)
                    javascript.0	2018-12-22 14:27:12.929	warn	getState "hm-rpc.2.LEQ0257346.0.UNREACH" not found (3) states[id]=null
                    javascript.0	2018-12-22 14:27:12.929	warn	at script.js.common.Service.Servicemeldung_der_ccu:52:9
                    javascript.0	2018-12-22 14:27:12.929	warn	getState "hm-rpc.2.KEQ0956203.0.UNREACH" not found (3) states[id]=null</anonymous></anonymous>
                    • Peoples
                      @totocotonio:
                      Kann ich dir nicht sagen, nur wenn das dann so ist wäre es unschön….
                      deshalb lieber vorbeugen
                        excalibur270 last edited by
                        Hallo. Wie bekomme ich den downgrade hin? Bei mir wird im expertenmodus bei dem Adapter kein pull-down angezeigt.
                          Sempre last edited by
                          Hi Excalibur270,
                          du bist aber schon im Expertenmodus? SObald du diesen aktiviert hast, hast du in dem jeweiligen Adapter ein kleines Quadrat mit einem Plus darin und darüber kanst du dann bestoimmen welche Version des Adapters zu installieren willst. Darüber bekommst du dann auch ein Downgrade der aktuellen Version hin, eventuell nach der Installation der vorherigen Version einen manuellen Upload machen.
                          Sempre
                            @excalibur270:
                            Bei mir wird im expertenmodus `
                            Screenshot bitte
                            @excalibur270:
                            bei dem Adapter `
                            wirklich Adapter, oder suchst du bei Instanzen?
                            Screenshot bitte
                            Rainer
                              @Homoran:
                              @excalibur270:
                              Screenshot bitte
                              @excalibur270:
                              bei dem Adapter `
                              Screenshot bitte
                              Rainer `
                              Hallo Rainer. Ich gehe mittlerweile davon aus das bei mir das System im Ar… ist. Das hatte ich schon in einem anderen Beitrag geschrieben wo du angegeben hast ein neues Image bereitzustellen.
                              Ich habe heute mal ein komplett Backup eingespielt. Erst War soweit alles okay. Js War bei 3.6. Mir wurde auch ein update für backitup angezeigt. Jedoch nach einer Stunde ging es wieder los. Scripte laufen nicht mehr. Wenn ich ein neues erstelle taucht es bei enabled in Js. 0 nicht auf. Bei Servicemeldungen die Objekte werden gar nicht mehr angelegt.
                              Ich hatte das Image vom April installiert. Nach einer defekten sd konnte ich kein Backup einspielen. Also neu aufgesetzt. Alles nach Anleitung gemacht. Da hatte ich dann auf einmal
                              Unterschiedliche node und nodejs Versionen drauf und die Probleme nahmen ihren Lauf. Es dauerte auch knapp 2 Stunden bis ich überhaupt auf den Broker kam. Beim ersten mal waren das keine 20 Minuten. Hat evtl was mit diesen neuen Routinen zu tun. Kp. Bin gerade erst am Anfang mit pi und Broker. Derzeit freeze der Broker regelmäßig. Deswegen warte ich auf das neue Image da ich mir das von Hand noch nicht zutraue.
                              1861
