    4. [Adapter] Sonoff- Tasmota
    • smartboart
      smartboart last edited by
      ist her im prinzip alles gut erklärt…
      https://github.com/arendst/Sonoff-Tasmo ... leshooting
      2.3.0
      All Tasmota features works
      Modem Sleep works to save energy (see Wiki Energy Saving)
      WEB UI is slow
      Low Ram Available - Not much features can be enabled at once (sensors, etc)
      It has the Krack Vulnerability
      Software Serial can produce a restart exception (not enough RAM) if several features are enabled. (So, in this case only hardware serial will work - TX and RX pins)
      Most Wifi Repeaters produces conflicts and disconnections
      Mesh Networks are not supported
      Some Routers of brands Ubiquity and Fritzbox produces conflicts and disconnections
      If the wifi router has auto channel it is reliably managed the channel's jump by this core
      2.4.0:
      This core has several bugs and produces wifi disconnections. Do not use.
      2.4.1:
      2.4.2: (By releasing the firmware 6.4.0, the Arduino Core used is v2.4.2 by default)
      All Tasmota features works except Alexa that needs a patch in the core (in the precompiled bins this patch is included)
      Modem Sleep don't works but Tasmota has a CPU dynamic sleep to save energy, so it is not a big issue for this core
      WEB UI is faster
      Serial Software exceptions of 2.3.0 are solved
      Krack Vulnerability is solved.
      More RAM is available
      Firmware is a little bigger in size
      If the wifi router has auto channel, it is not very reliable how it is managed the channel's jump by this core. Use Fixed Channels in the router instead.
      2.5.0:
      Alexa works
      WEB UI is faster
      Much More RAM is available compared to 2.4.2
      Firmware is a little bigger in size compared to 2.4.2
      Most Wifi Repeaters don't produces conflicts or disconnections
      Mesh Networks are supported
      Most Routers of brands Ubiquity and Fritzbox don't produces conflicts or disconnections
      If the wifi router has auto channel, it is not very reliable how it is managed the channel change by this core. Use Fixed Channels in the router instead.
        ltsalvatore last edited by
        @Jan1:
        Mit Atom kannst das in der platformio.ini einstellen welche Core verwendet wird. Das bin lässt sich dann wie gehabt über die Weboberfläche flashen. Derzeit ist in Tasmot wieder der 2.4.2 als default drin und der hat einige Probleme. Also entweder den 2.3.0 oder den neuen 2.5.0, wobei der neue laut Beschreibung einige gute Verbesserungen beinhaltet und bei mir auch bis jetzt ohne Probleme läuft. `
        Hi zusammen,
        ich habe die tage eine meiner sonoff basics über das webfrontend auf die neuste v6.4.1 aktualisiert.
        nach dem update lief diese ein paar stunden ohne probleme und irgendwann im laufe des tages ging dann gar nichts mehr.
        die led war dauerhaft am blinken und die wlan verbindung war (laut fritzbox) nicht mehr vorhanden.
        jetzt bin ich nochmal hingegangen und habe die bin über atom erstellt und nudemcu (mit nem erase flash) hochgeladen.
        da ich hier und da ein paar schwierigkeiten hatte mit atom die bin zu erstellen, bin ich dann zufällig auf diesen thread gestoßen und habe das erste mal etwas über eine core version gelesen.
        jetzt würde ich gerne die vorhandene 2.4.2 core, welche, so wie ich gelesen habe, probleme macht, auf die 2.5.0 aktualisieren.
        jedoch gelingt mir das über atom nicht so richtig bzw. habe ich nicht ganz verstanden, wo exakt ich diese einstellung in der platformio.ini vornehmen muss.
        danke schon mal im voraus.
          dirkhe Developer last edited by
          Unter dem Bereich Common stehen die verschiedenen Versionen, einfach die 2.4 auskommentirrennhnc die 2.5 einkommentieren, indem du die semicolon wegmachst, bzw. Hinzufügst
            @dirkhe:
            Unter dem Bereich Common stehen die verschiedenen Versionen, einfach die 2.4 auskommentirrennhnc die 2.5 einkommentieren, indem du die semicolon wegmachst, bzw. Hinzufügst `
            hm…
            bei mir steht im bereich common nichts dergleichen....
            [common]
            framework                 = arduino
            board                     = esp01_1m
            board_build.flash_mode    = dout
            platform                  = ${core_active.platform}
            build_flags               = ${core_active.build_flags}
            ;                            -DUSE_CLASSIC
            ;                            -DBE_MINIMAL
            ;                            -DUSE_SENSORS
            ;                            -DUSE_BASIC
            ;                            -DUSE_KNX_NO_EMULATION
            ;                            -DUSE_DISPLAYS
            ;                            -DUSE_CONFIG_OVERRIDE
            ; *** Fix espressif8266@1.7.0 induced undesired all warnings
            build_unflags             = -Wall
            ; set CPU frequency to 80MHz (default) or 160MHz
            board_build.f_cpu         = 80000000L
            ;board_build.f_cpu         = 160000000L
            monitor_speed             = 115200
            upload_speed              = 115200
            upload_resetmethod        = nodemcu
            ; *** Upload Serial reset method for Wemos and NodeMCU
            upload_port               = COM5
            extra_scripts             = pio/strip-floats.py
            ; *** Upload file to OTA server using SCP
            ;upload_port               = user@host:/path
            ;extra_scripts             = pio/strip-floats.py, pio/sftp-uploader.py
            ; *** Upload file to OTA server in folder api/arduino using HTTP
            ;upload_port               = domus1:80/api/upload-arduino.php
            ;extra_scripts             = pio/strip-floats.py, pio/http-uploader.py
              Sorry war falsch
              [core_active]
              ; Select one core set for platform and build_flags
              ;platform                  = ${core_2_3_0.platform}
              ;build_flags               = ${core_2_3_0.build_flags}
              ;platform                  = ${core_2_4_2.platform}
              ;build_flags               = ${core_2_4_2.build_flags}
              platform                  = ${core_2_5_0.platform}
              build_flags               = ${core_2_5_0.build_flags}
              ;platform                  = ${core_stage.platform}
              ;build_flags               = ${core_stage.build_flags}
              • X
                xADDRx last edited by
                @Chaot:
                Ich vermute das könnte am Core liegen.
                Der wurde in den neuen Tasmota Versionen auf 2.4.2 geändert.
                Wenn du beim Update nicht aufpasst hast du den salat:
                http://forum.creationx.de/forum/index.p … -0er-core/
                Abhilfe (zumindest bei mir) wäre neu erstellen und dann mit der eigenen Version und Cor 2.3.0 updaten. `
                Daran hat es wohl gelegen!
                Vielen Dank!!
                  @dirkhe:
                  Sorry war falsch
                  [core_active]
                  danke..
                  wenn ich das so einstelle, dann bekomme ich folgende fehlermeldung beim kompilieren:
                  ompiling .pioenvs\sonoff-DE\src\core_esp8266_timer.c.o
                  Compiling .pioenvs\sonoff-DE\src\core_esp8266_wiring_digital.c.o
                  Compiling .pioenvs\sonoff-DE\src\core_esp8266_wiring_pwm.c.o
                  Compiling .pioenvs\sonoff-DE\src\sonoff.ino.cpp.o
                  Generating LD script .pioenvs\sonoff-DE\ld\local.eagle.app.v6.common.ld
                  xtensa-lx106-elf-g++: error: sonoff\sonoff.ino.cpp: No such file or directory
                  xtensa-lx106-elf-g++: fatal error: no input files
                  compilation terminated.
                  Compiling .pioenvs\sonoff-DE\lib2c2\TasmotaMqtt-1.1.1\TasmotaMqtt.cpp.o
                  *** [.pioenvs\sonoff-DE\src\sonoff.ino.cpp.o] Error 1
                  Compiling .pioenvs\sonoff-DE\lib2c2\TasmotaMqtt-1.1.1\mqtt\mqtt.c.o
                   [ERROR] Took 40.81 seconds
                  EDIT
                  ich hab es einfach noch ein zweites mal durchlaufen lassen, und dann hat es funktioniert.. komisch…. :roll:
                  jetzt hab ich in den infos des basics unter core version nicht mehr die versions nummer stehen sonder stage..
                  ist das normal?
                  Tasmota Version	6.4.1.2(sonoff)
                  Build-Datum & -Uhrzeit	2018.12.28 23:51:11
                  Core-/SDK-Version	STAGE/3.0.0-dev(c0f7b44)
                  Laufzeit	0T00:00:31
                  EDIT2
                  irgendwas stimmt da vorn und hinten nicht mit dem basic.. bzw. seit dem ursprünglichen update…
                  das basic teil läuft ein paar minuten..
                  und sobald ich anfange es zu konfigurieren (den gpio14 auf WS2812 umzustellen), verliert es die verbindung und ich komme gar nicht mehr drauf.
                  gibt es dir möglichkeit die alte 6.2.1 mit core 2.3.0 irgendwo herunterzuladen?
                  • smartboart
                    Kann ich bestätigen.. 2.5.0 core bekomme ich auch nicht umgestellt mit der 6.4.1. Egal welches sonoff… Habs auch mit nem rgbw Controller und nem smart plug probiert.. Dann steht immer stage da... Alle anderen core Versionen lassen sich ohne weiteres umstellen... Evtl. Mal mit ner niedrigeren tasmota Version probieren... Hab ich noch nicht probiert...
                    Aber mit festem WLAN Kanal sollte es laut Wiki auch mit dem Standart core tun...
                    Und blöden basic Module machen bei mir schon ne ganze weile Probleme... Fliegen alle raus wenn das nicht in den Griff zu bekommen ist.
                    Gesendet von meinem CLT-L09 mit Tapatalk
                    • smartboart
                      @ltsalvatore:
                      @dirkhe:
                      Sorry war falsch
                      [core_active]
                      danke..
                      EDIT
                      ist das normal?
                      Laufzeit	0T00:00:31
                      EDIT2
                      gibt es dir möglichkeit die alte 6.2.1 mit core 2.3.0 irgendwo herunterzuladen? ` Es lassen sich alle alten Release von tasmota runter laden…
                        kannst du mir nen tipp geben wie ich da vorgehen muss um an ältere Versionen heranzukommen..
                        git ist für mich immer noch ein bisschen wie ein Labyrinth.. :roll:
                        • smartboart
                          https://github.com/arendst/Sonoff-Tasmota/releases
                          Einfach googeln nach tasmota releases…
                          Aber oben der link...
                          Einfach nach unten scrollen... Die neusten releases sind immer ganz oben..
                          • Chaot
                            Chaot last edited by
                            Die Lösung ist eigentlich eher anders.
                            Ich habe die Erfahrung gemacht das ich zerst ein leeres Bin auf die Geräte flashe bevor ich einen anderen Core verwende. Irgendwie scheinen da immer Reste zu verbleiben die sich verschieden auswirken. Mit den Umweg über das leere Bin passiert das nicht.
                              Jan1 last edited by
                              Das mit dem leeren bin ist ja schon richtig, nur wie willst das machen ohne mit Kabel zu flashen?
                              • Chaot
                                Oh, sorry OTA habe ich irgendwo überlesen …. 😮
                                  Jan1 last edited by
                                  Die meisten Geräte (Shelly) sind eben hinter Schalter verbaut und die da raus holen ist eben nicht gerade in 5 Minuten erledigt. An sonst hast mit dem leer bin völlig recht. Wenn merkwürdige Dinge auftauchen und man alles durch hat, kommt man um ein leeres bin nicht rum, hatte ich auch schon. In der Regel sind es aber doch falsche Einstellungen und veraltete Tasmota Versionen die für die meisten Probleme verantwortlich sind.
                                    Balu0127 last edited by
                                    Ich hab die (5.10.0,5.11.1b,5.12.0 und die 6.3.0) und wollte diese Woche alle ausbauen und Updaten.
                                    Wenn ich das so lese warte ich lieber bis eine vernünftige Version da ist.
                                      Jan1 last edited by
                                      Hä, die aktuelle Version ist gut und nicht schlecht. Die einzige Info zu neueren Versionen die irgendwie unter ging, ist die Tatsache, dass der Core default wieder auf auf 2.4.2 ist, was bei einigen Deiner alten Tasmota Versionen auch der Fall sein dürfte.
                                      2.4.2 hat nun mal einige bekannte Probleme und wenn man die kennt, dann kann man damit leben, oder einfac h wieder den Core auf 2.3.0 oder eben auf den neuen 2.5.0 umstellen.
                                        Das mit dem leeren bin verstehe ich nicht so ganz.
                                        Wenn ich das bin über Kabel flash, wie soll ich dann noch auf das Gerät drauf kommen?
                                        Da sind ja keine wlan Einstellungen hinterlegt, worüber man sich verbinden könnte…?!
                                        Und zum Thema sonota flashen, mein letzter Wissenstand, ist doch seit längerem nicht mehr möglich darüber zu flashen, oder?
                                          Jan1 last edited by
                                          Das leere bin löscht den Flash komplett und dann ist nix mit verbinden zum Gerät 😉
                                          Danach muss natürlich noch die gewünschte FW geflasht werden. Das leere bin sorgt nur dafür, dass definitiv beine Code reste mehr im Flash sind, die irgendwie die neue FW beeinflussen. Das kommt zwar eh recht selten vor, da ich das allerdings bei mir auch schon hatte, ist es eben doch manchmal die einzige Möglichkeit ein seltsames Verhalten zu eliminieren.
                                          Das geht natürlich nur mit Kabel und nicht OTA!
                                            @Jan1:
                                            Das geht natürlich nur mit Kabel und nicht OTA! `
                                            Ah ok… Wollt schon sagen <emoji seq="1f60a">😊</emoji>
                                            Aber jetzt wo wir darüber schreiben fällt mir ein, dass auch ich hin und wieder feststellen musste, dass trotz neu flashen, Reste nicht alle sauber entfernt wurden.
                                            In solchen Fällen flashen ich die kompilierte bin mit nodemcu und setzte den Haken auf "wipe all data".
                                            720
                                            203092
