    4. [Aufruf] fullyBrowser Adapter
      Georgius last edited by
      Danke, hatte das Problem. Super
        super danke.. wurde korrigiert
        • Chaot
          Chaot last edited by
          Oha!
          Die Systembelastung ging schlagartig zurück.
          Ich habe den Effekt mit dem nicht reagierenden ioBroker am NUC zwar nicht stark gemerkt, aber jetzt sehe ich den Unterschied deutlich!
            Kueppert last edited by
            ich erhalten beim Update vom fullyBrowser über die Katze immer eine npm-Fehlermeldung:
            $ ./iobroker url "https://github.com/arteck/ioBroker.fullybrowser/tarball/master" fullybrowser
            install https://github.com/arteck/ioBroker.fullybrowser/tarball/master
            npm install https://github.com/arteck/ioBroker.fullybrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
            npm
            ERR! path /root/.npm/_logsnpm
            ERR! code EACCESnpm ERR! errno -13
            npm ERR! syscall
            scandir
            npm ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'npm
            ERR! at Error (native)npm ERR! { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
            npm
            ERR! at Error (native)npm ERR! stack: 'Error: EACCES: permission denied, scandir '/root/.npm/_logs'\n at Error (native)',
            npm
            ERR! errno: -13,npm ERR! code: 'EACCES',
            npm ERR! syscall: 'scandir',
            npm ERR! path: '/root/.npm/_logs' }
            npm ERR!
            npm ERR! The operation was rejected by your operating system.
            npm ERR! It is likely you do not have the permissions to access this file as the current user
            npm ERR!
            npm ERR! If you believe this might be a permissions issue, please double-check the
            npm ERR! permissions of the file and its containing directories, or try running
            npm ERR! the command again as root/Administrator (though this is not recommended).
            glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
            at Error (native)
            errno: -13,
            code: 'EACCES',
            syscall: 'scandir',
            ! npm ERR! path /root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74fnpm ERR! code EACCES
            npm ERR! errno -13
            npm ERR! syscall open
            npm ERR! Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'
            npm ERR! at Error (native)
            npm ERR! { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'
            npm ERR! cause:
            npm ERR! errno: -13,
            npm ERR! syscall: 'open',
            npm ERR! path: '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f' },
            npm ERR! isOperational: true,
            npm ERR! stack: 'Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'\n at Error (native)',
            npm ERR!
            npm ERR!
            ! npm
            WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
            npm WARN
            optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            ! npm
            WARN optional
            SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):
            npm
            WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: npm install node-pre-gypnpm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 243
            ! got /opt/iobroker/node_modules/iobroker.fullybrowser/admin
            upload [3] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/words.js words.js application/javascript
            upload [2] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index_m.html index_m.html text/html
            upload [1] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index.html index.html text/html
            upload [0] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/fully.png fully.png image/png
            process exited with code 0
            Mit npm hab ich sonst nie Probleme. Hab auch keinen user - bei mir läuft alles über root (so sollte es zumindest sein). Mir ist bisher auch bei keinem anderen Update/Installation über die Katze diese Fehlermeldung aufgefallen.
            Jemand ne Idee?
            Gemäß Adapter-Übersicht hat das Update auf aktuell 0.0.10 aber geklappt…
              Hi Arti,
              womit setzt du / würdest du Helligkeit auf 0 setzen? Über den Adapter geht es ja nicht (bei mir, is nix in den Objekten dazu). Mit dem PAW-Adapter? Den hatte ich jetzt nicht mehr in Nutzung wegen deinem neuen Adapter.
              Danke und Grüße, Thorsten
                hanswurst0815 last edited by
                Mahlzeit,
                Ich habe den fullybrower Adapter eben das erste mal installiert. Hatte auch eine Fehlermeldung, aber der Adapter taucht trotzdem in der Liste auf.
                Ebenfalls v 0.0.10. Aber irgendwie bekomme ich es nicht zum laufen. Also die angelegte Instanz ist im Run, aber ich kann das eingerichtete Tablet nicht steuern. Bekomme auch unter Objekten/Info bei Status einen Error
                Obwohl die Verbindung zum Tablet ja scheinbar aufgebaut wurde.
                Hat jemand eine Idee?
                • metaxa
                  metaxa last edited by
                  @hanswurst0815:
                  Hat jemand eine Idee? `
                  Passwort hast du im Fully auf deinem Device angegeben und auch im Adapter (ioBroker) eingetragen?
                  LG, mxa
                    sagmal wofür schreiben wir Wiki oder Doku
                    https://github.com/arteck/iobroker.fullybrowser/wiki
                      @Kueppert:
                      Hi Arti,
                      Danke und Grüße, Thorsten `
                      na klar geht das … wenn das nicht gehtn würde.. hätte ich den Adapter nicht geschrieben.. ich brauch die Funktion 😉 😉
                      https://github.com/arteck/iobroker.full ... e-absetzen
                        @metaxa:
                        @hanswurst0815:
                        LG, mxa `
                        Ja, das habe ich natürlich gemacht. Mehrfach…
                        @arteck:
                        https://github.com/arteck/iobroker.fullybrowser/wiki `
                        Auch die Doku habe ich vorher durchgelesen und den Browser extakt so eingestellt
                          was passiert wenn du die Adresse im Browser eingibst..
                            Also, was ich jetzt herausgefunden habe….
                            Ich habe jetzt das PW testweise auf ein Hochsicherheitspasswort geändert: 12345
                            und siehe da, es geht. ich habe es dann wieder zurück auf ein Passwort bestehend aus Buchstaben, Zahlen und Sonderzeichen geändert.
                            Und dann geht es wieder nicht mehr. Dieses Spiel habe ich jetzt zur sicherheit mehrere Male getestet. Sobald ich ein sicheres Passwort gewählt habe, geht es nicht mehr.
                            Über den normalen Browser gings mit meinem ursprünglichen Passwort.
                            • Webranger
                              Webranger last edited by
                              @arteck:
                              @Kueppert:
                              Hi Arti,
                              https://github.com/arteck/iobroker.full ... e-absetzen `
                              Ich bekomme das im BLockly nicht hin.
                              Das script schreibt den Befehl zwar in den Datenpunkt aber schickt ihn nicht weiter zum Fullytablet.
                              Muss ich da noch was anderes ausführen oder anderen Befehl für nehmen?
                              Gruss
                              edit
                              Fehler selber gefunden wenn ich "steuere" nehme geht es.
                              Schönen Sonntag euch noch.
                              Gruss Danyel
                              • Chaot
                                So wie es scheint ist das Problem mit dem Ladezustand behoben.
                                Aber ich habe jetzt ein Problem mit meinem Ladescript.
                                Das Gerät lädt auf 80% und schaltet sich ab.
                                Dann fängt es an alle 3-4 Minuten den Ladestecker kurz ein und sofort wieder auszuschalten.
                                Hat jemand eine Idee woran das jetzt liegen könnte?
                                Mit der vorherigen Lösung hat er das nicht gemacht.
                                const idBatt = 'fullybrowser.0.192_168_8_225.Info.batteryLevel'; // Batterielevel in %
                                const idPlug = 'sonoff.0.Ladestecker.POWER'; // Ladegerät ein
                                const idVis = 'Vis.Batterieanzeige'; // Für Vis
                                createState(idVis, 0, {
                                type: 'number',
                                min: 0,
                                max: 7,
                                role: 'level',
                                states: {
                                0: 'leer',
                                1: '20 %',
                                2: '40 %',
                                3: '60 %',
                                4: '80 %',
                                5: 'voll',
                                6: 'Ladegerät'
                                var level = getState(idBatt).val;
                                var plug = getState(idPlug).val;
                                function batt() {
                                var state = 5; // full 80 %
                                if(level <= 79) state = 4; // 79 %
                                if(level <= 60) state = 3; // 60 %
                                if(level <= 40) state = 2; // 40 %
                                if(level <= 30) state = 1; // 20 %
                                if(level <= 22) state = 0; // empty 20 %
                                if(plug) state = 6; // Ladegerät ein
                                setState(idVis, state, true);
                                if(level >= 80 && plug) setState(idPlug, false);
                                if(level <= 30 && !plug) setState(idPlug, true);
                                batt(); // Skriptstart
                                on(idBatt, function(dp) {
                                level = dp.state.val;
                                batt();
                                on(idPlug, function(dp) {
                                plug = dp.state.val;
                                batt();
                                  Schalt mal ein debug in die Zeile "if(level >= 80 && plug) setState(idPlug, false);"
                                  • Chaot
                                    Ok, und wie mache ich das?
                                      Kann ich auch nicht sagen, mach es mal in Blocky und schau dann wie das JS dann aussieht.
                                      • Chaot
                                        Ja, aber das Script läuft ja normalerweise.
                                        Im Originalzustand hole ich direkt aus Fully (separates Script) den Akkuwert und schreibe den dann in einen Datenpunkt.
                                        Diesen Datenpunkt frage ich dann mit dem Script ab und es lädt zwischen 20 und 80%.
                                        Erst wenn ich den Datenpunkt dann auf den Datenpunkt vom Adapter lege gibt es das seltsame Verhalten.
                                          Darum sollt man eben schauen was der Skript wirklich ausliest.
                                          • Chaot
                                            Also:
                                            Script 1 zum Auslesen des Akkustands und in einen Datenpunkt schreiben - funktioniert
                                            var request = require('request');
                                            var link = "http://192.168.8.XXX:2323/?cmd=deviceInfo&type=json&password=XXXX";
                                            var state = "javascript.0.Allgemein.Akku_Tablet"/*Akku_Tablet*/;
                                            function fully() {
                                                request(link, function(error,response, body) {
                                                    if(error) log('Fehler request: ' + error, 'error');
                                                    else {
                                                        objects = JSON.parse(body);
                                                        bat = objects.batteryLevel;
                                                        setState(state, bat);
                                                        log ("batteryLevel = " + bat);
                                            fully();
                                            schedule('*/10 * * * *', fully);
                                            Script 2 zum Laden aus diesem Datenpunkt - funktioniert
                                            const idBatt = 'javascript.0.Allgemein.Akku_Tablet'; // Batterielevel in %
                                            type: 'number',
                                            min: 0,
                                            max: 7,
                                            role: 'level',
                                            states: {
                                            0: 'leer',
                                            1: '20 %',
                                            2: '40 %',
                                            3: '60 %',
                                            4: '80 %',
                                            5: 'voll',
                                            6: 'Ladegerät'
                                            function batt() {
                                            batt();
                                            batt();
                                            Script 3 zum Auslesen und Laden aus dem Fully Adapter - funktioniert nicht:
                                            type: 'number',
                                            min: 0,
                                            max: 7,
                                            role: 'level',
                                            states: {
                                            0: 'leer',
                                            1: '20 %',
                                            2: '40 %',
                                            3: '60 %',
                                            4: '80 %',
                                            5: 'voll',
                                            6: 'Ladegerät'
                                            function batt() {
                                            batt();
                                            batt();
                                            Script 2 und 3 Unterscheiden sich nur im abgefragten Datenpunkt in Zeile 1
                                            1.0k
                                            fullybrowser fullybrowser adapter
                                            45
                                            289
                                            43551
