    4. Cloud websocket error und iobroker.net nicht zu erreichen
      therod666 last edited by
      Hallo Zusammen,
      ich habe leider den gleichen Fehler. Gibts es bereits ein Lösung, wo der Fehler liegt?
      cloud.0 2018-12-30 14:58:45.442 error Error while connecting to cloud: Error: websocket error
      cloud.0 2018-12-30 14:58:35.451 info Trying to connect as system.user.admin
      cloud.0 2018-12-30 14:57:45.427 error Error while connecting to cloud: Error: websocket error
      cloud.0 2018-12-30 14:57:35.436 info Trying to connect as system.user.admin
      cloud.0 2018-12-30 14:57:08.476 error Error while connecting to cloud: Error: websocket error
      cloud.0 2018-12-30 14:56:45.414 error Error while connecting to cloud: Error: websocket error
      cloud.0 2018-12-30 14:56:35.427 info Trying to connect as system.user.admin
      cloud.0 2018-12-30 14:55:35.378 info Connection changed: io client disconnect
      cloud.0 2018-12-30 14:55:35.370 info Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
      cloud.0 2018-12-30 14:55:28.482 info Trying to connect as system.user.admin
      cloud.0 2018-12-30 14:55:28.010 info Connecting with https://iobroker.net:10555 with "@.com_***********-hier steht mein Schlüssel"
      cloud.0 2018-12-30 14:55:27.918 info starting. Version 2.6.2 in /opt/iobroker/node_modules/iobroker.cloud, node: v8.15.0
      cloud.0 2018-12-30 14:55:22.465 info Connection changed: io client disconnect
      cloud.0 2018-12-30 14:55:14.980 info Request devices
      cloud.0 2018-12-30 14:55:03.754 info Request enums
      cloud.0 2018-12-30 14:55:02.091 info Request devices
      cloud.0 2018-12-30 14:54:52.670 info Request devices
      cloud.0 2018-12-30 14:54:34.156 error Error while connecting to cloud: timeout
      cloud.0 2018-12-30 14:54:24.167 info Trying to connect as system.user.admin
      cloud.0 2018-12-30 14:54:08.195 error Error while connecting to cloud: Error: websocket error
      cloud.0 2018-12-30 14:53:34.333 error Error while connecting to cloud: Error: websocket error
      cloud.0 2018-12-30 14:53:24.462 info Trying to connect as system.user.admin
      cloud.0 2018-12-30 14:53:24.125 info Connecting with https://iobroker.net:10555 with "@.com_***********-hier steht mein Schlüssel"
      Vielen Dank im Voraus.
      therod666
        JustClever last edited by
        ich habe den Fehler jetzt auch…
        websocket error und iobroker.net nicht zu erreichen...
        Noch jemand betroffen?
        Beste Grüße
        JustClever
          JayDee last edited by
          Dito. Seit heute … :?
            Kampfratte last edited by
            ja, ich habe den Fehler zur Zeit auch.
              Mento last edited by
              Ja habe den Fehler ebenfalls:
              2018-12-30 15:28:23.381 error Error while connecting to cloud: Error: websocket error
                wolf last edited by
                Auch bei mir:
                2018-12-30 15:53:03.955 Error while connecting to cloud: Error: websocket error
                • Troya
                  Troya last edited by
                  Bei mir auch. Hoffe hab nichts kaputt gemacht, hab grad webhosts eingerichtet/getestet :?
                    A Former User last edited by
                    Bei mir auch
                    • uweklatt
                      uweklatt last edited by
                      <size size="200">https://iobroker.net ist down</size>
                        Dann könntest du hier nicht schreiben 😉
                        (forum.iobroker.net ist Teil von iobroker.net)
                        EDIT:
                        mit tracert komme ich durch
                        Rainer
                        • Q
                          qosi last edited by
                          selbe hier…
                          wie ist der Status, wann ist wieder mit der Funktion zu rechnen?
                          • Q
                            qosi last edited by
                            @Homoran:
                            EDIT:
                            Rainer `
                            Der Domänen Anteil https://iobroker.net/ ist down
                            8-)
                            • Q
                              qosi last edited by
                              @Homoran:
                              EDIT:
                              Rainer `
                              gratuliere, Du kannst den Host erreichen…kann mal jemand Fakten zum Status der WEB API nenne?
                                @Homoran:
                                EDIT:
                                Rainer `
                                ist nicht gesagt, wenn die Haupdomain im Nameserver auf eine andere IP geroutet wird, wie das Forum, dann kannst du im Forum drauf, auch wenn der Server der Hauptdomain off ist.
                                  Wir checken das gerade
                                    mblass last edited by
                                    Bei mir auch Error while connecting to cloud: Error: websocket error seit ca. 15:00
                                      Sollte wieder laufen!
                                      Rainer
                                        teaborn last edited by
                                        Wollte nur kurz Bescheid geben, dass ich aktuell auch Probleme habe:
                                        cloud.0 2018-12-30 16:39:34.809 error Error while connecting to cloud: Error: websocket error
                                        cloud.0 2018-12-30 16:39:24.815 info Trying to connect as system.user.admin
                                        cloud.0 2018-12-30 16:38:34.808 error Error while connecting to cloud: Error: websocket error
                                        cloud.0 2018-12-30 16:38:24.813 info Trying to connect as system.user.admin
                                        cloud.0 2018-12-30 16:37:24.794 info Connection changed: io client disconnect
                                        Edit: Just in diesem Moment ist alles wieder grün. Danke
                                        • thexbrain
                                          thexbrain last edited by
                                          Jup bei mir läuft es wieder.
                                          • Troya
                                            Ist wieder grün bei mir , danke!
                                            81.1k
                                            54
                                            6456
