    4. Raspi rebooten
    Raspi rebooten
      pfuhsy last edited by
      @wendy2702:
      Mach doch mal in Summe 3 Putty Sessions zu dem PI auf und dann in
      Session 1````
      tail -f /opt/iobroker/log/iobroker.2018-05-25.log
      Session 2````
      tail -f /var/log/syslog
      Session 3````
      sudo reboot
      Eventuell kommt in den beiden Logfiles eine Info warum der reboot nicht klappt bzw. Welcher Prozess scheinbar nicht sauber beendet wird. `
      Xession 1:
      pi@ioBroker-Pi:~ $ tail -f /opt/iobroker/log/iobroker.2018-05-25.log
      2018-05-25 23:59:42.047  - warn: javascript.0     at Object. <anonymous>(script.js.Scripte.HAA.Status_abfragen:6:3)
      2018-05-25 23:59:45.050  - warn: javascript.0 Wrong type of node-red.0.HAA.Kommandos.HAA_Status: "boolean". Please fix, while deprecated and will not work in next versions.
      2018-05-25 23:59:47.048  - warn: javascript.0 Wrong type of node-red.0.HAA.Kommandos.HAA_Status: "boolean". Please fix, while deprecated and will not work in next versions.
      2018-05-25 23:59:47.049  - warn: javascript.0     at Object. <anonymous>(script.js.Scripte.HAA.Status_abfragen:6:3)
      2018-05-25 23:59:50.052  - warn: javascript.0 Wrong type of node-red.0.HAA.Kommandos.HAA_Status: "boolean". Please fix, while deprecated and will not work in next versions.
      2018-05-25 23:59:52.052  - warn: javascript.0 Wrong type of node-red.0.HAA.Kommandos.HAA_Status: "boolean". Please fix, while deprecated and will not work in next versions.
      2018-05-25 23:59:52.053  - warn: javascript.0     at Object. <anonymous>(script.js.Scripte.HAA.Status_abfragen:6:3)
      2018-05-25 23:59:55.058  - warn: javascript.0 Wrong type of node-red.0.HAA.Kommandos.HAA_Status: "boolean". Please fix, while deprecated and will not work in next versions.
      2018-05-25 23:59:57.054  - warn: javascript.0 Wrong type of node-red.0.HAA.Kommandos.HAA_Status: "boolean". Please fix, while deprecated and will not work in next versions.
      2018-05-25 23:59:57.055  - warn: javascript.0     at Object. <anonymous>(script.js.Scripte.HAA.Status_abfragen:6:3)</anonymous></anonymous></anonymous></anonymous>
      Session 2:
      pi@ioBroker-Pi:~ $ tail -f /var/log/syslog
      May 26 21:03:39 ioBroker-Pi systemd[9648]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
      May 26 21:03:39 ioBroker-Pi systemd[9648]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
      May 26 21:03:39 ioBroker-Pi systemd[9648]: Listening on GnuPG cryptographic agent and passphrase cache.
      May 26 21:03:39 ioBroker-Pi systemd[9648]: Reached target Sockets.
      May 26 21:03:39 ioBroker-Pi systemd[9648]: Reached target Basic System.
      May 26 21:03:39 ioBroker-Pi systemd[9648]: Reached target Default.
      May 26 21:03:39 ioBroker-Pi systemd[9648]: Startup finished in 39ms.
      May 26 21:03:39 ioBroker-Pi systemd[1]: Started User Manager for UID 1000.
      May 26 21:03:52 ioBroker-Pi systemd[1]: Started Session c3 of user pi.
      May 26 21:04:06 ioBroker-Pi systemd[1]: Started Session c4 of user pi.
      Und nu ?
        @arteck:
        was sagt
        Code: Alles auswählen
        shutdown -r now
        shutdown -h `
        pi@ioBroker-Pi:~ $ shutdown -r now
        Failed to set wall message, ignoring: The name org.freedesktop.PolicyKit1 was no                     t provided by any .service files
        Failed to reboot system via logind: The name org.freedesktop.PolicyKit1 was not                      provided by any .service files
        Failed to open /dev/initctl: Keine Berechtigung
        Failed to talk to init daemon.
        pi@ioBroker-Pi:~ $ shutdown -h
        Failed to set wall message, ignoring: The name org.freedesktop.PolicyKit1 was not provided by any .service files
        Failed to call ScheduleShutdown in logind, proceeding with immediate shutdown: The name org.freedesktop.PolicyKit1 was not provided by any .service files
          Gibt es dazu eine Lösung ?
          • wendy2702
            wendy2702 last edited by
            Von mir zumindest nicht…. da mir deine Antwort mit den Logs irgendwie durchgegangen ist.
            Allerdings nützen die Logs nicht wirklich da du das iobroker log vom Vortag genommen hast.
            Lässt der PI sich rebooten wenn du iobroker zuerst stoppst?
            sudo iobroker stop
            sudo shutdown -r now
            ````oder
            sudo reboot
              @pfuhsy:
              Ich denke ich hab so 2-3 min gewartet, was normalerweise ca. 1min. dauert. `
              Es gibt Installationen bei denen der Shutdown ca. 10 Minuten dauert - warum auch immer.
              Irgendwo hatte jemand dagegen sogar einen Workaround gepostet.
              Rainer
                @wendy2702:
                Lässt der PI sich rebooten wenn du iobroker zuerst stoppst? `
                Ja das geht.
                • wendy2702
                  Was hast du außer der iobroker Image installation noch gemacht?
                  Neue USER angelegt?
                  Irgendeine config datei editiert?
                  @pfuhsy:
                  Projektierung und Anpassungen nehme ich dann 3 Etagen höher im Arbeitszimmer vor. Da muss ich zwischendurch mal neustarten. Wäre schon ziemlich nervig dafür ständig runter laufen zu müssen. `
                  Was für Projektierungen und Anpassungen hast du gemacht bzw. was davon erfordert einen restart?
                  Mal Tante google bemüht? –> https://www.google.com/search?q=Failed+ ... refox-b-ab
                    @wendy2702:
                    Was hast du außer der iobroker Image installation noch gemacht? `
                    Keine weitere Image installiert. Jeden einzelen Punkt, was ich alles gemacht habe, hab ich natürklich nicht notiert. Wer macht das schon ?
                    @wendy2702:
                    Neue USER angelegt? `
                    Nein.
                    @wendy2702:
                    Irgendeine config datei editiert? `
                    Es gab eine Datei die ich editieren musste um die UART-Schnittstelle nutzen zu können.
                    @wendy2702:
                    Was für Projektierungen und Anpassungen hast du gemacht bzw. was davon erfordert einen restart? `
                    Das ist eine gute Frage. Wenn ich das noch richtig in Erinnerung habe, war es nach der Installation bei den einen oder anderen Adatper notwendig neuzustarten. Auch wenn ich manuell neue Objekte anlegte, konnte ich Sie in Node-Red erstmal gar nicht sehen. Da half meistens ein Neustart. Da waren bestimmt noch ein paar mehr Punkt. Das sind aber die, die mir so auf anhieb eingefallen sind.
                    @wendy2702:
                    Mal Tante google bemüht? –> https://www.google.com/search?q=Failed+ ... refox-b-ab `
                    Ja, werde aber nicht so richtig schlau daraus.
                      cimba007 last edited by
                      Verhalten ist immernoch identisch .. so I can only assume this is working as intended?
                      • haselchen
                        haselchen Most Active last edited by
                        Nunja, ich bin wahrlich kein Experte.
                        Habe die App Raspi Check und benutze haargenau den Befehl sudo shutdown -h 0 und es geht.
                        Node.js: v6.14.3
                        NPM: 6.2.0
                        Den PI eventuell mal geupdatet?
                        http://raspberrypiguide.de/howtos/raspb … re-update/
                        Gibt auch Foreneinträge, die besagen, dass es bei einer 8GB SD-Karte Fehlermeldungen gibt.
                          @Homoran:
                          @pfuhsy:
                          Rainer `
                          6537
