    3. Cloud Dienste
    4. Iobroker.alexa2 v0.4+
    • modmax
      modmax last edited by
      Bin gerade nicht zuhause … kann daher nicht den genauen Namen sagen ... geht aber über den Player und dort Pause...
      • padrino
        padrino Most Active last edited by
        Leider klappt die Funktion nur bei Musik, nicht aber z.B. bei Timern.
        Da würde ich noch was suchen. 😉
        CU,
        padrino
          Apropo last edited by
          Ich habe hier eine Meldung aus dem Log. Um was für ein Gerät es sich dabei handelt kann ich leider nicht sagen. Vielleicht hast du ja eine Idee?
          ` > 2018-12-22 03:02:47.676 - [32minfo[39m: alexa2.0 Smarthome-Device Capability Alexa.AcousticEventSensor unknown. Report to developer this and next log line from logfile on disk!
          2018-12-22 03:02:47.677 - [32minfo[39m: alexa2.0 {"applianceId":"AAA_SonarCloudService_a3c5a3fe-4687-358c-a6a8-89d6aa4a5e02","endpointTypeId":"","driverIdentity":{"namespace":"AAA","identifier":"SonarCloudService"},"manufacturerName":"Amazon","friendlyDescription":"Amazon intelligentes Gerät","modelName":"A7WXQPH584YP","deviceType":"","version":"0","friendlyName":"Wohnzimmer","friendlyNameModifiedAt":1544528719014,"capabilitiesModifiedAt":1544911102875,"ipAddress":"","port":"","entityId":"10e5eb01-1fd7-4c67-9892-7f538d11ae4d","applianceNetworkState":{"reachability":"REACHABLE","lastSeenAt":1545444167144,"createdAt":1544528697776,"lastSeenDiscoverySessionId":{"value":"d0d2c29f-9427-4f5a-a06c-f313d1bb84fe"}},"tags":{"tagNameToValueSetMap":{}},"additionalApplianceDetails":{"additionalApplianceDetails":{}},"firmwareVersion":"0","actions":[],"capabilities":[{"capabilityType":"AVSInterfaceCapability","type":"AlexaInterface","version":"3","properties":{"supported":[{"name":"overallMode"},{"name":"smokeAlarmDetectionState"},{"name":"glassBreakDetectionState"},{"name":"detectionModes"}],"proactivelyReported":true,"retrievable":true,"readOnly":false},"interfaceName":"Alexa.AcousticEventSensor"}],"applianceTypes":["OTHER"],"isEnabled":true,"aliases":[],"connectedVia":"Wohnzimmer","alexaDeviceIdentifierList":[],"applianceDriverIdentity":{"namespace":"AAA","identifier":"SonarCloudService"},"ipaddress":"","applianceLambdaControlled":true} / undefined `
          • padrino
            was mir gerade aufgefallen ist..
            In den Objekten "Player/Volume":
            Beispiel:
            • Wert: 50
            • Alexa, Ton aus
            -> Wert: 50
            • Alexa, Ton an
            -> Wert ist "leer"
            Ist das normal? 😃
            CU,
            padrino
              apollon77 last edited by
              Höre ich zum ersten Mal. Am Ende mach mal debug an dann siehst du was genau gemeldet wird. Sonst mit logfile bitte issue anlegen. Und sicherstellen das du die aktuellste 1.x hast!!
              Gesendet vom Handy …
              • Espace0401
                Espace0401 last edited by
                Benutzt hier jemand auch den Fire Stick 4K? Dieser schreibt in das Logfile folgende Meldung rein:
                2018-12-30 19:54:08.005 - warn: alexa2.0 Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                2018-12-30 19:54:08.006 - warn: alexa2.0 Device-type:AKPGW064GI9HE (SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SUPPORTS_SOFTWARE_VERSION,CHANGE_NAME,PERSISTENT_CONNECTION,ARTHUR_TARGET,ACTIVE_AFTER_FRO,FLASH_BRIEFING,MICROPHONE,VOLUME_SETTING)
                2018-12-30 19:59:17.761 - warn: alexa2.0 Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                2018-12-30 19:59:17.762 - warn: alexa2.0 Device-type:AKPGW064GI9HE (ARTHUR_TARGET,CHANGE_NAME,ACTIVE_AFTER_FRO,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,PERSISTENT_CONNECTION,FLASH_BRIEFING,SUPPORTS_SOFTWARE_VERSION,VOLUME_SETTING,MICROPHONE)
                  GitHub issue bitte
                    Bongo last edited by
                    Ich habe mir die Alexa APP für PC installiert. Unter dem Device gibt es kein Commands. Wird das nicht unterstützt?
                      Check es doch in der Alexa App. Kannst du eine Routine anlegen die eine Sprachausgabe dort tut?
                        @apollon77:
                        Check es doch in der Alexa App. Kannst du eine Routine anlegen die eine Sprachausgabe dort tut? `
                        Die Sprachausgabe über eine Routine in der mobilen Alexa App funktioniert.
                          Dann github issue öffnen mir device Type und capabilities (bei dem device unter „Info“ sind States die so heissen.)
                            MyMeyer last edited by
                            bekomme folgende Meldung für das Gerät " Fire HD 8 Tablet".
                            2019-01-02 21:28:56.478 - warn: alexa2.0 Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                            2019-01-02 21:28:56.478 - warn: alexa2.0 Device-type:A1C66CX2XD756O (SUPPORTS_SOFTWARE_VERSION,MICROPHONE,PEONY,REMINDERS,ASX_TIME_ZONE,VOLUME_SETTING,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION)
                            Muss man dazu jetzt ein "GitHub issue" machen ?
                              Wäre sinnvoll. Aber bitte mit Infos zu dem was das gerät kann. Also: Kannst Du per Alexa App dort ne Sprachausgabe machen oder nicht?
                              • padrino
                                @padrino:
                                Hmm, jetzt bin ich grad am "globalen Reminder" am basteln, da seh ich "add new reminder" funzt nimmer?
                                Kann das sein?
                                Wenn ich dort 19:00,text eintrage, wird das Obekt rot und der String bleibt stehen, gestern wurde noch eine neue Erinnerung draus gestrickt. 😄
                                CU,
                                padrino `
                                @apollon77
                                Kannst Du mir sagen, in welchem Format man bei "new reminder" ein Datum mit eintragen muss/kann?
                                z.B. 2019-02-02,15:00,Betreff
                                geht nicht.
                                  Du kannst einen Unix Timestamp in Millisekunden nutzen: siehe https://www.epochconverter.com/ … nur bei der Zahl nochmal drei Nullen ans Ende 🙂
                                  Mehr geht aktuell nicht
                                  padrino 1 Reply Last reply Reply Quote 0
                                  • padrino
                                    Uff, das klingt nicht gut… :oops:
                                    Und das aktuell funktionierende "15:00,Text" wird auch vom Adapter in einen Unix timecode convertiert und dann an Alexa/den Echo geschickt?
                                    CU,
                                    padrino
                                      Jain, aber der Adapter kann aktuell nichts anderes. Feature Request Issue anlegen
                                      • padrino
                                        Ich notiere es. 😉
                                        Mir ist gerade aufgefallen, dass "Alexa" auch bei "Sprich mir nach" wohl KI anwendet. 🙂
                                        Ich lasse mir im Moment eine Temperatur ansagen.
                                        Da das Signal des Sensors leider nicht so oft empfangen wird, wie es sollte und der Wert dadurch evtl. nicht wirlich aktuell ist, lass ich mir die Zeit seit den erfassten Daten mit ansagen.
                                        Nun dachte ich mir, ich müsse mein "speak" entsprechend anpassen für "vor 1 Minute" und "vor 2+ Minuten".
                                        Aber nix da. 😄
                                        Habe nur die Ansage "vor $X Minuten" und raus kommt brav, "vor einer Minute" (auch nicht "vor eins") oder eben z.B. "vor zwei Minuten". :!:
                                        Bin (ausnahmsweise) mal begeistert. :lol:
                                        CU,
                                        padrino
                                          LJSven last edited by
                                          Hallo, ich habe 2 Fragen:
                                          <u>1. Frage:</u>
                                          Ich habe 3 Sonos PLAY ONE - wenn ich eine Spotify Playlist mit dem korrekten Namen:
                                          "Kinderlieder zum Mitsingen - Die 100 Besten"
                                          Kommt folgendes raus und die Liste wird nicht aufgerufen:
                                          SUCCESS - [Alexa Bad] - spiel Playlist Kinderlieder zum Mitsingen die one hundred Besten von spotify
                                          Wie muss ich das eingeben?
                                          <u>2. Frage:</u>
                                          Kann ich die Play ONE auch im Multiroom verbinden? Wenn ja, wie? So könnte ich mir den SONOS Adapter sparen.
                                            Keine Ahnung, versuch doch mal "einhundert" 🙂
                                            618
                                            153391
