    4. Frage zu Modbus
    Frage zu Modbus
      Rapsi last edited by
      Habe ich eingetragen. Der Adapter wird für ca. 10 sek. grün und dann wieder gelb.
      Muss ich was bei diskreten Eingängen, Ausgängen, Eingangsregister und Holding eintragen?
        Gibts denn irgendwelche logs?
        Wenn nicht stell doch mal bitte den Adapter um auf debug!
        Enrico
          Hier ist mein Log:
          modbus.0	2018-12-30 22:47:01.304	debug	system.adapter.admin.0: logging true
          modbus.0	2018-12-30 22:46:44.456	debug	Cleaning up request fifo.
          modbus.0	2018-12-30 22:46:44.455	debug	Clearing timeout of the current request.
          modbus.0	2018-12-30 22:46:44.450	info	Disconnected from slave
          modbus.0	2018-12-30 22:46:43.450	warn	Poll error count: 1 code: {"err":"timeout"}
          modbus.0	2018-12-30 22:46:43.448	error	Request timed out.
          modbus.0	2018-12-30 22:46:43.448	warn	Error: undefined
          modbus.0	2018-12-30 22:46:38.436	debug	Poll inputRegs DevID(1) address 1 - 1 bytes
          modbus.0	2018-12-30 22:46:38.434	debug	Poll device 1
          modbus.0	2018-12-30 22:46:38.432	info	Connected to slave
          modbus.0	2018-12-30 22:46:38.414	debug	connect to serial /dev/ttyUSB0 with 9600
          modbus.0	2018-12-30 22:46:38.051	info	starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v6.14.4
          modbus.0	2018-12-30 22:46:37.929	debug	statesDB connected
          modbus.0	2018-12-30 22:46:37.858	debug	objectDB connected
          modbus.0	2018-12-30 22:46:37.030	info	terminating
          modbus.0	2018-12-30 22:46:36.046	warn	Poll error count: 10 code: {"err":"timeout"}
          modbus.0	2018-12-30 22:46:36.045	error	Request timed out.
          modbus.0	2018-12-30 22:46:36.045	warn	Error: undefined
          modbus.0	2018-12-30 22:46:31.039	info	Connected to slave
          modbus.0	2018-12-30 22:45:31.024	info	Disconnected from slave
          modbus.0	2018-12-30 22:45:30.023	warn	Poll error count: 9 code: {"err":"timeout"}
          modbus.0	2018-12-30 22:45:30.023	error	Request timed out.
          modbus.0	2018-12-30 22:45:30.022	warn	Error: undefined
          modbus.0	2018-12-30 22:45:25.014	info	Connected to slave
          modbus.0	2018-12-30 22:44:25.001	info	Disconnected from slave
          modbus.0	2018-12-30 22:44:24.001	warn	Poll error count: 8 code: {"err":"timeout"}
            modbus.0	2018-12-30 22:50:02.516	debug	Cleaning up request fifo.
            modbus.0	2018-12-30 22:50:02.516	debug	Clearing timeout of the current request.
            modbus.0	2018-12-30 22:50:02.513	info	Disconnected from slave
            modbus.0	2018-12-30 22:50:01.520	warn	Poll error count: 4 code: {"err":"timeout"}
            modbus.0	2018-12-30 22:50:01.520	error	Request timed out.
            modbus.0	2018-12-30 22:50:01.520	warn	Error: undefined
            modbus.0	2018-12-30 22:49:56.511	debug	Poll inputRegs DevID(1) address 1 - 1 bytes
            modbus.0	2018-12-30 22:49:56.511	debug	Poll device 1
            modbus.0	2018-12-30 22:49:56.510	info	Connected to slave
            modbus.0	2018-12-30 22:49:56.497	debug	connect to serial /dev/ttyUSB0 with 9600
            modbus.0	2018-12-30 22:48:56.503	debug	Cleaning up request fifo.
            modbus.0	2018-12-30 22:48:56.502	debug	Clearing timeout of the current request.
            modbus.0	2018-12-30 22:48:56.493	info	Disconnected from slave
            modbus.0	2018-12-30 22:48:55.493	warn	Poll error count: 3 code: {"err":"timeout"}
            modbus.0	2018-12-30 22:48:55.493	error	Request timed out.
            modbus.0	2018-12-30 22:48:55.493	warn	Error: undefined
            modbus.0	2018-12-30 22:48:50.496	debug	Poll inputRegs DevID(1) address 1 - 1 bytes
            modbus.0	2018-12-30 22:48:50.496	debug	Poll device 1
            modbus.0	2018-12-30 22:48:50.492	info	Connected to slave
            modbus.0	2018-12-30 22:48:50.486	debug	connect to serial /dev/ttyUSB0 with 9600
            modbus.0	2018-12-30 22:47:50.487	debug	Cleaning up request fifo.
            modbus.0	2018-12-30 22:47:50.486	debug	Clearing timeout of the current request.
            modbus.0	2018-12-30 22:47:50.483	info	Disconnected from slave
            modbus.0	2018-12-30 22:47:49.482	warn	Poll error count: 2 code: {"err":"timeout"}
            modbus.0	2018-12-30 22:47:49.482	error	Request timed out.
            modbus.0	2018-12-30 22:47:49.481	warn	Error: undefined
            modbus.0	2018-12-30 22:47:44.484	debug	Poll inputRegs DevID(1) address 1 - 1 bytes
              Da steht was von Pollerror, ich denke mal, dass da noch eine Einstellung falsch ist.
              Hast du denn mal die oberste Einstellung, RTU usw verändert?
              Enrico
                Das ist ein USB-Serial-Adapter. Also Einstellung "Serial" ist richtig.
                Vierschiedene Boudrate habe ich probiert - gleiches Ergebnis.
                Was ist bei diskreten Eingängen, Ausgängen, Eingangsregister und Holding Registers einzutragen?
                Bei mir sind die Felder leer.
                • V
                  vupls1 last edited by
                  ich habe sehr ähnliches, wie das hier beschriebene Problem.
                  Mein Adapter hängt ebenfalls am USB Anschluss und wird auch entsprechend (/dev/ttyUSB) erkannt. Das Adernpaar geht dann zu meiner Lüftungsanlage, welche für Modbus RS485 RTU konfiguriert ist. Beide Enden habe ich mit dem Abschluss-Widerstand versehen. Wenn ich mit anderen Tools (eg. Modbus Poll oder Modbus Master) mich mit dem gleichen USB-Stick und der gleichen Hardwarekonstellation verbinden, funktioniert es sehr gut und ich kann die Coils und Register auslesen.
                  Mache ich das gleiche via IOBroker und dem Modbus Adapter geht es schief.
                  Der Adapter geht nach der Konfiguaration von Rot auf Gelb, flackert dann für eine kurze Zeit in Richtung grün, fällt dann aber wieder auf gelb zurück und bleibt dann dan.
                  Im Log (debug) steht dann folgendes:
                  modbus.0 2019-01-01 13:09:32.908 info Disconnected from slave
                  modbus.0 2019-01-01 13:09:32.907 info Connected to slave
                  modbus.0 2019-01-01 13:09:32.892 debug connect to serial /dev/ttyUSB0 with 9600
                  modbus.0 2019-01-01 13:08:32.906 debug redis pmessage io.modbus.0.* io.modbus.0.info.connection {"val":false,"ack":true,"ts":1546344512893,"q":0,"from":"system.adapter.modbus.0","lc":1546344032780}
                  modbus.0 2019-01-01 13:08:32.904 debug redis pmessage io.modbus.0.* io.modbus.0.info.connection {"val":true,"ack":true,"ts":1546344512890,"q":0,"from":"system.adapter.modbus.0","lc":1546344512890}
                  modbus.0 2019-01-01 13:08:32.903 debug Cleaning up request fifo.
                  und das wiederholt sich dann.
                  Leider stehe ich jetzt im Wald und würde mich freuen, von euch einen Tipp zu bekommen.
                  Besten Dank schon im Voraus.
                    Ich habe nicht viel Ahnung vom Modbus, bin aber auch bei dir der Meinung, wie auch bei Rapsi, dass die Einstellung im ioBoker-Modbus-Adapter auf RTU stehen muss! Da muss, meinem Verständnis nach, nicht die Einstellung des USB-Adapters eingegeben werden, sondern, der Modbus-Typ, so habe ich bisher die Infos dazu verstanden. Ich gerade auf der Suche nach einem Modbus-Zähler und wie ich das anstellen kann.
                    Enrico
                    • V
                      Hallo Enrico,
                      vielen Dank für deine Antwort, mit meinem Halbwissen würde ich aber vermuten, dass Serial ja RS485 RTU bedeutet. Eine RTU Abfrage kann aber auch über TCP erfolgen. Das geht natürlich gar nicht, weil ich keinen ETH zu Serial Adapter habe.
                      Beste Grüße
                      Thomas
                      • wendy2702
                        wendy2702 last edited by
                        @Rapsi:
                        Muss ich was bei diskreten Eingängen, Ausgängen, Eingangsregister und Holding eintragen? `
                        ja es muss etwas eingetragen werden. Je nachdem was du machen willst, auslesen, schreiben etc.
                        Wichtig ist auch zu beachten das der Adapter immer das gleiche Device bleibt. Da ändert sich z.B. schon mal nach einem PI reboot.
                        • V
                          Chapeau! Wendy
                          Das war genau der richtige Tip. In den Registern muss etwas stehen, sonst verbindet sich der Adapter nicht.
                          Herzlichen Dank. jetzt kann es bei mir los gehen.
                          • wendy2702
                            Sehr schön.
                            Kannst du dann bitte noch den Titel deines ersten Posts um ein "Gelöst" ergänzen.
                              Hallo Wendy,
                              was muss ich denn bei Eingängen, Ausgängen usw eintragen?
                              Ich nutze diese Komponente:
                              https://www.ebay.de/itm/RS485-Konverter … 2749.l2649
                              https://www.ebay.de/itm/16-Kanal-RS485- ... 2749.l2649
                              Wo bekomme ich die Adressen her?
                              Hast du oder jemand Anderer eine Idee/Vorschlag?
                              • wendy2702
                                Da wirst du wohl Kontakt zum Hersteller/Verkäufer aufnehmen müssen wenn es keine Dokumentation gibt.
                                Aus der Ebay Auktion gehen auch keine Modbus Register hervor.
                                2740
