    4. Neue Installationsroutine (für Linux)
    • eric2905
      eric2905 last edited by
      Hat er.
      Wenn man die Node-Installation vom Pi2/3 nimmt, kommt genau dieser Hinweis.
      Mit der Node-Installation des Pi1 geht es dann.
      Gruß,
      Eric
      Von unterwegs getippert
        Griesemer last edited by
        Sehr gute Arbeit! Vielen Dank.
        Ich war schon am verzweifeln, weil ich den Autostart nicht hinbekommen hatte. Nun geht wieder alles 😉
          Golan last edited by
          Thanks for the instructions, everything is fine. A question, and on Windows 7, the installer has not changed?, otherwise I have been fighting for the second day, nothing happens.
          Thank.
          ` > Danke für die Anweisungen, alles ist gut. Eine frage, und unter Windows7 hat sich der Installer nicht geändert ?, ansonsten habe ich den zweiten tag gekämpft, nichts passiert.
          Danke.
          PS: Sorry für mein Deutsch, ich habe einen Übersetzer benutzt `
          • AlCalzone
            @Golan:
            Thanks for the instructions, everything is fine. A question, and on Windows 7, the installer has not changed?, otherwise I have been fighting for the second day, nothing happens. `
            The installer itself has not changed. But under the hood, the installation works differently now, which is why you now need to execute "npm install" twice.
            If you want to do a manual installation, you can find the relevant steps in the new documentation we are currently working on:
            https://iobroker.github.io/ioBroker.doc … d=nodeinst => replace "https://github.com/ioBroker/ioBroker/tarball/master" with just "iobroker". Or continue to read here:
            Open an administrative command prompt and execute the following:
            npm install --global windows-build-tools
            md C:\iobroker
            cd /d C:\iobroker
            npm install iobroker
            Now follow the instructions on screen, which should be
            npm install --production
            or something similar.
              Thank you very much, I will learn and try to install
                Tell me please, what version of the node.js is necessary to pre-install, and then Windows does not perceive npm
                • Oberjembker
                  Oberjembker last edited by
                  Ich habe mir das Skript (https://raw.githubusercontent.com/ioBro … staller.sh) angeschaut.
                  Die logischen Vergleiche mit IS_ROOT passen meiner Ansicht nach so nicht.
                  Habe folgendes aus dem Skript getestet:
                  if [[ $EUID -eq 0 ]]; then
                          IS_ROOT=true
                  else
                          IS_ROOT=false
                  fi
                  if [[ IS_ROOT -eq true ]]; then
                          echo "running as ROOT"
                  else
                          echo "NOT running as ROOT"
                  fi
                  Das liefert IMMER "running as ROOT".
                  Funktionieren wuerde es mit einer der folgenden Abfragen:
                  if [ "$IS_ROOT" = true ]; then ...
                  if $IS_ROOT ; then ...
                    rewenode last edited by
                    Recht hat er
                    https://stackoverflow.com/questions/295 … ell-script
                    • eric2905
                      Ist schon an die Entwickler weitergeleitet.
                      Die schauen sich das an.
                      Danke für den Hinweis [emoji106]
                      Gruß,
                      Eric
                        danyo80 last edited by
                        wäre es möglich, den User iobroker in die SUDO Gruppe aufzunehmen, so dass er Kommandos mit sudo ausführen kann.
                        Ja, ich weiß, dass man damit dem unpreviligierten User nahezu Adminrechte verleiht, aber würde das evtl. helfen, bei Installation wie
                        z.B. ZWAVE aus dem Admin heraus? Oder sollte man dies lieber nicht tun, und die Installtion solcher Adapter auf anderem Wege durchführen?
                        Danyo
                        • AlCalzone
                          Ist auf meiner TODO-Liste. Das löst noch einige andere Probleme, wenn wir das tun.
                          https://github.com/ioBroker/ioBroker/issues/87
                          https://github.com/ioBroker/ioBroker/issues/89
                          AlCalzone created this issue in ioBroker/ioBroker
                          closed Create a script that fixes permissions and autostart and stuff on existing installations #87
                          closed More stuff to do in the installer script #89
                          • MathiasJ
                            MathiasJ last edited by
                            Wie sieht es mit Bluetooth im allgemeinen aus?
                            Ich hatte bisher bei der neuen Installationsroutine das Problem, daß weder Radar noch BLE ging.
                            Wenn ich sudo hcitool lescan eingegeben habe, wurden alle Geräte erkannt, jedoch nicht weitergereicht.
                            Mit der alten Installationsroutine hatte ich das Problem nicht.
                            Gruß,
                            Mathias
                            Gesendet von meinem MI 8 mit Tapatalk
                              könnte es daran liegen, dass der iobroker nicht in der Bluetooth Gruppe ist? Ich meine mich erinnern zu können, dass es eine solche Gruppe gibt. Guck mal in die /etc/group ob es da so eine Gruppe gibt.
                              Danyo
                                LibertyX82 last edited by
                                Ich habe mit dem node-red das Problem, dass ich die Nodes nicht updaten kann
                                https://github.com/ioBroker/ioBroker.node-red/issues/41%5B [Mit der alten Installation (über den alten Weg) konnte ich diese zumindest über die Konsole updaten
                                z.B. ~~[code]~~npm update node-red-node-email[/code] Nach der Installation des iobrokers über das neue Script geht das auch nicht mehr.](</s><LINK_TEXT text=)
                                [" target="_blank">](</s><LINK_TEXT text=)[<link_text text="https://github.com/ioBroker/ioBroker.no … issues/41[">https://github.com/ioBroker/ioBroker.node-red/issues/41[</link_text>[/url]
                                z.B.
                                libertyx82 created this issue in ioBroker/ioBroker.node-red
                                closed Update von nodes nicht möglich #41
                                • AlCalzone
                                  @LibertyX82:
                                  Nach der Installation des iobrokers über das neue Script geht das auch nicht mehr. `
                                  "Geht nicht" ist keine gute Fehlermeldung 😐
                                  Vielleicht kannst du ja ein paar mehr Details nennen, damit man den Fehler beheben kann?
                                    Es gab leider keine Fehlermeldung.
                                    Das Problem hat aber wohl nichts mit der neuen Installationsroutine zu tun, npm funktioniert auch, man sollte es nur im Projektordner ausführen.
                                    • AlCalzone
                                      @LibertyX82:
                                      npm funktioniert auch, man sollte es nur im Projektordner ausführen. `
                                      Das hilft tatsächlich :mrgreen:
                                      • Oberjembker
                                        Kleiner Hinweis seit der neuen Installationsroutine:
                                        Das System meldet, dass die Datei````
                                        /lib/systemd/system/iobroker.service
                                        Jedenfalls bei mir taucht folgendes auf:
                                        $ sudo dmesg | grep iobroker
                                        [ 9.360610] systemd[1]: Configuration file /lib/systemd/system/iobroker.service is marked executable. Please remove executable permission bits. Proceeding anyway.
                                        Ist erstmal wohl nicht kritisch, aber vielleicht ein security issue.
                                        Lieben Gruß… Arne.
                                        • AlCalzone
                                          Danke für den Hinweis! Da ich eh gerade dabei bin das noch etwas zu überarbeiten, kann ich das mit angehen.
                                            keynight last edited by
                                            Wars jemand mit meinen Installer unzufrieden ?
                                            https://raw.githubusercontent.com/ioBro … spbian8.sh
                                            oder
                                            https://github.com/ioBroker/ioBroker/bl ... stretch.sh
                                            Man sollte nur ab und zu Node-Version korrigieren, sonnst hat er schon ein paar Jahren funktioniert :lol:
                                            installation
                                            64
                                            415
                                            114251
