    4. [Aufruf] Test Shelly Adapter
      bigtwinch last edited by
      Habe ein Problem mit dem Shelly Adapter.
      Heute den Adapter/Instanz installiert und nun habe ich diese errors beim start der Instanz.
      ! host.debian-iobroker 2019-01-04 08:34:35.658 info Do not restart adapter system.adapter.shelly.0 because disabled or deleted
      ! host.debian-iobroker 2019-01-04 08:34:35.657 error instance system.adapter.shelly.0 terminated with code 3 (Adapter disabled or invalid config)
      ! host.ioBroker-RasPi-1 2019-01-04 08:34:14.134 info object change system.adapter.shelly.0
      ! host.ioBroker-RasPi 2019-01-04 08:34:14.135 info object change system.adapter.shelly.0
      ! host.debian-iobroker 2019-01-04 08:34:13.947 info object change system.adapter.shelly.0
      ! host.debian-iobroker 2019-01-04 08:34:05.014 info Restart adapter system.adapter.shelly.0 because enabled
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error instance system.adapter.shelly.0 terminated with code 0 (OK)
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: syscall: 'addMembership' }
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: code: 'EADDRINUSE',
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: errno: 'EADDRINUSE',
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:142:11)
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at _handle.lookup (dgram.js:273:7)
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at startListening (dgram.js:156:10)
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at Socket.emit (events.js:208:7)
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at emitNone (events.js:106:13)
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at Object.onceWrapper (events.js:313:30)
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/coap/lib/server.js:232:42)
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at Array.forEach (<anonymous>)
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at /opt/iobroker/node_modules/coap/lib/server.js:233:24
      ! host.debian-iobroker 2019-01-04 08:34:05.014 error Caught by controller[0]: at Socket.addMembership (dgram.js:615:11)
      ! host.debian-iobroker 2019-01-04 08:34:05.013 error Caught by controller[0]: { Error: addMembership EADDRINUSE
      ! host.ioBroker-RasPi-1 2019-01-04 08:34:04.494 info object change system.adapter.shelly.0
      ! host.ioBroker-RasPi 2019-01-04 08:34:04.495 info object change system.adapter.shelly.0
      ! host.debian-iobroker 2019-01-04 08:34:04.311 info instance system.adapter.shelly.0 started with pid 2935
      ! host.debian-iobroker 2019-01-04 08:34:04.310 info object change system.adapter.shelly.0</anonymous></anonymous>
      Mein system läuft auf einem NUC siehe Systeminformationen
      ! debian-iobroker
      ! Betriebssystem linux
      ! Architektur x64
      ! CPUs 4
      ! Geschwindigkeit 1427 MHz
      ! Modell Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      ! RAM 7.6 GB
      ! System Betriebszeit 00:21:37
      ! Node.js v8.15.0
      ! NPM 6.4.1
      ! Disk size 108788408320
      ! Disk free 95147958272
      ! Anzahl der Adapter 213
      ! Betriebszeit 00:21:24
      ! Active instances 28
      ! Hostname debian-iobroker
      Auch nach einem Reboot das gleiche Problem
      Hat jemand eine Idee was da nicht OK ist?
      Grüsse
      Christian
      • Stuebi
        Stuebi last edited by
        Moin Christian,
        sieht so aus, als ob der Shelly Adapter schon läuft. Fehlermeldung EADDRINUSE ist hier z.B. beschrieben https://stackoverflow.com/questions/407 … ill-server.
        VG
        Thorsten
          @bigtwinch:
          ! debian-iobroker
          ! Architektur x64
          ! CPUs 4
          ! RAM 7.6 GB
          ! Node.js v8.15.0
          ! NPM 6.4.1
          Grüsse
          Christian `
          OK habe noch einiges versucht!
          Mein NUC hat 2 Netzwerkanschlüsse:
          enp3s0 (LAN 192.168.5.120) und ein wlp2s0 WIFI (192.168.1.120)
          bei "ip link set dev enp3s0 down" kann ich den Shelly Adapter starten 😉 auch nach "ip link set dev enp3s0 up" läuft der Shelly Adapter 🙂
          nur wenn das dev enp3s0 up ist kann der Shelly nicht gestartet werden. 😞
          ich bin doch sicherlich nicht der einzige der mehrere Netzwerk Interfaces / Devices am laufen hat :!:
          Wie habt ihr das gelöst :?: :?: (z.B. Reboot vom System)
          Christian
          • Stuebi
            In der neuen Shelly Adapter Version 2.0.3 werden für den Shelly 1 und 2 nun die rssi Werte angezeigt. Voraussetzung ist die Shelly Firmware 1.4.4.
            Hilft vielleicht den Leuten, die immer wieder WLAN Probleme mit dem Shelly haben.
            VG
            Stübi
              poldi last edited by
              @tstueben:
              VG
              Stübi `
              Danke damit kann ich dann die Position von meinem Access Point optimieren 😉
                @tstueben:
                Moin Christian,
                VG
                Thorsten `
                Hi Thorsten
                Nö leider nicht! Ist das LAN Interface…
                siehe:
                ! root@debian-iobroker:~# ps aux | grep io.shelly
                ! root 13445 1.4 0.5 973320 46592 ? Sl 11:17 0:00 io.shelly.0
                ! root 13502 0.0 0.0 6076 880 pts/1 S+ 11:18 0:00 grep io.shelly
                • jetzt stoppe ich die Instanz shelly.0 über web admin
                ! root 13571 0.0 0.0 6076 828 pts/1 S+ 11:20 0:00 grep io.shelly
                • kein io.shelly vorhanden
                starte shelly bleibt aber rot
                ! root 13652 0.0 0.0 6076 888 pts/1 S+ 11:21 0:00 grep io.shelly
                • immer noch kein io.shelly.0
                ! root@debian-iobroker:~# ip link set dev enp3s0 down
                • jetzt wird die shelly instanz grün
                ! root 13734 3.3 0.5 973320 46348 ? Sl 11:22 0:00 io.shelly.0
                ! root 13766 0.0 0.0 6076 876 pts/1 S+ 11:22 0:00 grep io.shelly
                ! root@debian-iobroker:~# ip link set dev enp3s0 up
                ! root 13734 1.6 0.5 973320 46356 ? Sl 11:22 0:00 io.shelly.0
                ! root 13796 0.0 0.0 6076 884 pts/1 S+ 11:23 0:00 grep io.shelly
                • bis zum nächsten reboot ok
                Gruss
                Christian
                  danw last edited by
                  @tstueben:
                  VG
                  Stübi `
                  Wird bei mir leider nicht angezeigt. Versionen passen.
                    FoxMulder last edited by
                    Habe grade auch probiert und auch bei mir wird nichts dergleichen angezeigt .
                    • Stuebi
                      verwundert mich jetzt ein wenig. Beim Shelly 1 und 2 sollte es wie folgt aussehen:
                        danw last edited by
                        Nope, genau die Zeile fehlt.
                          LJSven last edited by
                          Bei mir sind die RSSI Werte da.
                          • Stuebi
                            @danw:
                            Nope, genau die Zeile fehlt. `
                            Starte einmal die Shelly Instanz neu
                              danw last edited by
                              Ich hatte das sicher schon gemacht, aber nach einem erneuten Neustart isse da. Danke!
                                Nach einen neustart ist es bei mir jetzt auch da 😉
                                  MadTrinity last edited by
                                  bis eben lief alles super mit dem Adapter dann tauchten auf einmal im log nur fehler auf und der adapter startete sich immer neu.
                                  Scheinbar ist ein Shelly aus dem Wlan geflogen.
                                  Habe am Router das Wlan aus und wieder eingeschaltet und es läuft wieder einwandfrei.
                                  Habe mal eine Frage bezüglich abdate da ich nicht viel Ahnung von der ganzen sache habe wie update ich den Adapter? Bei Iobroker taucht keine neue version auf
                                  Vielen Dank vorab
                                  Christian
                                    danw last edited by
                                    Am besten über GitHub updaten. Instanzen in der Menüleiste 8te von links (links neben Expertenmodus).
                                      Danke werde ich mal versuchen,
                                      ist das normal wenn ein Shelly nicht mehr erreichbar ist das der adapter dann immer neustartet ?
                                      • Stuebi
                                        @MadTrinity:
                                        ist das normal wenn ein Shelly nicht mehr erreichbar ist das der adapter dann immer neustartet ? `
                                        Kannst Du mir mal Dein Logfile von den Fehlern schicken. Dann schaue ich einmal ob, wo und was man machen kann.
                                        Stübi
                                          Habe immer die dumme Angewohnheit das zu löschen, sollte das nochmal auftreten sag ich bescheid und füge das Log bei irgendwas mit starts with war eine warunung dann error zeilenweise und dann terminate Shelly.0 dann wurde der Adapter wieder neu gestartet praktisch in einer Endlosschleife.
                                          Jetzt wo alle Shelly's wieder erreichbar sind gibt es keine Fehler im Log.
                                          Gruss
                                          Christian
                                            dodi666 last edited by
                                            Hallo liebe Shelly Freunde,
                                            mir ist jetzt mehrfach aufgefallen, das nach einem iobroker Reboot der eingestellte Auschalttimer in einem Shelly1 abgeschaltet war.
                                            Ist jemandem dieses Verhalten schonmal aufgefallen?
                                            Vielleicht kann das jemand mal testen…
                                            LG
                                            Sascha
                                            adapter shelly
                                            81
                                            717
                                            184175
