    4. Neue Installationsroutine (für Linux)
    • AlCalzone
      @Golan:
      Thanks for the instructions, everything is fine. A question, and on Windows 7, the installer has not changed?, otherwise I have been fighting for the second day, nothing happens. `
      The installer itself has not changed. But under the hood, the installation works differently now, which is why you now need to execute "npm install" twice.
      If you want to do a manual installation, you can find the relevant steps in the new documentation we are currently working on:
      https://iobroker.github.io/ioBroker.doc … d=nodeinst => replace "https://github.com/ioBroker/ioBroker/tarball/master" with just "iobroker". Or continue to read here:
      Open an administrative command prompt and execute the following:
      npm install --global windows-build-tools
      md C:\iobroker
      cd /d C:\iobroker
      npm install iobroker
      Now follow the instructions on screen, which should be
      npm install --production
      or something similar.
        Golan last edited by
        Thank you very much, I will learn and try to install
          Tell me please, what version of the node.js is necessary to pre-install, and then Windows does not perceive npm
          • Oberjembker
            Oberjembker last edited by
            Ich habe mir das Skript (https://raw.githubusercontent.com/ioBro … staller.sh) angeschaut.
            Die logischen Vergleiche mit IS_ROOT passen meiner Ansicht nach so nicht.
            Habe folgendes aus dem Skript getestet:
            if [[ $EUID -eq 0 ]]; then
                    IS_ROOT=true
            else
                    IS_ROOT=false
            fi
            if [[ IS_ROOT -eq true ]]; then
                    echo "running as ROOT"
            else
                    echo "NOT running as ROOT"
            fi
            Das liefert IMMER "running as ROOT".
            Funktionieren wuerde es mit einer der folgenden Abfragen:
            if [ "$IS_ROOT" = true ]; then ...
            if $IS_ROOT ; then ...
              rewenode last edited by
              Recht hat er
              https://stackoverflow.com/questions/295 … ell-script
              • eric2905
                eric2905 last edited by
                Ist schon an die Entwickler weitergeleitet.
                Die schauen sich das an.
                Danke für den Hinweis [emoji106]
                Gruß,
                Eric
                Von unterwegs getippert
                  danyo80 last edited by
                  wäre es möglich, den User iobroker in die SUDO Gruppe aufzunehmen, so dass er Kommandos mit sudo ausführen kann.
                  Ja, ich weiß, dass man damit dem unpreviligierten User nahezu Adminrechte verleiht, aber würde das evtl. helfen, bei Installation wie
                  z.B. ZWAVE aus dem Admin heraus? Oder sollte man dies lieber nicht tun, und die Installtion solcher Adapter auf anderem Wege durchführen?
                  Danyo
                  • AlCalzone
                    Ist auf meiner TODO-Liste. Das löst noch einige andere Probleme, wenn wir das tun.
                    https://github.com/ioBroker/ioBroker/issues/87
                    https://github.com/ioBroker/ioBroker/issues/89
                    AlCalzone created this issue in ioBroker/ioBroker
                    closed Create a script that fixes permissions and autostart and stuff on existing installations #87
                    closed More stuff to do in the installer script #89
                    • MathiasJ
                      MathiasJ last edited by
                      Wie sieht es mit Bluetooth im allgemeinen aus?
                      Ich hatte bisher bei der neuen Installationsroutine das Problem, daß weder Radar noch BLE ging.
                      Wenn ich sudo hcitool lescan eingegeben habe, wurden alle Geräte erkannt, jedoch nicht weitergereicht.
                      Mit der alten Installationsroutine hatte ich das Problem nicht.
                      Gruß,
                      Mathias
                      Gesendet von meinem MI 8 mit Tapatalk
                        könnte es daran liegen, dass der iobroker nicht in der Bluetooth Gruppe ist? Ich meine mich erinnern zu können, dass es eine solche Gruppe gibt. Guck mal in die /etc/group ob es da so eine Gruppe gibt.
                        Danyo
                          LibertyX82 last edited by
                          Ich habe mit dem node-red das Problem, dass ich die Nodes nicht updaten kann
                          https://github.com/ioBroker/ioBroker.node-red/issues/41%5B [Mit der alten Installation (über den alten Weg) konnte ich diese zumindest über die Konsole updaten
                          z.B. ~~[code]~~npm update node-red-node-email[/code] Nach der Installation des iobrokers über das neue Script geht das auch nicht mehr.](</s><LINK_TEXT text=)
                          [" target="_blank">](</s><LINK_TEXT text=)[<link_text text="https://github.com/ioBroker/ioBroker.no … issues/41[">https://github.com/ioBroker/ioBroker.node-red/issues/41[</link_text>[/url]
                          z.B.
                          libertyx82 created this issue in ioBroker/ioBroker.node-red
                          closed Update von nodes nicht möglich #41
                          • AlCalzone
                            @LibertyX82:
                            Nach der Installation des iobrokers über das neue Script geht das auch nicht mehr. `
                            "Geht nicht" ist keine gute Fehlermeldung 😐
                            Vielleicht kannst du ja ein paar mehr Details nennen, damit man den Fehler beheben kann?
                              Es gab leider keine Fehlermeldung.
                              Das Problem hat aber wohl nichts mit der neuen Installationsroutine zu tun, npm funktioniert auch, man sollte es nur im Projektordner ausführen.
                              • AlCalzone
                                @LibertyX82:
                                npm funktioniert auch, man sollte es nur im Projektordner ausführen. `
                                Das hilft tatsächlich :mrgreen:
                                • Oberjembker
                                  Kleiner Hinweis seit der neuen Installationsroutine:
                                  Das System meldet, dass die Datei````
                                  /lib/systemd/system/iobroker.service
                                  Jedenfalls bei mir taucht folgendes auf:
                                  $ sudo dmesg | grep iobroker
                                  [ 9.360610] systemd[1]: Configuration file /lib/systemd/system/iobroker.service is marked executable. Please remove executable permission bits. Proceeding anyway.
                                  Ist erstmal wohl nicht kritisch, aber vielleicht ein security issue.
                                  Lieben Gruß… Arne.
                                  • AlCalzone
                                    Danke für den Hinweis! Da ich eh gerade dabei bin das noch etwas zu überarbeiten, kann ich das mit angehen.
                                      keynight last edited by
                                      Wars jemand mit meinen Installer unzufrieden ?
                                      https://raw.githubusercontent.com/ioBro … spbian8.sh
                                      oder
                                      https://github.com/ioBroker/ioBroker/bl ... stretch.sh
                                      Man sollte nur ab und zu Node-Version korrigieren, sonnst hat er schon ein paar Jahren funktioniert :lol:
                                      • haselchen
                                        haselchen Most Active last edited by
                                        Vielleicht könnt ihr den Usern in diesem Thread helfen…..
                                        Node-Red Module updaten.....
                                        viewtopic.php?f=32&t=19873
                                          denjo last edited by
                                          ich habe Raspbian Desktop installiert mit iobroker, da nicht mehr viel arbeits speicher über ist "PI 3" dachte ich mir ich mach mal ein backup und Raspbian Lite und setz mein system neu auf. Mein Problem ist das der Adapter Amazon-Dash nach einer neu installation nicht mehr läuft, es liegt wie ich gelesen habe an der neu installation Methode von IObroker. Zum Glück habe ich eine andere SD Karte genommen, kann also auf mein altes iobroker zurück greifen. weiß jemand Rat?
                                          Es sollen wohl auch ein zwei andere Adapter davon betroffen sein
                                            Ich nutze zwar den Adapter nicht, aber ich vermute mal es liegt an dem iobroker user ohne root (sudo) Rechte
                                            installation
                                            64
                                            415
                                            114241
