    4. Adapter: iobroker.backitup (stable Release)
    • simatec
      Schaue mal, ob alles gesichert wurde.
      Gab es ein Fehler im log
      • Segway
        Segway last edited by
        Woran sehe ich das ob alles gesichert wurde ?
        Meine sql DB ist recht gross da kann das file doch nicht so klein sein
        • simatec
          Öffne die Datei mit einem geeigneten Tool
          Winzip, winrar, 7zip …
          • Segway
            so hier erstmal das Log; sind auf jedenfall error drin:
            2019-01-05 08:43:15.732  - [34mdebug[39m: backitup.0 [minimal/mount] done
            2019-01-05 08:43:21.901  - [34mdebug[39m: backitup.0 [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-08_43_15_backupiobroker.tar.gz
            2019-01-05 08:43:21.970  - [34mdebug[39m: backitup.0 [minimal/minimal] done
            2019-01-05 08:43:21.996  - [34mdebug[39m: backitup.0 [minimal/mysql] [IGNORED] Error: spawn mysqldump ENOENT
            2019-01-05 08:43:22.013  - [34mdebug[39m: backitup.0 [minimal/mysql] done
            2019-01-05 08:43:22.036  - [34mdebug[39m: backitup.0 [minimal/cifs] done
            2019-01-05 08:43:22.051  - [34mdebug[39m: backitup.0 [minimal/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
            2019-01-05 08:43:22.051  - [34mdebug[39m: backitup.0 [minimal/clean] done
            2019-01-05 08:43:22.057  - [34mdebug[39m: backitup.0 [minimal/mysql] done
            2019-01-05 08:43:22.064  - [34mdebug[39m: backitup.0 [minimal/telegram] [minimal] used Telegram-Instance: telegram.0
            2019-01-05 08:43:22.067  - [34mdebug[39m: backitup.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
            2019-01-05 08:43:22.067  - [34mdebug[39m: backitup.0 [minimal/telegram] done
            2019-01-05 08:43:22.072  - [34mdebug[39m: backitup.0 [minimal/mysql] MySql File deleted!
            2019-01-05 08:43:22.079  - [34mdebug[39m: backitup.0 [minimal/umount] wait 60 seconds for umount!
            2019-01-05 08:43:22.085  - [34mdebug[39m: backitup.0 [minimal/history] done
            2019-01-05 08:43:22.086  - [34mdebug[39m: backitup.0 [minimal] exec: done
            2019-01-05 08:43:22.094  - [34mdebug[39m: backitup.0 redis pmessage  io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546674202093,"q":0,"from":"system.adapter.backitup.0","lc":1546674202093}
            2019-01-05 08:43:22.134  - [34mdebug[39m: backitup.0 [minimal/redis] done
            2019-01-05 08:43:22.135  - [34mdebug[39m: backitup.0 [minimal] exec: done
            2019-01-05 08:43:22.140  - [34mdebug[39m: backitup.0 redis pmessage  io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546674202138,"q":0,"from":"system.adapter.backitup.0","lc":1546674202093}
            2019-01-05 08:44:22.147  - [34mdebug[39m: backitup.0 [minimal/umount] done
            2019-01-05 08:44:22.148  - [34mdebug[39m: backitup.0 [minimal] exec: done
            2019-01-05 08:44:22.153  - [34mdebug[39m: backitup.0 redis pmessage  io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546674262151,"q":0,"from":"system.adapter.backitup.0","lc":1546674202093}
            • Segway
              @nieIP:
              die Installation von
              apt-get install mysql-client
              war die Lösung `
              Das hier hat die Lösung gebracht ! Zumindest ist der Fehler weg und alles läuft sauber durch –> oder nicht ? mysql.tar.gz ist immer noch sehr klein
              backitup.0	2019-01-05 09:45:34.911	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal
              {"val":false,"ack":true,"ts":1546677934908,"q":0,"from":"system.adapter.backitup.0","lc":1546677874890}
              backitup.0	2019-01-05 09:45:34.910	debug	[minimal] exec: done
              backitup.0	2019-01-05 09:45:34.909	debug	[minimal/umount] done
              host.ioBdebian	2019-01-05 09:45:10.805	info	instance system.adapter.daswetter.0 terminated with code 0 (OK)
              daswetter.0	2019-01-05 09:45:01.308	info	starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.15.0
              host.ioBdebian	2019-01-05 09:45:00.024	info	instance system.adapter.daswetter.0 started with pid 1810
              backitup.0	2019-01-05 09:44:39.905	debug	system.adapter.admin.0: logging true
              backitup.0	2019-01-05 09:44:39.904	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1546677879900,"q":0,"from":"system.adapter.admin.0","lc":1546677879900}
              backitup.0	2019-01-05 09:44:34.963	debug	[minimal/mysql] MySql File deleted!
              backitup.0	2019-01-05 09:44:34.891	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546677874890,"q":0,"from":"system.adapter.backitup.0","lc":1546677874890}
              backitup.0	2019-01-05 09:44:34.888	debug	[minimal] exec: done
              backitup.0	2019-01-05 09:44:34.885	debug	[minimal/redis] done
              backitup.0	2019-01-05 09:44:34.846	debug	[minimal/umount] wait 60 seconds for umount!
              backitup.0	2019-01-05 09:44:34.844	debug	[minimal/history] done
              backitup.0	2019-01-05 09:44:34.831	debug	[minimal/telegram] done
              backitup.0	2019-01-05 09:44:34.830	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
              backitup.0	2019-01-05 09:44:34.828	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
              backitup.0	2019-01-05 09:44:34.823	debug	[minimal/clean] done
              backitup.0	2019-01-05 09:44:34.819	debug	[minimal/cifs] done
              backitup.0	2019-01-05 09:44:34.814	debug	[minimal/mysql] done
              backitup.0	2019-01-05 09:44:34.774	debug	[minimal/mysql] done
              backitup.0	2019-01-05 09:44:34.674	debug	[minimal/minimal] done
              backitup.0	2019-01-05 09:44:34.561	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-09_44_29_backupiobroker.tar.gz
              backitup.0	2019-01-05 09:44:29.848	debug	[minimal/mount] done
              backitup.0	2019-01-05 09:44:25.496	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546677865495,"q":0,"from":"system.adapter.admin.0","lc":1546677865495}
              backitup.0	2019-01-05 09:44:22.157	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
              backitup.0	2019-01-05 09:44:22.154	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
              backitup.0	2019-01-05 09:43:48.300	debug	system.adapter.admin.0: logging false
              backitup.0	2019-01-05 09:43:48.298	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546677828296,"q":0,"from":"system.adapter.admin.0","lc":1546677828296}
              • simatec
                Wie gesagt … öffne das backup und schaue nach.
                Alles andere ist Glaskugel schauen ...
                • Segway
                  Musste dafür an den Win-Rechner. Also das mysql file ist leer. Das wurde also nicht erstellt - kein Wunder bei 1Kb Größe.
                  Im Log ist aber auch keine Meldung gewesen.
                  Debug File sieht sauber aus aber SQL dump wird nicht gemacht 😞
                  backitup.0	2019-01-05 12:56:51.107	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546689411103,"q":0,"from":"system.adapter.backitup.0","lc":1546689351091}
                  backitup.0	2019-01-05 12:56:51.104	debug	[minimal] exec: done
                  backitup.0	2019-01-05 12:56:51.104	debug	[minimal/umount] done
                  backitup.0	2019-01-05 12:55:51.093	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546689351091,"q":0,"from":"system.adapter.backitup.0","lc":1546689351091}
                  backitup.0	2019-01-05 12:55:51.088	debug	[minimal] exec: done
                  backitup.0	2019-01-05 12:55:51.086	debug	[minimal/redis] done
                  backitup.0	2019-01-05 12:55:51.041	debug	[minimal/umount] wait 60 seconds for umount!
                  backitup.0	2019-01-05 12:55:51.038	debug	[minimal/history] done
                  backitup.0	2019-01-05 12:55:51.031	debug	[minimal/mysql] MySql File deleted!
                  backitup.0	2019-01-05 12:55:51.020	debug	[minimal/telegram] done
                  backitup.0	2019-01-05 12:55:51.019	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                  backitup.0	2019-01-05 12:55:51.017	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
                  backitup.0	2019-01-05 12:55:51.009	debug	[minimal/clean] done
                  backitup.0	2019-01-05 12:55:51.004	debug	[minimal/cifs] done
                  backitup.0	2019-01-05 12:55:50.995	debug	[minimal/mysql] done
                  backitup.0	2019-01-05 12:55:50.899	debug	[minimal/mysql] done
                  backitup.0	2019-01-05 12:55:50.840	debug	[minimal/minimal] done
                  backitup.0	2019-01-05 12:55:50.774	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-12_55_45_backupiobroker.tar.gz
                  backitup.0	2019-01-05 12:55:45.829	debug	[minimal/mount] done
                  backitup.0	2019-01-05 12:55:41.309	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546689341308,"q":0,"from":"system.adapter.admin.0","lc":1546689341308}
                  backitup.0	2019-01-05 12:55:38.285	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
                  backitup.0	2019-01-05 12:55:38.280	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4
                  • simatec
                    Schaue mal genau rein.
                    Da liegt ein File drin mit dem Dateinamen „.“ (Punkt)
                    Die kannst du im Editor öffnen
                    • Segway
                      Puh, jetzt hab ichs entpacken können und meine AUGENESA hen gar nicht das "_" File 🙂
                      Hier das Ergebnis was auch immer mir das sagen soll:
                      -- MySQL dump 10.16  Distrib 10.1.37-MariaDB, for debian-linux-gnu (x86_64)
                      -- Host: 192.168.40.11    Database: iobroker
                      -- Server version	5.1.73
                      /*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
                      /*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
                      /*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
                      /*!40101 SET NAMES utf8mb4 */;
                      /*!40103 SET @OLD_TIME_ZONE=@@TIME_ZONE */;
                      /*!40103 SET TIME_ZONE='+00:00' */;
                      /*!40014 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0 */;
                      /*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */;
                      /*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */;
                      /*!40111 SET @OLD_SQL_NOTES=@@SQL_NOTES, SQL_NOTES=0 */;
                      Zur Info: Ich habe mal per sqldump auf dem NAS direkt ein backup angestossen. Datei ist 155MB gross und nicht 1kB
                      • simatec
                        Wie hast das manuell gemacht?
                        Nur die iobroker Datenbank oder alles
                        Prüfe deine Daten in der backitup config auch noch einmal
                        Vor allem den Port
                        • Segway
                          Jo habe das manuell angestossen über die Seite STANDARD und Haken angekreuzt das SQL mitgemacht werden soll.
                          Auf der Seite von SQL habe ich schon sämtliche Einstellungen ausprobiert inkl unterschiedlich Ports (0, 3306, 3307 und leer). Immer das gleiche Ergebnise 😞 Daten sind vom sql.0 Adapter übernommen
                          • simatec
                            zeige mal bitte deine Einstellung für mysql
                            • simatec
                              Ab sofort ist die Version 1.0.2 im github und latest verfügbar.
                              1.0.2 (05.01.2019)
                              (simatec) Fix start/stop for new iobroker-Installer
                              • Segway
                                Hier meine Einstellung
                                backitup.0	2019-01-05 18:56:41.675	debug	[minimal] exec: done
                                backitup.0	2019-01-05 18:56:41.673	debug	[minimal/umount] done
                                backitup.0	2019-01-05 18:56:23.162	debug	system.adapter.admin.0: logging false
                                backitup.0	2019-01-05 18:56:23.162	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546710983160,"q":0,"from":"system.adapter.admin.0","lc":1546710983160}
                                backitup.0	2019-01-05 18:56:16.972	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"xxxxxxxxx"}
                                backitup.0	2019-01-05 18:56:16.970	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
                                backitup.0	2019-01-05 18:55:46.977	debug	system.adapter.admin.0: logging true
                                backitup.0	2019-01-05 18:55:46.977	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1546710946975,"q":0,"from":"system.adapter.admin.0","lc":1546710946975}
                                backitup.0	2019-01-05 18:55:41.669	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546710941667,"q":0,"from":"system.adapter.backitup.0","lc":1546710941667}
                                backitup.0	2019-01-05 18:55:41.663	debug	[minimal] exec: done
                                backitup.0	2019-01-05 18:55:41.661	debug	[minimal/redis] done
                                backitup.0	2019-01-05 18:55:41.645	debug	[minimal/mysql] MySql File deleted!
                                backitup.0	2019-01-05 18:55:41.616	debug	[minimal/umount] wait 60 seconds for umount!
                                backitup.0	2019-01-05 18:55:41.614	debug	[minimal/history] done
                                backitup.0	2019-01-05 18:55:41.603	debug	[minimal/telegram] done
                                backitup.0	2019-01-05 18:55:41.603	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                                backitup.0	2019-01-05 18:55:41.601	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
                                backitup.0	2019-01-05 18:55:41.597	debug	[minimal/clean] done
                                backitup.0	2019-01-05 18:55:41.593	debug	[minimal/cifs] done
                                backitup.0	2019-01-05 18:55:41.588	debug	[minimal/mysql] done
                                backitup.0	2019-01-05 18:55:41.563	debug	[minimal/mysql] done
                                backitup.0	2019-01-05 18:55:41.504	debug	[minimal/minimal] done
                                backitup.0	2019-01-05 18:55:41.460	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-18_55_36_backupiobroker.tar.gz
                                backitup.0	2019-01-05 18:55:36.556	debug	[minimal/mount] done
                                backitup.0	2019-01-05 18:55:33.202	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546710933201,"q":0,"from":"system.adapter.admin.0","lc":1546710933201}
                                backitup.0	2019-01-05 18:55:29.368	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
                                backitup.0	2019-01-05 18:55:29.367	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
                                backitup.0	2019-01-05 18:55:23.853	debug	system.adapter.admin.0: logging false
                                backitup.0	2019-01-05 18:55:23.853	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546710923850,"q":0,"from":"system.adapter.admin.0","lc":1546710923850}
                                • simatec
                                  Hast du mal probiert den Hostname statt der IP Adresse zu nehmen?
                                  Wo liegt deine mysqldump?
                                  Gib mal zum testen den Pfad mit ein
                                  • Segway
                                    Weder der Name noch der Pfad bringt was
                                    Warte mal ich glaub ich habs !
                                    • Segway
                                      So, man muss den PFAD eintragen und ich hatte noch zusaetzlich das Programm eingetragen.
                                      Jedenfalls verstehe ich den Text so, wie er da steht - da gehört aber anscheinend nur der Pfad hin.
                                      Nun rödelt er am backup rum !
                                      Frage:
                                      Warum kam keine Meldung im Log ? Kann du das noch einbauen oder nicht erforderlich ?
                                      • Segway
                                        zu früh gefreut ?
                                        seit (fast) einer Stunde dieses Bild
                                        • Segway
                                          Jo, nach diesen Meldungen ist der Adapter neu gestartet 😞 kannst du damit was anfangen ?
                                          backitup.0	2019-01-05 20:06:31.445	debug	[minimal] 10 00 01 */5 * *
                                          backitup.0	2019-01-05 20:06:31.444	info	[minimal] backup was activated at 01:00 every 5 day(s)
                                          backitup.0	2019-01-05 20:06:31.402	error	Error: spawn sudo umount ENOENT at Process.ChildProcess._handle.onexit (internal/child_process.js:190:19) at onErrorNT (internal/child_process.js:362:16) at _combinedTickCallback (internal
                                          backitup.0	2019-01-05 20:06:31.402	error	uncaught exception: spawn sudo umount ENOENT
                                          backitup.0	2019-01-05 20:06:31.402	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
                                          backitup.0	2019-01-05 20:05:59.854	error	Error: spawn EACCES at ChildProcess.spawn (internal/child_process.js:313:11) at exports.spawn (child_process.js:508:9) at WriteStream.stream.once.fd (/opt/iobroker/node_modules/iobroker.ba
                                          backitup.0	2019-01-05 20:05:59.853	error	uncaught exception: spawn EACCES
                                          backitup.0	2019-01-05 20:05:59.825	debug	[minimal/minimal] done
                                          backitup.0	2019-01-05 20:05:59.761	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-20_05_54_backupiobroker.tar.gz
                                          backitup.0	2019-01-05 20:05:54.762	debug	[minimal/mount] done
                                          • simatec
                                            Was liegt jetzt auf dem NAS?
                                            Hat er etwas erstellt?
                                            1.0k
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1192902
