    4. Adapter: iobroker.backitup (stable Release)
    • Segway
      Segway last edited by
      so hier erstmal das Log; sind auf jedenfall error drin:
      2019-01-05 08:43:15.732  - [34mdebug[39m: backitup.0 [minimal/mount] done
      2019-01-05 08:43:21.901  - [34mdebug[39m: backitup.0 [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-08_43_15_backupiobroker.tar.gz
      2019-01-05 08:43:21.970  - [34mdebug[39m: backitup.0 [minimal/minimal] done
      2019-01-05 08:43:21.996  - [34mdebug[39m: backitup.0 [minimal/mysql] [IGNORED] Error: spawn mysqldump ENOENT
      2019-01-05 08:43:22.013  - [34mdebug[39m: backitup.0 [minimal/mysql] done
      2019-01-05 08:43:22.036  - [34mdebug[39m: backitup.0 [minimal/cifs] done
      2019-01-05 08:43:22.051  - [34mdebug[39m: backitup.0 [minimal/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      2019-01-05 08:43:22.051  - [34mdebug[39m: backitup.0 [minimal/clean] done
      2019-01-05 08:43:22.057  - [34mdebug[39m: backitup.0 [minimal/mysql] done
      2019-01-05 08:43:22.064  - [34mdebug[39m: backitup.0 [minimal/telegram] [minimal] used Telegram-Instance: telegram.0
      2019-01-05 08:43:22.067  - [34mdebug[39m: backitup.0 sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
      2019-01-05 08:43:22.067  - [34mdebug[39m: backitup.0 [minimal/telegram] done
      2019-01-05 08:43:22.072  - [34mdebug[39m: backitup.0 [minimal/mysql] MySql File deleted!
      2019-01-05 08:43:22.079  - [34mdebug[39m: backitup.0 [minimal/umount] wait 60 seconds for umount!
      2019-01-05 08:43:22.085  - [34mdebug[39m: backitup.0 [minimal/history] done
      2019-01-05 08:43:22.086  - [34mdebug[39m: backitup.0 [minimal] exec: done
      2019-01-05 08:43:22.094  - [34mdebug[39m: backitup.0 redis pmessage  io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546674202093,"q":0,"from":"system.adapter.backitup.0","lc":1546674202093}
      2019-01-05 08:43:22.134  - [34mdebug[39m: backitup.0 [minimal/redis] done
      2019-01-05 08:43:22.135  - [34mdebug[39m: backitup.0 [minimal] exec: done
      2019-01-05 08:43:22.140  - [34mdebug[39m: backitup.0 redis pmessage  io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546674202138,"q":0,"from":"system.adapter.backitup.0","lc":1546674202093}
      2019-01-05 08:44:22.147  - [34mdebug[39m: backitup.0 [minimal/umount] done
      2019-01-05 08:44:22.148  - [34mdebug[39m: backitup.0 [minimal] exec: done
      2019-01-05 08:44:22.153  - [34mdebug[39m: backitup.0 redis pmessage  io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546674262151,"q":0,"from":"system.adapter.backitup.0","lc":1546674202093}
      • Segway
        @nieIP:
        die Installation von
        apt-get install mysql-client
        war die Lösung `
        Das hier hat die Lösung gebracht ! Zumindest ist der Fehler weg und alles läuft sauber durch –> oder nicht ? mysql.tar.gz ist immer noch sehr klein
        backitup.0	2019-01-05 09:45:34.911	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal
        {"val":false,"ack":true,"ts":1546677934908,"q":0,"from":"system.adapter.backitup.0","lc":1546677874890}
        backitup.0	2019-01-05 09:45:34.910	debug	[minimal] exec: done
        backitup.0	2019-01-05 09:45:34.909	debug	[minimal/umount] done
        host.ioBdebian	2019-01-05 09:45:10.805	info	instance system.adapter.daswetter.0 terminated with code 0 (OK)
        daswetter.0	2019-01-05 09:45:01.308	info	starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.15.0
        host.ioBdebian	2019-01-05 09:45:00.024	info	instance system.adapter.daswetter.0 started with pid 1810
        backitup.0	2019-01-05 09:44:39.905	debug	system.adapter.admin.0: logging true
        backitup.0	2019-01-05 09:44:39.904	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1546677879900,"q":0,"from":"system.adapter.admin.0","lc":1546677879900}
        backitup.0	2019-01-05 09:44:34.963	debug	[minimal/mysql] MySql File deleted!
        backitup.0	2019-01-05 09:44:34.891	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546677874890,"q":0,"from":"system.adapter.backitup.0","lc":1546677874890}
        backitup.0	2019-01-05 09:44:34.888	debug	[minimal] exec: done
        backitup.0	2019-01-05 09:44:34.885	debug	[minimal/redis] done
        backitup.0	2019-01-05 09:44:34.846	debug	[minimal/umount] wait 60 seconds for umount!
        backitup.0	2019-01-05 09:44:34.844	debug	[minimal/history] done
        backitup.0	2019-01-05 09:44:34.831	debug	[minimal/telegram] done
        backitup.0	2019-01-05 09:44:34.830	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
        backitup.0	2019-01-05 09:44:34.828	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
        backitup.0	2019-01-05 09:44:34.823	debug	[minimal/clean] done
        backitup.0	2019-01-05 09:44:34.819	debug	[minimal/cifs] done
        backitup.0	2019-01-05 09:44:34.814	debug	[minimal/mysql] done
        backitup.0	2019-01-05 09:44:34.774	debug	[minimal/mysql] done
        backitup.0	2019-01-05 09:44:34.674	debug	[minimal/minimal] done
        backitup.0	2019-01-05 09:44:34.561	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-09_44_29_backupiobroker.tar.gz
        backitup.0	2019-01-05 09:44:29.848	debug	[minimal/mount] done
        backitup.0	2019-01-05 09:44:25.496	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546677865495,"q":0,"from":"system.adapter.admin.0","lc":1546677865495}
        backitup.0	2019-01-05 09:44:22.157	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
        backitup.0	2019-01-05 09:44:22.154	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
        backitup.0	2019-01-05 09:43:48.300	debug	system.adapter.admin.0: logging false
        backitup.0	2019-01-05 09:43:48.298	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546677828296,"q":0,"from":"system.adapter.admin.0","lc":1546677828296}
        • simatec
          Wie gesagt … öffne das backup und schaue nach.
          Alles andere ist Glaskugel schauen ...
          • Segway
            Musste dafür an den Win-Rechner. Also das mysql file ist leer. Das wurde also nicht erstellt - kein Wunder bei 1Kb Größe.
            Im Log ist aber auch keine Meldung gewesen.
            Debug File sieht sauber aus aber SQL dump wird nicht gemacht 😞
            backitup.0	2019-01-05 12:56:51.107	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546689411103,"q":0,"from":"system.adapter.backitup.0","lc":1546689351091}
            backitup.0	2019-01-05 12:56:51.104	debug	[minimal] exec: done
            backitup.0	2019-01-05 12:56:51.104	debug	[minimal/umount] done
            backitup.0	2019-01-05 12:55:51.093	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546689351091,"q":0,"from":"system.adapter.backitup.0","lc":1546689351091}
            backitup.0	2019-01-05 12:55:51.088	debug	[minimal] exec: done
            backitup.0	2019-01-05 12:55:51.086	debug	[minimal/redis] done
            backitup.0	2019-01-05 12:55:51.041	debug	[minimal/umount] wait 60 seconds for umount!
            backitup.0	2019-01-05 12:55:51.038	debug	[minimal/history] done
            backitup.0	2019-01-05 12:55:51.031	debug	[minimal/mysql] MySql File deleted!
            backitup.0	2019-01-05 12:55:51.020	debug	[minimal/telegram] done
            backitup.0	2019-01-05 12:55:51.019	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
            backitup.0	2019-01-05 12:55:51.017	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
            backitup.0	2019-01-05 12:55:51.009	debug	[minimal/clean] done
            backitup.0	2019-01-05 12:55:51.004	debug	[minimal/cifs] done
            backitup.0	2019-01-05 12:55:50.995	debug	[minimal/mysql] done
            backitup.0	2019-01-05 12:55:50.899	debug	[minimal/mysql] done
            backitup.0	2019-01-05 12:55:50.840	debug	[minimal/minimal] done
            backitup.0	2019-01-05 12:55:50.774	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-12_55_45_backupiobroker.tar.gz
            backitup.0	2019-01-05 12:55:45.829	debug	[minimal/mount] done
            backitup.0	2019-01-05 12:55:41.309	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546689341308,"q":0,"from":"system.adapter.admin.0","lc":1546689341308}
            backitup.0	2019-01-05 12:55:38.285	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
            backitup.0	2019-01-05 12:55:38.280	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4
            • simatec
              Schaue mal genau rein.
              Da liegt ein File drin mit dem Dateinamen „.“ (Punkt)
              Die kannst du im Editor öffnen
              • Segway
                Puh, jetzt hab ichs entpacken können und meine AUGENESA hen gar nicht das "_" File 🙂
                Hier das Ergebnis was auch immer mir das sagen soll:
                -- MySQL dump 10.16  Distrib 10.1.37-MariaDB, for debian-linux-gnu (x86_64)
                -- Host: 192.168.40.11    Database: iobroker
                -- Server version	5.1.73
                /*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
                /*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
                /*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
                /*!40101 SET NAMES utf8mb4 */;
                /*!40103 SET @OLD_TIME_ZONE=@@TIME_ZONE */;
                /*!40103 SET TIME_ZONE='+00:00' */;
                /*!40014 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0 */;
                /*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */;
                /*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */;
                /*!40111 SET @OLD_SQL_NOTES=@@SQL_NOTES, SQL_NOTES=0 */;
                Zur Info: Ich habe mal per sqldump auf dem NAS direkt ein backup angestossen. Datei ist 155MB gross und nicht 1kB
                • simatec
                  Wie hast das manuell gemacht?
                  Nur die iobroker Datenbank oder alles
                  Prüfe deine Daten in der backitup config auch noch einmal
                  Vor allem den Port
                  • Segway
                    Jo habe das manuell angestossen über die Seite STANDARD und Haken angekreuzt das SQL mitgemacht werden soll.
                    Auf der Seite von SQL habe ich schon sämtliche Einstellungen ausprobiert inkl unterschiedlich Ports (0, 3306, 3307 und leer). Immer das gleiche Ergebnise 😞 Daten sind vom sql.0 Adapter übernommen
                    • simatec
                      zeige mal bitte deine Einstellung für mysql
                      • simatec
                        Ab sofort ist die Version 1.0.2 im github und latest verfügbar.
                        1.0.2 (05.01.2019)
                        (simatec) Fix start/stop for new iobroker-Installer
                        • Segway
                          Hier meine Einstellung
                          backitup.0	2019-01-05 18:56:41.675	debug	[minimal] exec: done
                          backitup.0	2019-01-05 18:56:41.673	debug	[minimal/umount] done
                          backitup.0	2019-01-05 18:56:23.162	debug	system.adapter.admin.0: logging false
                          backitup.0	2019-01-05 18:56:23.162	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546710983160,"q":0,"from":"system.adapter.admin.0","lc":1546710983160}
                          backitup.0	2019-01-05 18:56:16.972	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"xxxxxxxxx"}
                          backitup.0	2019-01-05 18:56:16.970	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
                          backitup.0	2019-01-05 18:55:46.977	debug	system.adapter.admin.0: logging true
                          backitup.0	2019-01-05 18:55:46.977	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1546710946975,"q":0,"from":"system.adapter.admin.0","lc":1546710946975}
                          backitup.0	2019-01-05 18:55:41.669	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546710941667,"q":0,"from":"system.adapter.backitup.0","lc":1546710941667}
                          backitup.0	2019-01-05 18:55:41.663	debug	[minimal] exec: done
                          backitup.0	2019-01-05 18:55:41.661	debug	[minimal/redis] done
                          backitup.0	2019-01-05 18:55:41.645	debug	[minimal/mysql] MySql File deleted!
                          backitup.0	2019-01-05 18:55:41.616	debug	[minimal/umount] wait 60 seconds for umount!
                          backitup.0	2019-01-05 18:55:41.614	debug	[minimal/history] done
                          backitup.0	2019-01-05 18:55:41.603	debug	[minimal/telegram] done
                          backitup.0	2019-01-05 18:55:41.603	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                          backitup.0	2019-01-05 18:55:41.601	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
                          backitup.0	2019-01-05 18:55:41.597	debug	[minimal/clean] done
                          backitup.0	2019-01-05 18:55:41.593	debug	[minimal/cifs] done
                          backitup.0	2019-01-05 18:55:41.588	debug	[minimal/mysql] done
                          backitup.0	2019-01-05 18:55:41.563	debug	[minimal/mysql] done
                          backitup.0	2019-01-05 18:55:41.504	debug	[minimal/minimal] done
                          backitup.0	2019-01-05 18:55:41.460	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-18_55_36_backupiobroker.tar.gz
                          backitup.0	2019-01-05 18:55:36.556	debug	[minimal/mount] done
                          backitup.0	2019-01-05 18:55:33.202	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546710933201,"q":0,"from":"system.adapter.admin.0","lc":1546710933201}
                          backitup.0	2019-01-05 18:55:29.368	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
                          backitup.0	2019-01-05 18:55:29.367	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
                          backitup.0	2019-01-05 18:55:23.853	debug	system.adapter.admin.0: logging false
                          backitup.0	2019-01-05 18:55:23.853	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546710923850,"q":0,"from":"system.adapter.admin.0","lc":1546710923850}
                          • simatec
                            Hast du mal probiert den Hostname statt der IP Adresse zu nehmen?
                            Wo liegt deine mysqldump?
                            Gib mal zum testen den Pfad mit ein
                            • Segway
                              Weder der Name noch der Pfad bringt was
                              Warte mal ich glaub ich habs !
                              • Segway
                                So, man muss den PFAD eintragen und ich hatte noch zusaetzlich das Programm eingetragen.
                                Jedenfalls verstehe ich den Text so, wie er da steht - da gehört aber anscheinend nur der Pfad hin.
                                Nun rödelt er am backup rum !
                                Frage:
                                Warum kam keine Meldung im Log ? Kann du das noch einbauen oder nicht erforderlich ?
                                • Segway
                                  zu früh gefreut ?
                                  seit (fast) einer Stunde dieses Bild
                                  • Segway
                                    Jo, nach diesen Meldungen ist der Adapter neu gestartet 😞 kannst du damit was anfangen ?
                                    backitup.0	2019-01-05 20:06:31.445	debug	[minimal] 10 00 01 */5 * *
                                    backitup.0	2019-01-05 20:06:31.444	info	[minimal] backup was activated at 01:00 every 5 day(s)
                                    backitup.0	2019-01-05 20:06:31.402	error	Error: spawn sudo umount ENOENT at Process.ChildProcess._handle.onexit (internal/child_process.js:190:19) at onErrorNT (internal/child_process.js:362:16) at _combinedTickCallback (internal
                                    backitup.0	2019-01-05 20:06:31.402	error	uncaught exception: spawn sudo umount ENOENT
                                    backitup.0	2019-01-05 20:06:31.402	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
                                    backitup.0	2019-01-05 20:05:59.854	error	Error: spawn EACCES at ChildProcess.spawn (internal/child_process.js:313:11) at exports.spawn (child_process.js:508:9) at WriteStream.stream.once.fd (/opt/iobroker/node_modules/iobroker.ba
                                    backitup.0	2019-01-05 20:05:59.853	error	uncaught exception: spawn EACCES
                                    backitup.0	2019-01-05 20:05:59.825	debug	[minimal/minimal] done
                                    backitup.0	2019-01-05 20:05:59.761	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-20_05_54_backupiobroker.tar.gz
                                    backitup.0	2019-01-05 20:05:54.762	debug	[minimal/mount] done
                                    • simatec
                                      Was liegt jetzt auf dem NAS?
                                      Hat er etwas erstellt?
                                      • Segway
                                        Bitte schön 🙂
                                        • simatec
                                          Starte am besten dein iob und dein System mal neu.
                                          Laut Log hat sich da irgendwas verabschiedet
                                            neues Update gemacht, Adapter bleibt Rot Fehlerlog:
                                            backitup.0	2019-01-06 09:18:08.763	info	terminating
                                            backitup.0	2019-01-06 09:18:08.591	debug	system.adapter.admin.0: logging false
                                            backitup.0	2019-01-06 09:18:08.251	error	at tryOnImmediate (timers.js:768:5)
                                            backitup.0	2019-01-06 09:18:08.251	error	at runCallback (timers.js:814:20)
                                            backitup.0	2019-01-06 09:18:08.251	error	at Immediate.createInstancesObjects [as _onImmediate] (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:748:13)
                                            backitup.0	2019-01-06 09:18:08.251	error	at C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:788:29
                                            backitup.0	2019-01-06 09:18:08.251	error	at initAdapter (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:4990:18)
                                            backitup.0	2019-01-06 09:18:08.251	error	at Adapter.emit (events.js:208:7)
                                            backitup.0	2019-01-06 09:18:08.251	error	at emitNone (events.js:106:13)
                                            backitup.0	2019-01-06 09:18:08.251	error	at Adapter.main (C:\ioBroker\node_modules\iobroker.backitup\main.js:555:5)
                                            backitup.0	2019-01-06 09:18:08.251	error	at createBashScripts (C:\ioBroker\node_modules\iobroker.backitup\main.js:483:16)
                                            backitup.0	2019-01-06 09:18:08.251	error	at Object.fs.unlinkSync (fs.js:1061:18)
                                            backitup.0	2019-01-06 09:18:08.251	error	Error: ENOENT: no such file or directory, unlink 'C:\ioBroker\node_modules\iobroker.backitup\lib\stopIOB.bat'
                                            backitup.0	2019-01-06 09:18:08.251	error	uncaught exception: ENOENT: no such file or directory, unlink 'C:\ioBroker\node_modules\iobroker.backitup\lib\stopIOB.bat'
                                            backitup.0	2019-01-06 09:18:08.251	info	starting. Version 1.0.2 in C:/ioBroker/node_modules/iobroker.backitup, node: v8.15.0
                                            backitup.0	2019-01-06 09:18:08.001	debug	statesDB connected
                                            backitup.0	2019-01-06 09:18:07.986	debug	objectDB connected
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1141143
