    4. Adapter: iobroker.backitup (stable Release)
    • Segway
      Segway last edited by
      Musste dafür an den Win-Rechner. Also das mysql file ist leer. Das wurde also nicht erstellt - kein Wunder bei 1Kb Größe.
      Im Log ist aber auch keine Meldung gewesen.
      Debug File sieht sauber aus aber SQL dump wird nicht gemacht 😞
      backitup.0	2019-01-05 12:56:51.107	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546689411103,"q":0,"from":"system.adapter.backitup.0","lc":1546689351091}
      backitup.0	2019-01-05 12:56:51.104	debug	[minimal] exec: done
      backitup.0	2019-01-05 12:56:51.104	debug	[minimal/umount] done
      backitup.0	2019-01-05 12:55:51.093	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546689351091,"q":0,"from":"system.adapter.backitup.0","lc":1546689351091}
      backitup.0	2019-01-05 12:55:51.088	debug	[minimal] exec: done
      backitup.0	2019-01-05 12:55:51.086	debug	[minimal/redis] done
      backitup.0	2019-01-05 12:55:51.041	debug	[minimal/umount] wait 60 seconds for umount!
      backitup.0	2019-01-05 12:55:51.038	debug	[minimal/history] done
      backitup.0	2019-01-05 12:55:51.031	debug	[minimal/mysql] MySql File deleted!
      backitup.0	2019-01-05 12:55:51.020	debug	[minimal/telegram] done
      backitup.0	2019-01-05 12:55:51.019	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
      backitup.0	2019-01-05 12:55:51.017	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
      backitup.0	2019-01-05 12:55:51.009	debug	[minimal/clean] done
      backitup.0	2019-01-05 12:55:51.004	debug	[minimal/cifs] done
      backitup.0	2019-01-05 12:55:50.995	debug	[minimal/mysql] done
      backitup.0	2019-01-05 12:55:50.899	debug	[minimal/mysql] done
      backitup.0	2019-01-05 12:55:50.840	debug	[minimal/minimal] done
      backitup.0	2019-01-05 12:55:50.774	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-12_55_45_backupiobroker.tar.gz
      backitup.0	2019-01-05 12:55:45.829	debug	[minimal/mount] done
      backitup.0	2019-01-05 12:55:41.309	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546689341308,"q":0,"from":"system.adapter.admin.0","lc":1546689341308}
      backitup.0	2019-01-05 12:55:38.285	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
      backitup.0	2019-01-05 12:55:38.280	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":4
      • simatec
        Schaue mal genau rein.
        Da liegt ein File drin mit dem Dateinamen „.“ (Punkt)
        Die kannst du im Editor öffnen
        • Segway
          Puh, jetzt hab ichs entpacken können und meine AUGENESA hen gar nicht das "_" File 🙂
          Hier das Ergebnis was auch immer mir das sagen soll:
          -- MySQL dump 10.16  Distrib 10.1.37-MariaDB, for debian-linux-gnu (x86_64)
          -- Host: 192.168.40.11    Database: iobroker
          -- Server version	5.1.73
          /*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
          /*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
          /*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
          /*!40101 SET NAMES utf8mb4 */;
          /*!40103 SET @OLD_TIME_ZONE=@@TIME_ZONE */;
          /*!40103 SET TIME_ZONE='+00:00' */;
          /*!40014 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0 */;
          /*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */;
          /*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */;
          /*!40111 SET @OLD_SQL_NOTES=@@SQL_NOTES, SQL_NOTES=0 */;
          Zur Info: Ich habe mal per sqldump auf dem NAS direkt ein backup angestossen. Datei ist 155MB gross und nicht 1kB
          • simatec
            Wie hast das manuell gemacht?
            Nur die iobroker Datenbank oder alles
            Prüfe deine Daten in der backitup config auch noch einmal
            Vor allem den Port
            • Segway
              Jo habe das manuell angestossen über die Seite STANDARD und Haken angekreuzt das SQL mitgemacht werden soll.
              Auf der Seite von SQL habe ich schon sämtliche Einstellungen ausprobiert inkl unterschiedlich Ports (0, 3306, 3307 und leer). Immer das gleiche Ergebnise 😞 Daten sind vom sql.0 Adapter übernommen
              • simatec
                zeige mal bitte deine Einstellung für mysql
                • simatec
                  Ab sofort ist die Version 1.0.2 im github und latest verfügbar.
                  1.0.2 (05.01.2019)
                  (simatec) Fix start/stop for new iobroker-Installer
                  • Segway
                    Hier meine Einstellung
                    backitup.0	2019-01-05 18:56:41.675	debug	[minimal] exec: done
                    backitup.0	2019-01-05 18:56:41.673	debug	[minimal/umount] done
                    backitup.0	2019-01-05 18:56:23.162	debug	system.adapter.admin.0: logging false
                    backitup.0	2019-01-05 18:56:23.162	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546710983160,"q":0,"from":"system.adapter.admin.0","lc":1546710983160}
                    backitup.0	2019-01-05 18:56:16.972	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"xxxxxxxxx"}
                    backitup.0	2019-01-05 18:56:16.970	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
                    backitup.0	2019-01-05 18:55:46.977	debug	system.adapter.admin.0: logging true
                    backitup.0	2019-01-05 18:55:46.977	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1546710946975,"q":0,"from":"system.adapter.admin.0","lc":1546710946975}
                    backitup.0	2019-01-05 18:55:41.669	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1546710941667,"q":0,"from":"system.adapter.backitup.0","lc":1546710941667}
                    backitup.0	2019-01-05 18:55:41.663	debug	[minimal] exec: done
                    backitup.0	2019-01-05 18:55:41.661	debug	[minimal/redis] done
                    backitup.0	2019-01-05 18:55:41.645	debug	[minimal/mysql] MySql File deleted!
                    backitup.0	2019-01-05 18:55:41.616	debug	[minimal/umount] wait 60 seconds for umount!
                    backitup.0	2019-01-05 18:55:41.614	debug	[minimal/history] done
                    backitup.0	2019-01-05 18:55:41.603	debug	[minimal/telegram] done
                    backitup.0	2019-01-05 18:55:41.603	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
                    backitup.0	2019-01-05 18:55:41.601	debug	[minimal/telegram] [minimal] used Telegram-Instance: telegram.0
                    backitup.0	2019-01-05 18:55:41.597	debug	[minimal/clean] done
                    backitup.0	2019-01-05 18:55:41.593	debug	[minimal/cifs] done
                    backitup.0	2019-01-05 18:55:41.588	debug	[minimal/mysql] done
                    backitup.0	2019-01-05 18:55:41.563	debug	[minimal/mysql] done
                    backitup.0	2019-01-05 18:55:41.504	debug	[minimal/minimal] done
                    backitup.0	2019-01-05 18:55:41.460	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-18_55_36_backupiobroker.tar.gz
                    backitup.0	2019-01-05 18:55:36.556	debug	[minimal/mount] done
                    backitup.0	2019-01-05 18:55:33.202	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1546710933201,"q":0,"from":"system.adapter.admin.0","lc":1546710933201}
                    backitup.0	2019-01-05 18:55:29.368	debug	sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"638246091":"Schecki_Homematic"}
                    backitup.0	2019-01-05 18:55:29.367	debug	redis pmessage messagebox.system.adapter.backitup.0 messagebox.system.adapter.backitup.0 {"command":"getTelegramUser","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1
                    backitup.0	2019-01-05 18:55:23.853	debug	system.adapter.admin.0: logging false
                    backitup.0	2019-01-05 18:55:23.853	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1546710923850,"q":0,"from":"system.adapter.admin.0","lc":1546710923850}
                    • simatec
                      Hast du mal probiert den Hostname statt der IP Adresse zu nehmen?
                      Wo liegt deine mysqldump?
                      Gib mal zum testen den Pfad mit ein
                      • Segway
                        Weder der Name noch der Pfad bringt was
                        Warte mal ich glaub ich habs !
                        • Segway
                          So, man muss den PFAD eintragen und ich hatte noch zusaetzlich das Programm eingetragen.
                          Jedenfalls verstehe ich den Text so, wie er da steht - da gehört aber anscheinend nur der Pfad hin.
                          Nun rödelt er am backup rum !
                          Frage:
                          Warum kam keine Meldung im Log ? Kann du das noch einbauen oder nicht erforderlich ?
                          • Segway
                            zu früh gefreut ?
                            seit (fast) einer Stunde dieses Bild
                            • Segway
                              Jo, nach diesen Meldungen ist der Adapter neu gestartet 😞 kannst du damit was anfangen ?
                              backitup.0	2019-01-05 20:06:31.445	debug	[minimal] 10 00 01 */5 * *
                              backitup.0	2019-01-05 20:06:31.444	info	[minimal] backup was activated at 01:00 every 5 day(s)
                              backitup.0	2019-01-05 20:06:31.402	error	Error: spawn sudo umount ENOENT at Process.ChildProcess._handle.onexit (internal/child_process.js:190:19) at onErrorNT (internal/child_process.js:362:16) at _combinedTickCallback (internal
                              backitup.0	2019-01-05 20:06:31.402	error	uncaught exception: spawn sudo umount ENOENT
                              backitup.0	2019-01-05 20:06:31.402	info	starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
                              backitup.0	2019-01-05 20:05:59.854	error	Error: spawn EACCES at ChildProcess.spawn (internal/child_process.js:313:11) at exports.spawn (child_process.js:508:9) at WriteStream.stream.once.fd (/opt/iobroker/node_modules/iobroker.ba
                              backitup.0	2019-01-05 20:05:59.853	error	uncaught exception: spawn EACCES
                              backitup.0	2019-01-05 20:05:59.825	debug	[minimal/minimal] done
                              backitup.0	2019-01-05 20:05:59.761	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_01_05-20_05_54_backupiobroker.tar.gz
                              backitup.0	2019-01-05 20:05:54.762	debug	[minimal/mount] done
                              • simatec
                                Was liegt jetzt auf dem NAS?
                                Hat er etwas erstellt?
                                • Segway
                                  Bitte schön 🙂
                                  • simatec
                                    Starte am besten dein iob und dein System mal neu.
                                    Laut Log hat sich da irgendwas verabschiedet
                                      neues Update gemacht, Adapter bleibt Rot Fehlerlog:
                                      backitup.0	2019-01-06 09:18:08.763	info	terminating
                                      backitup.0	2019-01-06 09:18:08.591	debug	system.adapter.admin.0: logging false
                                      backitup.0	2019-01-06 09:18:08.251	error	at tryOnImmediate (timers.js:768:5)
                                      backitup.0	2019-01-06 09:18:08.251	error	at runCallback (timers.js:814:20)
                                      backitup.0	2019-01-06 09:18:08.251	error	at Immediate.createInstancesObjects [as _onImmediate] (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:748:13)
                                      backitup.0	2019-01-06 09:18:08.251	error	at C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:788:29
                                      backitup.0	2019-01-06 09:18:08.251	error	at initAdapter (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:4990:18)
                                      backitup.0	2019-01-06 09:18:08.251	error	at Adapter.emit (events.js:208:7)
                                      backitup.0	2019-01-06 09:18:08.251	error	at emitNone (events.js:106:13)
                                      backitup.0	2019-01-06 09:18:08.251	error	at Adapter.main (C:\ioBroker\node_modules\iobroker.backitup\main.js:555:5)
                                      backitup.0	2019-01-06 09:18:08.251	error	at createBashScripts (C:\ioBroker\node_modules\iobroker.backitup\main.js:483:16)
                                      backitup.0	2019-01-06 09:18:08.251	error	at Object.fs.unlinkSync (fs.js:1061:18)
                                      backitup.0	2019-01-06 09:18:08.251	error	Error: ENOENT: no such file or directory, unlink 'C:\ioBroker\node_modules\iobroker.backitup\lib\stopIOB.bat'
                                      backitup.0	2019-01-06 09:18:08.251	error	uncaught exception: ENOENT: no such file or directory, unlink 'C:\ioBroker\node_modules\iobroker.backitup\lib\stopIOB.bat'
                                      backitup.0	2019-01-06 09:18:08.251	info	starting. Version 1.0.2 in C:/ioBroker/node_modules/iobroker.backitup, node: v8.15.0
                                      backitup.0	2019-01-06 09:18:08.001	debug	statesDB connected
                                      backitup.0	2019-01-06 09:18:07.986	debug	objectDB connected
                                      • Segway
                                        @simatec:
                                        Laut Log hat sich da irgendwas verabschiedet `
                                        Habe ich alles schon mehrfach gemacht ! Bringt nichts.
                                        Da es sich um mein Prod.-System handelt (ich habe noch kein Testsystem aufgesetzt) nehme ich den SQL jetzt raus und mache das direkt auf meinem NAS per Cronjob. Klappt auf Anhieb und tar-Datei ist 155MB groß.
                                        Daher lasse ich es mal so jetzt. Wenn Testsystem aufgesetzt dann kann ich mal wieder weitertesten, okay ?
                                        • Merlin123
                                          Merlin123 last edited by
                                          Bei mir wirft die neue Version leider auch Fehler:
                                          host.orangepiplus2e	2019-01-06 09:40:45.971	info	Restart adapter system.adapter.backitup.0 because enabled
                                          host.orangepiplus2e	2019-01-06 09:40:45.971	error	instance system.adapter.backitup.0 terminated with code 0 (OK)
                                          host.orangepiplus2e	2019-01-06 09:40:45.971	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh' }
                                          host.orangepiplus2e	2019-01-06 09:40:45.971	error	Caught by controller[0]: syscall: 'unlink',
                                          host.orangepiplus2e	2019-01-06 09:40:45.970	error	Caught by controller[0]: code: 'ENOENT',
                                          host.orangepiplus2e	2019-01-06 09:40:45.970	error	Caught by controller[0]: errno: -2,
                                          host.orangepiplus2e	2019-01-06 09:40:45.970	error	Caught by controller[0]: at tryOnImmediate (timers.js:768:5)
                                          host.orangepiplus2e	2019-01-06 09:40:45.970	error	Caught by controller[0]: at runCallback (timers.js:814:20)
                                          host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at Immediate.createInstancesObjects [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
                                          host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
                                          host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
                                          host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at Adapter.emit (events.js:208:7)
                                          host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at emitNone (events.js:106:13)
                                          host.orangepiplus2e	2019-01-06 09:40:45.968	error	Caught by controller[0]: at Adapter.main (/opt/iobroker/node_modules/iobroker.backitup/main.js:555:5)
                                          host.orangepiplus2e	2019-01-06 09:40:45.968	error	Caught by controller[0]: at createBashScripts (/opt/iobroker/node_modules/iobroker.backitup/main.js:489:16)
                                          host.orangepiplus2e	2019-01-06 09:40:45.968	error	Caught by controller[0]: at Object.fs.unlinkSync (fs.js:1061:18)
                                          host.orangepiplus2e	2019-01-06 09:40:45.967	error	Caught by controller[0]: { Error: ENOENT: no such file or directory, unlink '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh'
                                          backitup.0	2019-01-06 09:40:45.448	error	Error: ENOENT: no such file or directory, unlink '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh' at Object.fs.unlinkSync (fs.js:1061:18) at createBashScripts (/opt/iobroker/node_
                                          backitup.0	2019-01-06 09:40:45.448	error	uncaught exception: ENOENT: no such file or directory, unlink '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh'
                                          backitup.0	2019-01-06 09:40:45.447	info	starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.12.0
                                            Jan1 last edited by
                                            auch hier sehr viele Fehler im Log und der Adapter geht immer wieder auf rot
                                            host.raspberrypi	2019-01-06 09:58:40.435	error	instance system.adapter.backitup.0 terminated with code 0 (OK)
                                            Caught	2019-01-06 09:58:40.435	error	by controller[0]: path: '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh' }
                                            Caught	2019-01-06 09:58:40.435	error	by controller[0]: syscall: 'unlink',
                                            Caught	2019-01-06 09:58:40.435	error	by controller[0]: code: 'ENOENT',
                                            Caught	2019-01-06 09:58:40.435	error	by controller[0]: errno: -2,
                                            Caught	2019-01-06 09:58:40.435	error	by controller[0]: at tryOnImmediate (timers.js:768:5)
                                            Caught	2019-01-06 09:58:40.435	error	by controller[0]: at runCallback (timers.js:814:20)
                                            Caught	2019-01-06 09:58:40.434	error	by controller[0]: at Immediate.createInstancesObjects [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
                                            Caught	2019-01-06 09:58:40.434	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
                                            Caught	2019-01-06 09:58:40.434	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
                                            Caught	2019-01-06 09:58:40.434	error	by controller[0]: at Adapter.emit (events.js:208:7)
                                            Caught	2019-01-06 09:58:40.434	error	by controller[0]: at emitNone (events.js:106:13)
                                            Caught	2019-01-06 09:58:40.434	error	by controller[0]: at Adapter.main (/opt/iobroker/node_modules/iobroker.backitup/main.js:555:5)
                                            Caught	2019-01-06 09:58:40.434	error	by controller[0]: at createBashScripts (/opt/iobroker/node_modules/iobroker.backitup/main.js:489:16)
                                            Caught	2019-01-06 09:58:40.433	error	by controller[0]: at Object.fs.unlinkSync (fs.js:1061:18)
                                            Caught	2019-01-06 09:58:40.433	error	by controller[0]: { Error: ENOENT: no such file or directory, unlink '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh'
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1193472
