    4. Hilfe!!! Ich komme nicht mehr auf meinen Iobroker
      Führe mal bitte im Verzeichnis /opt/iobroker folgenden Befehl aus:
      npm i
      Rainer
      • N
        NinjaTurtle last edited by
        OMG ich glaube ich hab es 😄 :shock:
        systemctl start iobroker
          Das wäre die Antwort gewesen
          http://www.iobroker.net/docu/?page_id=8 … de#Hinweis
          dann hattest du aber nicht mit npm install iobroker –unsafe-perm installiert
          Rainer
          • N
            > bufferutil@1.1.0 install /opt/iobroker/node_modules/kodi-ws/node_modules/bufferutil
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/kodi-ws/node_modules/bufferutil/build“ wird betreten
              CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
            In file included from ../../nan/nan.h:82:0,
                             from ../src/bufferutil.cc:16:
            ../../nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Int32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:
            ../../nan/nan_new.h:34:64: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             To<v8::int32>(v8::Handle <v8::integer>i)   { return i->ToInt32(); }
            In file included from ../src/bufferutil.cc:7:0:
            /root/.node-gyp/8.15.0/include/node/v8.h:9864:14: note: declared here
             Local <int32>Value::ToInt32() const {
            ../../nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handle<v8::integer>) [with T = v8::Uint32; v8::Handle <v8::integer>= v8::Local<v8::integer>]’:
            ../../nan/nan_new.h:39:65: warning: ‘v8::Local <v8::uint32>v8::Value::ToUint32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             To<v8::uint32>(v8::Handle <v8::integer>i)  { return i->ToUint32(); }
            /root/.node-gyp/8.15.0/include/node/v8.h:9858:15: note: declared here
             Local <uint32>Value::ToUint32() const {
            In file included from ../../nan/nan_new.h:189:0,
                             from ../../nan/nan.h:82,
            ../../nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::booleanobject>::return_t NanIntern::Factory<v8::booleanobject>::New(bool)’:
            ../../nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local <v8::value>v8::BooleanObject::New(bool)’ is deprecated: Pass an isolate [-Wdeprecated-declarations]
               return v8::BooleanObject::New(value).As<v8::booleanobject>();
            In file included from /root/.node-gyp/8.15.0/include/node/v8.h:26:0,
            /root/.node-gyp/8.15.0/include/node/v8.h:4895:56: note: declared here
               V8_DEPRECATED("Pass an isolate", static Local <value>New(bool value));
            /root/.node-gyp/8.15.0/include/node/v8config.h:318:3: note: in definition of macro ‘V8_DEPRECATED’
               declarator __attribute__((deprecated(message)))
            ../../nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::script>::return_t NanIntern::Factory<v8::script>::New(v8::Local<v8::string>)’:
            ../../nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local <v8::script>v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
            /root/.node-gyp/8.15.0/include/node/v8.h:1475:21: note: declared here
                   Local</v8::script></v8::string></v8::script></v8::script></value></v8::booleanobject></v8::value></v8::booleanobject></v8::booleanobject></uint32></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></int32></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer>
            • N
              ja doch, aber dann habe ich bestimmt bei downgrade irgendwas verpiddelt :oops: :oops: :oops: ich konnte bis dahin noch iobroker stop und start verwenden
              • N
                Aber es läuft jetzt kann ich den iobroker automatisch starten lassen?
                Auf jeden Fall vielen vielen Dank für die Hilfe :!: :!: :!: mir fällt ein rießen Stein vom Herzen 😄
                  @NinjaTurtle:
                  kann ich den iobroker automatisch starten lassen? `
                  • Backup
                  • platt machen
                  • Debian neu installieren
                  • iobroker nach verlinkter Anleitung (neu) neu installieren
                  • restore
                  Da kann zu viel zerschossen sein.
                  Das zu finden und zu fixen wird nicht leicht
                  Rainer
                  • N
                    Ok Dankeschön!!!
                    • N
                      Wo finde ich den den richtigen weg um das Packet von Node 10 auf 8 zu ändern?
                        Hier:
                        http://www.iobroker.net/docu/?page_id=8 … ion_Nodejs
                        Viel Glück
                        81.1k
                        1421
