    2. Русский
    3. ioBroker
    4. ioBroker установка и конфигурация
    5. Инсталляция под Windows
    • Bluefox
      Bluefox last edited by
      @instalator:
      Поставил новый дистр. набрал cd %ProgramFiles%\iobroker
      node controller.js
      ! C:\Program Files\ioBroker>node controller.js
      ! 2014-11-28 23:53:40.075 - info: ioBroker.js-controller version 0.1.1 js-controller starting
      ! 2014-11-28 23:53:40.077 - info: Copyright © 2014 hobbyquaker, bluefox
      ! 2014-11-28 23:53:40.078 - info: controller hostname: instalator
      ! 2014-11-28 23:53:40.078 - info: controller ip addresses: 192.168.1.35 2001:0:5ef5:79fb:2867:b
      ! a2:ac09:16a1 fe80::2867:ba2:ac09:16a1
      ! events.js:72
      ! throw er; // Unhandled 'error' event
      ! Error: EPERM, open 'C:\Program Files\ioBroker\log\iobroker.log'
      http://localhost:8081/ - Веб страница недоступна
      ! C:\Program Files\ioBroker>net start iobroker
      ! Системная ошибка 5.
      ! Отказано в доступе.
      При повторной установке выдает ошибку filename="Безымянный.png" index="0">~~
      После повторной переустановки
      ! 2014-11-29 00:09:48.894 - info: ioBroker.js-controller version 0.1.1 js-controller starting
      ! 2014-11-29 00:09:48.897 - info: Copyright © 2014 hobbyquaker, bluefox
      ! 2014-11-29 00:09:48.897 - info: controller hostname: instalator
      ! 2014-11-29 00:09:48.898 - info: controller ip addresses: 192.168.1.35 2001:0:5ef5:79fb:2867:b
      ! 2014-11-29 00:09:49.093 - info: controller couchdb connected
      ! 2014-11-29 00:09:49.118 - info: controller 1 instance found
      ! 2014-11-29 00:09:49.119 - info: controller starting 1 instance
      ! 2014-11-29 00:09:49.123 - warn: controller startInstance cannot find start file for adapter "
      ! admin". Try to install it...1 attempt
      ! 2014-11-29 00:09:49.124 - info: iobroker install admin
      ! events.js:72
      ! Error: Redis connection to 127.0.0.1:6379 failed - connect ECONNREFUSED
      ! at RedisClient.on_error (C:\Program Files\ioBroker\node_modules\redis\index.js:185:24)
      ! at Socket. <anonymous>(C:\Program Files\ioBroker\node_modules\redis\index.js:95:14)
      ! at Socket.emit (events.js:95:17)
      ! at net.js:440:14
      ! at process._tickCallback (node.js:419:13)</anonymous> `
      Взялся за установщик. Удалил node и couch, redis и поставил отсюда: http://download.iobroker.org/ioBrokerIn … .0.1.6.exe
      У меня заработало после исправления нескольких ошибок. Они уже в 0.1.6 исправлены.
      • I
        instalator last edited by
        Удалил все, поставил ioBrokerInstaller.0.1.6.exe, http://localhost:8081/ - веб страница не доступна.
        ! 2014-11-30 11:38:15.128 - info: ioBroker.js-controller version 0.1.6 js-controller starting
        ! 2014-11-30 11:38:15.148 - info: Copyright © 2014 hobbyquaker, bluefox
        ! 2014-11-30 11:38:15.148 - info: controller hostname: instalator
        ! 2014-11-30 11:38:15.149 - info: controller ip addresses: 192.168.1.10 2001:0:9d38:90d7:2094:2
        ! 107:3f57:fef5 fe80::2094:2107:3f57:fef5
        ! events.js:72
        В логе вот что
        ! 2014-11-30 11:46:40.893 - [32minfo[39m: ioBroker.js-controller version 0.1.6 js-controller starting
        ! 2014-11-30 11:46:40.894 - [32minfo[39m: Copyright © 2014 hobbyquaker, bluefox
        ! 2014-11-30 11:46:40.894 - [32minfo[39m: controller hostname: instalator
        ! 2014-11-30 11:46:40.894 - [32minfo[39m: controller ip addresses: 192.168.1.10 2001:0:9d38:90d7:2094:2107:3f57:fef5 fe80::2094:2107:3f57:fef5
        ! 2014-11-30 11:46:41.087 - [32minfo[39m: controller couchdb connected
        ! 2014-11-30 11:46:41.111 - [32minfo[39m: controller 1 instance found
        ! 2014-11-30 11:46:41.111 - [32minfo[39m: controller starting 1 instance
        ! 2014-11-30 11:46:41.123 - [33mwarn[39m: controller startInstance cannot find start file for adapter "admin". Try to install it...1 attempt
        ! 2014-11-30 11:46:41.124 - [32minfo[39m: iobroker install admin[/spoiler]
        • aurodionov
          aurodionov last edited by
          instalator, а если запустить с правами админа ?
          • I
            @aurodionov:
            instalator, а если запустить с правами админа ? `
            Запустить что?
            Набрал iobroker install admin
            Поругался. Скачал с гитхаба по ссылке, пытаясь сохранить в c:\Program Files\ioBroker\tmp\ сказал что нету прав. Навесил прав - iobroker install admin прошло успешно. Сайт все равно не доступен
            ! 2014-11-30 12:12:28.221 - info: ioBroker.js-controller version 0.1.6 js-controller starting
            ! 2014-11-30 12:12:28.223 - info: Copyright © 2014 hobbyquaker, bluefox
            ! 2014-11-30 12:12:28.224 - info: controller hostname: instalator
            ! 2014-11-30 12:12:28.224 - info: controller ip addresses: 192.168.1.10 2001:0:9d38:90d7:2094:2
            ! 2014-11-30 12:12:28.416 - info: controller couchdb connected
            ! 2014-11-30 12:12:28.440 - info: controller 1 instance found
            ! 2014-11-30 12:12:28.441 - info: controller starting 1 instance
            ! 2014-11-30 12:12:28.454 - info: controller instance system.adapter.admin.0 started with pid 5
            ! 084
            ! module.js:340
            ! throw err;
            ! Error: Cannot find module 'express'
            ! at Function.Module._resolveFilename (module.js:338:15)
            ! at Function.Module._load (module.js:280:25)
            ! at Module.require (module.js:364:17)
            ! at require (module.js:380:17)
            ! at Object. <anonymous>(C:\Program Files\ioBroker\adapter\admin\admin.js:5:16)
            ! at Module._compile (module.js:456:26)
            ! at Object.Module._extensions..js (module.js:474:10)
            ! at Module.load (module.js:356:32)
            ! at Function.Module._load (module.js:312:12)
            ! at Function.Module.runMain (module.js:497:10)
            ! 2014-11-30 12:12:28.501 - error: controller instance system.adapter.admin.0 terminated with c
            ! ode 8
            ! 2014-11-30 12:12:28.502 - info: Restart adapter system.adapter.admin.0 because enabled
            ! events.js:72
            ! at net.js:440:14
            ! at process._tickCallback (node.js:419:13)</anonymous></anonymous>
            • aurodionov
              по "форточкам не подскажу ,пользую на дебиане и шастаю с бука удалённо , после обновления постоянно слетают права на iobroker.
              даю права на запуск всё стартует , попробуйте запускать файл с правами админа (вроде для запуска под форточками iobroker.bat)
              • I
                @aurodionov:
                даю права на запуск всё стартует , попробуйте запускать файл с правами админа (вроде для запуска под форточками iobroker.bat) `
                Уже пробовал.
                Запускаю батник, окно промелькивает, сайт не доступен.
                • Bluefox
                  @instalator:
                  @aurodionov:
                  Уже пробовал.
                  Запускаю батник, окно промелькивает, сайт не доступен. `
                  Просто нет прав администратора на машине. Запустить можно всё и из консоли управления (не путать с коммандной строкой).
                  http://softlakecity.ru/os/windows/vklyu … uyu-stroku
                  Вот выдержка:
                  ` > Для того, чтобы выполнять описанные выше действия с любой службой Windows, необходимо знать её короткое имя. Получить это имя можно в свойствах службы:
                  Нажмите комбинацию клавиш Win+R.
                  В появившееся окно введите services.msc и нажмите Enter.
                  Когда перед Вами появится список служб Windows, выберите необходимую, кликните по ней правой кнопкой мыши и выберите пункт Свойства.
                  Вы увидите окно, в верхней части которого можно прочесть имя службы.
                  Свойства службы автоматических обновлений
                  Примечание. В операционных системах Windows 7 и Windows 8 командную строку необходимо запускать от имени администратора, иначе у Вас не будет полномочий для задание вышеуказанных настроек. `
                  Надо запустить Redis/CouchDB и ioBroker
                  А эта ошибка:
                  2014-11-30 11:38:15.148 - info: Copyright (c) 2014 hobbyquaker, bluefox
                  events.js:72
                  Вылезает только потому, что командная строка запущена не с администраторскими правами.
                  Запустите строку как здесь и всё заработает. И net stat и node controller.js
                  • I
                    @Bluefox:
                    Запустите строку как здесь и всё заработает. И net stat и node controller.js `
                    И так запускал.
                    ! c:\Program Files (x86)\ioBroker>node controller.js
                    ! 2014-12-01 20:09:07.420 - info: ioBroker.js-controller version 0.1.6 js-control
                    ! ler starting
                    ! 2014-12-01 20:09:07.422 - info: Copyright © 2014 hobbyquaker, bluefox
                    ! 2014-12-01 20:09:07.423 - info: controller hostname: instalator
                    ! 2014-12-01 20:09:07.423 - info: controller ip addresses: 192.168.1.10 2001:0:9d
                    ! 38:6abd:3447:2e3:3f57:fef5 fe80::3447:2e3:3f57:fef5
                    ! 2014-12-01 20:09:11.764 - info: controller couchdb connected
                    ! 2014-12-01 20:09:13.286 - info: controller 1 instance found
                    ! 2014-12-01 20:09:13.287 - info: controller starting 1 instance
                    ! 2014-12-01 20:09:13.299 - info: controller instance system.adapter.admin.0 star
                    ! ted with pid 3212
                    ! module.js:340
                    ! throw err;
                    ! at Object. <anonymous>(c:\Program Files (x86)\ioBroker\adapter\admin\admin.j
                    ! s:5:16)
                    ! 2014-12-01 20:09:13.350 - error: controller instance system.adapter.admin.0 ter
                    ! minated with code 8
                    ! 2014-12-01 20:09:13.350 - info: Restart adapter system.adapter.admin.0 because
                    ! enabled
                    ! 2014-12-01 20:09:43.359 - info: controller instance system.adapter.admin.0 star
                    ! ted with pid 5180</anonymous>
                    • Bluefox
                      @instalator:
                      @Bluefox:
                      И так запускал.
                      ! ler starting
                      ! ted with pid 3212
                      ! module.js:340
                      ! throw err;
                      ! s:5:16)
                      ! enabled
                      ! ted with pid 5180</anonymous> `
                      Может быть такое, что интернет был не доступен во время установки?
                      Надо под админом в консоли зайти в c:\Program Files (x86)\ioBroker\ и выполнить
                      npm install "c:\Program Files (x86)\ioBroker\adapter\admin" --production --prefix "c:\Program Files (x86)\ioBroker\adapter\admin"
                      • I
                        @Bluefox:
                        Инет доступен.
                        Выполнил строку выше
                        теперь вот что выдает:
                        ! c:\Program Files\ioBroker>node controller.js
                        ! 2014-12-01 21:48:03.203 - info: ioBroker.js-controller version 0.1.6 js-control
                        ! ler starting
                        ! 2014-12-01 21:48:03.206 - info: Copyright © 2014 hobbyquaker, bluefox
                        ! 2014-12-01 21:48:03.207 - info: controller hostname: instalator
                        ! 2014-12-01 21:48:03.207 - info: controller ip addresses: 192.168.1.10 2001:0:5e
                        ! f5:79fb:2867:ba2:ac09:16a1 fe80::2867:ba2:ac09:16a1
                        ! 2014-12-01 21:48:06.081 - info: controller couchdb connected
                        ! 2014-12-01 21:48:06.186 - info: controller 1 instance found
                        ! 2014-12-01 21:48:06.187 - info: controller starting 1 instance
                        ! 2014-12-01 21:48:06.196 - info: controller instance system.adapter.admin.0 star
                        ! ted with pid 5636
                        ! module.js:340
                        ! throw err;
                        ! Error: Cannot find module 'socket.io'
                        ! at Object. <anonymous>(c:\Program Files\ioBroker\adapter\admin\admin.js:6:16
                        ! 2014-12-01 21:48:06.338 - error: controller instance system.adapter.admin.0 ter
                        ! 2014-12-01 21:48:06.338 - info: Restart adapter system.adapter.admin.0 because
                        ! enabled</anonymous>
                        Может через тимвьювер попробуешь сам?
                        • Bluefox
                          @instalator:
                          @Bluefox:
                          Инет доступен.
                          ! ler starting
                          ! ted with pid 5636
                          ! module.js:340
                          ! throw err;
                          Может через тимвьювер попробуешь сам? `
                          Попробую, как только доберусь до дома. У меня витает сейчас идея: выбросить couchDb и redis вообще и всё делать через mqtt broker.
                          Сегодня посоветуюсь со вторым товарищем, а пока, я думаю, следует подождать следующей итерации.
                          • X
                            X13 last edited by
                            @Bluefox:
                            У меня витает сейчас идея: выбросить couchDb и redis вообще и всё делать через mqtt broker. `
                            Одна из особенностей MQTT - на subscribe приходят только топики с установленным retain, остальное только по изменению. Из моего опыта - сильно не хватает возможности сказать сделай вот это. Я потому и смотрю на WAMP, что у него RPC есть в дополнение.
                            • Bluefox
                              @X13:
                              Одна из особенностей MQTT - на subscribe приходят только топики с установленным retain, остальное только по изменению. `
                              А что мешает мне установить все мои топики, как retain?
                              @X13:
                              Из моего опыта - сильно не хватает возможности сказать сделай вот это. `
                              "Вот это". Что именно?
                              @X13:
                              Я потому и смотрю на WAMP, что у него RPC есть в дополнение. `
                              Я не могу найти версии рутера для node.js.
                              https://github.com/Orange-OpenSource/wamp.rt - это ещё сыроват,
                              а вот этот - https://github.com/mcollina/mosca уже выглядит работающим.
                              А если не применять node.js для брокера/рутера, то опять проблема установки. Через это мы уже проходили. 😢
                                KondorSoft last edited by
                                @Bluefox:
                                Сегодня посоветуюсь со вторым товарищем, а пока, я думаю, следует подождать следующей итерации. `
                                База данных в любом случае нужна, для хранения истории, доведите систему до рабочего состояния, осталось уже совсем немножко 😉
                                • X
                                  X13 last edited by
                                  @Bluefox:
                                  А что мешает мне установить все мои топики, как retain? `
                                  Только из личного опыта, за истину в последней инстанции прошу не считать.
                                  Лучше не сохранять: вычисляемые значения(меньше нагрузка на диск), состояние внешних устройств(корректное отображение подключен/значения после перезагрузки)
                                  @Bluefox:
                                  "Вот это". Что именно? `
                                  Основные проблемы у меня связаны с UI. Например undo/redo, правильно работающая реализация copy/paste, заменить устройство(перенять конфигурацию).
                                  При подписке неизвестно когда пришли все относящиеся к данному subsribe данные, приходится извращаться с задержками.
                                  Попытка эмулировать RPC при нескольких потоках тоже доставляет мало удовольствия.
                                  @Bluefox:
                                  А если не применять node.js для брокера/рутера, то опять проблема установки. Через это мы уже проходили. 😢 `
                                  Я начал разработку версии с MQTT почти 2 года назад, но для дальнейшего развития вынужден менять протокол. И тоже не нашёл подходящего проекта, поэтому беру существующий и напильником его. :roll:
                                  • I
                                    …надзор нагадил конечно. гитхаб заблочили
                                      electric69 last edited by
                                      @instalator:
                                      …надзор нагадил конечно. гитхаб заблочили `
                                      Я вот в серьез подумываю купить OpenVZ/KVM за границей…
                                      • Bluefox
                                        Есть новый инсталлятор http://download.iobroker.org/ioBrokerIn … .0.2.7.exe
                                        • I
                                          @Bluefox:
                                          Есть новый инсталлятор http://download.iobroker.org/ioBrokerIn … .0.2.7.exe `
                                          При установке зависает. редис устанавливается. в окне установки iobroker пишет завершение установки и висит.
                                          • Bluefox
                                            @instalator:
                                            @Bluefox:
                                            Есть новый инсталлятор http://download.iobroker.org/ioBrokerIn … .0.2.7.exe При установке зависает. редис устанавливается. в окне установки iobroker пишет завершение установки и висит.
                                            Это он не висит, а выполняет npm install и команда длится около 2-5 минут, в зависимости от скорости интернета.
                                            Можно посмотреть появляются ли новые папки в c:\program files\iobroker\node_modules
                                            1.0k
                                            100
                                            34734
