    4. Adapter: iobroker.backitup (stable Release)
    • Merlin123
      Merlin123 last edited by
      Bei mir wirft die neue Version leider auch Fehler:
      host.orangepiplus2e	2019-01-06 09:40:45.971	info	Restart adapter system.adapter.backitup.0 because enabled
      host.orangepiplus2e	2019-01-06 09:40:45.971	error	instance system.adapter.backitup.0 terminated with code 0 (OK)
      host.orangepiplus2e	2019-01-06 09:40:45.971	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh' }
      host.orangepiplus2e	2019-01-06 09:40:45.971	error	Caught by controller[0]: syscall: 'unlink',
      host.orangepiplus2e	2019-01-06 09:40:45.970	error	Caught by controller[0]: code: 'ENOENT',
      host.orangepiplus2e	2019-01-06 09:40:45.970	error	Caught by controller[0]: errno: -2,
      host.orangepiplus2e	2019-01-06 09:40:45.970	error	Caught by controller[0]: at tryOnImmediate (timers.js:768:5)
      host.orangepiplus2e	2019-01-06 09:40:45.970	error	Caught by controller[0]: at runCallback (timers.js:814:20)
      host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at Immediate.createInstancesObjects [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
      host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
      host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
      host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at Adapter.emit (events.js:208:7)
      host.orangepiplus2e	2019-01-06 09:40:45.969	error	Caught by controller[0]: at emitNone (events.js:106:13)
      host.orangepiplus2e	2019-01-06 09:40:45.968	error	Caught by controller[0]: at Adapter.main (/opt/iobroker/node_modules/iobroker.backitup/main.js:555:5)
      host.orangepiplus2e	2019-01-06 09:40:45.968	error	Caught by controller[0]: at createBashScripts (/opt/iobroker/node_modules/iobroker.backitup/main.js:489:16)
      host.orangepiplus2e	2019-01-06 09:40:45.968	error	Caught by controller[0]: at Object.fs.unlinkSync (fs.js:1061:18)
      host.orangepiplus2e	2019-01-06 09:40:45.967	error	Caught by controller[0]: { Error: ENOENT: no such file or directory, unlink '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh'
      backitup.0	2019-01-06 09:40:45.448	error	Error: ENOENT: no such file or directory, unlink '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh' at Object.fs.unlinkSync (fs.js:1061:18) at createBashScripts (/opt/iobroker/node_
      backitup.0	2019-01-06 09:40:45.448	error	uncaught exception: ENOENT: no such file or directory, unlink '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh'
      backitup.0	2019-01-06 09:40:45.447	info	starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.12.0
        Jan1 last edited by
        auch hier sehr viele Fehler im Log und der Adapter geht immer wieder auf rot
        host.raspberrypi	2019-01-06 09:58:40.435	error	instance system.adapter.backitup.0 terminated with code 0 (OK)
        Caught	2019-01-06 09:58:40.435	error	by controller[0]: path: '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh' }
        Caught	2019-01-06 09:58:40.435	error	by controller[0]: syscall: 'unlink',
        Caught	2019-01-06 09:58:40.435	error	by controller[0]: code: 'ENOENT',
        Caught	2019-01-06 09:58:40.435	error	by controller[0]: errno: -2,
        Caught	2019-01-06 09:58:40.435	error	by controller[0]: at tryOnImmediate (timers.js:768:5)
        Caught	2019-01-06 09:58:40.435	error	by controller[0]: at runCallback (timers.js:814:20)
        Caught	2019-01-06 09:58:40.434	error	by controller[0]: at Immediate.createInstancesObjects [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
        Caught	2019-01-06 09:58:40.434	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
        Caught	2019-01-06 09:58:40.434	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
        Caught	2019-01-06 09:58:40.434	error	by controller[0]: at Adapter.emit (events.js:208:7)
        Caught	2019-01-06 09:58:40.434	error	by controller[0]: at emitNone (events.js:106:13)
        Caught	2019-01-06 09:58:40.434	error	by controller[0]: at Adapter.main (/opt/iobroker/node_modules/iobroker.backitup/main.js:555:5)
        Caught	2019-01-06 09:58:40.434	error	by controller[0]: at createBashScripts (/opt/iobroker/node_modules/iobroker.backitup/main.js:489:16)
        Caught	2019-01-06 09:58:40.433	error	by controller[0]: at Object.fs.unlinkSync (fs.js:1061:18)
        Caught	2019-01-06 09:58:40.433	error	by controller[0]: { Error: ENOENT: no such file or directory, unlink '/opt/iobroker/node_modules/iobroker.backitup/lib/stopIOB.sh'
        • Merlin123
          Ist der gleiche Fehler wie bei mir. Da scheinen Dateien zu fehlen
          • simatec
            Handelt es sich bei euch um eine Neuinstallation oder ein Update?
            Denke da hat sich bei Update ein Fehler eingeschlichen
            • Merlin123
              Update von der Version eins davor
              Gesendet von meinem CLT-L09 mit Tapatalk
                @simatec:
                Gesendet von iPhone mit Tapatalk `
                Update…...
                  Jan1 last edited by
                  Bei mir war es ein Update, bin zurück auf die Version 1.0.1 und sofort fehlerfrei.
                  • simatec
                    Schaut mal bitte in den Ordner /opt/iobroker/node_modules/iobroker.backitup/lib vom Adapter.
                    Könnte ich mal ein Screenshot bekommen, was da alles drin ist?
                      • simatec
                        Löscht mal die Datei .update… danach startet der Adapter neu.
                        Ich fixe das gleich.
                          Danke, geht wieder….......
                          backitup.0	2019-01-06 11:11:40.579	debug	[total] 10 00 03 */7 * *
                          backitup.0	2019-01-06 11:11:40.579	info	[total] backup was activated at 03:00 every 7 day(s)
                          backitup.0	2019-01-06 11:11:40.579	debug	[ccu] 10 30 04 */3 * *
                          backitup.0	2019-01-06 11:11:40.577	info	[ccu] backup was activated at 04:30 every 3 day(s)
                          backitup.0	2019-01-06 11:11:40.577	debug	[minimal] 10 00 02 */1 * *
                          backitup.0	2019-01-06 11:11:40.566	info	[minimal] backup was activated at 02:00 every 1 day(s)
                          backitup.0	2019-01-06 11:11:40.527	info	starting. Version 1.0.2 in C:/ioBroker/node_modules/iobroker.backitup, node: v8.15.0
                          backitup.0	2019-01-06 11:11:40.386	debug	statesDB connected
                          backitup.0	2019-01-06 11:11:40.386	debug	objectDB connected
                          backitup.0	2019-01-06 11:11:16.034	debug	system.adapter.admin.0: logging true
                          backitup.0	2019-01-06 11:11:14.028	debug	[total] 10 00 03 */7 * *
                          backitup.0	2019-01-06 11:11:14.028	info	[total] backup was activated at 03:00 every 7 day(s)
                          backitup.0	2019-01-06 11:11:14.027	debug	[ccu] 10 30 04 */3 * *
                          backitup.0	2019-01-06 11:11:14.027	info	[ccu] backup was activated at 04:30 every 3 day(s)
                          backitup.0	2019-01-06 11:11:14.026	debug	[minimal] 10 00 02 */1 * *
                          backitup.0	2019-01-06 11:11:14.021	info	[minimal] backup was activated at 02:00 every 1 day(s)
                          backitup.0	2019-01-06 11:11:13.979	info	starting. Version 1.0.2 in C:/ioBroker/node_modules/iobroker.backitup, node: v8.15.0
                          backitup.0	2019-01-06 11:11:13.939	debug	statesDB connected
                          backitup.0	2019-01-06 11:11:13.930	debug	objectDB connected
                          • simatec
                            Hintergrund der .update ist folgender gewesen.
                            Für den stop und start werden shells vom Adapter erstellt.
                            Da diese automatisch angelegt werden und sich hier bei dem Update der Inhalt geändert hat, sollte die Datei .update dafür sorgen, dass die shell beim ersten Start nach dem Update gelöscht werden.
                            Anscheinend ist es aber so, dass diese beim Update sowieso gelöscht sind und neu erstellt werden.
                            Von daher der error, da backitup die shells nicht findet.
                            Wie gesagt ich fixe das gleich, damit backitup wieder sauber läuft
                            • Merlin123
                              Danke für den schnellen Fix!
                                Jan1 last edited by
                                Wurde die Version hoch gezählt? Ich hatte eben mal kurz wieder die 1.0.2 drauf und die hatte das selbe Problem, allerdings liegt bei mir auch keine .update im lib Verzeichnis.
                                • simatec
                                  Ab sofort ist die Version 1.0.3 im Github und latest verfügbar.
                                  1.0.3 (06.01.2019)
                                  (simatec) Bugfix
                                  • simatec
                                    @Jan1:
                                    Wurde die Version hoch gezählt? Ich hatte eben mal kurz wieder die 1.0.2 drauf und die hatte das selbe Problem, allerdings liegt bei mir auch keine .update im lib Verzeichnis. `
                                    Dann hast du sicher die Anzeige für versteckte Dateien ausgeschaltet
                                    Mit Version 1.0.3 ist der Fehler behoben.
                                      Jan1 last edited by
                                      im latest hab ich immer noch die 1.0.2 drin :?:
                                      und ja ich hab die Adapter eite mehrfach neu geladen 😉
                                        wenn er das gerade gepusht hat ist es morgen im latest
                                        • Diginix
                                          Diginix last edited by
                                          Habe eben auf 1.0.3 mit der Katze geupdatet und läuft wieder.
                                          • simatec
                                            Im latest wird es erst heute Nacht sein.
                                            Für alle die Probleme haben, bitte über github updaten (oben der Button mit die Katze in den Adapter Tab)
                                            Sorry nochmal für den eingeschlichenen Bug.
                                            1.0k
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1193829
