    4. Adapter: iobroker.backitup (stable Release)
      @simatec:
      Handelt es sich bei euch um eine Neuinstallation oder ein Update?
      Denke da hat sich bei Update ein Fehler eingeschlichen
      Gesendet von iPhone mit Tapatalk `
      Update…...
        Jan1 last edited by
        Bei mir war es ein Update, bin zurück auf die Version 1.0.1 und sofort fehlerfrei.
        • simatec
          Schaut mal bitte in den Ordner /opt/iobroker/node_modules/iobroker.backitup/lib vom Adapter.
          Könnte ich mal ein Screenshot bekommen, was da alles drin ist?
            • simatec
              Löscht mal die Datei .update… danach startet der Adapter neu.
              Ich fixe das gleich.
                Danke, geht wieder….......
                backitup.0	2019-01-06 11:11:40.579	debug	[total] 10 00 03 */7 * *
                backitup.0	2019-01-06 11:11:40.579	info	[total] backup was activated at 03:00 every 7 day(s)
                backitup.0	2019-01-06 11:11:40.579	debug	[ccu] 10 30 04 */3 * *
                backitup.0	2019-01-06 11:11:40.577	info	[ccu] backup was activated at 04:30 every 3 day(s)
                backitup.0	2019-01-06 11:11:40.577	debug	[minimal] 10 00 02 */1 * *
                backitup.0	2019-01-06 11:11:40.566	info	[minimal] backup was activated at 02:00 every 1 day(s)
                backitup.0	2019-01-06 11:11:40.527	info	starting. Version 1.0.2 in C:/ioBroker/node_modules/iobroker.backitup, node: v8.15.0
                backitup.0	2019-01-06 11:11:40.386	debug	statesDB connected
                backitup.0	2019-01-06 11:11:40.386	debug	objectDB connected
                backitup.0	2019-01-06 11:11:16.034	debug	system.adapter.admin.0: logging true
                backitup.0	2019-01-06 11:11:14.028	debug	[total] 10 00 03 */7 * *
                backitup.0	2019-01-06 11:11:14.028	info	[total] backup was activated at 03:00 every 7 day(s)
                backitup.0	2019-01-06 11:11:14.027	debug	[ccu] 10 30 04 */3 * *
                backitup.0	2019-01-06 11:11:14.027	info	[ccu] backup was activated at 04:30 every 3 day(s)
                backitup.0	2019-01-06 11:11:14.026	debug	[minimal] 10 00 02 */1 * *
                backitup.0	2019-01-06 11:11:14.021	info	[minimal] backup was activated at 02:00 every 1 day(s)
                backitup.0	2019-01-06 11:11:13.979	info	starting. Version 1.0.2 in C:/ioBroker/node_modules/iobroker.backitup, node: v8.15.0
                backitup.0	2019-01-06 11:11:13.939	debug	statesDB connected
                backitup.0	2019-01-06 11:11:13.930	debug	objectDB connected
                • simatec
                  Hintergrund der .update ist folgender gewesen.
                  Für den stop und start werden shells vom Adapter erstellt.
                  Da diese automatisch angelegt werden und sich hier bei dem Update der Inhalt geändert hat, sollte die Datei .update dafür sorgen, dass die shell beim ersten Start nach dem Update gelöscht werden.
                  Anscheinend ist es aber so, dass diese beim Update sowieso gelöscht sind und neu erstellt werden.
                  Von daher der error, da backitup die shells nicht findet.
                  Wie gesagt ich fixe das gleich, damit backitup wieder sauber läuft
                  • Merlin123
                    Merlin123 last edited by
                    Danke für den schnellen Fix!
                    Gesendet von meinem CLT-L09 mit Tapatalk
                      Jan1 last edited by
                      Wurde die Version hoch gezählt? Ich hatte eben mal kurz wieder die 1.0.2 drauf und die hatte das selbe Problem, allerdings liegt bei mir auch keine .update im lib Verzeichnis.
                      • simatec
                        Ab sofort ist die Version 1.0.3 im Github und latest verfügbar.
                        1.0.3 (06.01.2019)
                        (simatec) Bugfix
                        • simatec
                          @Jan1:
                          Wurde die Version hoch gezählt? Ich hatte eben mal kurz wieder die 1.0.2 drauf und die hatte das selbe Problem, allerdings liegt bei mir auch keine .update im lib Verzeichnis. `
                          Dann hast du sicher die Anzeige für versteckte Dateien ausgeschaltet
                          Mit Version 1.0.3 ist der Fehler behoben.
                            Jan1 last edited by
                            im latest hab ich immer noch die 1.0.2 drin :?:
                            und ja ich hab die Adapter eite mehrfach neu geladen 😉
                              wenn er das gerade gepusht hat ist es morgen im latest
                              • Diginix
                                Diginix last edited by
                                Habe eben auf 1.0.3 mit der Katze geupdatet und läuft wieder.
                                • simatec
                                  Im latest wird es erst heute Nacht sein.
                                  Für alle die Probleme haben, bitte über github updaten (oben der Button mit die Katze in den Adapter Tab)
                                  Sorry nochmal für den eingeschlichenen Bug.
                                    Jan1 last edited by
                                    Jou die Katz hatts gerettet :lol:
                                    • bergjet
                                      bergjet last edited by
                                      @simatec:
                                      Sorry nochmal für den eingeschlichenen Bug. `
                                      Danke, läuft.
                                      • bergjet
                                        Habe den ioBroker zerschossen.
                                        Aber mit backitup ein vollständiges Backup gemacht. Das liegt am NAS.
                                        Laut Beschreibung soll ich nun diese Datei ins Wurzelverzeichnis root/ kopieren. Aber wie mache ich das?
                                        • StM47
                                          StM47 last edited by
                                          Ich würde ioBroker neu aufsetzten, dann Backitup installieren und dann das Backup direkt mit Backitup wieder herstellen.
                                          • simatec
                                            @bergjet:
                                            Laut Beschreibung soll ich nun diese Datei ins Wurzelverzeichnis root/ kopieren. Aber wie mache ich das? `
                                            Installiere backitup und stelle direkt in backitup dein backup wieder her.
                                            Dort gibt es einen Tab Restore (Wiederherstellen)
                                            Am besten du legst dein backup vorher in den Ordner /opt/iobroker/backup
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1141378
