    3. Entwicklung
    4. Neuen Adapter für tracer x210A Solarregler?
      sottomihai last edited by
      @apollon77:
      Und wo ist der Code vom Adapter? Welcher Fehler kommt? `
      Die Fehlermeldung, welche beim Instalieren vorkommt, habe ich mir nicht aufgeschrieben.
      Ich habe den Adapter manuell in IObroker installiert. und funktioniert auch.
      Trotzdem habe ich beim laufenden Betrieb diese Fehlermeldung.
      epsolar.0 2017-08-31 17:45:01.268 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.epsolar, node: v6.10.3
      host.zotac 2017-08-31 17:45:00.032 info instance system.adapter.epsolar.0 started with pid 833
      host.zotac 2017-08-31 17:44:56.317 error instance system.adapter.epsolar.0 terminated with code 1 ()
      epsolar.0 2017-08-31 17:44:56.289 error force terminate
      epsolar.0 2017-08-31 17:44:01.256 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.epsolar, node: v6.10.3
      host.zotac 2017-08-31 17:44:00.028 info instance system.adapter.epsolar.0 started with pid 622
      host.zotac 2017-08-31 17:43:56.341 error instance system.adapter.epsolar.0 terminated with code 1 ()
      epsolar.0 2017-08-31 17:43:56.317 error force terminate
      epsolar.0 2017-08-31 17:43:01.283 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.epsolar, node: v6.10.3
      host.zotac 2017-08-31 17:43:00.031 info instance system.adapter.epsolar.0 started with pid 410
      host.zotac 2017-08-31 17:42:56.325 error instance system.adapter.epsolar.0 terminated with code 1 ()
      epsolar.0 2017-08-31 17:42:56.299 error force terminate
      epsolar.0 2017-08-31 17:42:01.266 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.epsolar, node: v6.10.3
      host.zotac 2017-08-31 17:42:00.031 info instance system.adapter.epsolar.0 started with pid 32661
      host.zotac 2017-08-31 17:41:56.342 error instance system.adapter.epsolar.0 terminated with code 1 ()
      epsolar.0 2017-08-31 17:41:56.314 error force terminate
      epsolar.0 2017-08-31 17:41:01.277 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.epsolar, node: v6.10.3
      host.zotac 2017-08-31 17:41:00.032 info instance system.adapter.epsolar.0 started with pid 32454
      host.zotac 2017-08-31 17:40:56.388 error instance system.adapter.epsolar.0 terminated with code 1 ()
      epsolar.0 2017-08-31 17:40:56.365 error force terminate
      Code ist im Anhang
      2696_iobroker.epsolar.7z
        apollon77 last edited by
        kann ich gern checken. Standard ist aber die Verfügbarkeit auf GitHub. So ist das viel besser zu managen.
        Kennst Du das schon: http://forum.iobroker.net/viewtopic.php?f=24&t=6383
        In dem Fall scheint irgendwo eine Exception zu fliegen.
        Du kannst den Adapter manuell an der Kommandozeile mit
        node node_modules/<adaptername>/<mainfile>.js –force --logs
        starten, dann sieht man in solchen Fällen ggf die echte Exception.</mainfile></adaptername>
          @apollon77:
          starten, dann sieht man in solchen Fällen ggf die echte Exception.</mainfile></adaptername> `
          Ich habe den Adapter über die Kommandozeile gestartet und kommt keine andere Fehlermeldung.
          Der Adapter wird in cron minutilich ausgeführt um die Daten abzurufen, deswegen kommt die Meldung so oft vor.
            Jupp, da hast Du recht, jetzt da ich den Code gesehen hab.
            Du musst alle States die Du nutzen willst vor einem "setState" auch mit "setObject" - oder besser setObjectNotExist anlegen. Beispiele wie Die Objekte am besten aussehen sollten gibt unter https://github.com/ioBroker/ioBroker/wi … umentation
              @apollon77:
              Du musst alle States die Du nutzen willst vor einem "setState" auch mit "setObject" - oder besser setObjectNotExist anlegen. Beispiele wie Die Objekte am besten aussehen sollten gibt unter https://github.com/ioBroker/ioBroker/wi … umentation `
              Meinst du Hier:
              "instanceObjects": [
              "_id": "epsolar.pvarrayvoltage",
              "type": "state",
              "common": {
              "name": "PV array voltage",
              "type": "number",
              "role": "value.pvarrayvoltage",
              "read": true,
              "write": false,
              "unit": "V",
              "desc": "PV array voltage"
              "native": {}
              "_id": "epsolar.pvarraycurrent",
              "type": "state",
              "common": {
              "name": "PV array current",
              "type": "number",
              "role": "value.pvarraycurrent",
              "read": true,
              "write": false,
              "unit": "A",
              "desc": "PV array current."
              "native": {}
              oder hier:
              function (error, response, ret) {
              if (!error && response.statusCode === 200) {
              for (var i = 0; i < ret["realtime"].length; i++) {
              adapter.setState('epsolar.' + ret["realtime"]["name"].split(" ").join("").toLowerCase() , {val: ret["realtime"]["val"], ack: true});
              Gruß Mihai____
                Also erst einmal legst Du in Start einen channel an mit nem "_" im Namen, was später nirgendwo verwendet wird wenn ich reicht gesehen habe. Wird der gebraucht?
                Ansonsten geht es genau um die die Du geschrieben hast. Ich weiss jetzt nicht wie genau das JSON aussieht, aber DU geshst es in einer Schleife durch und setzt alles was drin steht als State. Wenn das nur die beiden Werte sind die du per "InstanceObjects" initial anlegst dann ist das alles ok, aber wozu dann die Schleife. Und in der Schleife machst Du viele setStates und bevor Du das tust müssen die Objekte angelegt sein, sonst wird der State zwar geschrieben, aber nirgends angezeigt.
                Ingo F
                  @apollon77:
                  Ich denke das da in jedem Fall interesse besteht. Wenn DU noch support bei veröffentlichen und so brauchst sag Bescheid.
                  Ingo F `
                  Die Fehlermeldungen habe ich beseitigt, kannst du mir dabei helfen den Adapter zu veröffentlichen?
                  Gruß Mihai
                    exporzer last edited by
                    Hi Mihai,
                    ist der Adapter jetzt verfügbar oder gibt es irgendwo ne finale Version.
                    Gruß,
                    exporzer
                      ich nutze immer noch die alte Version. Funktioniet stabil bei mir mit Ubuntu 16.
                      Gruß Mihai
                      • wkhard
                        wkhard last edited by
                        Ich wäre auch sehr an einer Veröffentlichung interessiert.
                        Beste Grüße
                        Kurt
                        2195
