    4. IRobot Roomba Adapter
    • Zefau
      Zefau last edited by
      This is caused by an earlier version of the adapter.
      Please try https://github.com/Zefau/ioBroker.roomb … -453733177 to fix.
        Gonzo0815 last edited by
        Hab den Adapter soweit installiert und er läuft auch und ich seh meinen Roomba.
        Bekomme aber im Log disen Fehler: Canvas not installed! Thus, no map drawings are possible.
        Die Installation von Canvas klappt leider nicht. Bekomme diese Meldung:
        > canvas@2.3.0 install /home/admin/node_modules/canvas
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using request for node-pre-gyp https download
        [canvas] Success: "/home/admin/node_modules/canvas/build/Release/canvas.node" is installed via remote
        npm WARN saveError ENOENT: no such file or directory, open '/home/admin/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/home/admin/package.json'
        npm WARN admin No description
        npm WARN admin No repository field.
        npm WARN admin No README data
        npm WARN admin No license field.
        + canvas@2.3.0
        added 25 packages from 28 contributors and audited 1610 packages in 26.917s
        found 65 vulnerabilities (1 low, 39 moderate, 25 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        • Zefau
          https://github.com/Zefau/ioBroker.roomba#installation
            Dann kommt dies:
            root@ubuntu-hd:/opt/iobroker/node_modules/iobroker.roomba# sudo npm install canvas --unsafe-perm=true
            > canvas@2.3.0 install /opt/iobroker/node_modules/iobroker.roomba/node_modules/canvas
            [canvas] Success: "/opt/iobroker/node_modules/iobroker.roomba/node_modules/canvas/build/Release/canvas.node" is installed via remote
            + canvas@2.3.0
            added 240 packages from 445 contributors, updated 1 package and audited 1633 packages in 29.625s
            found 5 vulnerabilities (1 low, 4 high)
            und geht immer noch nicht
            • Zefau
              Sieht doch super aus. Hast du danach den Adapter auch nochmal installiert?
              iobroker url https://github.com/Zefau/ioBroker.roomba
              iobroker add roomba
              iobroker upload roomba
                Hab ich gemacht, im Log steht immer noch
                • Zefau
                  Was für ein OS / System nutzt du?
                  Kannst du Debugging für den Roomba aktivieren (unter Instanzen bei Roomba "debug" wählen), dann sollte nach der Fehlermeldung noch ein Log-Eintrag mit Details folgen.
                  Viele Grüße
                  Zefau
                    roomba.0
                    2019-01-13 07:23:50.118
                    debug
                    Subscribed to states missions.current._endMission.
                    roomba.0
                    debug
                    Subscribed to states commands.dock.
                    roomba.0
                    debug
                    Subscribed to states commands.resume.
                    roomba.0
                    debug
                    Subscribed to states commands.pause.
                    roomba.0
                    debug
                    Subscribed to states commands.stop.
                    roomba.0
                    debug
                    Subscribed to states commands.start.
                    roomba.0
                    2019-01-13 07:23:50.117
                    debug
                    Retrieved preferences: {"netinfo":{xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx{"
                    roomba.0
                    2019-01-13 07:23:32.401
                    debug
                    system.adapter.admin.0: logging true
                    roomba.0
                    2019-01-13 07:23:25.873
                    debug
                    system.adapter.admin.0: logging false
                    roomba.0
                    2019-01-13 07:22:54.779
                    debug
                    roomba.0
                    2019-01-13 07:22:54.778
                    debug
                    roomba.0
                    2019-01-13 07:22:54.777
                    debug
                    roomba.0
                    debug
                    roomba.0
                    debug
                    roomba.0
                    2019-01-13 07:22:54.775
                    debug
                    roomba.0
                    2019-01-13 07:22:54.772
                    debug
                    Retrieved preferences: {"netinfo":{"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx,"sec":4},"wifistat":{"wifi":1,"uap":false,"cl
                    roomba.0
                    2019-01-13 07:22:52.325
                    info
                    Roomba online. Connection established.
                    roomba.0
                    2019-01-13 07:22:50.199
                    debug
                    roomba.0
                    2019-01-13 07:22:49.844
                    info
                    Connecting to Roomba..
                    roomba.0
                    debug
                    the module (for instance, using `npm rebuild` or `npm install`).
                    roomba.0
                    debug
                    NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
                    roomba.0
                    debug
                    NODE_MODULE_VERSION 67\. This version of Node.js requires
                    roomba.0
                    debug
                    was compiled against a different Node.js version using
                    roomba.0
                    debug
                    The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                    roomba.0
                    warn
                    roomba.0
                    2019-01-13 07:22:49.832
                    info
                    starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.roomba, node: v8.15.0
                    roomba.0
                    2019-01-13 07:22:49.725
                    debug
                    statesDB connected
                    roomba.0
                    2019-01-13 07:22:49.648
                    debug
                    objectDB connected
                    Hab eine VM auf der QNAP am laufen mit Ubuntu 14.04
                    • Zefau
                      Welche Node.js und npm version?
                      Der Fehler sagt
                      The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 67\. This version of Node.js requires NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
                      Google sagt, npm install sollte funktionieren. Ggf. mal npm rebuild wie in der Fehlerbeschreibung probieren.
                      Wenn alles nicht geht, dann mit rm -r node_modules (im iobroker.roomba Ordner) alle Packages löschen und nochmal in Reihenfolge.
                      sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                      npm install canvas
                      Viel Erfolg
                        Hier die Versionen:
                        Node V11.0.0
                        NPM V6.5.0
                          Hab es zum laufen gebracht.
                          Danke für die Hilfe
                          • Zefau
                            Klasse, das freut mich. Viel Spaß.
                              Thebuh last edited by
                              Also ich muss sagen der adapter läuft soweit echt gut.
                              Das mit dem docked status passt auch, das einzige waa mir aufgefallen ist das der roomba jetzt öfters disconnected.
                              Beispiel: ich lasse ein programm laufen, bei dem bei anwesenheit mit 60min Verzögerung der roomba gestartez werden soll, die lief super mit version 0.2, mit version 0.4 wird der befehl nicht ausgeführt, anbei die Meldung:
                              2019-01-15 15:20:52.279 - info: roomba.0 Triggered action -start- on Roomba.
                              2019-01-15 15:20:52.280 - warn: roomba.0 Roomba not online! Action not triggered.
                              Wie gesagt mit version 0.2 war alles gut 🙂
                              • ThomasLPZ
                                ThomasLPZ last edited by
                                @Thebuh:
                                Wie gesagt mit version 0.2 war alles gut 🙂 `
                                das ist mir auch aufgefallen. Seid der neuen Version steht der Roomba öfter auf disconnected. In früheren Version war das nicht so. Bin allerdings noch nicht dazugekommen das genauer unter die Lupe zu nehmen.
                                Ansonsten aber ein echt klasse Adapter! Zumal ich glaube dass es einem iRobot echt schwer macht
                                VG
                                ThomasL
                                • JB_Sullivan
                                  JB_Sullivan last edited by
                                  Never tough a running System - aber nein, ich muss ja auf die Version 0.4.0 updaten.
                                  Nun ist alles kaputt. Der Adapter funktioniert nicht mehr. Ich kann ihn nicht starten und er zeigt immer rot an.
                                  Was ist da schief gelaufen?
                                  ! $ ./iobroker url "https://github.com/Zefau/ioBroker.roomba" –debug
                                  ! install https://github.com/Zefau/ioBroker.roomba/tarball/master
                                  ! npm install https://github.com/Zefau/ioBroker.roomba/tarball/master --production --save --prefix "C:/ioBroker" (System call)
                                  ! > canvas@2.3.1 install C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas
                                  ! > node-pre-gyp install --fallback-to-build
                                  ! node-pre-gyp
                                  ! WARN
                                  ! Using request for node-pre-gyp https download
                                  ! node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas ... a32.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.3.1 and node@8.13.0 (node-v57 ABI, unknown) (falling back to source compile with node-gyp)
                                  ! Warning: Missing input files:
                                  ! C:\GTK\bin\libpangoft2-1.0-0.dll
                                  ! C:\GTK\bin\zlib1.dll
                                  ! C:\GTK\bin\libintl-8.dll
                                  ! C:\GTK\bin\libgmodule-2.0-0.dll
                                  ! C:\GTK\bin\libglib-2.0-0.dll
                                  ! C:\GTK\bin\libexpat-1.dll
                                  ! C:\GTK\bin\libpng14-14.dll
                                  ! C:\GTK\bin\libcairo-2.dll
                                  ! C:\GTK\bin\libfontconfig-1.dll
                                  ! C:\GTK\bin\libgobject-2.0-0.dll
                                  ! C:\GTK\bin\libgthread-2.0-0.dll
                                  ! C:\GTK\bin\libpangocairo-1.0-0.dll
                                  ! C:\GTK\bin\libfreetype-6.dll
                                  ! C:\GTK\bin\libpango-1.0-0.dll
                                  ! C:\GTK\bin\libpangowin32-1.0-0.dll
                                  ! Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu erm�glichen, m�ssen Sie den Schalter "/m" hinzuf�gen.
                                  ! Backend.cc
                                  ! ImageBackend.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\backend\Backend.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\backend\ImageBackend.cc) [C:\ioBro
                                  ! ker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! PdfBackend.cc
                                  ! SvgBackend.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\backend\SvgBackend.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\backend\PdfBackend.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! BMPParser.cc
                                  ! Backends.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\Backends.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! Canvas.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\Canvas.cc) [C:\ioBroker\node_modul
                                  ! es\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! CanvasGradient.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(193): warning C4018: ">": Konflikt zwischen "signed" und "unsigned" [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(208): warning C4018: ">": Konflikt zwischen "signed" und "unsigned" [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(275): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! with
                                  ! T=uint32_t
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(276): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! with
                                  ! T=uint32_t
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(277): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! with
                                  ! T=uint32_t
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(278): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! with
                                  ! T=uint32_t
                                  ! CanvasPattern.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\canvaspattern.h(5): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\CanvasPattern.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! CanvasRenderingContext2d.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\canvasrenderingcontext2d.h(5): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\CanvasRenderingContext2d.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! closure.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\closure.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! color.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(164): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! with
                                  ! T=int
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(558): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(557): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(556): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(555): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(571): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(570): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(569): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(585): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(584): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(583): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(582): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(598): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(597): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(596): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(642): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\program files\microsoft visual studio\2017\buildtools\vc\tools\msvc\14.16.27023\include\algorithm(1443): warning C4244: "=": Konvertierung von "int" in "char", m�glicher Datenverlust (Quelldatei wird kompiliert ..\src\color.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(725): note: Siehe Verweis auf die Instanziierung der gerade kompilierten Funktions-Vorlage "_OutIt std::transform<std::_string_iterator<std::_string_val<std::_simple_types<_ty>>>,std::_String_iterator<std::_string_val<std::_simple_types<_ty>>>,int(__cdecl *)(int)>(const _InIt,const _InIt,_OutIt,_Fn)".
                                  ! with
                                  ! _OutIt=std::_String_iterator<std::_string_val<std::_simple_types<char>>>,
                                  ! _Ty=char,
                                  ! _InIt=std::_String_iterator<std::_string_val<std::_simple_types<char>>>,
                                  ! _Fn=int (__cdecl *)(int)
                                  ! Image.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\canvasgradient.h(7): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\CanvasGradient.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\image.h(5): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\Image.cc) [C:\ioBroker\node_modules\iobroker
                                  ! .roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! ImageData.cc
                                  ! init.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\init.cc(4): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "pango/pango.h": No such file or directory [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! register_font.cc
                                  ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\register_font.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "pango/pango.h": No such file or directory (Quelldatei wird kompiliert ..\src\register_font.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                                  ! win_delay_load_hook.cc
                                  ! gyp
                                  ! ERR!
                                  ! build error
                                  ! gyp
                                  ! ERR! stack Error: C:\Program Files\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1
                                  ! gyp
                                  ! ERR!
                                  ! stack
                                  ! at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
                                  ! gyp
                                  ! ERR!
                                  ! stack
                                  ! at emitTwo (events.js:126:13)
                                  ! gyp
                                  ! ERR!
                                  ! stack
                                  ! at ChildProcess.emit (events.js:214:7)
                                  ! gyp
                                  ! ERR!
                                  ! stack
                                  ! at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                                  ! gyp
                                  ! ERR!
                                  ! System
                                  ! Windows_NT 10.0.17763
                                  ! gyp
                                  ! ERR!
                                  ! command
                                  ! "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "build" "–fallback-to-build" "--module=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node" "--module_name=canvas" "--module_path=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
                                  ! gyp
                                  ! ERR!
                                  ! cwd
                                  ! C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas
                                  ! gyp
                                  ! ERR!
                                  ! node -v
                                  ! v8.13.0
                                  ! gyp
                                  ! ERR!
                                  ! node-gyp -v
                                  ! v3.8.0
                                  ! gyp
                                  ! ERR!
                                  ! not ok
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! build error
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! stack
                                  ! Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node --module_name=canvas --module_path=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! stack
                                  ! at ChildProcess. <anonymous>(C:\ioBroker\node_modules\iobroker.roomba\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! stack
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! stack
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! stack
                                  ! at maybeClose (internal/child_process.js:915:16)
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! stack
                                  ! at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                                  ! node-pre-gyp
                                  ! ERR! System Windows_NT 10.0.17763node-pre-gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\ioBroker\node_modules\iobroker.roomba\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
                                  ! node-pre-gyp ERR! cwd C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! node -v
                                  ! v8.13.0
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! node-pre-gyp -v
                                  ! v0.11.0
                                  ! node-pre-gyp
                                  ! ERR!
                                  ! not ok
                                  ! Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node --module_name=canvas --module_path=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                                  ! npm
                                  ! ERR! code ELIFECYCLEnpm
                                  ! ERR!
                                  ! errno
                                  ! 1
                                  ! npm
                                  ! ERR!
                                  ! canvas@2.3.1 install: node-pre-gyp install --fallback-to-buildnpm
                                  ! ERR! Exit status 1npm
                                  ! ERR!
                                  ! npm
                                  ! ERR!
                                  ! Failed at the canvas@2.3.1 install script.
                                  ! npm
                                  ! ERR!
                                  ! This is probably not a problem with npm. There is likely additional logging output above.
                                  ! npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-01-19T11_38_11_298Z-debug.log
                                  ! process exited with code 0</anonymous></std::_string_val<std::_simple_types<char></std::_string_val<std::_simple_types<char></std::_string_val<std::_simple_types<_ty></std::_string_iterator<std::_string_val<std::_simple_types<_ty>
                                  Ich habe im GitHub auf diese FORK Dings geklickt und habe ich Roomba Adapter auch in meinem GitHub Account drin. Wie bekomme ich das wieder weg?
                                  • Zefau
                                    Siehe Anleitung auf Github. Erst canvas installieren, dann sollte es passen.
                                    Sent from my SM-G950F using Tapatalk
                                    • JB_Sullivan
                                      Ich hatte ja schon die 0.2.x Version und wollte über die Katze einfach nur "hochrüsten" - Muss ich trotzdem den ganzen Canvas Prozess nochmal machen?
                                      • Zefau
                                        Die 0.2.0 benötigte kein canvas. Canvas wird erst ab 0.3.0 benötigt, um eine Live-Karte zu erzeugen während der Roomba sauber macht.
                                        • JB_Sullivan
                                          OK, Live Karte brauche ich nicht - wie komme ich wieder zurück zur 0.2.x Version?
                                          … hat sich erledigt .... das Update auf den 0.4.0 hat mir im nodes Ordner mal schön alle roomba Adapter Daten rausgelöscht. Habe sie dann von meinem Backup wieder rein kopiert und - LÄUFT.
                                          • 0
                                            0mathew0 last edited by
                                            Ich habe es noch nicht so ganz durchblickt,.. Teste nun schon länger die 0.4.0, läuft aber nicht sauber wie davor. Es scheint als würden die Missions nur bei manuellem Auslösen gespeichert, nicht beim (im Staubsauger gespeichertem) Zeitprogramm. Aktueller Status wird auch nur angezeigt, wenn der Sauger fährt, nicht im Dock. Darüber hinaus ist die Map spiegelverkehrt und unterscheidet sich gerne mal von der Fläche, welche in der Roomba IOS App (korrekt) dargestellt wird. Ist das nur bei mir so?
                                            LG
                                            1.3k
                                            81.1k
                                            851
                                            300907
