    4. IRobot Roomba Adapter
    • Zefau
      Zefau last edited by
      https://github.com/Zefau/ioBroker.roomba#installation
        Gonzo0815 last edited by
        Dann kommt dies:
        root@ubuntu-hd:/opt/iobroker/node_modules/iobroker.roomba# sudo npm install canvas --unsafe-perm=true
        > canvas@2.3.0 install /opt/iobroker/node_modules/iobroker.roomba/node_modules/canvas
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Using request for node-pre-gyp https download
        [canvas] Success: "/opt/iobroker/node_modules/iobroker.roomba/node_modules/canvas/build/Release/canvas.node" is installed via remote
        + canvas@2.3.0
        added 240 packages from 445 contributors, updated 1 package and audited 1633 packages in 29.625s
        found 5 vulnerabilities (1 low, 4 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        und geht immer noch nicht
        • Zefau
          Sieht doch super aus. Hast du danach den Adapter auch nochmal installiert?
          iobroker url https://github.com/Zefau/ioBroker.roomba
          iobroker add roomba
          iobroker upload roomba
            Hab ich gemacht, im Log steht immer noch
            Canvas not installed! Thus, no map drawings are possible.
            • Zefau
              Was für ein OS / System nutzt du?
              Kannst du Debugging für den Roomba aktivieren (unter Instanzen bei Roomba "debug" wählen), dann sollte nach der Fehlermeldung noch ein Log-Eintrag mit Details folgen.
              Viele Grüße
              Zefau
                roomba.0
                2019-01-13 07:23:50.118
                debug
                Subscribed to states missions.current._endMission.
                roomba.0
                debug
                Subscribed to states commands.dock.
                roomba.0
                debug
                Subscribed to states commands.resume.
                roomba.0
                debug
                Subscribed to states commands.pause.
                roomba.0
                debug
                Subscribed to states commands.stop.
                roomba.0
                debug
                Subscribed to states commands.start.
                roomba.0
                2019-01-13 07:23:50.117
                debug
                Retrieved preferences: {"netinfo":{xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx{"
                roomba.0
                2019-01-13 07:23:32.401
                debug
                system.adapter.admin.0: logging true
                roomba.0
                2019-01-13 07:23:25.873
                debug
                system.adapter.admin.0: logging false
                roomba.0
                2019-01-13 07:22:54.779
                debug
                roomba.0
                2019-01-13 07:22:54.778
                debug
                roomba.0
                2019-01-13 07:22:54.777
                debug
                roomba.0
                debug
                roomba.0
                debug
                roomba.0
                2019-01-13 07:22:54.775
                debug
                roomba.0
                2019-01-13 07:22:54.772
                debug
                Retrieved preferences: {"netinfo":{"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx,"sec":4},"wifistat":{"wifi":1,"uap":false,"cl
                roomba.0
                2019-01-13 07:22:52.325
                info
                Roomba online. Connection established.
                roomba.0
                2019-01-13 07:22:50.199
                debug
                roomba.0
                2019-01-13 07:22:49.844
                info
                Connecting to Roomba..
                roomba.0
                debug
                the module (for instance, using `npm rebuild` or `npm install`).
                roomba.0
                debug
                NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
                roomba.0
                debug
                NODE_MODULE_VERSION 67\. This version of Node.js requires
                roomba.0
                debug
                was compiled against a different Node.js version using
                roomba.0
                debug
                The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                roomba.0
                warn
                roomba.0
                2019-01-13 07:22:49.832
                info
                starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.roomba, node: v8.15.0
                roomba.0
                2019-01-13 07:22:49.725
                debug
                statesDB connected
                roomba.0
                2019-01-13 07:22:49.648
                debug
                objectDB connected
                Hab eine VM auf der QNAP am laufen mit Ubuntu 14.04
                • Zefau
                  Welche Node.js und npm version?
                  Der Fehler sagt
                  The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 67\. This version of Node.js requires NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).
                  Google sagt, npm install sollte funktionieren. Ggf. mal npm rebuild wie in der Fehlerbeschreibung probieren.
                  Wenn alles nicht geht, dann mit rm -r node_modules (im iobroker.roomba Ordner) alle Packages löschen und nochmal in Reihenfolge.
                  sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                  npm install canvas
                  Viel Erfolg
                    Hier die Versionen:
                    Node V11.0.0
                    NPM V6.5.0
                      Hab es zum laufen gebracht.
                      Danke für die Hilfe
                      • Zefau
                        Klasse, das freut mich. Viel Spaß.
                          Thebuh last edited by
                          Also ich muss sagen der adapter läuft soweit echt gut.
                          Das mit dem docked status passt auch, das einzige waa mir aufgefallen ist das der roomba jetzt öfters disconnected.
                          Beispiel: ich lasse ein programm laufen, bei dem bei anwesenheit mit 60min Verzögerung der roomba gestartez werden soll, die lief super mit version 0.2, mit version 0.4 wird der befehl nicht ausgeführt, anbei die Meldung:
                          2019-01-15 15:20:52.279 - info: roomba.0 Triggered action -start- on Roomba.
                          2019-01-15 15:20:52.280 - warn: roomba.0 Roomba not online! Action not triggered.
                          Wie gesagt mit version 0.2 war alles gut 🙂
                          • ThomasLPZ
                            ThomasLPZ last edited by
                            @Thebuh:
                            Wie gesagt mit version 0.2 war alles gut 🙂 `
                            das ist mir auch aufgefallen. Seid der neuen Version steht der Roomba öfter auf disconnected. In früheren Version war das nicht so. Bin allerdings noch nicht dazugekommen das genauer unter die Lupe zu nehmen.
                            Ansonsten aber ein echt klasse Adapter! Zumal ich glaube dass es einem iRobot echt schwer macht
                            VG
                            ThomasL
                            • JB_Sullivan
                              JB_Sullivan last edited by
                              Never tough a running System - aber nein, ich muss ja auf die Version 0.4.0 updaten.
                              Nun ist alles kaputt. Der Adapter funktioniert nicht mehr. Ich kann ihn nicht starten und er zeigt immer rot an.
                              Was ist da schief gelaufen?
                              ! $ ./iobroker url "https://github.com/Zefau/ioBroker.roomba" –debug
                              ! install https://github.com/Zefau/ioBroker.roomba/tarball/master
                              ! npm install https://github.com/Zefau/ioBroker.roomba/tarball/master --production --save --prefix "C:/ioBroker" (System call)
                              ! > canvas@2.3.1 install C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas
                              ! > node-pre-gyp install --fallback-to-build
                              ! node-pre-gyp
                              ! WARN
                              ! Using request for node-pre-gyp https download
                              ! node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas ... a32.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.3.1 and node@8.13.0 (node-v57 ABI, unknown) (falling back to source compile with node-gyp)
                              ! Warning: Missing input files:
                              ! C:\GTK\bin\libpangoft2-1.0-0.dll
                              ! C:\GTK\bin\zlib1.dll
                              ! C:\GTK\bin\libintl-8.dll
                              ! C:\GTK\bin\libgmodule-2.0-0.dll
                              ! C:\GTK\bin\libglib-2.0-0.dll
                              ! C:\GTK\bin\libexpat-1.dll
                              ! C:\GTK\bin\libpng14-14.dll
                              ! C:\GTK\bin\libcairo-2.dll
                              ! C:\GTK\bin\libfontconfig-1.dll
                              ! C:\GTK\bin\libgobject-2.0-0.dll
                              ! C:\GTK\bin\libgthread-2.0-0.dll
                              ! C:\GTK\bin\libpangocairo-1.0-0.dll
                              ! C:\GTK\bin\libfreetype-6.dll
                              ! C:\GTK\bin\libpango-1.0-0.dll
                              ! C:\GTK\bin\libpangowin32-1.0-0.dll
                              ! Die Projekte in dieser Projektmappe werden nacheinander erstellt. Um eine parallele Erstellung zu erm�glichen, m�ssen Sie den Schalter "/m" hinzuf�gen.
                              ! Backend.cc
                              ! ImageBackend.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\backend\Backend.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\backend\ImageBackend.cc) [C:\ioBro
                              ! ker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! PdfBackend.cc
                              ! SvgBackend.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\backend\SvgBackend.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\backend\PdfBackend.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! BMPParser.cc
                              ! Backends.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\Backends.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! Canvas.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\Canvas.cc) [C:\ioBroker\node_modul
                              ! es\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! CanvasGradient.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(193): warning C4018: ">": Konflikt zwischen "signed" und "unsigned" [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(208): warning C4018: ">": Konflikt zwischen "signed" und "unsigned" [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(275): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! with
                              ! T=uint32_t
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(276): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! with
                              ! T=uint32_t
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(277): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! with
                              ! T=uint32_t
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\bmp\bmpparser.cc(278): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! with
                              ! T=uint32_t
                              ! CanvasPattern.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\canvaspattern.h(5): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\CanvasPattern.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! CanvasRenderingContext2d.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\canvasrenderingcontext2d.h(5): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\CanvasRenderingContext2d.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! closure.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\backend\backend.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\closure.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! color.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(164): warning C4244: "=": Konvertierung von "T" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! with
                              ! T=int
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(558): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(557): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(556): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(555): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(571): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(570): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(569): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(585): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(584): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(583): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(582): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(598): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(597): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(596): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(642): warning C4244: "Argument": Konvertierung von "int" in "uint8_t", m�glicher Datenverlust [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\program files\microsoft visual studio\2017\buildtools\vc\tools\msvc\14.16.27023\include\algorithm(1443): warning C4244: "=": Konvertierung von "int" in "char", m�glicher Datenverlust (Quelldatei wird kompiliert ..\src\color.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\color.cc(725): note: Siehe Verweis auf die Instanziierung der gerade kompilierten Funktions-Vorlage "_OutIt std::transform<std::_string_iterator<std::_string_val<std::_simple_types<_ty>>>,std::_String_iterator<std::_string_val<std::_simple_types<_ty>>>,int(__cdecl *)(int)>(const _InIt,const _InIt,_OutIt,_Fn)".
                              ! with
                              ! _OutIt=std::_String_iterator<std::_string_val<std::_simple_types<char>>>,
                              ! _Ty=char,
                              ! _InIt=std::_String_iterator<std::_string_val<std::_simple_types<char>>>,
                              ! _Fn=int (__cdecl *)(int)
                              ! Image.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\canvasgradient.h(7): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\CanvasGradient.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\image.h(5): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "cairo.h": No such file or directory (Quelldatei wird kompiliert ..\src\Image.cc) [C:\ioBroker\node_modules\iobroker
                              ! .roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! ImageData.cc
                              ! init.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\init.cc(4): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "pango/pango.h": No such file or directory [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! register_font.cc
                              ! c:\iobroker\node_modules\iobroker.roomba\node_modules\canvas\src\register_font.h(3): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: "pango/pango.h": No such file or directory (Quelldatei wird kompiliert ..\src\register_font.cc) [C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\canvas.vcxproj]
                              ! win_delay_load_hook.cc
                              ! gyp
                              ! ERR!
                              ! build error
                              ! gyp
                              ! ERR! stack Error: C:\Program Files\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe failed with exit code: 1
                              ! gyp
                              ! ERR!
                              ! stack
                              ! at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
                              ! gyp
                              ! ERR!
                              ! stack
                              ! at emitTwo (events.js:126:13)
                              ! gyp
                              ! ERR!
                              ! stack
                              ! at ChildProcess.emit (events.js:214:7)
                              ! gyp
                              ! ERR!
                              ! stack
                              ! at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                              ! gyp
                              ! ERR!
                              ! System
                              ! Windows_NT 10.0.17763
                              ! gyp
                              ! ERR!
                              ! command
                              ! "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "build" "–fallback-to-build" "--module=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node" "--module_name=canvas" "--module_path=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
                              ! gyp
                              ! ERR!
                              ! cwd
                              ! C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas
                              ! gyp
                              ! ERR!
                              ! node -v
                              ! v8.13.0
                              ! gyp
                              ! ERR!
                              ! node-gyp -v
                              ! v3.8.0
                              ! gyp
                              ! ERR!
                              ! not ok
                              ! node-pre-gyp
                              ! ERR!
                              ! build error
                              ! node-pre-gyp
                              ! ERR!
                              ! stack
                              ! Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node --module_name=canvas --module_path=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                              ! node-pre-gyp
                              ! ERR!
                              ! stack
                              ! at ChildProcess. <anonymous>(C:\ioBroker\node_modules\iobroker.roomba\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
                              ! node-pre-gyp
                              ! ERR!
                              ! stack
                              ! node-pre-gyp
                              ! ERR!
                              ! stack
                              ! node-pre-gyp
                              ! ERR!
                              ! stack
                              ! at maybeClose (internal/child_process.js:915:16)
                              ! node-pre-gyp
                              ! ERR!
                              ! stack
                              ! at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                              ! node-pre-gyp
                              ! ERR! System Windows_NT 10.0.17763node-pre-gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\ioBroker\node_modules\iobroker.roomba\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
                              ! node-pre-gyp ERR! cwd C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas
                              ! node-pre-gyp
                              ! ERR!
                              ! node -v
                              ! v8.13.0
                              ! node-pre-gyp
                              ! ERR!
                              ! node-pre-gyp -v
                              ! v0.11.0
                              ! node-pre-gyp
                              ! ERR!
                              ! not ok
                              ! Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js build --fallback-to-build --module=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release\canvas.node --module_name=canvas --module_path=C:\ioBroker\node_modules\iobroker.roomba\node_modules\canvas\build\Release --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                              ! npm
                              ! ERR! code ELIFECYCLEnpm
                              ! ERR!
                              ! errno
                              ! 1
                              ! npm
                              ! ERR!
                              ! canvas@2.3.1 install: node-pre-gyp install --fallback-to-buildnpm
                              ! ERR! Exit status 1npm
                              ! ERR!
                              ! npm
                              ! ERR!
                              ! Failed at the canvas@2.3.1 install script.
                              ! npm
                              ! ERR!
                              ! This is probably not a problem with npm. There is likely additional logging output above.
                              ! npm ERR! A complete log of this run can be found in:npm ERR! C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-01-19T11_38_11_298Z-debug.log
                              ! process exited with code 0</anonymous></std::_string_val<std::_simple_types<char></std::_string_val<std::_simple_types<char></std::_string_val<std::_simple_types<_ty></std::_string_iterator<std::_string_val<std::_simple_types<_ty>
                              Ich habe im GitHub auf diese FORK Dings geklickt und habe ich Roomba Adapter auch in meinem GitHub Account drin. Wie bekomme ich das wieder weg?
                              • Zefau
                                Siehe Anleitung auf Github. Erst canvas installieren, dann sollte es passen.
                                Sent from my SM-G950F using Tapatalk
                                • JB_Sullivan
                                  Ich hatte ja schon die 0.2.x Version und wollte über die Katze einfach nur "hochrüsten" - Muss ich trotzdem den ganzen Canvas Prozess nochmal machen?
                                  • Zefau
                                    Die 0.2.0 benötigte kein canvas. Canvas wird erst ab 0.3.0 benötigt, um eine Live-Karte zu erzeugen während der Roomba sauber macht.
                                    • JB_Sullivan
                                      OK, Live Karte brauche ich nicht - wie komme ich wieder zurück zur 0.2.x Version?
                                      … hat sich erledigt .... das Update auf den 0.4.0 hat mir im nodes Ordner mal schön alle roomba Adapter Daten rausgelöscht. Habe sie dann von meinem Backup wieder rein kopiert und - LÄUFT.
                                      • 0
                                        0mathew0 last edited by
                                        Ich habe es noch nicht so ganz durchblickt,.. Teste nun schon länger die 0.4.0, läuft aber nicht sauber wie davor. Es scheint als würden die Missions nur bei manuellem Auslösen gespeichert, nicht beim (im Staubsauger gespeichertem) Zeitprogramm. Aktueller Status wird auch nur angezeigt, wenn der Sauger fährt, nicht im Dock. Darüber hinaus ist die Map spiegelverkehrt und unterscheidet sich gerne mal von der Fläche, welche in der Roomba IOS App (korrekt) dargestellt wird. Ist das nur bei mir so?
                                        LG
                                          Hey,
                                          ich hab nun das Problem das der Sauger sich über die Commands Steuern lässt, aber er zeichnet nix auf.
                                            Stefan1984 last edited by
                                            @Thebuh:
                                            Hallo Zefau,
                                            hab genau das gleiche Problem. Hatte gesehen, dass sich inzwischen viel getan hat und ein Update von Version 0.2 auf die aktuelle 0.4 gefahren. Seit dem verliert der Adapter die Verbindung zum Roomba "Status _connected = false". Ich hatte mich so daran gewöhnt, dass ich Roomba nach Abwesenheit fahren lassen konnte. Seit dem Update fährt er aber nicht mehr los, da der Status _connected = false ausgibt. Adapter neu starten, dann läuft es wieder.
                                            Also Workaround erstellt. Der Adapter wird jede Nacht neu gestartet. Leider hilft das nicht wirklich, da der Adapter sporadisch die Verbindung zum Roomba verliert.
                                            Die Installation habe ich nach Deiner Anleitung durchgeführt und lief auch ohne Fehler durch.
                                            Eingesetzt wird ein 980er Modell.
                                            Jetzt wollte ich wieder runter zur 0.2. Das funktioniert leider auch nicht, da ich keine frühere Version installieren kann.
                                            Ergebnis:
                                            $ ./iobroker upgrade roomba@0.2.0
                                            Adapter "roomba" is not in the repository and cannot be updated.
                                            Gibt es mittlerweile eine Lösung für das Problem mit der Connectivity der 0.4? Wenn nein, wie komme ich am besten wieder zu 0.2?
                                            Grüße,
                                            Stefan
                                            1.3k
                                            81.1k
                                            851
                                            300926
