    4. [Aufruf] Neuer Adapter ioBroker.tuya (WLAN devices Tuya Smart Life und andere)
      hansl100 last edited by
      Als Nachtrag hier noch das LOG von der Adapter Installation bis zum ersten Start der Smart Live APP:
      tuya.0 2019-01-12 23:04:09.282 info Anyproxy ready to receive requests
      tuya.0 2019-01-12 23:03:11.468 info 04200218ecfabc93b538: No schema exists, init basic states …
      tuya.0 2019-01-12 23:03:11.454 info 04200218ecfabc93b538: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:11.451 info 04200218ecfabc93b538 Init with IP=192.168.123.71, Key=undefined
      tuya.0 2019-01-12 23:03:11.357 info 01200559ecfabc05cc3c: No schema exists, init basic states ...
      tuya.0 2019-01-12 23:03:11.339 info 01200559ecfabc05cc3c: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:11.336 info 01200559ecfabc05cc3c Init with IP=192.168.123.37, Key=undefined
      tuya.0 2019-01-12 23:03:11.064 info 01200559ecfabc05cc3a: No schema exists, init basic states ...
      tuya.0 2019-01-12 23:03:11.038 info 01200559ecfabc05cc3a: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:11.035 info 01200559ecfabc05cc3a Init with IP=192.168.123.85, Key=undefined
      tuya.0 2019-01-12 23:03:10.889 info 01200559ecfabc05cc49: No schema exists, init basic states ...
      tuya.0 2019-01-12 23:03:10.874 info 01200559ecfabc05cc49: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:10.871 info 01200559ecfabc05cc49 Init with IP=192.168.123.63, Key=undefined
      tuya.0 2019-01-12 23:03:10.588 info 83318041bcddc2ee6de9: No schema exists, init basic states ...
      tuya.0 2019-01-12 23:03:10.575 info 83318041bcddc2ee6de9: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:10.572 info 83318041bcddc2ee6de9 Init with IP=192.168.123.87, Key=undefined
      tuya.0 2019-01-12 23:03:10.038 info 012005596001946651db: No schema exists, init basic states ...
      tuya.0 2019-01-12 23:03:10.023 info 012005596001946651db: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:10.021 info 012005596001946651db Init with IP=192.168.123.47, Key=undefined
      tuya.0 2019-01-12 23:03:09.890 info 012005592c3ae843d92b: No schema exists, init basic states ...
      tuya.0 2019-01-12 23:03:09.871 info 012005592c3ae843d92b: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:09.868 info 012005592c3ae843d92b Init with IP=192.168.123.39, Key=undefined
      tuya.0 2019-01-12 23:03:09.794 info 02200057ecfabc8b7a5d: No schema exists, init basic states ...
      tuya.0 2019-01-12 23:03:09.767 info 02200057ecfabc8b7a5d: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:09.764 info 02200057ecfabc8b7a5d Init with IP=192.168.123.80, Key=undefined
      tuya.0 2019-01-12 23:03:09.686 info 012005592c3ae8433807: No schema exists, init basic states ...
      tuya.0 2019-01-12 23:03:09.642 info 0220012668c63aa81e70: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:09.638 info 0220012668c63aa81e70 Init with IP=192.168.123.84, Key=undefined
      tuya.0 2019-01-12 23:03:09.634 info 012005592c3ae8433807: No local encryption key available, get data using polling, controlling of device NOT possibe. Please sync with App!
      tuya.0 2019-01-12 23:03:09.600 info 012005592c3ae8433807 Init with IP=192.168.123.62, Key=undefined
      tuya.0 2019-01-12 23:03:09.353 info Discover for local Tuya devices on port 6666
      tuya.0 2019-01-12 23:03:09.328 info Existing devices initialized
      tuya.0 2019-01-12 23:03:09.270 info starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.tuya, node: v8.14.0
      tuya.0 2019-01-12 23:03:09.065 info States connected to redis: 127.0.0.1:6379
      tuya.0 2019-01-12 23:03:08.875 error no connection to objects DB
      Beginnt das Problem schon bei dr Adapterinstallation mit dieser Logzeile??
        apollon77 last edited by
        Nein der Fehler ist ok beim Start, da ging es nicht schnell genug.
        Naja Du musst den Proxy Sync machen. Ggf hier schauen https://github.com/Apollon77/ioBroker.t … r/PROXY.md
          Apropo last edited by
          Hast du denn auch den Proxy in deinen WLAN Einstellungen eingetragen? Davon hast du zumindest nichts geschrieben
            Hallo und danke für deine Antwort.
            Ich habe den QR Code mit dem Handy gescannt,die Datei runtergeladen und nach Anleitung mit der Einstellung "WLAN" installiert.
            Danach die Smart Live APP geöffnet und gewartet das sich der Proxy ausschaltet. Aberdas Fenster mit dem QR Code ist offen geblieben.
            Habe ich da noch etwas übersehen?
            Hansl
              Wenn ich dich richtig verstehe hast du nur das Zertifikat installiert. Du musst aber auch noch in den Wlan Einstellungen bei Proxy die IP deines IoBroker und den Port eingeben.
                Könntest du mir da helfn?
                Hab eben das versucht,komme aber nicht weiter.
                Habe in den erweiterten Netzwekeinstellungen für mein wlan folgende Einstellmöglichkeiten:
                DHCP
                Proxy=ohne
                Dann wenn ich Proxy auf manuell stelle:
                Proxy Hostname
                Proxy Port
                Proxy umgehen
                Wo müsste ich das was eintrsgen?
                Mein Handy ist ein samsung J5 mit Android 7
                  Bei Proxy Hostname muss die IP von deinem IoBroker rein und der Port ist 8888 wenn du ihn nicht geändert hast. Das wars dann eigentlich auch schon. Danach sollte es eigentlich funktionieren wenn du die App öffnest. Also das Fenster mit dem QR Code sollte sich automatisch schließen.
                    Kilik last edited by
                    OWSOO RGBW Controller
                    https://www.amazon.de/dp/B0792ZYXTS/?coliid=IF6WBA4G45X4Y&colid=2QZIWWQH4LRD1&psc=0&ref_=lv_ov_lig_dp_it
                    {"schema":"[{"mode":"rw","code":"switch_on","name":"开关","property":{"type":"bool"},"iconname":"icon-dp_power3","id":1,"type":"obj","desc":""},{"mode":"rw","code"
                    new Shema added for product type qxJSyTLEtX5WrzA9. Please send next line from logfile on disk to developer!
                      ronaldm last edited by
                      Hallo, ist nun bei mir eingerichtet, die Geräte funktionieren nun auch ohne direkter Internetverbindung. Leider geht meine Lampe an und aus, aber Alexa sagt Lampe unterstützt dies nicht wenn ich versuche die Farbe zu setzen.
                      Unterstützt der Tuya Adapter Farbe bei LEDs?
                      Wenn ja, wie muss ich das Einstellen?
                        @Kilik:
                        new Shema added for product type qxJSyTLEtX5WrzA9. Please send next line from logfile on disk to developer! `
                        Bitte vollständig aus dem Logfile auf Platte holen, hier abgeschnitten und als GitHub issue melden. Danke
                          @ronaldm:
                          Wenn ja, wie muss ich das Einstellen? `
                          Kommt darauf an was Du so für States hast und so … zeig doch mal bzw hast Du ein Log vom Proxy-Sync mit einer Ausgabe für den Entwickler?)
                            Hallo Apropo, das klappt nicht.
                            Die APP startet mit Fehler "incorrect lokal time, please correct it" und mehr passiert nicht.
                            Ich weis nicht weiter würde aber sehr gern den Adapter benutzen.
                            Muss der QR Code evtl. immer bei jedem Versuch neu gescannt werden?
                            Hansl
                              Wenn der Fehler kommt stimmt mit dem Proxy was nicht.
                              Nein der qr Code ist die url zum zertifikat und das sollte das gleiche sein bei mehreren versuchen.
                              Gesendet vom Handy …
                                Der Proxy hat Ben zweiten Port mit einer Webseite wo man sieht was er do überträgt und anfängt. Port 8889.
                                Im Browser aufrufen. Dann mach mal die App auf. Tut sich was? Was steht da?
                                  @apollon77:
                                  @ronaldm:
                                  Kommt darauf an was Du so für States hast und so … zeig doch mal bzw hast Du ein Log vom Proxy-Sync mit einer Ausgabe für den Entwickler?) `
                                  Log File anbei
                                    Hallo, hoffe ich habe die Bilder vom Handy Browser richtig angehängt.
                                    Das geht so weiter bis Zeile 150 und mehr.
                                    MFG
                                      Ok, zu den tuya Servern steht nur CONNECT. Bedeutetet: Zertifikat nicht korrekt eingerichtet. Du hast es bei WLAN drin?
                                        @ronaldm:
                                        @apollon77:
                                        @ronaldm:
                                        Meine States filename="tuya_states_lampe.JPG" index="1">~~
                                        Log File anbei `
                                        Hm … also spontan geschaut bohrt sich da ein State Name direkt in meine Augen der für Farbe zuständig sein müsste. Dir auch?
                                        Warum die Chinesen eine Farbabrieb in rgb und hsv (Google mal) in einem State vereinen verstehe ich nicht aber das wäre ein Ansatzpunkt. Ich glaube am Anfang dieses Threads hat ein User das mal auseinander genommen. Mach ein paar Farben per App und schau dir die werte an und versuche es ...
                                        Gesendet vom Handy ...
                                          Hallo apollon77,mein Problem ist nun anscheinend gelöst.
                                          Ich habe ein Android 6 Handy genommen und da hat es funktioniert.
                                          Nun sind die richtigen Device namen unter den Objekten und der Proxy hat einen "Haken" gezeigt.
                                          Danke für deine Unterstützung und den Adapter
                                          Hansl
                                            @apollon77:
                                            @ronaldm:
                                            @apollon77:
                                            Log File anbei `
                                            Gesendet vom Handy ... `
                                            Hallo und danke für deine prompte Antwort apollon77,
                                            ich habe den kompletten Thread durchsucht aber nichts gefunden.
                                            Der ensprechende Datenpunkt heist "colour_data", hier ein paar Farbcodes:
                                            0007ff00eeffff blau
                                            ff002f015cffff rot
                                            07ff000076ffff grün
                                            fff3000039ffff gelb
                                            ff8a000020ffff orange
                                            c600ff011effff lila
                                            00fff600b1ffff turkis
                                            Ein und ausschalten geht ja direkt über den cloud adapter, aber wie lasse ich Alexa die Farben setzen. Ich denke über Scripts aber da hab ich keine Ahnung. Schon jemand ein Script dafür geschrieben?
                                            79.9k
                                            547
                                            149679
