    4. Amazon Dash Adapter spinnt sich aus
    • Chaot
      Chaot last edited by
      Seit gestern gehen bei mir die DasButtons plötzlich auch nicht mehr.
      host.haus	2018-09-03 17:54:37.250	error	instance system.adapter.amazon-dash.0 terminated with code 3 (Adapter disabled or invalid config)
      host.haus	2018-09-03 17:54:20.421	info	instance system.adapter.daswetter.0 terminated with code 0 (OK)
      host.haus	2018-09-03 17:54:19.777	info	object change system.adapter.amazon-dash.0
      host.haus	2018-09-03 17:54:06.378	info	Restart adapter system.adapter.amazon-dash.0 because enabled
      host.haus	2018-09-03 17:54:06.378	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:787:25)
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at Adapter.emit (events.js:208:7)
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at emitNone (events.js:106:13)
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:42:5)
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
      Caught	2018-09-03 17:54:06.378	error	by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
      Caught	2018-09-03 17:54:06.377	error	by controller[0]: Error: socket: Operation not permitted
      host.haus	2018-09-03 17:54:04.890	info	instance system.adapter.amazon-dash.0 started with pid 28668</anonymous></anonymous>
      Ich habe aber nichts am System geändert ausser den ioBroker neu zu starten.
        apollon77 last edited by
        "operation not permitted" weiss für mich auf Rechtekram hin … Warum es bisher tat und jetzt nicht mehr keine Ahnung, aber vllt ein Ansatz
        • Stabilostick
          Stabilostick last edited by
          "Für unixartige Betriebssysteme stellt die Bibliothek „libpcap“ (packet capture library) Funktionen zur Verfügung, um den Datenverkehr, welcher über die Netzwerkschnittstellen läuft, mitzuschneiden und zu analysieren. Das JavaScript Modul „pcap“ stellt die entsprechenden Bindungen (engl. Bindings) für diese Bibliothek zur Verfügung. Diese können dann mit Node.js verwendet werden.
          <size size="150">Problem</size>
          Diese Bibliothek wird gerne in Node.js Modulen, wie z. B. dem Amazon Dashbutton Adapter für ioBroker, verwendet.
          Da die libpcap Bibliothek auf Funktionen des Betriebssystems zugreift, kann es zu folgender Fehlermeldung kommen, wenn der Code ausgeführt wird.
          Der Benutzer, durch den der Code ausgeführt wurde, besitzt anscheinend nicht die notwendigen Rechte.
          Am Beispiel des Amazon Dashbutton Adapters, würde dann folgende Fehlermeldung im Log auftauchen.
          error   at Adapter. (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:50:29)
          error   at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
          error   at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
          error   Error: socket: Operation not permitted
          error   uncaught exception: socket: Operation not permitted
          <size size="150">Lösung</size>
          Um das Problem zu lösen, müssen die Dateisystem „Capabilities“ für das Programm „node“ angepasst werden. Dies kann durch das Kommandozeilen-Tool „setcap“ erreicht werden.
          Hierzu muss folgender Befehl in der Kommandozeile ausgeführt werden.
          sudo setcap 'cap_net_raw,cap_net_admin+eip' $(readlink -f $(which node))
          Mit dem Tool „getcap“ kann geprüft werden, ob alles korrekt gesetzt wurde. Hierzu muss folgender Befehl in der Kommandozeile ausgeführt werden.
          sudo getcap $(readlink -f $(which node))
          Dies Ausgabe sollte dann z. B. so aussehen:
          /usr/bin/nodejs = cap_net_admin,cap_net_raw+eip
          Hier noch eine kurze Erklärung aus der Dokumentation:
          ` > In many distributions you can use the 'setcap' utility to add capabilities to individual files.
          CAP_NET_RAW:
          Allow use of RAW and PACKET sockets.
          CAP_NET_ADMIN:
          Allow various network-related operations (e.g. setting privileged socket options, enabling multicasting, setting promiscuous mode, interface configuration, modifying routing tables).
          The “+eip” means you’re adding the file capability sets Effective, Inherited and Permitted.
          Each thread has three capability sets containing zero or more of the above capabilities:
          The three file capability sets are:
          e: Effective - The capabilities used by the kernel to perform permission checks for the thread.
          i: Inherited - The capabilities preserved across an execve(2). A child created via fork(2) inherits copies of its parent's capability sets. See below for a discussion of the treatment of capabilities during exec(). Using capset(2), a thread may manipulate its own capability sets, or, if it has the CAP_SETPCAP capability, those of a thread in another process.
          p: Permitted - The capabilities that the thread may assume (i.e., a limiting superset for the effective and inheritable sets). If a thread drops a capability from its permitted set, it can never re-acquire that capability (unless it exec()s a set-user-ID-root program). `
          Um zu prüfen, ob das pcap Module korrekt funktioniert, kann die im Module mitgelieferte Bespieldatei „network_grep.js“ über die Kommandozeile ausgeführt werden. Diese Datei befindet sich z. B. im Ordner „node_modules“ unter pcap/examples/network_grep.js
          Beispiel Befehl:
          node /opt/iobroker/node_modules/pcap/examples/network_grep.js
          Hier sollte dann folgender Fehler NICHT mehr auftreten:
          /opt/iobroker/node_modules/pcap/pcap.js:49
                  this.link_type = this.session.open_live(this.device_name, this.filter, this.buffer_size, this.outfile, packet_ready, this.is_monitor);
              at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:49:39)
              at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:123:12)
              at Object. <anonymous>(/opt/iobroker/node_modules/pcap/examples/network_grep.js:2:25)
              at Module._compile (module.js:571:32)
              at Object.Module._extensions..js (module.js:580:10)
              at Module.load (module.js:488:32)
              at tryModuleLoad (module.js:447:12)
              at Function.Module._load (module.js:439:3)
              at Module.runMain (module.js:605:10)
              at run (bootstrap_node.js:427:7)</anonymous>
          Vollquote von [https://www.blogging-it.com/node-pcap-m … odejs.html](https://www.blogging-it.com/node-pcap-module-error-socket-operation-not-permitted-fehler-wenn-pcapsession-geoeffnet-wird/programmierung/javascript/nodejs.html)
          Danke, Markus.
          • Chaot
            Dankeschön. Das hat funktioniert.
            Aber mir ist ehrlich gesagt immer noch nicht klar warum die plötzlich nicht mehr funktioniert haben.
              msiemers last edited by
              @Stabilostick:
              Beispiel Befehl:
              Danke, Markus. `
              Was macht man denn wenn nach dem Befehl immer noch folgender Fehler kommt?
              TypeError: Cannot read property 'ip' of undefined
                  at PcapSession. <anonymous>(/opt/iobroker/node_modules/pcap/examples/network_grep.js:9:28)
                  at emitOne (events.js:116:13)
                  at PcapSession.emit (events.js:211:7)
                  at PcapSession.on_packet_ready (/opt/iobroker/node_modules/pcap/pcap.js:99:10)
                  at packet_ready (/opt/iobroker/node_modules/pcap/pcap.js:44:14)
                  at SocketWatcher.pcap_read_callback [as callback] (/opt/iobroker/node_modules/pcap/pcap.js:64:45)
              root@iobroker:/opt/iobroker#</anonymous>
              Ich habe das gleiche Problem wie mein Vorredner.
                denjo last edited by
                @msiemers:
                @Stabilostick:
                Beispiel Befehl:
                Danke, Markus. `
                Ich habe das gleiche Problem wie mein Vorredner. `
                schon eine lösung gefunden???
                  Ich nutze den nicht.
                  Aber in letzten Tagen häufen sich da Probleme
                  Kennt ihr das:
                  https://www.tagesschau.de/wirtschaft/am … n-103.html
                  Rainer
                  • V
                    vondefenn last edited by
                    kann kaum an dem Urteil des Gerichtes liegen, dass die pcap auf einmal bzgl. Rechte spinnt 😉
                    Sobald die Kommunikation des Dash-Buttons einmal nach Ersteinrichtung mit dem Internet unterbunden ist - ist Ama da raus 😉
                      ltsalvatore last edited by
                      hi zusammen,
                      eine frage vorab..
                      sind die dash buttons, in naher zukunft hier in deutschland verboten und somit auch nicht mehr nutzbar?
                      oder kann man diese dann zu hause weiterhin nutzen?
                      ich vermute mal, dass wenn diese verboten werden, dann auch nicht mehr funktionieren werden, da keine verbindung mehr zu dem amazon server bestehen wird.
                      sollte dies der fall sein, dann brauch ich auch keine lösung zu meinem anliegen und ich schmeiß das ding einfach ausm fenster.
                      falls diese doch noch nutzbar sein sollten:
                      ich bin gerade dabei mein iobroker von pi auf nuc umzustellen und installiere gerade auf das neue system alle adapter, die ich benötige.
                      auf dem nuc ist proxmox inst. und auf diesen eine vm mit debian.
                      jetzt bekomme ich bei der inst. des dash adapters folgende fehlermeldung:
                      Fertig mit Fehler: host.shsrv Cannot install amazon-dash
                      $ ./iobroker add amazon-dash  --host shsrv
                      NPM version: 6.4.1
                      npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
                      WARNING:
                      apt
                      does not have a stable CLI interface.
                      Use with caution in scripts.
                      E
                      Sperrdatei /var/lib/dpkg/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                      E
                      Sperren des Administrationsverzeichnisses (/var/lib/dpkg/) nicht möglich, sind Sie root?
                      ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::Callback(uv_poll_t*, int, int)’:../socket_watcher.cpp:77:60: warning: ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’ is deprecated [-Wdeprecated-declarations]
                         Nan::MakeCallback(watcher->handle(), callback, argc, argv);
                      In file included from ../socket_watcher.hpp:8:0,                 from ../socket_watcher.cpp:5:
                      ../../nan/nan.h:959:46: note: declared here
                         NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback(
                      ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">
                      compilation terminated.
                      make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1gyp ERR! build error
                      gyp ERR! stack Error: `make` failed with exit code: 2
                      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                      gyp ERR! stack     at emitTwo (events.js:126:13)
                      gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                      gyp ERR! System Linux 4.9.0-8-amd64
                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                      gyp ERR! cwd /opt/iobroker/node_modules/pcap
                      gyp
                       ERR! node -v v8.15.0gyp ERR! node-gyp -v v3.8.0
                      gyp ERR! not ok
                      npm
                      ERR!
                      code
                       ELIFECYCLE
                      npm
                      ERR!
                      errno
                      npm
                      ERR!
                       pcap@2.1.0 install: `node-gyp rebuild`
                      npm
                      ERR!
                       Exit status 1
                      npm
                       ERR! npm ERR!
                       Failed at the pcap@2.1.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      npm
                      ERR!
                       A complete log of this run can be found in:
                      npm
                      ERR!
                           /home/iobroker/.npm/_logs/2019-01-17T18_36_18_665Z-debug.log
                      host.shsrv install adapter amazon-dash
                      NPM version: 6.4.1npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
                      WARNING:
                      apt
                      E
                      E
                      gyp ERR! node -v v8.15.0
                      gyp ERR! not ok
                      npm
                      ERR!
                      code
                       ELIFECYCLE
                      npm
                      ERR!
                      errno
                      npm
                      ERR!
                      npm
                      ERR!
                       Exit status 1
                      npm
                       ERR! npm ERR! Failed at the pcap@2.1.0 install script.
                      npm
                      ERR!
                      npm
                      ERR!
                           /home/iobroker/.npm/_logs/2019-01-17T18_36_26_041Z-debug.log
                      WARNING:
                      apt
                      E
                      E
                      gyp
                      ERR!
                      not ok
                      npm
                      ERR!
                      code
                       ELIFECYCLE
                      npm
                      ERR!
                      errno
                      npm
                      ERR!
                      npm ERR! Exit status 1npm
                       ERR! npm
                       ERR! Failed at the pcap@2.1.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      npm
                      ERR!
                      npm
                      ERR!
                           /home/iobroker/.npm/_logs/2019-01-17T18_36_33_546Z-debug.log
                      ERROR: host.shsrv Cannot install amazon-dash
                      ERROR: process exited with code 13</pcap></v8::value></v8::value></v8::function></v8::object></v8::value></pcap></v8::value></v8::value></v8::function></v8::object></v8::value></pcap></v8::value></v8::value></v8::function></v8::object></v8::value>
                      leider kann ich mit dem ganzen code, der ausgespuckt wird nicht viel anfangen und hoffe, dass mir da jemand weiter helfen kann.
                      danke und schöne grüße
                        Das liegt an der neuen Installation Routine, bzw an den root rechten. Mach ein issus auf habe ich auch schon
                          @denjo:
                          Das liegt an der neuen Installation Routine, bzw an den root rechten. Mach ein issus auf habe ich auch schon `
                          ein issue auf git?
                          installatiosroutine bezogen auf den adapter oder der neuen iobroker installations routine?
                            Es gibt ein issue in dem alle befehle gesammelt werden, die der user iobroker ausführen können muss, aber bisher nicht kann.
                            Dort bitte als Kommentar hinzuzufügen
                            Rainer
                              @Homoran:
                              Rainer `
                              hm.. wo denn und was soll ich da dann eintragen?
                              @denjo:
                              ich habe mich jetzt einfach mal bei deinem issue dazugesellt.
                              den adapter konnt ich mittlerweile inst. aber aktiv ist dieser immer noch nicht und spuckt fehlermeldungen im iobroker log aus.
                              host.shsrv	2019-01-18 14:05:16.401	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:787:25)
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at Adapter.emit (events.js:208:7)
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at emitNone (events.js:106:13)
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:123:12)
                              host.shsrv	2019-01-18 14:05:16.401	error	Caught by controller[0]: at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:49:39)
                              host.shsrv	2019-01-18 14:05:16.400	error	Caught by controller[0]: Error: socket: Operation not permitted</anonymous></anonymous>
                                @ltsalvatore:
                                hm.. wo denn und was soll ich da dann eintragen? `
                                Sorry, war gestern unterwegs und konnte nicht suchen:
                                https://github.com/ioBroker/ioBroker/issues/96
                                dort einen Kommentar einfügen in dem der Command steht bei dem EACCESS oder ähnliche Fehler wegen fehlender Rechte stehen.
                                Rainer
                                AlCalzone created this issue in ioBroker/ioBroker
                                closed Which commands should iobroker be allowed to execute as `sudo`? #96
                                  @Homoran:
                                  @ltsalvatore:
                                  Rainer `
                                  super, danke für den link.
                                  werde ich eintragen, sobald ich gecheckt habe, welcher eintrag genau gemeint ist. :roll:
                                    @ltsalvatore:
                                    sobald ich gecheckt habe, welcher eintrag genau gemeint ist. :roll: `
                                    ich bin auch kein scripter, aber das sieht z.B. danach aus:
                                    make steht schon auf der Liste!
                                    Am besten einen Link auf diese Fehlermeldungen in dem Kommentar angeben.
                                    Rainer
                                      deifel last edited by
                                      ich habe leider nach wie vor Probleme, den Dash-Adapter ans Laufen zu bekommen.
                                      Nachdem alles funktioniert hatte und ich einen Neustart vom System machen musste (Debian), spinnt Libcap bei mir.
                                      Der Befehl:
                                      bringt
                                      :sudo: setcap: Befehl nicht gefunden
                                      Egal ob mit oder ohne sudo.
                                      Libcap ist allerdings installiert.
                                      Remove klappt allerdings auch nicht:
                                      Statusinformationen werden eingelesen…. Fertig
                                      Paket »libcap-dev« ist nicht installiert, wird also auch nicht entfernt.
                                      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                      Er sagt, es ist nicht installiert...
                                      Wenn ich installieren möchte, erscheint:
                                      libpcap-dev ist schon die neueste Version (1.8.1-3).
                                      Kann mir jemand sagen, wie ich das Teil richtig entfernen kann oder mit welchem Befehl ich die Rechte wieder richtig setze?
                                      Ausfgabe dpkg ist:
                                      root@IOBrokerhost:~# dpkg -L libpcap0.8
                                      /usr
                                      /usr/lib
                                      /usr/lib/x86_64-linux-gnu
                                      /usr/lib/x86_64-linux-gnu/libpcap.so.1.8.1
                                      /usr/share
                                      /usr/share/doc
                                      /usr/share/doc/libpcap0.8
                                      /usr/share/doc/libpcap0.8/CREDITS.gz
                                      /usr/share/doc/libpcap0.8/README
                                      /usr/share/doc/libpcap0.8/README.Debian
                                      /usr/share/doc/libpcap0.8/changelog.Debian.gz
                                      /usr/share/doc/libpcap0.8/changelog.gz
                                      /usr/share/doc/libpcap0.8/copyright
                                      /usr/share/man
                                      /usr/share/man/man7
                                      /usr/share/man/man7/pcap-filter.7.gz
                                      /usr/lib/x86_64-linux-gnu/libpcap.so.0.8
                                      Vielen Dank im Voraus
                                        @denjo:
                                        @msiemers:
                                        @Stabilostick:
                                        Beispiel Befehl:
                                        Danke, Markus. `
                                        schon eine lösung gefunden??? `
                                        Habe es (wenn auch evtl. nur vorübergehend) geschafft, den Dash-Adapter zum "Leben" zu erwecken.
                                        Dazu haben ich
                                        apt-get install libcap2-bin
                                        installiert und danach den Befehl:
                                        ausgeführt. Adapter neu starten - dann sollte er wieder laufen. Habe aber noch keine Neustart getestet…
                                          rebe09 last edited by
                                          Hallo.
                                          Ich bekomme bei install Versuch folgende Fehlermeldung(en)
                                          ! $ ./iobroker add amazon-dash –host octopi
                                          ! npm install iobroker.amazon-dash --production --prefix "/root" (System call)
                                          ! npm
                                          ! WARN addRemoteGit Error: Command failed: git config --get remote.origin.urlnpm WARN addRemoteGit
                                          ! npm WARN addRemoteGit at ChildProcess.exithandler (child_process.js:199:12)
                                          ! npm WARN addRemoteGit at emitTwo (events.js:106:13)
                                          ! npm WARN addRemoteGit at ChildProcess.emit (events.js:191:7)
                                          ! npm WARN addRemoteGit at maybeClose (internal/child_process.js:920:16)
                                          ! npm WARN addRemoteGit at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                                          ! npm WARN addRemoteGit git+https://github.com/bytzdev/node-socketwatcher.git resetting remote /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de because of error: { Error: Command failed: git config --get remote.origin.url
                                          ! npm WARN addRemoteGit killed: false,
                                          ! npm WARN addRemoteGit code: 1,
                                          ! npm WARN addRemoteGit signal: null,
                                          ! npm WARN addRemoteGit cmd: 'git config --get remote.origin.url' }
                                          ! npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de: Please run git without sudo, your regular user account is enough 🙂
                                          ! npm ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/root"
                                          ! npm
                                          ! ERR! node v6.13.0
                                          ! npm ERR! npm v3.10.10
                                          ! npm ERR! code 1
                                          ! npm
                                          ! ERR! Command failed: git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02denpm ERR!
                                          ! npm ERR!
                                          ! npm ERR! If you need help, you may report this error at:
                                          ! npm ERR! <https://github.com/npm/npm/issues>
                                          ! npm
                                          ! ERR! Please include the following file with any support request:npm ERR!
                                          ! /npm-debug.log
                                          ! host.octopi install adapter amazon-dash
                                          ! npm
                                          ! at Socket. <anonymous>(internal/child_process.js:351:11)npm WARN addRemoteGit at emitOne (events.js:96:13)
                                          ! npm WARN addRemoteGit at Socket.emit (events.js:188:7)
                                          ! npm WARN addRemoteGit at Pipe._handle.close [as _onclose] (net.js:509:12)
                                          ! npm WARN addRemoteGit git+https://github.com/bytzdev/node-socketwatcher.git resetting remote /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de because of error: { Error: Command failed: git config –get remote.origin.url
                                          ! npm WARN addRemoteGit at Socket. <anonymous>(internal/child_process.js:351:11)
                                          ! npm WARN addRemoteGit at emitOne (events.js:96:13)
                                          ! npm
                                          ! WARN addRemoteGit at Pipe._handle.close [as _onclose] (net.js:509:12)npm WARN addRemoteGit killed: false,
                                          ! npm
                                          ! WARN
                                          ! addRemoteGit
                                          ! code: 1,npm WARN addRemoteGit signal: null,
                                          ! npm WARN addRemoteGit cmd: 'git config –get remote.origin.url' }
                                          ! npm
                                          ! ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02de: Please run git without sudo, your regular user account is enough 🙂
                                          ! npm
                                          ! ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/root"
                                          ! npm ERR! node v6.13.0
                                          ! npm ERR! code 1
                                          ! npm
                                          ! npm ERR!
                                          ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
                                          ! npm
                                          ! npm WARN addRemoteGit npm WARN addRemoteGit at ChildProcess.exithandler (child_process.js:199:12)
                                          ! at ChildProcess.exithandler (child_process.js:199:12)npm WARN addRemoteGit at emitTwo (events.js:106:13)
                                          ! npm
                                          ! WARN
                                          ! addRemoteGit at Socket. <anonymous>(internal/child_process.js:351:11)npm WARN addRemoteGit at emitOne (events.js:96:13)
                                          ! code: 1,
                                          ! npm
                                          ! WARN addRemoteGit signal: null,npm WARN addRemoteGit cmd: 'git config –get remote.origin.url' }
                                          ! npm
                                          ! ERR!
                                          ! Please run git without sudo, your regular user account is enough 🙂
                                          ! npm
                                          ! npm ERR! npm v3.10.10npm ERR! code 1
                                          ! npm ERR! Command failed: git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/bytzdev/node-socketwatcher.git /root/.npm/_git-remotes/git-https-github-com-bytzdev-node-socketwatcher-git-e2de02denpm ERR!
                                          ! npm ERR!
                                          ! ERROR: host.octopi Cannot install amazon-dash
                                          ! ERROR: process exited with code 13</anonymous></anonymous></anonymous></anonymous>
                                          weiss jemand was zu tun ist und sagt es mir auch?
                                          Vielen Dank!!
                                            Hallo nochmals.
                                            Ich habe nun nochmals versucht auf einem andern Raspberry iobroker neu aufzusetzen und anschließend den Amazon Adapter zu installieren.
                                            Das klappt leider auch nicht.
                                            folgender Output:
                                            ! $ ./iobroker add amazon-dash –host raspberrypi
                                            ! NPM version: 6.4.1
                                            ! npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
                                            ! WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                                            ! E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
                                            ! ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::Callback(uv_poll_t*, int, int)’:../socket_watcher.cpp:77:60: warning: ‘v8::Local v8::valueNan::MakeCallback(v8::Localv8::object, v8::Localv8::function, int, v8::Localv8::value*)’ is deprecated [-Wdeprecated-declarations]
                                            ! Nan::MakeCallback(watcher->handle(), callback, argc, argv);
                                            ! In file included from ../socket_watcher.hpp:8:0, from ../socket_watcher.cpp:5:
                                            ! ../../nan/nan.h:959:46: note: declared here
                                            ! NAN_DEPRECATED inline v8::Local v8::valueMakeCallback(
                                            ! ^~~~~~~~~~~~</v8::value></v8::value></v8::function></v8::object></v8::value>
                                            25
                                            4358
