    4. Adapter: DasWetter
    Adapter: DasWetter
      Creator last edited by
      > So hat es bei mir funktioniert. Bis auf den weißen Rand, den ich nicht wegbekomme.
      Das CSS was du benutzt ist ja für das ganzes Layout aus dem Link. Das dann noch global eingebunden überschreibt es das eine oder andere.
      Ich habe das für mich auf das nötigste gekürzt. Es bezieht sich nur noch auf den Bargraph:
         bargraph
      .mdui-h-flip  { transform: scaleX(-1); }
      .mdui-v-flip  { transform: scaleY(-1); }
      .mdui-h-flip.mdui-v-flip  { transform: scale(-1); }
      /* Hintergrund und Border */
      .mdui-h-bargraph,
      .mdui-v-bargraph {
        background-position: -1000px !important;
        background-repeat: no-repeat !important;
        box-shadow:0 0 0 1000px rgba(255,255,255,0.1) inset;
        border:none !important;
      .mdui-h-bargraph>*,
      .mdui-v-bargraph>* {
        background-image:inherit !important;
      .mdui-h-bargraph:after,
      .mdui-v-bargraph:after {
        content:"";
        position:absolute;
        left:0;
        top:0;
        width:100%;
        height:100%;
        opacity:0.1;
      .mdui-h-bargraph.mdui-segment-10 {
          clip-path: polygon(
             0% 100%,  0% 0%,  9% 0%,  9% 100%,
            10% 100%, 10% 0%, 19% 0%, 19% 100%,
            20% 100%, 20% 0%, 29% 0%, 29% 100%,
            30% 100%, 30% 0%, 39% 0%, 39% 100%,
            40% 100%, 40% 0%, 49% 0%, 49% 100%,
            50% 100%, 50% 0%, 59% 0%, 59% 100%,
            60% 100%, 60% 0%, 69% 0%, 69% 100%,
            70% 100%, 70% 0%, 79% 0%, 79% 100%,
            80% 100%, 80% 0%, 89% 0%, 89% 100%,
            90% 100%, 90% 0%, 100% 0%, 100% 100%
      .mdui-h-bargraph.mdui-triangle  {
          clip-path: polygon(0% 40%, 100% 0%, 100% 100%, 0% 60%);
      .mdui-h-bargraph.mdui-ramp  {
          clip-path: polygon(0% 80%, 100% 0%, 100% 100%, 0% 100%);
      .mdui-h-bargraph.mdui-segment-10.mdui-ramp {
          clip-path: polygon(
             9% 100%,  9% 71%,  0% 80%,  0% 100%,
            19% 100%, 19% 63%, 10% 72%, 10% 100%,
            29% 100%, 29% 55%, 20% 64%, 20% 100%,
            39% 100%, 39% 47%, 30% 56%, 30% 100%,
            49% 100%, 49% 39%, 40% 48%, 40% 100%,
            59% 100%, 59% 31%, 50% 40%, 50% 100%,
            69% 100%, 69% 23%, 60% 32%, 60% 100%,
            79% 100%, 79% 15%, 70% 24%, 70% 100%,
            89% 100%, 89%  7%, 80% 16%, 80% 100%,
           100% 100%,100%  0%, 90%  8%, 90% 100%
      .mdui-h-bargraph.mdui-segment-10.mdui-triangle {
          clip-path: polygon(
             9% 37%,  9% 63%,  0% 60%,  0% 40%,
            19% 33%, 19% 67%, 10% 64%, 10% 36%,
            29% 29%, 29% 71%, 20% 68%, 20% 32%,
            39% 25%, 39% 75%, 30% 72%, 30% 28%,
            49% 21%, 49% 79%, 40% 76%, 40% 24%,
            59% 17%, 59% 83%, 50% 80%, 50% 20%,
            69% 13%, 69% 87%, 60% 84%, 60% 16%,
            79%  9%, 79% 91%, 70% 88%, 70% 12%,
            89%  5%, 89% 95%, 80% 92%, 80% 8%,
            100% 0%, 100% 100%, 90% 96%, 90% 4%
      .mdui-v-bargraph.mdui-segment-10 {
          clip-path: polygon(
           100%  0%, 0%  0%, 0%  9%,100%  9% ,
           100% 10%, 0% 10%, 0% 19%,100% 19% ,
           100% 20%, 0% 20%, 0% 29%,100% 29% ,
           100% 30%, 0% 30%, 0% 39%,100% 39% ,
           100% 40%, 0% 40%, 0% 49%,100% 49% ,
           100% 50%, 0% 50%, 0% 59%,100% 59% ,
           100% 60%, 0% 60%, 0% 69%,100% 69% ,
           100% 70%, 0% 70%, 0% 79%,100% 79% ,
           100% 80%, 0% 80%, 0% 89%,100% 89% ,
           100% 90%, 0% 90%, 0% 100%,100% 100%
      .mdui-v-bargraph.mdui-triangle  {
          clip-path: polygon(60% 0%, 100% 100%, 0% 100%, 40% 0%);
      .mdui-v-bargraph.mdui-ramp  {
          clip-path: polygon(100% 0%, 100% 100%, 0% 100%, 80% 0%);
      .mdui-v-bargraph.mdui-segment-10.mdui-ramp {
          clip-path: polygon(
          100%   9%, 71%  9%, 80%  0%, 100%  0%,
          100%  19%, 63% 19%, 72% 10%, 100% 10%,
          100%  29%, 55% 29%, 64% 20%, 100% 20%,
          100%  39%, 47% 39%, 56% 30%, 100% 30%,
          100%  49%, 39% 49%, 48% 40%, 100% 40%,
          100%  59%, 31% 59%, 40% 50%, 100% 50%,
          100%  69%, 23% 69%, 32% 60%, 100% 60%,
          100%  79%, 15% 79%, 24% 70%, 100% 70%,
          100%  89%,  7% 89%, 16% 80%, 100% 80%,
          100% 100%, 0% 100%,  8% 90%, 100% 90%
      .mdui-v-bargraph.mdui-segment-10.mdui-triangle {
          clip-path: polygon(
           37%   9%, 63%  9%, 60%  0%, 40%  0%,
           33%  19%, 67% 19%, 64% 10%, 36% 10%,
           29%  29%, 71% 29%, 68% 20%, 32% 20%,
           25%  39%, 75% 39%, 72% 30%, 28% 30%,
           21%  49%, 79% 49%, 76% 40%, 24% 40%,
           17%  59%, 83% 59%, 80% 50%, 20% 50%,
           13%  69%, 87% 69%, 84% 60%, 16% 60%,
            9%  79%, 91% 79%, 88% 70%, 12% 70%,
            5%  89%, 95% 89%, 92% 80%,  8% 80%,
            0% 100%,100% 100%,96% 90%,  4% 90%
      Das reicht mir aus, da ich wie gesagt das Layout nicht brauche. Keine weißen Ränder oder so vorhanden.
      Ob du das Global oder nur für dein Widget einbaust ist deine Sache.
      Ich bin mir nicht 100% sicher aber ich glaube es braucht keine Zeile JS Code zu diesem Bargraph.
      Ich konnte zumindest kein Event in der JS Datei finden und es klappt auch ohne auf den ersten Blick kann mich aber auch täuschen…
      Nur das CSS da oben kein JS:
      • Negalein
        @Creator:
        Ob du das Global oder nur für dein Widget einbaust ist deine Sache. `
        Danke!
        Ich habs zuerst nur im Widget versucht. Da hat es nicht funktioniert!
        Erst als ich es im View und Widget machte, funktionierte es.
        Komisch!
        Aber ich werde dein CSS auch versuchen. Nur allein im Widget!
          martin last edited by
          Welches ist denn der richtige Schalter Eintrag für "Temperatur aktuell"?
          Ich finde da irgendwie nichts passendes.
            daswetter.0.NextHours.Location_1.Day_1.current.temp_value
            • wendy2702
              wendy2702 last edited by
              Oder der eventuell eigene lokale Aussensensor wenn vorhanden.
                Ich habe jetzt mal meinen Xiaomi Außensensor eingebunden.
                Wie und wo kann ich es einstellen, dass er die Nachkomma-Stellen nicht mit anzeigt?
                • Z
                  Zippolighter last edited by
                  In dem Du die Zahl änderst auf das Widget Basic Number. In dem Widget kannst dann definieren ob und wieviel Nachkommastellen
                    Vielen Dank euch allen für die tolle Hilfe.
                    So sieht meine fertige View jetzt aus.
                    • Rene_HM
                      Rene_HM Developer last edited by
                      @Jack01:
                      Moin,
                      auch ich möchte mich für die tollen Anregungen und Downloads bei allen bedanken.
                      Ich habe mich auch gefragt, was die Datenpunkte "value" und "value2" beim Adapter "das Wetter" bedeuten. Eine Antwort habe ich nach dem Einloggen auf daswetter.com unter Hilfe gefunden.
                      Ich habe hier den entsprechenden Hinweis einmal angehängt. Vielleicht hilft das ja dem Einen oder Anderen.
                      Hans-Jürgen `
                      Das pdf liegt übrigens auch im Adapter im Verzeichnis /doc… Ich denke, ich baue mal einen link aus dem Admin dahin ein..
                      • Rene_HM
                        @sigi234:
                        Bitte beachtet den Hinweis in der Info bzgl. current:
                        ` > "current" in NextHours_Day1:
                        DasWetter.com does not deliver real current weather values
                        but sometimes it's helpfull to have the forecast of current hour available
                        so we added "current" which is just a copy of related forecast hour values
                        please make sure you call the adapter at least one time per hour to make sure "current" is updated well
                        see also github feature request issue24 `
                          mrniceguy last edited by
                          Ich habe bisher meine Wetterdaten mit Wounderground bezogen und habe jetzt auf das Wetter umgestellt.
                          Mir ist aufgefallen, dass auch nach dem Sonnenuntergang immer ein Symbol mit einer Sonne verwendet wird. Beim Wunderground Adapter wurde nach dem Sonnenuntergang bei z.B. klarem Himmel ein Mond angezeigt oder bei z.B. bewölktem Himmel ein Icon mit einem Mond und Wolken davor.
                          Gibt es diese Möglichkeit hier auch ? Sieht irgendwie komisch aus, wenn Nachts als Symbol eine strahlende Sonne angezeigt wird.
                            andihome last edited by
                            Hallo Leute,
                            Ich bin am verzweifeln und würde mich über Ratschläge freuen.
                            Bei mir aktualisieren sich die Wetterdaten nicht in der VIS.
                            Den richtigen State im Objekt habe ich ausgewählt, im Iobroker zeigt es auch immer die richtigen Werte an aber es wird nicht in die Vis übertragen.
                            Dasselbe Problem habe ich beim Tankstellenwidget mit Tankerkönig Adapter.
                            Die Datenpunkte ändern sich da nur in der Vis wenn ich die Instanz Tankerkönig im Iobroker neu starte bzw. aktualisiere.
                            Werte werden in der Instanz alle 10min. aktualisiert.
                            Habe erst angefangen mit dem IoBroker /Alexa / Sonoff usw. und weiss einfach nicht wo der Fehler ist.
                              dondaik last edited by
                              um die änderungen zu sehen darfst du nicht im editor sein sonderen in der runtime - ansicht
                                Ja das weiss ich.Egal ob auf dem Tablett, Handy oder Laptop, in der Runtime bleiben die Werte fest.
                                  beachten das beide adapter auch lange änderungszeiten haben ? tankerkönig ist da ja gerade auch deswegen in einigen themen "im gespräch"
                                    Die Visualisierung ändert sich selbst nach Wochen nicht von alleine.
                                    Habe alles nach Anleitung gemacht. Die Vis ist lizensiert und alle adapter aktuell.
                                      Welche hast du genommen?
                                        Die iobroker Vis. IP…
                                        • wendy2702
                                          @andihome:
                                          Grüße `
                                          Was soll das bedeuten?
                                          Öffne doch bitte bezüglich deines Aktualisierung Problems ein neues Thema. Scheint ja eher allgemein und nicht nur bei Das Wetter.
                                          • SBorg
                                            Meine sieht nun so aus:
                                            Eben noch eine Sonnenstandsanzeige eingebaut, dann kann der "hässliche" Restlichtbalken unten auch weg 😉
                                            Muss ich mir nur noch etwas mit dem statischen Bild und für "Nacht" einfallen lassen…
                                            1208
                                            413200
