    4. [Adapter] Sonoff- Tasmota
      eMd last edited by
      Kann mir jemand sagen was da mit meinen Sonoff Basic los ist? Ist seit gestern so…
      2019-01-19 16:53:37.218 - warn: sonoff.0 Old client S-Wohnzimmer-Lampe_67171E with secret 1547913166391_3060 sends pingreq. Ignore! Actual secret is 1547913215375_6843
      2019-01-19 16:53:39.873 - info: sonoff.0 Client [S-Willi-Lampe_6B13B3] connection closed: closed
      2019-01-19 16:53:40.767 - info: sonoff.0 Client [S-Willi-Lampe_6B13B3] connected with secret 1547913220766_5656
      2019-01-19 16:54:23.464 - info: radar.0 ScanAll: From all 9 devices dedected 9 are whoHere: Ich, NAS, GigaBlue, CCU2, Kuechenradio, KODIHyperion, MI5, RedMi5, TVWohnzimmer
      2019-01-19 16:54:52.350 - info: sonoff.0 Client [S-Wohnzimmer-Lampe_67171E] connection closed: closed
      2019-01-19 16:55:00.058 - info: host.ioBroker-Tinker instance system.adapter.dwd.0 started with pid 26302
      2019-01-19 16:55:01.004 - info: dwd.0 starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v8.15.0
      2019-01-19 16:55:01.924 - info: host.ioBroker-Tinker instance system.adapter.dwd.0 terminated with code 0 (OK)
      2019-01-19 16:55:03.375 - info: sonoff.0 Client [S-Wohnzimmer-Lampe_67171E] connected with secret 1547913303370_7119
      2019-01-19 16:55:33.838 - info: sonoff.0 Client [S-Wohnzimmer-Lampe_67171E] connection closed: closed
      2019-01-19 16:55:34.374 - info: sonoff.0 Client [S-Wohnzimmer-Lampe_67171E] connected with secret 1547913334373_6455
      2019-01-19 16:55:44.409 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.178.20 vis.0
      2019-01-19 16:55:47.013 - info: sonoff.0 Client [S-Willi-Lampe_6B13B3] connection closed: closed
      2019-01-19 16:55:57.771 - info: sonoff.0 Client [S-Willi-Lampe_6B13B3] connected with secret 1547913357770_3323
      2019-01-19 16:56:45.110 - info: sonoff.0 Client [S-Wohnzimmer-Lampe_67171E] connection closed: closed
      2019-01-19 16:56:54.395 - info: sonoff.0 Client [S-Wohnzimmer-Lampe_67171E] connected with secret 1547913414393_4680
      MfG
      eMd
        eMd last edited by
        Umhängen auf anderen Adapter im anderen Host kommt auf das gleiche Ergebnisse raus… Was kann ich nur machen? Der Lichtschalter blinkt ständig wegen den Fehlern, muss mal die LED abkleben
          JMF90 last edited by
          @danw:
          Ich habe einen Sonoff S20. Wenn ich das Relay schalte und ich danach z.B. die sonoff Instanz neustarte, oder er anderweitig die MQTT Verbindung verliert, ist nach dem Reconnect der Powerstate falsch. Der ist dann anstatt auf true auf false.
          Man muss also dann erst einmal auf true schalten, nix passiert, weil ist ja schon an.
          Oder wenn man ausmachen wollte erst einmal auf an, dann auf aus.
          Was kann ich da tun? `
          Schließe mich diesem Problem an.
          Ich habe das gleiche mit meinen Sonoff Basics und Sonoff Touch.
          • modmax
            modmax last edited by
            Welche Tasmota Firmware-Version und welcher Core?
            Müßte so ähnlich aussehen wie das hier:
            Tasmota Version	6.4.1.4(sonoff)
            Core-/SDK-Version	2_3_0/1.5.3(aec24ac9)
            Die Core Version 2.4.0,2.4.2 oder 2.5.0 macht bei einigen WLAN Routern Probleme, daher ist die 2.3.0 zu bevorzugen;
            die entsprechende BIN muß man aber selber bauen dafür, oder die modifizierte Firmware von Reloxx13 nehmen:
            https://github.com/reloxx13/Sonoff-Tasm … d/releases
            Wenn das alles nicht hilft, dann einmal den Sonoff mit einer 1MB.bin flashen, die alles mit 0 überschreibt,
            und dann eine neue Firmware aufspielen. Evtl. hat sich da was über die Laufzeit der OTA-Updates etwas
            verheddert.
            Bzgl. des AN/AUS-Problems kann ich leider auch nicht viel sagen.
            Wird der POWER-State in der WebAnsicht des Sonoffs nur falsch dargestellt, oder im ioBroker sonoff-Adapter?
            Und was sagt das Kommando "PowerOnState"?
            MfG Markus
              eMd last edited by
              @modmax:
              verheddert.
              MfG Markus `
              Ich hatte vorher die 6.3.0 drauf und habe erst mit den Problemen jetzt auf 6.4.1 geupdated ohne Besserung, werde aber mal den reloox mod ausprobieren… Übernimmt der meine config oder muss ich den sonoff dann erst neu im WLAN anmelden?
              • modmax
                Ich habe den roloxx mod nicht installiert, da ich mir meine Firmware immer selber baue.
                Aber normalerweise sollten die Einstellungen beibehalten werden.
                MfG Markus
                  eMd last edited by
                  @modmax:
                  MfG Markus `
                  Würden beibehalten, und ich habe keine Probleme mehr, danke!
                  • MathiasJ
                    MathiasJ last edited by
                    Gibts das Problem nur mit dem Adapter Sonoff oder auch mit.MQTT?
                    Ich habe ein paar Sonoff zuhause, kam nur nicht dazu diese zu flashen.
                    Den Port für die Sonoff kann nan z.B. suf 1500 ändern? Ich brauche MQTT mit 1883 für etwas anderes.
                    Gruß, Mathias
                    Gesendet von meinem MI 8 mit Tapatalk
                    • MathiasJ
                      @modmax:
                      @ltsalvatore
                      Ich hab es in den letzten Threads nicht gefunden.
                      Wie hast Du denn die Sonoffs geflasht?
                      Per OTA oder Flashprogramm? Mit eigener Firmware oder Standard?
                      Idee wäre von mir nur noch einmal ein leeres BIN-File (1MB) drüber zu flashen, damit der ganze Flash im Sonoff wirklich leer ist.
                      Und dann noch mal deine Firmware aufspielen.
                      Konnte ich bei mir aber auch nicht nachvollziehen …
                      MfG Markus `
                      Wo bekomme ich die leere Firmware her?
                      Könntest Du die hier einstellen, oder eine Quelle nennen?
                      Gruß,
                      Mathias
                      • kmxak
                        Mit esp-tool.py kannst alles löschen.
                        Findest auf github.
                        esptool.py erase_flash
                        Und danach kann man damit auch wieder flashen
                        Gesendet von meinem SM-G930F mit Tapatalk
                          danw last edited by
                          @modmax:
                          verheddert.
                          MfG Markus `
                          Program Version	6.4.1(sonoff)
                          Build Date & Time	2018-12-24T14:41:00
                          Core/SDK Version	2_4_2/2.2.1(cfd48f3)
                          22:45:58 CMD: PowerOnState
                          22:45:58 MQT: stat/sonoff/RESULT = {"PowerOnState":3}
                          Status SonOff korrekt, ioBroker falsch.
                          Wohl wegen folgendem Kommando, was nach Reconnect automatisch abgesetzt wird:
                          22:47:01 MQT: Attempting connection...
                          22:47:01 MQT: Connected
                          22:47:01 MQT: tele/sonoff/LWT = Online (retained)
                          22:47:01 MQT: cmnd/sonoff/POWER =
                          Man kann es sehr einfach simulieren, wenn man die Sonoff Instanz neustartet.
                          • MathiasJ
                            Weiß hier jemand, ob Sonoff das Style der basics geändert hat?
                            ich habe bei 2 verschiedenen Verkäufern die Basic gekauft und vermute, es sind durchwegs Plagiate.
                            Mit den S20 hatte ich keine Probleme, die Basic lassen sich einfach nicht flashen.
                            Gruß,
                            Mathias
                            • modmax
                              @MatthiasJ
                              Ohne Foto der Platine oder Pinbelegung kann man schlecht was sagen, was sich geändert haben könnte …. 🙂
                              Versuchst Du via OTA oder seriellem Flashen?
                              MfG Markus
                              • modmax
                                @danw
                                Hab es nun nachgetestet und Du hast recht.
                                Wenn man den State des Sonoff auf TRUE hat, dann sendet der Reconnect des Sonoffs ein POWER-Command ohne Wert.
                                Das ist dann in JavaScript leer/undefined und wird deswegen wohl als FALSE ausgewertet.
                                DIe Frage ist nur, ob das in Tasmota verkehrt ist oder im Adapter. Ich denke mal an beiden Stellen.
                                Ich schau mal nach, was man da machen kann.
                                MfG Markus
                                • modmax
                                  @danw
                                  Hab mir mal das Repo von ioBroker.sonoff geforkt und dort die nötigen Änderungen gemacht.
                                  Kannst es tesweise erstmal von meinen GitHub-Repo über die Katze von beliebiger URL installieren:
                                  https://github.com/modmax/ioBroker.sonoff
                                  Upload ist hierbei glaube ich nicht nötig; schadet sonst aber auch nicht.
                                  Danach noch die sonoff-Instanz neu starten und die boolean-States sollten korrekt in ioBroker gesetzt werden;
                                  auch nach einem Neustart der sonoff-Instanz.
                                  PullRequest dafür ist erstellt.
                                  MfG Markus
                                  • 1Topf
                                    1Topf last edited by
                                    @MathiasJ:
                                    Weiß hier jemand, ob Sonoff das Style der basics geändert hat? `
                                    Keine Ahnung. Hab vor kurzem 5 Stück in China gekauft, die liesen sich problemlos flashen. Hatte aber vorher noch nie Basics.
                                    Bitte die bunten Drähte wegdenken, bin grad am testen mit Bewegungsmelder. 🙂
                                    • modmax
                                      @1Topf und @MatthiasJ
                                      meine Basics sahen irgendwie anders aus … anscheinend hat sich da inzwischen das Layout etwas geändert.
                                      Solange die Pins (oder besser gesagt die Löcher, wo die Pins rein sollten, wenn da kein Lötzinn drauf wäre)
                                      noch alle beschriftet sind, sollte das per seriellem Flashen auch weiterhin gehen.
                                      MfG Markus
                                      • 1Topf
                                        Da ist nur Lötzinn, weil auf der Oberseite meine eingelöteten Pins sind 8-) . Daneben liegt noch IO2 (blauer Draht). Außerdem gibt es noch 5 weitere Lötpunkte: 3V3, KEY, LED, K_P, GND. Wie gesagt, flashen ging problemlos. Nun müßte man noch die Basics von MathiasJ sehen.
                                        Andi
                                        • MathiasJ
                                          MathiasJ last edited by MathiasJ
                                          Ja, die neuen Sonoff basic haben sich geändert, was ich auf Deinem Bild so sehe.
                                          Ich habe meine Sonoff mal ausgepackt und versucht, diese zu flashen.
                                          Mit der Firmware von http://thehackbox.org/tasmota/release/
                                          ging es, mit meiner kompilierten Firmware mit Atom ging es nicht.
                                          In beiden Fällen bekam ich am Schluß die Meldung, daß beim Verlassen des Flashvorgangs
                                          ein Fehler aufgetreten ist und deshalb der Flashvorgang nicht erfolgreich war.
                                          Beim Flashen mit der Firmware von Jerome HMLOX wurden keine Fehler gemeldet.
                                          Meine "Rollo-Aktoren" bestehend aus den Sonoff Dual werde ich mit HMLOX flashen und per CuxD
                                          in die CCU3 integrieren.
                                          Gruß,
                                          Mathias
                                          • 1Topf
                                            Ich beziehe Tasmota von Github und flashe dann mit ArduinoIDE unter Win10. Geht super.
                                            Andi
                                            720
                                            199100
