    4. Test Adapter SourceAnalytix v0.2.x
    • bahnuhr
      so, 0.2.0 installiert.
      Fehlermeldungen sind weg.
      Objekte vom smartmeter werden angelegt.
      Aber…....
      Ich bekomme jetzt im log Meldungen bzgl. rpi ????
      sourceanalytix.0	2019-01-20 20:29:49.823	info	state : rpi2.0.wlan removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:49.823	info	state : rpi2.0.uptime removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:49.823	info	state : rpi2.0.temperature removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:49.823	info	state : rpi2.0.swap removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:49.823	info	state : rpi2.0.sdcard removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:49.823	info	state : rpi2.0.network removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:49.823	info	state : rpi2.0.memory removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:49.823	info	state : rpi2.0.raspberry removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:49.807	info	state : rpi2.0.cpu removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:39.243	info	state : rpi2.0.wlan removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:39.243	info	state : rpi2.0.uptime removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:39.243	info	state : rpi2.0.temperature removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:39.243	info	state : rpi2.0.swap removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:39.243	info	state : rpi2.0.sdcard removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:39.243	info	state : rpi2.0.network removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:39.243	info	state : rpi2.0.memory removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:39.243	info	state : rpi2.0.raspberry removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:39.227	info	state : rpi2.0.cpu removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:38.641	info	state : rpi2.0.wlan removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:38.641	info	state : rpi2.0.uptime removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:38.641	info	state : rpi2.0.temperature removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:38.641	info	state : rpi2.0.swap removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:38.641	info	state : rpi2.0.sdcard removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:38.641	info	state : rpi2.0.network removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:38.641	info	state : rpi2.0.memory removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:38.641	info	state : rpi2.0.raspberry removed from SourceAnalytix
      sourceanalytix.0	2019-01-20 20:29:38.625	info	state : rpi2.0.cpu removed from SourceAnalytix
      Damit habe ich aber gar nichts gemacht !!
      Und bei den Objekten von rpi sehe ich auch nichts.
      Bitte klären.
      Danke.
      • bahnuhr
        Nachtrag:
        Und diese Meldung erscheint alle paar Sekunden im log.
        • Issi
          Issi Developer last edited by
          @bahnuhr:
          Aber…....
          Bitte klären.
          Danke. `
          das ist bereits bekannt und ist in arbeit
          @Dutchman:
          @Issi:
          ja bei mir auch nicht berechnen tut er sie aber und es kommen bei mir immer solche Meldungen
          sourceanalytix.0	2019-01-20 17:14:57.061	info	state : zigbee.0.00158d000237acf1.no_motion removed from SourceAnalytix
          sourceanalytix.0	2019-01-20 17:14:55.920	info	state : netatmo.0.Büro-Alex.Außensensor removed from SourceAnalytix
          sourceanalytix.0	2019-01-20 17:14:55.889	info	state : netatmo.0.Büro-Alex.Indoor removed from SourceAnalytix
          sourceanalytix.0	2019-01-20 17:14:52.437	info	state : zigbee.0.00124b0018ed36ae.state removed from SourceAnalytix
          sourceanalytix.0	2019-01-20 17:14:52.437	info	state : zigbee.0.00124b0018ed36ae.link_quality removed from SourceAnalytix
          sourceanalytix.0	2019-01-20 17:14:47.033	info	state : zigbee.0.00158d000237acf1.no_motion removed from SourceAnalytix
          sourceanalytix.0	2019-01-20 17:14:37.020	info	state : zigbee.0.00158d000237acf1.no_motion removed from SourceAnalytix
          Danke ! : https://github.com/iobroker-community-a … /issues/26
          hohle ich in 0.2.1 raus `
          setze den Adapter im loglevel auf warn dann siehst du es nicht mehr
          • bahnuhr
            Danke für die Info und deine Arbeit.
            Klasse.
            • bahnuhr
              Nochwas ist mir aufgefallen.
              Wenn man bei den Objekten in die config geht, dann steht wieder alles auf Englisch.
              Also: save und cancel
              mfg
              • Dutchman
                so version 0.2.1 ist released ! :mrgreen:
                • (Dutchman) fix "current_day" missing in object tree
                • (Dutchman) fix log messages "removed from SourceAnalytix"
                • (Dutchman) fix unit issue to support upper and lower case in values
                • (Dutchman) fix unit issue replace strange characters
                • (Dutchman) remove intervall setting from configuraiton screen (handle by state subscribtion now!)
                • (Dutchman) remove start meassurement from state configuraiton screen (not need, please use day start, week start etc !)
                Have Fun !
                Edit : Sorry leider werden die startwerte in 0.2.1 noch nicht richtig Gesetz. Fix kommt im laufe des Tages
                  Just last edited by
                  @Dutchman:
                  Have Fun !
                  Edit : Sorry leider werden die startwerte in 0.2.1 noch nicht richtig Gesetz. Fix kommt im laufe des Tages `
                  Bei mir wurde current day auch bereits unter der 0.2.0 erstellt.
                  Nur leider wurde der Wert Nachts nicht resettet 😕
                  • V
                    vatoslocos last edited by
                    bei mir legt sich der Adapter komplett weg!
                    Jemand eine Idee?
                    host.ioBroker-RasPi	2019-01-21 14:22:14.769	error	Caught by controller[54]: at set_zero_val (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:603:14)
                    host.ioBroker-RasPi	2019-01-21 14:22:14.769	error	Caught by controller[54]: (node:32357) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'val' of null
                    host.ioBroker-RasPi	2019-01-21 14:22:14.769	error	Caught by controller[54]: (node:32357) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by
                    host.ioBroker-RasPi	2019-01-21 14:22:14.769	error	Caught by controller[54]: at process._tickCallback (internal/process/next_tick.js:189:7)
                    host.ioBroker-RasPi	2019-01-21 14:22:14.769	error	Caught by controller[54]: at <anonymous></anonymous>
                    • Dutchman
                      @vatoslocos:
                      Jemand eine Idee? `
                      wan bekommst du diesen Fehler ?
                      • adapter start ?
                      • immer ?
                      • Adapter stop ?
                      • adapter restart
                      und zu letzt welche node version benutzt du ? (auf console node -v)
                      • V
                        immer wenn ich den adapter unter einem Wert aktivieren.
                        Als Beispiel: energyTotal bei einem Sonoff-Object.
                        Danach loggt er sich tot…
                        Node.js: v8.15.0
                        aktuellste GitHuv Version 0.2.1
                          Just last edited by
                          @Just:
                          @Dutchman:
                          Have Fun !
                          Nur leider wurde der Wert Nachts nicht resettet 😕 `
                          Haben andere das selbe Problem, dass current_day nach 24 Uhr einfach weiterzählt?
                          Getestet mit 0.2.0.
                          Mit current_week habe ich das selbe Problem
                          • Homer.J.
                            Homer.J. last edited by
                            @Just:
                            @Just:
                            @Dutchman:
                            Have Fun !
                            Getestet mit 0.2.0.
                            Mit current_week habe ich das selbe Problem `
                            Steht weiter oben soll im laufe des Tages mit Version 0.2.1 behoben sein.
                              Just last edited by
                              @Homer1976:
                              @Just:
                              @Just:
                              Getestet mit 0.2.0.
                              Steht weiter oben soll im laufe des Tages mit Version 0.2.1 behoben sein. `
                              Alles klar, sorry, muss ich wohl übersehen haben.
                              Danke dir!
                              • Dutchman
                                @vatoslocos:
                                Node.js: v8.15.0
                                aktuellste GitHuv Version 0.2.1 `
                                Zeig mal bitte das object von diesem Sonor state (Bleistift => raw data)
                                • V
                                  @Dutchman:
                                  @vatoslocos:
                                  Node.js: v8.15.0
                                  Zeig mal bitte das object von diesem Sonor state (Bleistift => raw data) `
                                  habe mal 0.2.0 kompiliert - da habe ich keine Probleme!
                                    "from": "system.adapter.sonoff.0",
                                    "user": "system.user.admin",
                                    "ts": 1547108461636,
                                    "common": {
                                      "name": "Sonoff-Waschm_Kuehlschrank ENERGY  Total",
                                      "type": "number",
                                      "role": "value.power.consumption",
                                      "unit": "kWh",
                                      "read": true,
                                      "write": false,
                                      "custom": {
                                        "sourceanalytix.0": {
                                          "enabled": true,
                                          "alias": "",
                                          "state_type": "kWh_consumption",
                                          "costs": true,
                                          "consumption": true,
                                          "meter_values": false,
                                          "start_meassure": 0,
                                          "start_day": 0,
                                          "start_week": 0,
                                          "start_month": 0,
                                          "start_quarter": 0,
                                          "start_year": 0
                                    "native": {},
                                    "acl": {
                                      "object": 1636,
                                      "owner": "system.user.admin",
                                      "state": 1636
                                    "_id": "sonoff.0.Sonoff-Waschm_Kuehlschrank.ENERGY_Total",
                                    "type": "state"
                                  • Dutchman
                                    @Just:
                                    Getestet mit 0.2.0.
                                    Ja, wird gefixt in 0.2.2 (innerhalb der niesten 2 Stunden verfügbar), siehe git issue : https://github.com/iobroker-community-a … x/issues/9
                                    • Dutchman
                                      @vatoslocos:
                                      @Dutchman:
                                      @vatoslocos:
                                      Node.js: v8.15.0
                                        "common": {
                                          "type": "number",
                                          "unit": "kWh",
                                          "read": true,
                                          "write": false,
                                          "custom": {
                                              "enabled": true,
                                              "alias": "",
                                              "costs": true,
                                              "start_day": 0,
                                              "start_week": 0,
                                              "start_month": 0,
                                              "start_quarter": 0,
                                              "start_year": 0
                                        "native": {},
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636
                                        "type": "state"
                                      ok … setzte mal bitte in der Konfiguration den Loggin modus auf Entwickler, adapter startet neu bitte komplette log posten.
                                      du hast aber nach er installation von git einen upload ausgeführt ?
                                        darkiop Most Active last edited by
                                        Hallo Dutchman,
                                        bin leider noch nicht dazugekommen im Detail mir das anzuschauen.
                                        Aufgefallen ist mir gestern auf die Schnelle folgendes:
                                        • Du hast die Möglichkeit geschaffen einen Normalstrom-Tarif, einen Nach-Stromtarif und einen Wert für die Produktion anzugeben. Ich hätte noch einen weiteren Vorschlag den hier sicher einige (inklusive mir :)) nutzen: Einen speziellen Tarif für eine Wärmepumpe.
                                        • Getestet habe ich auf die Schnell mit dem Smartmeter Adapter und musste dann im Log feststellen das der Wer "Watt" (noch) nicht unterstützt wird - das hast aber vor oder?
                                        Gruß und einen schönen Abend,
                                        Thorsten
                                          Just last edited by
                                          @darkiop:
                                          Hallo Dutchman,
                                          Thorsten `
                                          Aber warum denn Watt?
                                          Watt ist irrelevant dafür.
                                          Interessant sind die gesamt kWh.
                                            Ahh … Ok. Hab nun auch mein Erfolgserlebnis 🙂
                                            Testdaten werden nun erfasst!
                                            Wert des Energie_Counters in Wh + Anfangswert in den Sourceanalytix Optionen zu dem DP:
                                            Unklar ist sind mir gerade noch die Eingabefelder "Zählerstand bei …" ?
                                            81.1k
                                            adapter test
                                            103
                                            958
                                            282265
