    4. [gelöst] Fehler - HM-RPC läuft plötzlich nicht mehr
    • foxriver76
      Und welche Version von Node hast du drauf?
        skorpil last edited by
        Hier die Versionen….
          Node -v
          8.15.0
          • foxriver76
            Node passt. Ist das Logfile oben mit Rega 2.1.6 entstanden?
              Ja
              • foxriver76
                Hm okay, damit lässt sich leider nix anfangen, in der Zeile steht ne normal Zuweisung. 😐
                   host.raspberrypi	2019-01-21 14:33:05.669	info	Restart adapter system.adapter.hm-rega.0 because enabled
                  host.raspberrypi	2019-01-21 14:33:05.669	error	instance system.adapter.hm-rega.0 terminated with code 1 ()
                  host.raspberrypi	2019-01-21 14:33:05.669	error	Caught by controller[0]: at bootstrap_node.js:625:3
                  host.raspberrypi	2019-01-21 14:33:05.669	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
                  host.raspberrypi	2019-01-21 14:33:05.669	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
                  host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
                  host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                  host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Module.load (module.js:566:32)
                  host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                  host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Module._compile (module.js:617:28)
                  host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
                  host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: at createScript (vm.js:80:10)
                  host.raspberrypi	2019-01-21 14:33:05.668	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                  host.raspberrypi	2019-01-21 14:33:05.667	error	Caught by controller[0]:
                  host.raspberrypi	2019-01-21 14:33:05.667	error	Caught by controller[0]: ����{`��k�LU�����C�a)���t2���d�ݕ�C�H�=J�l��F�s��E�`<��W��7^�A,sNp:0ˬ�B�>����\�S��m&�6�,�;�O�K���y7����˚��_{�S#���!�ل���l�@@�Dz�|�~��RQ�y�P�'�㜜.V�����
                  host.raspberrypi	2019-01-21 14:33:05.667	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:258
                  host.raspberrypi	2019-01-21 14:33:05.334	info	instance system.adapter.hm-rega.0 started with pid 1932
                  host.raspberrypi	2019-01-21 14:32:35.331	info	Restart adapter system.adapter.hm-rega.0 because enabled
                  host.raspberrypi	2019-01-21 14:32:35.331	error	instance system.adapter.hm-rega.0 terminated with code 1 ()
                  host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at bootstrap_node.js:625:3
                  host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
                  host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
                  host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
                  host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                  host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Module.load (module.js:566:32)
                  host.raspberrypi	2019-01-21 14:32:35.330	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                  host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: at Module._compile (module.js:617:28)
                  host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
                  host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: at createScript (vm.js:80:10)
                  host.raspberrypi	2019-01-21 14:32:35.329	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                  host.raspberrypi	2019-01-21 14:32:35.328	error	Caught by controller[0]: ����{`��k�LU�����C�a)���t2���d�ݕ�C�H�=J�l��F�s��E�`<��W��7^�A,sNp:0ˬ�B�>����\�S��m&�6�,�;�O�K���y7����˚��_{�S#���!�ل���l�@@�Dz�|�~��RQ�y�P�'�㜜.V�����
                  host.raspberrypi	2019-01-21 14:32:35.322	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:258
                  host.raspberrypi	2019-01-21 14:32:34.991	info	instance system.adapter.hm-rega.0 started with pid 1926
                  Hier noch einmal ganz aktuell
                    Normale Zuweisung? Verstehe ich nicht.
                    Was musst Du wissen, um helfen zu können? Ich liefere…
                      paul53 last edited by
                      Ich tippe auf eine sich verabschiedende SD Card.
                        Daran hatte ich auch schon gedacht. Kann ich das unter Linux irgendwie testen? Unter Win gibt es ja chkdsk…
                        • foxriver76
                          @paul53:
                          Ich tippe auf eine sich verabschiedende SD Card. `
                          An ein korruptes File System habe ich auch schon gedacht. Allerdings kenne ich mich da leider nicht aus.
                          @skorpil:
                          Was musst Du wissen, um helfen zu können? Ich liefere… `
                          Hier scheint der Fehler seinen Urpsrung zu haben: https://github.com/ioBroker/ioBroker.hm … ga.js#L258 und das macht für mich keinen Sinn
                            @skorpil:
                            Kann ich das unter Linux irgendwie testen? `
                            Da kenne ich mich leider auch nicht aus.
                            Ich würde die Datei /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js mit WinSCP auf den PC kopieren, mit Notepad++ öffnen und das Umfeld von Zeile 258 ansehen.
                              So, jetzt der Hammer: auch das Backup macht den gleichen Fehler.
                              ! host.raspberrypi 2019-01-21 15:04:11.670 info Restart adapter system.adapter.hm-rpc.0 because enabled
                              ! host.raspberrypi 2019-01-21 15:04:11.669 error instance system.adapter.hm-rpc.0 terminated with code 1 ()
                              ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at bootstrap_node.js:625:3
                              ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at startup (bootstrap_node.js:204:16)
                              ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
                              ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
                              ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                              ! host.raspberrypi 2019-01-21 15:04:11.669 error Caught by controller[0]: at Module.load (module.js:566:32)
                              ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                              ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at Module._compile (module.js:653:30)
                              ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:1634:5)
                              ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:606:15)
                              ! host.raspberrypi 2019-01-21 15:04:11.668 error Caught by controller[0]: TypeError: utils.Adapter is not a constructor
                              ! host.raspberrypi 2019-01-21 15:04:11.667 error Caught by controller[0]: ^
                              ! host.raspberrypi 2019-01-21 15:04:11.667 error Caught by controller[0]: adapter = new utils.Adapter(options);
                              ! host.raspberrypi 2019-01-21 15:04:11.664 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:606
                              ! host.raspberrypi 2019-01-21 15:04:11.305 info instance system.adapter.hm-rpc.0 started with pid 1408</anonymous>
                              Ich verstehe gerade die Welt nicht mehr…
                                @skorpil:
                                auch das Backup macht den gleichen Fehler. `
                                hm-rpc ist nicht hm-rega.
                                  Das stimmt.
                                  Also, zur Klarheit: RPC läuft nicht. Warum ich eben und auch im Titel über rega gesprochen habe… ich bin verwirrt. Sorry
                                    ich habe unter windows und virtual dub noch eine iobroker Installation, die ich gelegentlich zum Testen nutze. Die habe ich gerade gestartet. Und, hier läuft die rpc Instanz. Damit kann ich nun mindestens ausschließen, dass das Problem nicht in der CCU liegt
                                      @skorpil:
                                      Warum ich eben und auch im Titel über rega gesprochen habe… ich bin verwirrt. `
                                      Weil die Fehlermeldung sich auf die Datei /opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js bezog.@skorpil:
                                      • foxriver76
                                        Jetzt ist es ja hm-rpc. Installier den mal neu.
                                          so, jetzt kann ich mindestens das Missverständnis aufklären (ich dachte schon, ich spinne):
                                          • in der aktuellen Version funktioniert REGA nicht
                                          • im backup läuft RPC nicht
                                          Ich verzweifele
                                            @foxriver
                                            den mal neu heißt löschen und neu installieren???????
                                            1.2k
                                            81.1k
                                            1607
