    4. Konvertierung von Zeichenkette nach Zahl?
    • X
      xbow42 last edited by
      schön dass es jetzt klappt!
      Um Blocky und js besser zu lernen habe ich mal versucht den Wert "Total_in" einzeln heraus zu kitzeln.
      Kann mir wer sagen warum die slice()-Funktion nicht funktioniert von dem Blocklyscript?
      ! <xml 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml">
      ! <block type="variables_set" id="J(;S,}.VY694q:bm7{RX" x="-87" y="13"><field name="VAR">MSG</field>
      ! <value name="VALUE"><block type="text" id="}QR6t|5yHFKulBE3MDg"><field name="TEXT">{"Time":"2019-01-24T19:33:29","SML":{"Total_in":6001.0760,"Total_out":0.1580,"Power_curr":0}}</field></block></value>
      ! <next><block type="variables_set" id="vu_7]U4wBf}NDqfu9k.;"><field name="VAR">Total_In_Anfang</field>
      ! <value name="VALUE"><block type="math_arithmetic" id="lZ*9j-Z7ry#|Dv@~qA@"><field name="OP">ADD</field> ! <value name="A"><shadow type="math_number" id="gt9WUG(t6ie[i0tKU2#{"><field name="NUM">1</field></shadow> ! <block type="text_indexOf" id="Fzr9Z_.VcNYSKogLRSW"><field name="END">FIRST</field>
      ! <value name="VALUE"><block type="variables_get" id="Y0[TCzK(_u,bbEwq6zkY"><field name="VAR">MSG</field></block></value>
      ! <value name="FIND"><shadow type="text" id="USy|6K2qk[Fo[GSXW;Ni"><field name="TEXT">Total_in</field></shadow></value></block></value>
      ! <value name="B"><shadow type="math_number" id="6dYrhU.Q+JCq,BiN4+"><field name="NUM">10</field></shadow></value></block></value>
      ! <next><block type="debug" id=".jvcF-W){%M[ioY}BX2s"><field name="Severity">log</field>
      ! <value name="TEXT"><shadow type="text" id="tl@EmOKRb!@{/qFiYavJ"><field name="TEXT">test</field></shadow>
      ! <block type="text_join" id="kDzGc/=@fs.;[1+x
      {W."><mutation items="2"></mutation>
      ! <value name="ADD0"><block type="text" id="0amyFZF@:-}un:C/}Ap9"><field name="TEXT">Total_in Anfang:</field></block></value>
      ! <value name="ADD1"><block type="variables_get" id=")#lY-5faPghWkOLQJOr}"><field name="VAR">Total_In_Anfang</field></block></value></block></value>
      ! <next><block type="variables_set" id="bH=X:.FnyZcLxbc4Gxu"><field name="VAR">MSG_temp</field>
      ! <value name="VALUE"><block type="text_getSubstring" id="b-}pQm]p1~{.+
      -n^z3w"><mutation at1="true" at2="true"></mutation>
      ! <field name="WHERE1">FROM_START</field>
      ! <field name="WHERE2">FROM_START</field>
      ! <value name="STRING"><block type="variables_get" id="I6Dj7iz4mGByHiGof]"><field name="VAR">MSG</field></block></value>
      ! <value name="AT1"><block type="variables_get" id="BTh9Y{g4GxjmywWlS?S_"><field name="VAR">Total_In_Anfang</field></block></value>
      ! <value name="AT2"><block type="text_length" id="3yNvV@(z!V2eu[PGJkV"><value name="VALUE"><shadow type="text" id="jEc3oYD0^{g~aWOoiyd"><field name="TEXT">abc</field></shadow> ! <block type="variables_get" id="ERMT^T1e-_Z2qF~^asqR"><field name="VAR">MSG</field></block></value></block></value></block></value> ! <next><block type="debug" id="n^a!SA,R;N2mtW%Y!FGx"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id="tl@EmOKRb!@{/qFiYavJ"><field name="TEXT">test</field></shadow> ! <block type="text_join" id="*^t{*5(L{8P0_0OLX=[J"><mutation items="2"></mutation> ! <value name="ADD0"><block type="text" id="2YcYNZt}@JVua}qe:[H!"><field name="TEXT">msg_temp:</field></block></value> ! <value name="ADD1"><block type="variables_get" id="l]^}U=9nv}H2=4j0ZYE"><field name="VAR">MSG_temp</field></block></value></block></value>
      ! <next><block type="variables_set" id="3T;;^[khXtinCJMhQ7A"><field name="VAR">Total_In_Ende</field>
      ! <value name="VALUE"><block type="math_arithmetic" id="Y)|^oQ}myYr9z2{Y=Ac"><field name="OP">MINUS</field> ! <value name="A"><shadow type="math_number" id="gt9WUG(t6ie[i0tKU2#{"><field name="NUM">1</field></shadow> ! <block type="text_indexOf" id="[}N#SvlVd/Wn%4UPRAk"><field name="END">FIRST</field>
      ! <value name="VALUE"><block type="variables_get" id="VL9+#!QZjT6J^R+ieH+?"><field name="VAR">MSG_temp</field></block></value>
      ! <value name="FIND"><shadow type="text" id="y0~a)00,%78~dWt
      |WF+"><field name="TEXT">,</field></shadow></value></block></value>
      ! <value name="B"><shadow type="math_number" id="Y4=}S=KwfSy)mx:f*O^c"><field name="NUM">1</field></shadow></value></block></value>
      ! <next><block type="debug" id="uetZ4+!2o~l/MYdRS]I["><field name="Severity">log</field>
      ! <block type="text_join" id="|(w.-P{}EP,Xg8u+^pFq"><mutation items="3"></mutation>
      ! <value name="ADD0"><block type="text" id="O#T[mg/@6]x24QAS;3"><field name="TEXT">total_in_ende:</field></block></value>
      ! <value name="ADD1"><block type="variables_get" id="g1Xk|JjJx0?Ed2oYvS?w"><field name="VAR">Total_In_Ende</field></block></value>
      ! <value name="ADD2"><block type="variables_get" id="D13lawug2;^NsIx?u{1)"><field name="VAR">MSG</field></block></value></block></value>
      ! <next><block type="variables_set" id="?1PY=A6,Fyz{*a(Vjs}^"><field name="VAR">Total_In</field>
      ! <value name="VALUE"><block type="convert_tonumber" id="o#N2EfkR^+A(|sMZ60Bv"><value name="VALUE"><block type="text_getSubstring" id="xnDhP9V_E^BDu|!q{0M~"><mutation at1="true" at2="true"></mutation>
      ! <value name="STRING"><block type="variables_get" id="+E|jMCP+AJt}Nw9(c~A
      ! <value name="AT1"><block type="variables_get" id="Nk,YVt?R5vJC2%!ZSdZ"><field name="VAR">Total_In_Anfang</field></block></value> ! <value name="AT2"><block type="variables_get" id="#lv!hlG8nsJdBa;SUb"><field name="VAR">Total_In_Ende</field></block></value></block></value></block></value> ! <next><block type="debug" id=";6og#CF0)(]Rxuv1dfW"><field name="Severity">log</field>
      ! <block type="text_join" id="KR=dUtSffy=D:}Gq8]dr"><mutation items="2"></mutation>
      ! <value name="ADD0"><block type="text" id="1kBDH/HP.tjPp4A._OC2"><field name="TEXT">Total_in ist:</field></block></value>
      ! <value name="ADD1"><block type="variables_get" id="v6Qt]msR*tM.@f1~Ozk4"><field name="VAR">Total_In</field></block></value></block></value></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></xml>
      • a200
        a200 last edited by
        nein, wird nicht aktualisiert.
        dafür musste du folgendes eintragen:
        on({id: "mqtt.0.tele.sonoff.SENSOR", change: "ne"}, function (obj) {
        	inhalt = JSON.parse(getState(id).val);
        	setState("javascript.0.Zählerstand_Haus", parseFloat(inhalt.SML.Total_in), true);
        jetzt wird, bei der Änderung des "mqtt.0.tele.sonoff.SENSOR" der Datenpunkt ausgelesen, verarbeitet und der Total_in Wert wird in "javascript.0.Zählerstand_Haus" geschrieben.
        Ist das das, was du willst?
          baumsass last edited by
          teste ich.
            ja nur mit diesen einen Satz macht IObroker das was ich möchte. Mehr steht jetzt nicht mehr im Script.
            Leider mit falschen Zahlen siehe oben.
            Die Aktualisierung erfolgt sofort.
            in der Ojekt ID der per MQTT kommt steht das in der Beschreibung:
            Zeichenkette
            "sql.0": {
            "enabled": true,
            "changesOnly": true,
            "debounce": 0,
            "maxLength": 10,
            "retention": "63072000",
            "changesRelogInterval": 0,
            "changesMinDelta": 0,
            "storageType": "",
            "aliasId": "StromzählerHaus"
            • a200
              a200 last edited by
              hast du noch eine Quelle, die da rein schreibt. wie man sieht sind die "fremden" Einträge mit Ack False, während unsere true sind.
              Die Quelle ist javascript, Also denke ich, dass du noch ein Skript am Laufen hast, das dir dort die Werte einfügt. Prüfe das mal.
              bis morgen.
              ps. kann es sein, dass in dem mqtt-Objekt mehrere Einträge mit "Total_in" gibt. Dann musst du [0] einfügen.
              setState("javascript.0.Zählerstand_Haus", parseFloat(inhalt.SML.Total_in[0]), true);
              oder mehrere SML Blöcke, dann;
              setState("javascript.0.Zählerstand_Haus", parseFloat(inhalt.SML[0].Total_in), true);
              Schick mir den gesamten Inhalt des MQTT-Datenpunktes.
                Du hattest recht da hat was anderes reingeschrieben war aber mein Fehler beim kopieren….
                Das Skript sieht jetzt so aus
                var inDP = "mqtt.0.tele.sonoff.SENSOR"; // Hier den Pfad zu deinem MQTT Datenpunkt angeben!
                var inhalt = getState(inDP).val;
                inhalt = JSON.parse(inhalt);
                var a = inhalt.Time;
                var b = inhalt.SML.Total_in;
                var c = inhalt.SML.Total_out;
                var d = inhalt.SML.Power_curr;
                log("Time = " + a);
                log("Total In = " + b);
                log("Total Out = " + c);
                log("Power = " + d);
                var ZaehlerstandDP = "javascript.0.Zählerstand_Haus"; // Dein ZielDatenpunkt
                setState(ZaehlerstandDP, b, true);
                var ZaehlerstandDP = "javascript.0.Zählerstand_PV"; // Dein ZielDatenpunkt
                setState(ZaehlerstandDP, c, true);
                leider wird aes immer nur einmal abgearbeitet… nur wenn ich das script neu starte.
                • a200
                  a200 last edited by
                  @baumsass:
                  log("Time = " + a);
                  mach folgendes:
                     setState("javascript.0.Zählerstand_PV", parseFloat(inhalt.SML.Total_Out), true);
                  mehr brauchst du nicht. Mit deinem Skript hast du die beide Werte mehrmals in den Datenpunkt geschrieben. Wenn das nicht hilft, dann brauche ich einen kompletten Eintrag aus mqtt.0.tele.sonoff.SENSOR um die Datenstruktur zu sehen.
                    leider funktioniert das nicht.
                    habe jetzt nur dein Script da drin.
                    • a200
                      a200 last edited by
                      @baumsass:
                      habe jetzt nur dein Script da drin. `
                      Ich kann dir nicht helfen, wenn du mir nicht den Inhalt deines Inputsobjekts zeigst.
                        reicht dir das :?: Sorry screenshot vom handy… bin noch auf Arbeit
                        {"Time":"2019-01-25T13:12:31","SML":{"Total_in":6021.8000,"Total_out":0.1580,"Power_curr":0}}
                        War der Letyte Eintrag
                        • a200
                          a200 last edited by
                             inhalt = JSON.parse(getState("mqtt.0.tele.sonoff.SENSOR").val);				// Diese Zeile wurde geändert!
                          Versuchs mal damit!
                            paul53 last edited by
                            Besser so:
                            on("mqtt.0.tele.sonoff.SENSOR", function (obj) {
                               inhalt = JSON.parse(obj.state.val);
                               setState("javascript.0.Zählerstand_Haus", inhalt.SML.Total_in, true);
                               setState("javascript.0.Zählerstand_PV", inhalt.SML.Total_out, true);
                              scheint zu funktionieren ich beobachte und Berichte morgen!!!
                              DANKE DANKE DANKE!
                                Eins noch…. was ich per Blocky nie hinbekommen habe.
                                Wie ziehe ich zb von einen aktuellen Datenpunkt(Zahl) einen in der Vergangenheit liegenden Datenpunkt ab? (zb Zählerstand aktuell-Zählerstand Vorletzter Wert oder Letzte Wert)
                                • a200
                                  a200 last edited by
                                  @baumsass:
                                  Wie ziehe ich zb von einen aktuellen Datenpunkt(Zahl) einen in der Vergangenheit liegenden Datenpunkt ab? (zb Zählerstand aktuell-Zählerstand Vorletzter Wert oder Letzte Wert) `
                                  Schau dir mal den Adapter an: viewtopic.php?f=36&t=20897 an. Wenn du den auf deine Verbrauchsdatenpunkte setzt, dann bekommst du automatisch eine Statistik.
                                    Der Adapter ist zwar toll aber ich würde mich freuen wenn mir einer helfen könnte das in Blocky oder Javascript zu machen.
                                    Achso @paul53 das anderfunktioniert wie erwartet!!! toll danke
                                    • a200
                                      a200 last edited by
                                      @baumsass:
                                      Achso @paul53 das anderfunktioniert wie erwartet!!! toll danke `
                                      Wenn du was als js haben willst, dann das hier: viewtopic.php?f=21&t=5251. Ist von mir. Du musst nur als
                                      var idHAGTotal = "javascript.0.Zählerstand_Haus";
                                      setzen. Vorher lesen. denn der erster Stundenwert, erst nach einer Stunde, der Tageswert erst morgen usw kommt.
                                        danke sehr super!!!
                                          Noch besser wäre für mich aber wirklich Zählerstand aktuelle Werst -Zählerstand letzter Wert.
                                          Kann das jemand per Javascript oder per Blocky? Blocky wäre noch besser damit ich daran weitermachen kann.
                                          Habe mittlerweile alles per Blocky durch und nichts funktioniert ….
                                            jemand ne Idee`?
                                            4366
