    4. Neuer Adapter: Yamaha MusicCast
      StefanWa last edited by
      Hallo
      als erstes solltest du mal in auf der Seite für die Adaptereinstellungen auf den button "JSON for developer" drücken.
      ==> schicke ich per PN da es relativ viel ist.
      Die anderen Dinge schreibe ich hier direkt rein obwohl es sehr viel ist. Hilf vielleicht auch jemand anderes.
      http://192.168.1.102/YamahaExtendedCont … eviceInfos
      -> nimmt Verbindung mit Gerät auf und zeigt ein paar Eigenschaften
      ==> {"response_code":3}
      http://192.168.1.102/YamahaExtendedCont ... r?power=on
      ==> funktioniert
      http://192.168.1.102/YamahaExtendedCont ... PresetInfo
      ==> {"response_code":4}
      http://192.168.1.102/YamahaExtendedCont ... d=fm&num=1
      ==> schaltet die Favoriten bei Radio / FM um, also dieser Befehl funktioniert 😄
      {"response_code":0,"preset_info":[{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""}],"func_list":["clear","move"]}
      {"response_code":0}
      http://192.168.1.102/YamahaExtendedCont … main&num=1
      -> in der Hoffnung es gibt einen ersten abgesicherten Netzsender, dann sollte der jetzt laufen
      ==> leider nicht 😞
      Wenn du über vis schaltest, dann sollte im log etwas stehen a la "MusicCast: ...1 identified for command with ...2"
      ...1 ist die Funktion auf den der Befehl rausgehen soll
      ...2 ist der Wert der versucht wird zu schicken
      musiccast.0 2019-01-19 08:28:52.668 debug device with uid = 0DA87303
      musiccast.0 2019-01-19 08:28:52.668 info MusicCast: musiccast.0.RX-D485_0DA87303.netusb.presetrecallnumber identified for command with 3
      musiccast.0 2019-01-19 08:28:52.668 debug stateChange musiccast.0.RX-D485_0DA87303.netusb.presetrecallnumber {"val":3,"ack":false,"ts":1547882932651,"q":0,"from":"system.adapter.web.0","lc":15
      PS Und das ganze hatte ich schon einmal getippt, aber dann hat mich die Seite wegen timeout rausgeschmissen :evil:
      ==> kenne ich, ist mir auch schon als passiert, ist total :evil: :evil: :evil: :twisted: :twisted: :twisted: Danke für´s nochmal tippen!!!
      So wie es ausschaut funktionieren die Favoriten im Radio / FM Mode und nicht in Radio / DAB wie auch bei Netradio
      ==> funktioniert
      ==> funktioniert nicht
      Stefan
        foxthefox Developer last edited by
        @StefanWa:
        Hallo
        ==> {"response_code":3} `
        War Schreibfehler meinerseits
        http://192.168.1.102/YamahaExtendedCont … DeviceInfo
        -> sollte jetzt gehen
        ` > http://192.168.1.102/YamahaExtendedCont … PresetInfo
        ==> {"response_code":4} `
        http://192.168.1.102/YamahaExtendedCont … fo?band=fm
        oder
        http://192.168.1.102/YamahaExtendedCont ... o?band=dab
        -> sollte jetzt die abgespeicherten Favoriten bringen (mindestens FM)
        http://192.168.1.102/YamahaExtendedCont ... main&num=1
        ==> leider nicht 😞 `
        Das hier ist schon eher schwierig. Also ich gehe noch davon aus, daß du unter Favoriten nichts abgespeichert hast. Da die Liste quasi leer ist, funktioniert auch der Aufruf des ersten Favoriten nix.
        Schau bitte in der MusicCast App was da so drin ist.
        Bei mir sieht es so aus:
        und bringt die Response:
        {"response_code":0,"preset_info":[{"input":"unknown","text":""},{"input":"net_radio","text":"rbb radioeins","attribute":0},{"input":"net_radio","text":"Antenne Thüringen 97.9 FM","attribute":0},{"input":"net_radio","text":"ANTENNE THÜRINGEN 80-er Channel","attribute":0},{"input":"net_radio","text":"1LIVE","attribute":0},{"input":"net_radio","text":"BBC Radio 2","attribute":0},{"input":"net_radio","text":"Deutschlandfunk","attribute":0},{"input":"net_radio","text":"Electronic Beats Berlin laut.fm","attribute":0},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""},{"input":"unknown","text":""}],"func_list":["clear","move"]}
        Wenn du etwas in den Favoriten der App siehst und nix im Response kommt, dann hab ich keinen Plan wie man da ran kommt.
        ` > So wie es ausschaut funktionieren die Favoriten im Radio / FM Mode und nicht in Radio / DAB wie auch bei Netradio
        Stefan `
        Bei DAB ist in dem Aufruf auch ?band=dab zu verwenden (anstatt ?band=fm). Funktioniert aber auch nur dann wenn DAB Favoriten hat.
        An dem Fehler mit dem pull down Menü für reset muss ich ggf. noch nach etwas anderen schauen. Evtl. baue ich die low-level API um, damit der leidige Offset zwischen Listenindex und Kommando wegfällt.
        Klaus
          @sigi234:
          Noch immer dieser Fehler:
          Screenshot (1600).png `
          Sollte jetzt gelöst sein, mit der neuen 0.1.0 des Adapters kommt auch die Korrektur des widget mit.
          Dazu ggf den Befehl sudo ./iobroker upload musiccast absetzen
          Klaus
            @foxthefox:
            @sigi234:
            Klaus `
            Ich Danke dir….......... 😄
              Problem gelöst 🙂 🙂
              Das testen mit dem Musiccast hat die Lösung gebracht, es gibt wohl zwei Arten von Favoriten :mrgreen:
              und es muss zu "Favoriten" rein.
              So schaut es bei mir aus 😮
              Danke für die tolle Unterstützung.
              Stefan
              • bahnuhr
                Hallo Stefan,
                view sieht klasse aus.
                Würdest du diese zur Verfügung stellen?
                mfg
                Dieter
                  @bahnuhr:
                  Hallo Stefan,
                  mfg
                  Dieter `
                  Gerne 🙂
                  3744_yamaha.txt
                  Stefan
                  • bahnuhr
                    wie heißt denn der http Befehl um eine mp3 abzuspielen.
                    mfg
                    Dieter
                    • bahnuhr
                      <u>BUG gefunden !!</u>
                      Ich habe einen neuen AV Receiver (RX-V685) und der ist im MC Adapter eingebunden.
                      Daneben habe ich mir einen neuen Mussiccast 20 Lautsprecher gekauft; und diese ebenfalls eingebunden.
                      Sieht dann so aus:
                      Dann habe ich in VIS eine View gebastelt, diese sieht so aus:
                      Die widgets fangen im Wohnzimmer z.B. mit:
                      musiccast.0.RX-V685_0DA87303.netusb…..
                      an und im Schlafzimmer logischerweise mit:
                      musiccast.0.WX-021_0DA87303.netusb....
                      widget wohnzimmer, z.B. (jqui-select value list)
                      Wenn ich nun im Wohnzimmer einen Favorit raussuche, schaltet der Receiver auf net und der Favorit wird abgespielt.
                      Wenn ich aber im Schlafzimmer das widget anklicke und einen Sender auswähle, schaltet der Sender im Wohnzimmer um !!!!
                      Mache ich etwas falsch oder ist dies tatsächlich ein bug.
                      mfg
                      Dieter
                      P.S.:
                      Wenn ich per Handy MC app schalte, dann funktioniert alles einwandfrei.
                        @bahnuhr:
                        Sieht dann so aus:
                        filename="bild1.JPG" index="2">~~
                        filename="bild2.JPG" index="1">~~
                        filename="bild3.JPG" index="0">~~
                        mfg
                        Dieter
                        P.S.:
                        Wenn ich per Handy MC app schalte, dann funktioniert alles einwandfrei. `
                        Hallo Dieter
                        Ist es wirklich so, dass die beide Geräte die gleiche ID mit 0DA87303 haben? Ich schicke heute Abend mal ein paar Befehle um das näher abzuprüfen.
                        Noch eine Anmerkung, im zweiten Bild sagst du es wären die Settings vom Wohnzimmer, aber es ist der datenpunkt vom Schlafzimmer.
                        Klaus
                        • bahnuhr
                          zu ID
                          wurde so vom Adapter erkannt.
                          Dein 2.Satz versteh ich jetzt nicht.
                          Im oberen Teil (Wohnzimmer) hab ich die widget angepasst an den av receiver.
                          Im unteren Teil (Schlafzimmer) entsprechend.
                          mfg
                          P.S.
                          Danke vorab für deine Hilfe.
                            @bahnuhr:
                            zu ID
                            mfg
                            P.S.
                            Danke vorab für deine Hilfe. `
                            Zu meinem unverständlichen Satz. Das 3te Bild hat die Überschrift Wohnzimmer, aber in Object-ID ist WX-021… drin.
                            Dies wäre dann entweder die falsche Überschrift oder der falsche Datenpunkt.
                            Bitte mal im Browser deiner Wahl dies beiden Adressen ausführen und den zurückgekommenen Text posten:
                            http://192.168.243.80/YamahaExtendedCon ... DeviceInfo
                            http://192.168.243.81/YamahaExtendedCon ... DeviceInfo
                            Wenn es wirklich so ist, daß es 2 gleiche IDs gibt, dann versagt meine Identifizierung welches Gerät gerade gemeint ist.
                            Klaus
                            • bahnuhr
                              Ja, Überschrift war falsch. Widgets passen.
                              Und nun die Ergebnisse:
                              {"response_code":0,"model_name":"RX-V685","destination":"G","device_id":"4C1B86A6CBF5","system_id":"0DA87303","system_version":1.47,"api_version":2.02,"netmodule_generation":2,"netmodule_version":"0502    ","netmodule_checksum":"BB1E23E6","serial_number":"Y459229YO","category_code":1,"operation_mode":"normal","update_error_code":"00000000"}
                              und
                              {"response_code":0,"model_name":"WX-021","destination":"G","device_id":"946AB093F174","system_id":"0DA87303","system_version":1.54,"api_version":2.02,"netmodule_generation":2,"netmodule_version":"0503    ","netmodule_checksum":"15ECEF06","serial_number":"Z224608TV","category_code":6,"operation_mode":"normal","update_error_code":"00000000"}
                              • bahnuhr
                                Könnte man nicht die device ID nehmen, anstatt der system id.
                                mfg
                                Dieter
                                Noch ne Frage:
                                Hast du einen api Befehl, wie man eine bestimmte mp3 auf dem server abspielen kann.
                                Dann schreib ich mir ein eigenes Script.
                                • bahnuhr
                                  oder auch die serial number
                                  Diese ist auch unterschiedlich.
                                    @bahnuhr:
                                    mfg
                                    Dieter
                                    Noch ne Frage:
                                    Dann schreib ich mir ein eigenes Script. `
                                    Ich glaube du solltest Lotto spielen [emoji848] bei so einem Treffer.
                                    Du könntest versuchen die id in der Tabelle zu ändern. Dann sollte der Adapter ein neues Gerät anlegen und dann nimmst du dessen Datenpunkte in vis. Die dann hinfällige Struktur kannst du dann löschen.
                                    Ursache ist die gerätesuche, die liefert nicht alle id's, sondern nur sehr begrenzte Info.
                                    Wenn ich den Befehl für mp3 Abspielen kennen würde, dann hätte ich sayit schon integriert. Gibt es wahrscheinlich nicht.
                                    Klaus
                                    • bahnuhr
                                      @foxthefox:
                                      Wenn ich den Befehl für mp3 Abspielen kennen würde, dann hätte ich sayit schon integriert. Gibt es wahrscheinlich nicht. `
                                      Doch, das geht.
                                      Bin gerade am rumspielen mit der "Yamaha Extended Control API Specification (Basic)"
                                      Ich verweise mal auf das Beispiel ab Seite 53.
                                      Das einzige was noch nicht klappt, ist:
                                      192.168.243.81/YamahaExtendedControl/v1/main/setInput?input=server&mode=autoplay_disabled
                                      Konkret:
                                      disabled wird noch ignoriert.
                                      Vielleicht hast du da eine Lösung für mich.
                                      mfg
                                      Dieter
                                      1540_yxc_api_spec_basic.pdf
                                      • bahnuhr
                                        @foxthefox:
                                        Du könntest versuchen die id in der Tabelle zu ändern. Dann sollte der Adapter ein neues Gerät anlegen und dann nimmst du dessen Datenpunkte in vis. Die dann hinfällige Struktur kannst du dann löschen. `
                                        Genau das hat geklappt.
                                        Super, danke schön für den Tipp.
                                        mfg
                                        Dieter
                                          @bahnuhr:
                                          @foxthefox:
                                          mfg
                                          Dieter `
                                          Hallo Dieter,
                                          na das ist ja super. Ich werde erstmal nix ändern, wenn nochmal ein solcher Fall auftritt, dann kann man es wieder über das Forum lösen.
                                          Ich werde mal noch einen Eintrag im Adapter machen.
                                          Klaus
                                            @bahnuhr:
                                            @foxthefox:
                                            Doch, das geht.
                                            Konkret:
                                            mfg
                                            Dieter `
                                            Hallo Dieter,
                                            und genau das ist ja das Problem.
                                            Das Beispiel beschreibt meiner Meinung nach das Browsing durch eine Dateistruktur des USB Sticks und weil die Funktion nicht für server vorgesehen ist, geht auch das auch nicht. Ich kann mich komplett irren und es geht doch irgendwie.
                                            Meine Idee zum Abspielen bisher war:
                                            1. DLNA-Server o.ä. ist unter Favoriten abgespeichert
                                            2. Man ruft genau diesen Favoriten auf
                                            3. An einer bestimmten Stelle liegt z.B. die Ansage.mp3 und man kennt den Index
                                            4. Man setzt das Abspielen auf genau diese Index
                                            Ich hatte noch nicht genügend Zeit zum rumexperimentieren. Wenn du auf irgendeine Weise ein Vorgangsweise gefunden hast, dann übernehme ich es gerne in den Adapter.
                                            Wäre super.
                                            Klaus
                                            musiccast yamaha
                                            44
                                            385
                                            92119
