    3. Cloud Dienste
    4. Alexa Anbindung ohne Cloud und Skill
      aldoa1 last edited by
      habe nach Anleitung von Seite 1 node-red installiert
      Konnte auch über 1880 starten und einen ersten Test an Alexa senden.
      Nun steht plötzlich die Instanz auf rot und kann nicht mehr starten.
      host.iobroker 2019-01-22 23:56:02.046 info Restart adapter system.adapter.node-red.0 because enabled
      host.iobroker 2019-01-22 23:56:02.046 error instance system.adapter.node-red.0 terminated with code 0 (OK)
      host.iobroker 2019-01-22 23:56:02.046 error Caught by controller[0]: filename: '/opt/iobroker/iobroker-data/node-red/flows.json' }
      host.iobroker 2019-01-22 23:56:02.046 error Caught by controller[0]: syscall: 'watch /opt/iobroker/iobroker-data/node-red/flows.json',
      host.iobroker 2019-01-22 23:56:02.046 error Caught by controller[0]: errno: 'ENOSPC',
      host.iobroker 2019-01-22 23:56:02.046 error Caught by controller[0]: code: 'ENOSPC',
      host.iobroker 2019-01-22 23:56:02.046 error Caught by controller[0]: at FSReqWrap.cb [as oncomplete] (fs.js:259:19)
      host.iobroker 2019-01-22 23:56:02.046 error Caught by controller[0]: at /opt/iobroker/node_modules/fs.notify/node_modules/async/lib/async.js:233:17
      host.iobroker 2019-01-22 23:56:02.045 error Caught by controller[0]: at /opt/iobroker/node_modules/fs.notify/node_modules/async/lib/async.js:94:25
      host.iobroker 2019-01-22 23:56:02.045 error Caught by controller[0]: at /opt/iobroker/node_modules/fs.notify/node_modules/async/lib/async.js:236:13
      host.iobroker 2019-01-22 23:56:02.045 error Caught by controller[0]: at /opt/iobroker/node_modules/fs.notify/notify.js:45:11
      host.iobroker 2019-01-22 23:56:02.045 error Caught by controller[0]: at Array.forEach (native)
      host.iobroker 2019-01-22 23:56:02.045 error Caught by controller[0]: at Notify.watch (/opt/iobroker/node_modules/fs.notify/notify.js:102:42)
      host.iobroker 2019-01-22 23:56:02.045 error Caught by controller[0]: at Object.fs.watch (fs.js:1478:11)
      host.iobroker 2019-01-22 23:56:02.045 error Caught by controller[0]: at FSWatcher.start (fs.js:1451:19)
      host.iobroker 2019-01-22 23:56:02.044 error Caught by controller[0]: at exports._errnoException (util.js:1020:11)
      host.iobroker 2019-01-22 23:56:02.044 error auf rot und ich kann ihn nicht mehr starten.
        apollon77 last edited by
        ENOSPC = Platte/SD-Karte voll
          Wenn ich den node-red Datenordner lösche und eine neue node-red Instanz erstelle, funktioniert es wieder.
          Wenn ich dann einen neuen Flow erstelle und auf Deploy drücke, ist die Verbindung wieder weg und kann node-red nicht mehr starten.
            Du hast meinen letzten Post gelesen?
            Was sagt denn "df -H" an der Kommandozeile
              Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
              none 3,0T 1,8T 1,2T 60% /
              tmpfs 4,2G 0 4,2G 0% /dev
              tmpfs 4,2G 0 4,2G 0% /sys/fs/cgroup
              /dev/vg1000/lv 3,0T 1,8T 1,2T 60% /opt/iobroker
              shm 68M 0 68M 0% /dev/shm
              tmpfs 4,2G 0 4,2G 0% /sys/firmware
              Warum ist da 0%? Muss ich die Pfade ändern? Wenn ja, wie? Auf der Synology ist ja noch 1,8TB frei.
              Iobroker läuft mit Docker.
                Ok, platz sollte genug sein 🙂 Was ist denn jetzt die Fehlermeldung im Log?
                  @apollon77:
                  Ok, platz sollte genug sein 🙂 Was ist denn jetzt die Fehlermeldung im Log? `
                  Der Log:
                  host.iobroker 2019-01-23 11:11:38.129 info Restart adapter system.adapter.node-red.0 because enabled
                  host.iobroker 2019-01-23 11:11:38.129 error instance system.adapter.node-red.0 terminated with code 0 (OK)
                  host.iobroker 2019-01-23 11:11:38.129 error Caught by controller[0]: filename: '/opt/iobroker/iobroker-data/node-red/flows.json' }
                  host.iobroker 2019-01-23 11:11:38.129 error Caught by controller[0]: syscall: 'watch /opt/iobroker/iobroker-data/node-red/flows.json',
                  host.iobroker 2019-01-23 11:11:38.129 error Caught by controller[0]: errno: 'ENOSPC',
                  host.iobroker 2019-01-23 11:11:38.129 error Caught by controller[0]: code: 'ENOSPC',
                  host.iobroker 2019-01-23 11:11:38.128 error Caught by controller[0]: at FSReqWrap.cb [as oncomplete] (fs.js:259:19)
                  host.iobroker 2019-01-23 11:11:38.128 error Caught by controller[0]: at /opt/iobroker/node_modules/fs.notify/node_modules/async/lib/async.js:233:17
                  host.iobroker 2019-01-23 11:11:38.128 error Caught by controller[0]: at /opt/iobroker/node_modules/fs.notify/node_modules/async/lib/async.js:94:25
                  host.iobroker 2019-01-23 11:11:38.128 error Caught by controller[0]: at /opt/iobroker/node_modules/fs.notify/node_modules/async/lib/async.js:236:13
                  host.iobroker 2019-01-23 11:11:38.126 error Caught by controller[0]: at /opt/iobroker/node_modules/fs.notify/notify.js:45:11
                  host.iobroker 2019-01-23 11:11:38.126 error Caught by controller[0]: at Array.forEach (native)
                  host.iobroker 2019-01-23 11:11:38.126 error Caught by controller[0]: at Notify.watch (/opt/iobroker/node_modules/fs.notify/notify.js:102:42)
                  host.iobroker 2019-01-23 11:11:38.126 error Caught by controller[0]: at Object.fs.watch (fs.js:1478:11)
                  host.iobroker 2019-01-23 11:11:38.126 error Caught by controller[0]: at FSWatcher.start (fs.js:1451:19)
                  host.iobroker 2019-01-23 11:11:38.125 error Caught by controller[0]: at exports._errnoException (util.js:1020:11)
                  host.iobroker 2019-01-23 11:11:38.124 error Caught by controller[0]: { Error: watch /opt/iobroker/iobroker-data/node-red/flows.json ENOSPC
                  host.iobroker 2019-01-23 11:11:37.068 info instance system.adapter.node-red.0 started with pid 6458
                  host.iobroker 2019-01-23 11:11:07.040 info Restart adapter system.adapter.node-red.0 because enabled
                  • Messiahs
                    Messiahs last edited by
                    Habe seit ein paar Wochen node-red-contrib-amazon-echo am laufen.
                    Bin echt zufrieden und m.m. einige fixes zu node-red-contrib-alexa-local
                    https://github.com/datech/node-red-contrib-amazon-echo
                      habe den mal installiert.
                      Gleiches Problem. Drücke ich auf Deploy hat der node-red keine Verbindung mehr (log siehe oben)
                        homecineplexx last edited by
                        @Messiahs:
                        https://github.com/datech/node-red-contrib-amazon-echo `
                        läuft es hier dann auch lokal ab?
                          rabuei62 last edited by
                          Bin auch neu hier im Forum und habe auch noch ein kleines Problem mit dem alexa-local adapter. Ich schalte darüber 5 Shellys für meine Deckenlampen in iobroker. Funktioniert alles recht gut, die Funktion zum umsetzen von on/off auf true/false arbeitet auch zuverlässig. Allerdings bekommt die Alexa App die Schaltzustände der Lampen nicht mit, wenn diese manuell über die Wandschalter ein- oder ausgeschaltet wurden. In der App stehen die dann immer noch auf dem alten Zustand.
                          Hat jemand hier im Forum eine Lösung dafür?
                          • Messiahs
                            Ja und bisher ohne Probleme..
                              @aldoa1:
                              Gleiches Problem. Drücke ich auf Deploy hat der node-red keine Verbindung mehr (log siehe oben) `
                              Also Google sagt da gleiche wie ich zu ENOSPC … https://stackoverflow.com/questions/224 ... w-to-solve
                              Passt nur nicht zu deinem „df“ Auszug. Sehr Strange.
                              Gesendet vom Handy ...
                                @apollon77:
                                @aldoa1:
                                Gesendet vom Handy ... `
                                Danke für die Antwort.
                                Habe keine Erklärung dafür und kann es nicht selbst beheben. Habe per google keine Lösung gefunden.
                                Außer node-red läuft ja alles. Sehr komisch.
                                  @rabuei62:
                                  Hat jemand hier im Forum eine Lösung dafür? `
                                  Hat sich erledigt. Habe es selbst rausbekommen. War ja eigentlich irgendwie logisch, dass das der ShellyState irgendwie zurück über den Input-Trigger gemeldet werden muß
                                    Frank_y last edited by
                                    @rabuei62:
                                    @rabuei62:
                                    Hat sich erledigt. Habe es selbst rausbekommen. War ja eigentlich irgendwie logisch, dass das der ShellyState irgendwie zurück über den Input-Trigger gemeldet werden muß `
                                    Der hub-node kann ja mehrere Geräte ansteuern. Was benötigt der Input des Hub, um das Rückmeldung dem richtigen Gerät zuzuordnen?
                                    Topic?
                                      @Frank_y:
                                      @rabuei62:
                                      @rabuei62:
                                      Topic? `
                                      Hallo Frank,
                                      hier habe ich mal meine Lösung am Beispiel für einen Shelly dokumentiert. Die 4 anderen sind im gleichen Flow genauso angebunden:
                                      18694_shelly_mit_alexa_local.pdf
                                        @rabuei62:
                                        @Frank_y:
                                        @rabuei62:
                                        Topic? `
                                        Hallo Frank,
                                        Shelly_mit_Alexa_Local.pdf `
                                        Danke, das ist mal eine tolle Anleitung. Der noLoop switch ist gut.
                                        Ich experimentiere z.Zt. auch noch mit
                                        herum. Wo würde man hier die Rückmeldung vom iobroker einfließen lassen: am Gerät oder am Hub?
                                          rewenode last edited by
                                          Tschuldigung, wenn ich da mal zwischen frage. Ich sehe in deiner Anleitung (@Frank-y) immer 3 node zum ändern der payload.
                                          Gibt es einen Grund, warum ihr das nicht mit einem change-node macht ?
                                            Viele Wege führen nach Rom…
                                            ...ich benutze auch den change -node
                                            1.2k
                                            622
                                            207237
