    4. Adapter: iobroker.backitup (stable Release)
    • Peoples
      Peoples last edited by
      Du kannst in den Adapter installieren aus Url machen und dort dann die GitHub Url einfügen so hast du den aktuellen Stand von Git.
      • simatec
        Ab sofort ist die Version 1.0.8 im Github und ab heute Nacht im latest verfügbar.
        1.0.8 (26.01.2019)
        __(simatec) modification for new installer
        (simatec) WOL-waittime adjustable
        (simatec) Fix History settings__
        Mit dieser Version sollten die Start/Stop Probleme bei neuen Installationen behoben sein.
        Ich habe die letzte Woche ausgiebige Test der Start/Stop Vorgänge inkl. Auswertungen gemacht.
        Viel Spaß mit der neuen Version … 😉
        • tripper
          tripper last edited by
          Bei mir funktioniert das Standard Backup nicht. Komplett Backup läuft soweit ich das sehe ohne Probleme
          Gestartet...
          [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****"}
          [DEBUG] [mount] - done
          [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"test","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"iobroker"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
          [ERROR] [minimal] - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:193
                                      result.objects[j].value.common.host === hostname) {
          TypeError: Cannot read property 'host' of undefined
              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:193:60
              at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
              at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
              at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
              at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
              at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
              at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
              at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
              at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
              at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
          [DEBUG] [minimal] - done
          [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
          [DEBUG] [cifs] - done
          [DEBUG] [clean] start with {"deleteBackupAfter":0}
          [DEBUG] [clean] - done
          [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","nameSuffix":"test","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_27-23_09_34_test_backupiobroker.tar.gz"],"errors":{},"done":["mount","minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"iobroker"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"27\. Januar 2019 um 23:09 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
          [DEBUG] [history] - backitup.1.history.html
          [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.0.11","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"","wolTime":"","smb":"vers=2.0","sudo":true,"deleteOldBackup":false,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/backitup_iobroker/standard","dirMinimal":"/Backup/backitup_iobroker/standard","dirTotal":"/Backup/backitup_iobroker/komplett","user":"backup","pass":"****","backupDir":"/opt/iobroker/backups"}
          [DEBUG] [umount] - wait 60 seconds for umount!
          [DEBUG] [umount] - done
          [EXIT] 1</anonymous></anonymous></anonymous>
          Leider verstehe ich nicht viel davon was mir hier gemeldet wird. Wenn ich in "/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/" nachschaue liegen da Dateien mit Datum um 1985 🙂 !
          Hab ich mir da evtl. mit der kürzlich per Komplett Backup (ja ich weiss das sollte man nicht, minimal ging aber auch dort schon nicht) wiederhergestellten iobroker Installation irgendwas eingeschleppt? Dort hatte ich auch öfters irgendwelche seltsamen Zeitstempel
          • MathiasJ
            MathiasJ last edited by
            Ich habe ein produktives und ein unproduktives System aufgebaut.
            Bei beiden habe ich das lastest installiert und den hier abgelegete sh-datei per WinSCP hochgeladen und ausgeführt.
            Bei beiden Systemen arbeitet iobroker.backitup ohne zu murren.
            Ich dachte ich muß mal ein positives Feddback hier abgeben. negative bekommst Du mehr als genug.
            Gruß,
            Mathias
            • simatec
              @MathiasJ:
              Gruß,
              Mathias `
              Sehe ich ehrlich gesagt nicht so … das meiste waren im großen und ganzen sehr oft Bedienfehler [emoji4]
                mguenther last edited by
                hmmm - bei mir funktionierte der Adapter auch 1a und speicherte auf meinem NAS die Standard-Backups täglich, die Komplett-Backups alle 2 Tage und meine CCU ebenfalls alle 2 Tage. Auf einmal speicherte der Adapter nichts mehr auf dem NAS. Warum, kann ich nicht sagen. Ich habe jetzt mehrmals den Adapter gestoppt und wieder neugestartet - jetzt bekomme ich zumindest wieder ein Backup von meiner CCU, allerdings nicht in dem vorgegebenen Ordner für die CCU, sondern im Ordner für meine Komplettbackup. Auch wenn ich händisch ein Standardbackup ausführe, wird es im Ordner für das Komplettbackup gespeichert. Ich habe keine Ahnung warum.
                installiert ist V1.0.1, ich habe js-controller 1.4.2, node und nodejs 8.15 und npm 6.4.1
                einer eine Idee?
                wenn ich das Backup händisch ausführe, bekomme ich folgendes:
                Gestartet...
                [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****"}
                [ERROR] [mount] - [undefined mount error(95): Operation not supported
                Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=XXXXXX,rw,file_mode=0777,dir_mode=0777 //192.168.222.175/iobroker_backup/standard /opt/iobroker/backups
                [DEBUG] [minimal] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","context":{"fileNames":[],"errors":{},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"XXXXXX"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal_2019_01_28-22_54_37_backupiobroker.tar.gz
                [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_28-22_54_37_backupiobroker.tar.gz"],"errors":{},"done":["minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"XXXXXXx"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","systemLang":"de","time":"28\. Januar 2019 um 22:54 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                [DEBUG] [telegram] - [minimal] used Telegram-Instance: telegram.0
                [DEBUG] [telegram] - done
                [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"mysqlEnabled":false,"redisEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal_2019_01_28-22_54_37_backupiobroker.tar.gz"],"errors":{},"done":["minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"NAS / Copy","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"XXXXXX"},"dropbox":{"enabled":false,"type":"storage","source":"NAS / Copy","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Total","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"28\. Januar 2019 um 22:54 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":true,"NoticeType":"shortTelegramNotice","User":"allTelegramUsers","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                [DEBUG] [history] - backitup.0.history.html
                [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"NAS / Copy","mount":"//192.168.222.175","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Total","dir":"/iobroker_backup/standard","dirMinimal":"/iobroker_backup/standard","dirTotal":"/iobroker_backup/komplett/","user":"iobroker","pass":"****","backupDir":"/opt/iobroker/backups"}
                Obwohl in dem Fenster "Schließen wenn fertig" aktiviert ist, passiert nix, das Backup liegt aber auf dem NAS, nur eben im falschen Verzeichnis.
                • Segway
                  Segway last edited by
                  Wie verbindest du dich mit dem Nas ? Cifs oder nfs ?
                  Ich mache es per cifs und habe gleiches Phänomen wie Du.
                  Nach einigen Recherchen kann ich behaupten das am Ende anscheinend irgendwann das UMOUNT nicht mehr richtig abgeschlossen wird.
                  Beim nächsten Mount vom Adapter hängt es dann.
                  Manuelles umount per Putty und Neustart des Adapters behob alles wieder. Bin aber immer noxh am beobachten
                    @Segway:
                    Gesendet von iPhone mit Tapatalk `
                    bin nicht so fit mit Linux, aber ich nutze cifs im Adapter - habe oben mal mein log gepostet
                    • Segway
                      Ja sieht so aus wie bei mir!
                      Ist noch gemountet aber busy und dann willst du nochmal mounten.
                      Versuche mal per Console umount und dann evtl . Auch den mount Befehl über Konsole ob es geht
                        @Segway:
                        äh - was muss ich denn genau machen?
                        • Segway
                          sudo umount <mount-point>Gesendet von iPhone mit Tapatalk</mount-point>
                          • simatec
                            Installiert mal die Version 1.0.8 Da sollte das Problem behoben sein.
                            Es ist halt ein Problem, was der Adapter nicht beheben kann, da es reine Shell Befehle sind, die backitup ausführt.
                            Wenn der Mount noch in Benutzung ist, dann kann kein umount stattfinden.
                            Das einzige was ich machen kann, ist die Wartezeit für den umount im Menü konfigurierbar machen.
                            Aktuell liegt sie bei 60 Sekunden.
                            Bei einigen scheint das aber nicht zu reichen.
                            • simatec
                              @mguenther:
                              @Segway:
                              […] äh - was muss ich denn genau machen?
                              Installier mal die Version 1.08 aus der latest repo
                                Buddinski88 last edited by
                                Vielen Dank für das Update mit der Einstellbaren WOL Wartezeit. Ich habe es mit 120 Sekunden mal soweit eingestellt und nun funktioniert das einwandfrei. Sicherlich geht noch ein bisschen weniger, aber sicher ist sicher 🙂
                                • Diginix
                                  Diginix last edited by
                                  Das Limit für die html History greift nun auch.
                                  Danke!
                                  • simatec
                                    Sehr gut … schön zu hören ... 😄
                                    • nik82
                                      nik82 Most Active last edited by
                                      erstmal danke für das super Programm, endlich keine Scripte basteln 😄
                                      Kurze Frage: Gibt es eine Möglichkeit die Benachrichtigung nur zu erhalten wenn das Backup schief läuft?
                                      Vielen Dank im Voraus.
                                      • Diginix
                                        Du könntest die Benachrichtigung im backitup ausschalten und ein eigenes Skript (JS, Blockly) schreiben was auf den History Success Datenpunkt triggert.
                                        Allerdings hat bei mir vor 2 und 8 Tagen das minimal nicht funktioniert und ich habe es dann später manuell gestartet. Ein false habe ich in dem Success DP nie. Also müsste man im Skript prüfen ob mind. 10min nach der Backup Sollzeit ein true geschrieben wird.
                                        • nik82
                                          Ah ok, danke.
                                          Eine Sache habe ich jetzt noch, ich habe beim Komplett Backup eingeschaltet "iobroker Stop bei einem Backup", nun habe ich manuell ein Komplett Backup gemacht.
                                          Das funktionierte auch, aber er startete nicht mehr meinen IOBroker, ich musste manuell wieder starten mit "sudo iobroker start".
                                          Ist das so gewollt?
                                            homecineplexx last edited by
                                            Könnte man nicht was einbauen, wo man sich aussuchen kann, an welchem Tag, (Montag, Dienstag,…) das Backup gemacht wird?
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1198119
