    4. [Update] HabPanel Adapter update 0.2.2
    • Bluemoon
      Bluemoon last edited by
      Hallo
      Danke für das Update und deine arbeit. 🙂
      Kann leider das Update 0.3.0 nicht Installieren.
      LOG:
      ! $ ./iobroker upgrade habpanel
      ! Update habpanel from @0.2.6 to @0.3.0
      ! NPM version: 6.4.1
      ! npm install iobroker.habpanel@0.3.0 –production --save --prefix "/opt/iobroker" (System call)
      ! npm
      ! WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.npm
      ! WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.npm WARN react-redux@5.1.1 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.habpanel"
      ! npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      ! npm WARN deprecated gulp-util@2.2.20: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      ! npm WARN deprecated gulp-util@3.0.7: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      ! npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      ! npm WARN deprecated graceful-fs@2.0.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      ! npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      ! npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      ! npm
      ! WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      ! npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      ! npm notice created a lockfile as package-lock.json. You should commit this file.
      ! npm WARN eslint-config-esnext@1.6.0 requires a peer of eslint@~3.4.0 but none is installed. You must install peer dependencies yourself.npm WARN eslint-config-recommended@1.5.0 requires a peer of eslint@~3.4.0 but none is installed. You must install peer dependencies yourself.
      ! npm WARN eslint-config-recommended@1.5.0 requires a peer of eslint-plugin-react@~6.2.0 but none is installed. You must install peer dependencies yourself.
      ! npm
      ! WARN eslint-config-recommended@1.5.0 requires a peer of eslint-plugin-react-native@~2.0.0 but none is installed. You must install peer dependencies yourself.
      ! got /opt/iobroker/node_modules/iobroker.habpanel/admin
      ! upload [0] habpanel.admin /opt/iobroker/node_modules/iobroker.habpanel/admin/habpanel.png habpanel.png image/png
      ! got /opt/iobroker/node_modules/iobroker.habpanel/www
      ! upload [1750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/vendor.js vendor/vendor.js application/javascript
      ! upload [1700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set.list.json assets/icons/smarthome-set.list.json application/json
      ! upload [1650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/yard-fountain.svg assets/icons/freepik-housethings/yard-fountain.svg image/svg+xml
      ! upload [1600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/shower-bathroom-tool.svg assets/icons/freepik-housethings/shower-bathroom-tool.svg image/svg+xml
      ! upload [1550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/livingroom-lamp.svg assets/icons/freepik-housethings/livingroom-lamp.svg image/svg+xml
      ! upload [1500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/house-building.svg assets/icons/freepik-housethings/house-building.svg image/svg+xml
      ! upload [1450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/door-design.svg assets/icons/freepik-housethings/door-design.svg image/svg+xml
      ! upload [1400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/bedroom-stairs-tool.svg assets/icons/freepik-housethings/bedroom-stairs-tool.svg image/svg+xml
      ! upload [1350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/window-6.svg assets/icons/freepik-household/window-6.svg image/svg+xml
      ! upload [1300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/sofa-17.svg assets/icons/freepik-household/sofa-17.svg image/svg+xml
      ! upload [1250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/mixer-2.svg assets/icons/freepik-household/mixer-2.svg image/svg+xml
      ! upload [1200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/door.svg assets/icons/freepik-household/door.svg image/svg+xml
      ! upload [1150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/bookshelf.svg assets/icons/freepik-household/bookshelf.svg image/svg+xml
      ! upload [1100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/synthesizer.svg assets/icons/freepik-gadgets/synthesizer.svg image/svg+xml
      ! upload [1050] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/cs-mixer.svg assets/icons/freepik-gadgets/cs-mixer.svg image/svg+xml
      ! upload [1000] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/wind.svg assets/icons/eclipse-smarthome-classic/wind.svg image/svg+xml
      ! upload [950] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/switch-off.svg assets/icons/eclipse-smarthome-classic/switch-off.svg image/svg+xml
      ! upload [900] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/slider-30.svg assets/icons/eclipse-smarthome-classic/slider-30.svg image/svg+xml
      ! upload [850] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/sewerage-20.svg assets/icons/eclipse-smarthome-classic/sewerage-20.svg image/svg+xml
      ! upload [800] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/qualityofservice.svg assets/icons/eclipse-smarthome-classic/qualityofservice.svg image/svg+xml
      ! upload [750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_6_3.svg assets/icons/eclipse-smarthome-classic/parents_6_3.svg image/svg+xml
      ! upload [700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_2_2.svg assets/icons/eclipse-smarthome-classic/parents_2_2.svg image/svg+xml
      ! upload [650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/man_3.svg assets/icons/eclipse-smarthome-classic/man_3.svg image/svg+xml
      ! upload [600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/humidity-100.svg assets/icons/eclipse-smarthome-classic/humidity-100.svg image/svg+xml
      ! upload [550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/garagedoor.svg assets/icons/eclipse-smarthome-classic/garagedoor.svg image/svg+xml
      ! upload [500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/fire-on.svg assets/icons/eclipse-smarthome-classic/fire-on.svg image/svg+xml
      ! upload [450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/dimmablelight-40.png assets/icons/eclipse-smarthome-classic/dimmablelight-40.png image/png
      ! upload [400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/cistern-30.png assets/icons/eclipse-smarthome-classic/cistern-30.png image/png
      ! upload [350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/boy_4.png assets/icons/eclipse-smarthome-classic/boy_4.png image/png
      ! upload [300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/battery-90.png assets/icons/eclipse-smarthome-classic/battery-90.png image/png
      ! upload [250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/sv.po assets/i18n/widgets/sv.po application/octet-stream
      ! upload [200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/ar.json assets/i18n/widgets/ar.json application/json
      ! upload [150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/main/en.po assets/i18n/main/en.po application/octet-stream
      ! upload [100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/it.json assets/i18n/admin/it.json application/json
      ! upload [90] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/fi.json assets/i18n/admin/fi.json application/json
      ! upload [80] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/cs.po assets/i18n/admin/cs.po application/octet-stream
      ! upload [70] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/admin.pot assets/i18n/admin/admin.pot application/vnd.ms-powerpoint
      ! upload [60] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/slider/slider.widget.js app/widgets/slider/slider.widget.js application/javascript
      ! upload [50] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/knob/knob.tpl.html app/widgets/knob/knob.tpl.html text/html
      ! upload [40] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/dummy/dummy.settings.tpl.html app/widgets/dummy/dummy.settings.tpl.html text/html
      ! upload [30] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/button/button.widget.js app/widgets/button/button.widget.js application/javascript
      ! upload [20] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/settings/settings.localconfig.controller.js app/settings/settings.localconfig.controller.js application/javascript
      ! upload [19] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/settings/settings.html app/settings/settings.html text/html
      ! upload [18] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/settings/settings.controller.js app/settings/settings.controller.js application/javascript
      ! upload [17] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/translation.service.js app/services/translation.service.js application/javascript
      ! upload [16] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/speech.service.js app/services/speech.service.js application/javascript
      ! upload [15] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/services.js app/services/services.js application/javascript
      ! upload [14] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/persistence.service.js app/services/persistence.service.js application/javascript
      ! upload [13] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/localfile.service.js app/services/localfile.service.js application/javascript
      ! upload [12] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/icon.service.js app/services/icon.service.js application/javascript
      ! upload [11] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/data.service.js app/services/data.service.js application/javascript
      ! upload [10] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/menu.settings.tpl.html app/menu/menu.settings.tpl.html text/html
      ! upload [9] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/menu.html app/menu/menu.html text/html
      ! upload [8] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/menu.controller.js app/menu/menu.controller.js application/javascript
      ! upload [7] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/drawer.tpl.html app/menu/drawer.tpl.html text/html
      ! upload [6] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/drawer.controller.js app/menu/drawer.controller.js application/javascript
      ! upload [5] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/transferwidget.html app/dashboard/transferwidget.html text/html
      ! upload [4] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.view.html app/dashboard/dashboard.view.html text/html
      ! upload [3] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.view.controller.js app/dashboard/dashboard.view.controller.js application/javascript
      ! upload [2] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.edit.html app/dashboard/dashboard.edit.html text/html
      ! upload [1] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.edit.controller.js app/dashboard/dashboard.edit.controller.js application/javascript
      ! upload [0] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/app.js app/app.js application/javascript
      ! Adapter "habpanel" updated
      ! process exited with code 0
      SYSTEM:
      IoBroker läuft in einem https://hub.docker.com/r/bluemoon1978/iobroker
      ! d-iobroker
      ! Betriebssystem linux
      ! Architektur x64
      ! CPUs 2
      ! Geschwindigkeit 2000 MHz
      ! Modell Intel(R) Pentium(R) Dual CPU T3200 @ 2.00GHz
      ! RAM 3.8 GB
      ! System Betriebszeit 00:34:43
      ! Node.js v8.15.0
      ! Disk size 54622781440
      ! Disk free 41406746624
      ! Anzahl der Adapter 247
      ! NPM v6.4.1
      ! Betriebszeit 00:34:22
      ! Active instances 24
      ! Hostname d-iobroker
      Gruß Bluemoon
        apollon77 last edited by
        Laut log hat alles geklappt. Warum denkst du er hat es nicht installiert?
        Gesendet vom Handy …
        • Bluemoon
          Weil unter Adapter weiter hin Installiert 0.2.6 und verfügbar 0.3.0 steht.
          Hat sich auch nichts geändert nach einem Host bzw System neustart und neu laden der Repository.
            Mach nochmal ein
            iobroker upload habpanel
            • Bluemoon
              leider keine Änderung
              auch einiobroker updateund````
              iobroker upgrade
              bei gestartetm und gestopten iobroker
              brachte nichts
              steht bei````
              iobroker update
              Adapter "habpanel" : 0.3.0 , installed 0.2.6 [Updateable]
              Es läuft ja alles als und Timeline und Chart ist vorhanden. Da ich History usw nicht nutze, kann ich da kein Feedback geben ob es da Bugs gibt.
                Ok, Grund gefunden. Ich hab an einer Stelle Versionsupdate vergessen 🙂 0.3.1 released
                • wendy2702
                  wendy2702 last edited by
                  schon im latest? Da wird mir noch die 0.3.0 angezeigt.
                  Wenn ich über GitHub installieren will ist HabPanel bei mir nicht auswählbar.
                  Wie wäre der richtige Befehl für beliebige Installation?
                    14 Uhr sollte es im Latest sein.
                    Direkte Installation: siehe oben in diesem Thread
                    • Bluemoon
                      Danke, nun läuft wieder alles. 🙂
                        Hallo, ich teste gerade.
                        Gibt es wo eine Beschreibung auf Deutsch bzw. kann man die Sprache umstellen?
                        • wendy2702
                          @sigi234:
                          Screenshot (1692).png `
                          Das würde mich auch interessieren. Habe am WE mal Openhab auf einem Rechner installiert, da war es direkt in Deutsch.
                          Mich würde noch interessieren wie man seinen Kalender vernünftig einbinden kann.
                          Habe zwar das Widget für die nächsten 5 Termine gefunden aber das ist mir etwas zu wenig.
                          Hat dafür jemand eine Lösung?
                            Zur Sprache: legt doch mal ein GitHub Issue an
                            • wendy2702
                              @apollon77:
                              Zur Sprache: legt doch mal ein GitHub Issue an `
                              Done: https://github.com/ioBroker/ioBroker.habpanel/issues/17
                              wendy2702 created this issue in ioBroker/ioBroker.habpanel
                              closed Language selection #17
                                holgerwolf last edited by
                                Ich bekomme beim Erstellen eines charts folgenden SQL Fehlermeldung im Log:
                                2019-01-30 10:00:46.922 - error: sql.0 Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ':00:46.860Z UNION ( SELECT ts, val FROM `iobroker`.ts_bool WHERE `iobroker`.ts_' at line 1
                                Grafik bleibt bis auf Legende leer.
                                Mysql Version ist 5.7.25
                                Holger
                                  Jupp, known: https://github.com/ioBroker/ioBroker.habpanel/issues/16
                                  matthiasgasser created this issue in ioBroker/ioBroker.habpanel
                                  closed data.service.js vs postgres sql query error #16
                                    wollinator last edited by
                                    Toller Adapter läuft bei mir soweit problemlos!
                                    Gibt es eine Möglichkeit das HabPanel über http statt https (damit kein Zertifikat angemeckert wird) und ohne "login zwang" anzusprechen?
                                    LG W
                                      habpanel rufst Du über eine deiner Web-Instanzen auf … dann schalte doch dort SSL und Auth aus bzw lege eine neue web-Instanz an
                                        ahhh, so funktioniert das!
                                        Vielen Dank für den Hinweis!
                                        LG W
                                          @apollon77:
                                          Jupp, known: https://github.com/ioBroker/ioBroker.habpanel/issues/16 `
                                          Auch noch unter 0.3.2.
                                          Habs auf Github geloggt.
                                            Bitte SQL auf Debug stellen und dann das HabPanel aufrufen und log posten von sql
                                            31.7k
                                            79.8k
                                            57
                                            7858
