    4. [Aufruf] Xbox Adapter testen
      jetlife last edited by
      Sorry, ja. Hab restartet. Hab jetzt alle möglichen Adapter mal wild restartet und aus irgendeinem Grund connected er jetzt wieder. Kein Plan, was da los ist.
      visibility
      build
      HOST RASPBERRYPIioBroker.admin 3.5.10
      refresh pausedelete delete_foreverLOG HERUNTERLADENLog-Größe: 0.01 MB
      	Zeit
      Meldung
      xbox.0	2019-01-27 18:25:41.823	info	[CONNECT] <=== Successfully connected to FD008C81FD5022D6 (192.168.178.24)
      cloud.0	2019-01-27 18:22:55.067	info	Request V3 devices
      cloud.0	2019-01-27 18:22:55.064	info	Request devices
      cloud.0	2019-01-27 18:22:48.949	info	Request V3 devices
      cloud.0	2019-01-27 18:22:48.586	info	Request devices
      cloud.0	2019-01-27 18:22:31.460	info	Request V3 devices
      cloud.0	2019-01-27 18:22:31.358	info	Request devices
      cloud.0	2019-01-27 18:22:16.763	info	Request devices
      cloud.0	2019-01-27 18:22:16.182	info	Request devices
      xbox.0	2019-01-27 18:21:55.753	info	[CONNECT] <=== Lost connection to your Xbox (192.168.178.24)
      cloud.0	2019-01-27 18:21:14.590	warn	Unknown applianceId: Konsole
      xbox.0	2019-01-27 18:19:35.108	info	[CONNECT] <=== Successfully connected to FD008C81FD5022D6 (192.168.178.24)
      admin.0	2019-01-27 18:16:55.421	info	Repository received successfully.
      host.raspberrypi	2019-01-27 18:16:53.900	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      admin.0	2019-01-27 18:16:53.830	info	Request actual repository...
      xbox.0	2019-01-27 18:13:28.005	warn	[CONNECT] Ping response, but provided LiveID has not been discovered until now
      xbox.0	2019-01-27 18:13:13.131	warn	[REQUEST] <=== Could not turn on Xbox
      xbox.0	2019-01-27 18:12:35.637	info	[START] Starting REST server
      xbox.0	2019-01-27 18:12:35.626	info	starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v8.15.0
      host.raspberrypi	2019-01-27 18:12:33.628	info	instance system.adapter.xbox.0 started with pid 12522
      host.raspberrypi	2019-01-27 18:12:31.532	info	instance system.adapter.xbox.0 terminated with code 0 (OK)
      xbox.0	2019-01-27 18:12:31.341	info	[END] cleaned everything up...
      xbox.0	2019-01-27 18:12:31.322	info	[END] REST server stopped
      host.raspberrypi	2019-01-27 18:12:31.102	info	stopInstance system.adapter.xbox.0 killing pid 12463
      host.raspberrypi	2019-01-27 18:12:31.101	info	object change system.adapter.xbox.0
      web.0	2019-01-27 18:12:30.644	info	http server listening on port 8082
      web.0	2019-01-27 18:12:30.640	info	socket.io server listening on port 8082
      web.0	2019-01-27 18:12:30.318	info	Allow states only when user is owner: false
      web.0	2019-01-27 18:12:30.317	info	simpleAPI server listening on port 8082
      web.0	2019-01-27 18:12:30.142	info	starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.15.0
      web.0	2019-01-27 18:12:30.127	error	setObject id missing!!
      host.raspberrypi	2019-01-27 18:12:28.618	info	instance system.adapter.web.0 started with pid 12509
      host.raspberrypi	2019-01-27 18:12:26.195	info	instance system.adapter.web.0 terminated with code 0 (OK)
      web.0	2019-01-27 18:12:26.127	info	terminating http server on port 8082
      web.0	2019-01-27 18:12:26.103	info	terminated http server on port 8082
      web.0	2019-01-27 18:12:26.101	info	terminating http server on port 8082
      host.raspberrypi	2019-01-27 18:12:26.097	info	stopInstance system.adapter.web.0 killing pid 570
      host.raspberrypi	2019-01-27 18:12:26.096	info	object change system.adapter.web.0
      xbox.0	2019-01-27 18:12:13.190	warn	[REQUEST] <=== Could not turn on Xbox
      xbox.0	2019-01-27 18:11:41.136	info	[START] Starting REST server
      xbox.0	2019-01-27 18:11:41.125	info	starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.xbox, node: v8.15.0
      host.raspberrypi	2019-01-27 18:11:39.182	info	instance system.adapter.xbox.0 started with pid 12463
      host.raspberrypi	2019-01-27 18:11:37.089	info	instance system.adapter.xbox.0 terminated with code 0 (OK)
      xbox.0	2019-01-27 18:11:36.942	info	[END] cleaned everything up...
      xbox.0	2019-01-27 18:11:36.757	info	[END] REST server stopped
      • foxriver76
        Habe jetzt nicht direkt einen Fehler gesehen, also der Adapter kann sich nur verbinden, wenn die Xbox an ist. Sprich solange die Xbox aus ist, ist der Adapter gelb. Anschalten ist das einzige Kommando das klappen 'kann', wenn die Xbox nicht verbunden ist. Allerdings nicht dann, wenn die Xbox vorher vom Strom getrennt war und seitdem nicht mehr gestartet wurde.
          Und schon wieder ist sie weg 😕 Ich hab so langsam das Gefühl, dass es über wlan nicht richtig funktioniert. Ich probiere es morgen mal mit LAN Verbindung bei der XBOX.
            @foxriver76:
            @Jey Cee:
            Ich hab das jetzt mal mit der App getestet, selbes Ergebnis, die Xbox lässt sich nicht starten. Übrigens ist Schnelles Hochfahren dafür immer Notwendig.
            Damit ist klar die Xbox muss erstmal gestartet worden sein und ist erst danach im Standby. Das ist darauf zurück zu führen das dass BIOS/UEFI gar kein WOL Unterstützt oder eben nicht aktiviert ist. Es gibt einen Standby Modus von Windows (läuft ja auf der Xbox) der WOL ermöglicht. Das konnte ich herausfinden als ich meinen Laptop per WOL wecken wollte, aber genau das gleiche Problem wie bei der Xbox.
            @foxriver76:
            Ich habe das Problem selbst und konnte es bislang nicht lösen, allerdings vermuten wir derzeit, dass es irgendwo in der Fritz!Box steckt. Ist die Xbox direkt mit der FritzBox verbunden? Die FritzBox hat ja auch ein Energiemanagment und schaltet die LAN Ports ab wenn da nix mehr kommt. Da könnte eventuell ein Switch dazwischen helfen.
            Danke, dass du etwas Licht ins dunkel bringst. Ich habe das ganze bei mir getestet im WLAN der Fritz und per LAN an einem DLAN-Adapter. Für mich persönlich ist es nicht relevant, da ich sowieso über den Harmony Hub die Box an und aus mache. Allerdings ist es schön, wenn man als Adapter-Entwickler den Usern im Falle des Problems helfen kann.
            @Jey Cee:
            Ich hab die Xbox mal 1-1,5 Stunden im Standby gelassen und das Starten war kein Problem. `
            Top, dann ist es wohl wie von dir erörtert die fehlende Wake-on-Lan Funktion von Win. `
            Das beschreibt denke ich genau mein Problem. Wobei meine XBOX immer am Strom ist. Ich habe also keine Möglichkeit, meine XBOX per Adapter anzuschalten, sobald diese länger im Standby war? Oder funktioniert das, sobald ich statt WLAN die XBOX per LAN anschließe?
              DKM last edited by
              Habt ihr ne feste IP an der Xbox und in der Fritzbox? Wenn ein Gerät länger nicht im Netz ist, wird die IP freigegeben und alles läuft ins Leere.
              Siehe DHCP Lease
              Gesendet von meinem SM-G960F mit Tapatalk
                Ja, feste IP ist natürlich bei allen Geräten eingestellt.
                  xbox.0	2019-01-28 23:17:50.366	warn	[REQUEST] <=== Could not turn on Xbox
                  xbox.0	2019-01-28 23:17:47.905	warn	[STATE] settings.power change to true dropped, because Xbox blocked
                  xbox.0	2019-01-28 22:09:11.433	info	[CONNECT] <=== Lost connection to your Xbox (192.168.178.24)
                  xbox.0	2019-01-28 22:08:59.105	info	[CONNECT] <=== Successfully connected to FD008C81FD5022D6 (192.168.178.24)
                  xbox.0	2019-01-28 22:08:29.319	info	[CONNECT] <=== Lost connection to your Xbox (192.168.178.24)
                  xbox.0	2019-01-28 22:06:56.515	info	[CONNECT] <=== Successfully connected to FD008C81FD5022D6 (192.168.178.24)
                    Also das Problem scheint definitiv die WLAN Verbindung zu sein . Über WLAN funktioniert die offizielle Xbox App auch nach einer kurzen Standby Phase nicht mehr. Instant on an, feste IP an, komplett alle Ports geöffnet (nur zum Test). Immer das gleiche, nach kurzer Standby Phase nicht mehr erreichbar.
                    Da werde ich wohl auf LAN umsteigen müssen oder mir einfach den Logitech Harmony Hub zulegen müssen. Hätte auch den Vorteil, dass ich meinen Samsung steuern kann (die Samsung Adapter unterstützen das neue Gerät leider nicht)
                    Sehr schade, der Adapter ist ansonsten sehr vielversprechend. Verstehe nicht, warum das WLAN komplett ausgeht trotz instant-on 😢
                    • foxriver76
                      @jetlife:
                      Sehr schade, der Adapter ist ansonsten sehr vielversprechend. Verstehe nicht, warum das WLAN komplett ausgeht trotz instant-on 😢 `
                      Ja schade, dass WOL grundsätzlich nicht unterstützt wird von der Xbox. Ich handhabe es auch so, dass ich mit dem Harmony Hub einschalte. Vorteil ist, man muss nicht den Always-On Modus nutzen und es funktioniert zuverlässiger.
                        DKM last edited by
                        Ich habe die Xbox One und die Xbox One x, bei beiden geht wol über WLAN. Aber nur, wenn ich in der Konsole die feste IP und bei der Fritz Box "Diesem Gerät immer die gleiche IP zuweisen" ausgewählt habe. Fehlt der Haken in der FB geht es nach ein paar Tagen auch nicht mehr.
                        • foxriver76
                          @DKM:
                          Gesendet von meinem SM-G960F mit Tapatalk `
                          Trenn mal die Konsole kurz vom Strom und probiere sie dann mittels WOL einzuschalten, geht meines Wissens nicht.
                          Bei mir funktioniert es über den Adapter sowie auch über die App nur, wenn die Konsole seit sie Saft hat ein mal an war + im Always-On Modus ist.
                          Siehe auch: viewtopic.php?f=36&t=17044&start=60#p192047
                            @foxriver76:
                            @jetlife:
                            Ja schade, dass WOL grundsätzlich nicht unterstützt wird von der Xbox. Ich handhabe es auch so, dass ich mit dem Harmony Hub einschalte. Vorteil ist, man muss nicht den Always-On Modus nutzen und es funktioniert zuverlässiger. `
                            Sehr schade, ja. Danke für deinen tollen Adapter! Wird dann wohl die Hub werden 😃
                              @DKM:
                              Danke für den Tipp, das werde ich dann heut Abend mal noch ausprobieren. Ich habe nur in der Fritzbox die Option gesetzt, dass die Konsole immer die gleiche IP haben soll. In der Konsole selbst, habe ich nichts eingestellt. Warum auch? Aber wenn das bei dir funktioniert, teste ich das heute Abend einfach mal.
                                DKM last edited by
                                Kann auch nicht, da bei WOL der Standby Modus aktiviert bleiben muss. Die XBOX speichert keine IP Adresse wenn sie vollständig aus ist.
                                Steht aber auch irgendwo im Menü das man schnelles Hochfahren (Standby) aktiviert haben muss.
                                Die Lampe vorne sagt leider nichts über den Zustand aus. Man erkennt die Unterschiede nur beim Hochfahren. Kommt das grüne Intro war sie komplett aus (kein WOL möglich). Landet man direkt im Menü war sie im Standby.
                                Ist bei PCs übrigens genauso. Schaltest du das Netzteil aus, geht WOL nicht, außer es wird systemintern gespeichert.
                                • foxriver76
                                  @DKM:
                                  Passt. Hatte deine Aussage falsch interpretiert und du meine so, dass WOL gar nicht geht (dann hätte ich power on nicht implementiert 😄 ). Danke für die Infos.
                                    @DKM:
                                    Ich hatte natürlich alles wie gewünscht konfiguriert. Das einzige, das ich nicht gemacht habe, ist im Setup der XBOX eine feste IP einzustellen. Dachte das reicht über die Fritzbox. Ich gebe dann heute Abend Rückmeldung, ob es so funktioniert. Ansonsten wird die Hub geordert =D
                                    • foxriver76
                                      Und nach wie vor hat sich hier noch niemand gemeldet, der mit mir BF5 spielen möchte. :lol:
                                        @foxriver76:
                                        Und nach wie vor hat sich hier noch niemand gemeldet, der mit mir BF5 spielen möchte. :lol: `
                                        Sorry, habe ich nicht xD
                                          DKM last edited by
                                          Ich spiele nur Qualitätsspiele [emoji39][emoji39]
                                            Erst einmal danke für die Hilfe! Es funktioniert jetzt endlich!!! Für die Zukunft, falls jemand ähnliche Probleme hat.
                                            Setup:
                                            • Xbox instant on Modus an
                                            • Feste IPs vergeben in Fritzbox und Xbox
                                            • Xbox verbunden über WLAN
                                            Ich musste sowohl in der Fritzbox eine feste IP für die Xbox vergeben, als auch im Setup der Xbox selbst eine feste IP (natürlich die selbe) einstellen. Jetzt funktioniert es auch endlich nach einer längeren Standby Phase, wie z.B. über Nacht.
                                            Danke nochmal an alle!!
                                            31.7k
                                            79.8k
                                            adapter xbox
                                            13
                                            205
                                            28379
