    4. Iot Fehler
    Iot Fehler
      War bei mir auch so….....
        RoWi last edited by
        Ok nach Neustart aktualisiert - starte iobroker neu und gut ist?
          https://github.com/ioBroker/ioBroker.iot/issues/4
            RoWi last edited by
            Ok scheint ein allgemeines Problem zu sein, nach wiederholten Eingabe des Passworts geht es wieder. Mal sehen wie lange 🙂
              RoWi last edited by Negalein
              Hilft nix ..fehler kommt direkt wieder
              undefined2019-01-06 13:09:50.191 - debug: iot.0 system.adapter.admin.0: logging false
              2019-01-06 13:10:25.736 - debug: iot.0 system.adapter.admin.0: logging true
              2019-01-06 13:12:00.543 - warn: hm-rpc.2 [KEEPALIVE] Connection timed out
              2019-01-06 13:12:30.791 - info: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
              2019-01-06 13:12:30.809 - info: hm-rpc.2 xmlrpc -> 0 devices
              2019-01-06 13:12:36.004 - debug: iot.0 offline
              2019-01-06 13:12:36.006 - error: iot.0 read ECONNRESET
              2019-01-06 13:12:36.007 - info: iot.0 Connection changed: disconnect
              2019-01-06 13:12:36.008 - info: iot.0 Connection lost
              2019-01-06 13:12:41.011 - debug: iot.0 reconnect
              2019-01-06 13:12:41.382 - info: iot.0 Connection changed: connect
              2019-01-06 13:13:10.695 - debug: iot.0 Request command/wilke_roland_gmx_de/alexa
              2019-01-06 13:13:10.696 - debug: iot.0 Data: {"header":{"namespace":"Alexa.ConnectedHome.Control","name":"TurnOffRequest","payloadVersion":"2","messageId":"9797c833-f698-4408-b7c9-f7fc6957921d"},"payload":{"accessToken":"[TOKEN ENTFERNT]","appliance":{"applianceId":"Licht_Esstisch","additionalApplianceDetails":{"role":"level.dimmer","friendlyNames":"Licht Esstisch","id":"knx.0.Beleuchtung.OG_Beleuchtung.Licht_Esstisch_Dimmen_Absolut"}}}}
              2019-01-06 13:13:10.697 - debug: iot.0 1546780390696 ALEXA: {"header":{"namespace":"Alexa.ConnectedHome.Control","name":"TurnOffRequest","payloadVersion":"2","messageId":"9797c833-f698-4408-b7c9-f7fc6957921d"},"payload":{"accessToken":"[TOKEN ENTFERNT]","appliance":{"applianceId":"Licht_Esstisch","additionalApplianceDetails":{"role":"level.dimmer","friendlyNames":"Licht Esstisch","id":"knx.0.Beleuchtung.OG_Beleuchtung.Licht_Esstisch_Dimmen_Absolut"}}}}
              2019-01-06 13:13:10.714 - debug: iot.0 {"id":"knx.0.Beleuchtung.OG_Beleuchtung.Licht_Esstisch_Dimmen_Absolut","role":"level.dimmer","name":"Licht Esstisch Dimmen Absolut","friendlyNames":"Licht Esstisch","smartType":"LIGHT","byON":"100","nameModified":true,"room":null,"func":null}
              2019-01-06 13:13:10.715 - debug: iot.0 New Request: TurnOffRequest
              2019-01-06 13:13:10.716 - debug: iot.0 ALEXA OFF: Licht_Esstisch
              2019-01-06 13:13:10.717 - debug: iot.0 knx.0.Beleuchtung.OG_Beleuchtung.Licht_Esstisch_Dimmen_Absolut
              2019-01-06 13:13:10.717 - debug: iot.0 Controlling off: knx.0.Beleuchtung.OG_Beleuchtung.Licht_Esstisch_Dimmen_Absolut
              2019-01-06 13:13:10.737 - debug: iot.0 Set "knx.0.Beleuchtung.OG_Beleuchtung.Licht_Esstisch_Dimmen_Absolut" to 0
              2019-01-06 13:13:15.107 - debug: iot.0 Request command/wilke_roland_gmx_de/alexa
              2019-01-06 13:13:15.108 - debug: iot.0 Data: {"header":{"namespace":"Alexa.ConnectedHome.Control","name":"TurnOffRequest","payloadVersion":"2","messageId":"b11dff00-132f-4e69-8bea-a7b425db693c"},"payload":{"accessToken":"[TOKEN ENTFERNT]","appliance":{"applianceId":"Licht_K_che","additionalApplianceDetails":{"role":"value.dimmer","friendlyNames":"Licht Küche","id":"knx.0.Beleuchtung.OG_Beleuchtung.Licht_Küche_gesamt_Dimmen_Absolut"}}}}
              2019-01-06 13:13:15.109 - debug: iot.0 1546780395109 ALEXA: {"header":{"namespace":"Alexa.ConnectedHome.Control","name":"TurnOffRequest","payloadVersion":"2","messageId":"b11dff00-132f-4e69-8bea-a7b425db693c"},"payload":{"accessToken":"[TOKEN ENTFERNT]","appliance":{"applianceId":"Licht_K_che","additionalApplianceDetails":{"role":"value.dimmer","friendlyNames":"Licht Küche","id":"knx.0.Beleuchtung.OG_Beleuchtung.Licht_Küche_gesamt_Dimmen_Absolut"}}}}
              2019-01-06 13:13:15.110 - debug: iot.0 {"id":"knx.0.Beleuchtung.OG_Beleuchtung.Licht_Küche_gesamt_Dimmen_Absolut","role":"value.dimmer","name":"Licht Küche gesamt Dimmen Absolut","friendlyNames":"Licht Küche","smartType":"LIGHT","byON":"100","nameModified":true,"room":null,"func":null}
              2019-01-06 13:13:15.111 - debug: iot.0 New Request: TurnOffRequest
              2019-01-06 13:13:15.111 - debug: iot.0 ALEXA OFF: Licht_K_che
              2019-01-06 13:13:15.112 - debug: iot.0 null
              2019-01-06 13:13:15.112 - debug: iot.0 Controlling off: knx.0.Beleuchtung.OG_Beleuchtung.Licht_Küche_gesamt_Dimmen_Absolut
              2019-01-06 13:13:15.122 - debug: iot.0 Set "knx.0.Beleuchtung.OG_Beleuchtung.Licht_Küche_gesamt_Dimmen_Absolut" to 0
              2019-01-06 13:15:30.644 - warn: hm-rpc.2 [KEEPALIVE] Connection timed out
              2019-01-06 13:16:00.905 - info: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
              2019-01-06 13:16:00.922 - info: hm-rpc.2 xmlrpc -> 0 devices
              2019-01-06 13:16:48.856 - debug: iot.0 offline
              2019-01-06 13:16:48.856 - error: iot.0 read ECONNRESET
              2019-01-06 13:16:48.857 - info: iot.0 Connection changed: disconnect
              2019-01-06 13:16:48.857 - info: iot.0 Connection lost
              2019-01-06 13:16:53.862 - debug: iot.0 reconnect
              2019-01-06 13:16:54.197 - info: iot.0 Connection changed: connect
              2019-01-06 13:18:49.373 - debug: iot.0 Request command/wilke_roland_gmx_de/alexa
              2019-01-06 13:18:49.374 - debug: iot.0 Data: {"header":{"namespace":"Alexa.ConnectedHome.Discovery","name":"DiscoverAppliancesRequest","payloadVersion":"2","messageId":"33631b2b-2403-4355-847f-d7f1b7dfa203"},"payload":{"accessToken":"[TOKEN ENTFERNT]"}}
              2019-01-06 13:18:49.374 - debug: iot.0 1546780729374 ALEXA: {"header":{"namespace":"Alexa.ConnectedHome.Discovery","name":"DiscoverAppliancesRequest","payloadVersion":"2","messageId":"33631b2b-2403-4355-847f-d7f1b7dfa203"},"payload":{"accessToken":"[TOKEN ENTFERNT]"}}
              2019-01-06 13:18:49.375 - debug: iot.0 New Request: DiscoverAppliancesRequest
              2019-01-06 13:19:00.741 - warn: hm-rpc.2 [KEEPALIVE] Connection timed out
              2019-01-06 13:19:31.006 - info: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
              2019-01-06 13:19:31.048 - info: hm-rpc.2 xmlrpc -> 0 devices
              2019-01-06 13:22:30.826 - warn: hm-rpc.2 [KEEPALIVE] Connection timed out
              2019-01-06 13:22:37.411 - debug: iot.0 offline
              2019-01-06 13:22:37.411 - error: iot.0 read ECONNRESET
              2019-01-06 13:22:37.412 - info: iot.0 Connection changed: disconnect
              2019-01-06 13:22:37.412 - info: iot.0 Connection lost
              2019-01-06 13:22:42.417 - debug: iot.0 reconnect
              2019-01-06 13:22:42.766 - info: iot.0 Connection changed: connect
              2019-01-06 13:23:01.140 - info: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
              2019-01-06 13:23:01.153 - info: hm-rpc.2 xmlrpc -> 0 devices
              2019-01-06 13:25:49.354 - debug: iot.0 offline
              2019-01-06 13:25:49.355 - error: iot.0 read ECONNRESET
              2019-01-06 13:25:49.355 - info: iot.0 Connection changed: disconnect
              2019-01-06 13:25:49.355 - info: iot.0 Connection lost
              2019-01-06 13:25:54.360 - debug: iot.0 reconnect
              2019-01-06 13:25:54.694 - info: iot.0 Connection changed: connect
              2019-01-06 13:26:00.911 - warn: hm-rpc.2 [KEEPALIVE] Connection timed out
              2019-01-06 13:26:31.145 - info: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
              2019-01-06 13:26:31.156 - info: hm-rpc.2 xmlrpc -> 0 devices
              2019-01-06 13:29:31.020 - warn: hm-rpc.2 [KEEPALIVE] Connection timed out
              2019-01-06 13:29:43.540 - debug: iot.0 offline
              2019-01-06 13:29:43.540 - error: iot.0 read ECONNRESET
              2019-01-06 13:29:43.541 - info: iot.0 Connection changed: disconnect
              2019-01-06 13:29:43.541 - info: iot.0 Connection lost
              2019-01-06 13:29:48.543 - debug: iot.0 reconnect
              2019-01-06 13:29:48.901 - info: iot.0 Connection changed: connect
              2019-01-06 13:30:01.304 - info: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
              2019-01-06 13:30:01.315 - info: hm-rpc.2 xmlrpc -> 0 devices
              2019-01-06 13:33:01.200 - warn: hm-rpc.2 [KEEPALIVE] Connection timed out
              2019-01-06 13:33:31.433 - info: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
              2019-01-06 13:33:31.445 - info: hm-rpc.2 xmlrpc -> 0 devices
              2019-01-06 13:33:31.693 - debug: iot.0 offline
              2019-01-06 13:33:31.693 - error: iot.0 read ECONNRESET
              2019-01-06 13:33:31.693 - info: iot.0 Connection changed: disconnect
              2019-01-06 13:33:31.694 - info: iot.0 Connection lost
              2019-01-06 13:33:36.698 - debug: iot.0 reconnect
              2019-01-06 13:33:37.135 - info: iot.0 Connection changed: connect
              2019-01-06 13:36:31.309 - warn: hm-rpc.2 [KEEPALIVE] Connection timed out
              2019-01-06 13:36:41.681 - debug: iot.0 offline
              2019-01-06 13:36:41.682 - error: iot.0 read ECONNRESET
              2019-01-06 13:36:41.683 - info: iot.0 Connection changed: disconnect
              2019-01-06 13:36:41.683 - info: iot.0 Connection lost
              2019-01-06 13:36:46.682 - debug: iot.0 reconnect
              2019-01-06 13:36:46.981 - info: iot.0 Connection changed: connect
              2019-01-06 13:37:01.569 - info: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
              2019-01-06 13:37:01.576 - info: hm-rpc.2 xmlrpc -> 0 devices
              2019-01-06 13:40:01.433 - warn: hm-rpc.2 [KEEPALIVE] Connection timed out
              2019-01-06 13:40:31.742 - info: hm-rpc.2 xmlrpc <- listDevices ["hm-rpc.2"]
              2019-01-06 13:40:31.753 - info: hm-rpc.2 xmlrpc -> 0 devices
              2019-01-06 13:40:40.763 - debug: iot.0 offline
              2019-01-06 13:40:40.764 - error: iot.0 read ECONNRESET
              2019-01-06 13:40:40.764 - info: iot.0 Connection changed: disconnect
              2019-01-06 13:40:40.764 - info: iot.0 Connection lost
              2019-01-06 13:40:45.769 - debug: iot.0 reconnect
              2019-01-06 13:40:46.130 - info: iot.0 Connection changed: connect
              Edit by eric2905, Token entfernt und Code- und Spoiler-Tags gesetzt
                RoWi last edited by
                Gibt es die Möglichkeit auf dem Cloud Server nachzuschauen, was denn dort ankommt und ggf. zu dem Fehler führt?
                  RoWi last edited by
                  Keine Ideen?
                  • Bluefox
                    Bluefox last edited by
                    Ich kann keine Einträge mit deinem Forum Email fibden.
                    Kannst du mich unter Info@iobroker.net diesbezüglich anschreiben und dein iot login (Ohne Password) mitteilen.
                    Bluefox
                    • Bluefox
                      Meistens kommen solche Probleme wenn man entwieder 2 iot Instanzen hat (weil eine noch im Ram läuft) oder 2 Geräte
                        apollon77 last edited by
                        Für die ECONNRESET geschädigten können wir auch hier nur auf ein Isseue bei Amazon verweisen, weil das aus aktueller Sicht nicht von den ioBroker-Systemen verursacht wird.
                        Hier wäre es https://github.com/aws/aws-iot-device-sdk-js/issues/251 zum VOten und ggf Kommentieren.
                        Auch hier müssen wir glaube ich zeigen das es uns wichtig ist!
                        Ingo
                        • marcuskl
                          marcuskl last edited by
                          Gibt es schon eine Lösung für das Problem?
                          Es besteht weiterhin.
                            Karsten69 last edited by
                            Habe das von Github nochmal für alle hierhin kopiert.
                            Guten Morgen,
                            ich kann jetzt bestätigen das es an DS-Lite liegt, habe meinen Anschluss gerade auf Dual Stack umstellen lassen und der Fehler ist weg. Ich habe bei UM angerufen und hatte direkt eine sehr freundliche und kompetente Mitarbeiterin am Telefon, die genau wusste wovon ich spreche, die Umstellung erfolgte noch während des Telefonates und seitdem habe ich keine Fehlermeldungen mehr.
                            UM stellt die Anschlüsse wohl nur auf Nachfrage Kostenlos um wenn man schon ein Zusatzpaket, in meinem Fall die FB6490, hat.
                            Gruß Karsten
                            • marcuskl
                              Kann mir jemand hier helfen bei Wireshark, um das Problem Aufzuzeichnen?
                              Für Github.
                              1922
