    3. Entwicklung
    4. ZigBee CC253x Adapter - nur neue/unbekannte Geräte Version 0.9.x
      rewe9 last edited by
      Hallo ArtecL,
      nachdem ich nun den Adapter neu installiert habe , bekomme ich folgendes Log:
      host.zbox-debian 2019-01-30 10:57:24.560 info Restart adapter system.adapter.zigbee.0 because enabled
      host.zbox-debian 2019-01-30 10:57:24.560 error instance system.adapter.zigbee.0 terminated with code 1 ()
      host.zbox-debian 2019-01-30 10:57:24.560 error Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
      host.zbox-debian 2019-01-30 10:57:24.560 error Caught by controller[0]: at Module._compile (module.js:653:30)
      host.zbox-debian 2019-01-30 10:57:24.560 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:81:44)
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at require (internal/module.js:11:18)
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at Module.require (module.js:597:17)
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at Function.Module._load (module.js:498:3)
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at tryModuleLoad (module.js:506:12)
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at Module.load (module.js:566:32)
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: Error: /opt/iobroker/node_modules/serialport/build/Release/serialport.node: wrong ELF class: ELFCLASS32
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: ^
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: throw e
      host.zbox-debian 2019-01-30 10:57:24.559 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:88
      host.zbox-debian 2019-01-30 10:57:24.371 info instance system.adapter.zigbee.0 started with pid 6688
      und er bleibt dauerhaft rot. Bin gerade etwas am verzweifeln. habe meinerseits alleemögliche getestet, ohne Erfolg.
      Gruß René</anonymous>
        @Smarti2019:
        hi,
        ich habe auch das Ikea Tradfri Remote Control E1524.
        Auf der Github Seite von koenkk steht beschrieben wie man die Group daten des Remote Controlls sniffen kann.
        Hab das auch erfolgreich hinbekommen.
        Dann steht da geschrieben
        https://github.com/Koenkk/zigbee2mqtt/b … devices.md
        wie man diese daten in eine datei configuraton.yaml hinterlegt:
        devices:
        '0x000b57fffecb472d':
        friendly_name: '0x000b57fffecb472d'
        retain: false
        coordinator_group: 0xeb12
        wo finde ich das bei iobroker? `
        garnicht..wir nutzen nur den converter…
          @rewe9:
          Hallo ArtecL,
          Gruß René</anonymous> `
          das richt nach Rechte sind falsch…
          at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)</anonymous>
          • I
            ich-auch last edited by
            und hier die RGB E27 Variante
              @ich-auch:
              Aldi Bulb E27 rgb200x200.png `
              danke dir aber so genau müssen wir nicht sein… bei 128x128 sieht man den unterschied nicht
                Hallo Arteck,
                kannst du mir einen Tip geben, wie man das mit der Rechtevergabe macht.
                Vielen Dank.
                Gruß René
                  gosund last edited by
                  Du wechselst mit cd [verzeichnisname] in das entsprechende Verzeichnis, dann kannst Du Dir den Inhalt mittels
                  ls -la
                  anzeigen lassen.
                  Die Berechtigungen änderst Du mit chmod, also z.B.
                  chmod -R ugo+rwX *
                  womit Du alles im aktuellen Ordner einschließlich Unterordner für jeden freigibst.
                  das -R steht für rekursiv, ugo steht für user, group, other und +rwX steht für lesen/schreiben/ausführen bzw. öffnen (bei Ordnern)
                  Normalerweise sollte eigentlich der richtige User gesetzt werden, mittels
                  chown -R [user].[group] [Verzeichnis oder Datei]
                  Wenn Du nicht weiter kommst, dann schreib hier mal was Du siehst, wenn Du ls -la eingibst.
                  • a200
                    a200 last edited by
                    Also verstehe ich das richtig, dass die Aldi Lampen mit dem 0.9.1 Adapter laufen?
                    Ich bin zu blöd die zu pairen. :oops:
                      @gosund:
                      ls -la
                      anzeigen lassen.
                      chmod -R ugo+rwX *
                      Wenn Du nicht weiter kommst, dann schreib hier mal was Du siehst, wenn Du ls -la eingibst. `
                      das gibt die Konsole aus:
                      insgesamt 900
                      drwxr-xr-x 21 iobroker iobroker 4096 Jan 19 22:49 .
                      drwxr-xr-x 3 root root 4096 Jan 3 23:32 ..
                      -rw–----- 1 iobroker iobroker 5147 Jan 30 14:57 .bash_history
                      -rw-r--r-- 1 iobroker iobroker 220 Jan 3 23:32 .bash_logout
                      -rw-r--r-- 1 iobroker iobroker 3526 Jan 3 23:32 .bashrc
                      drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Bilder
                      drwx------ 11 iobroker iobroker 4096 Jan 4 14:34 .cache
                      drwx------ 11 iobroker iobroker 4096 Jan 19 22:48 .config
                      drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Dokumente
                      drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Downloads
                      drwx------ 3 iobroker iobroker 4096 Jan 3 23:33 .gnupg
                      -rw------- 1 iobroker iobroker 4012 Jan 5 18:54 .ICEauthority
                      drwxr-xr-x 6 iobroker iobroker 4096 Jan 19 11:10 libmicrohttpd
                      -rw-r--r-- 1 iobroker iobroker 800143 Jan 19 11:09 libmicrohttpd-0.9.19.tar.gz
                      drwxr-xr-x 3 iobroker iobroker 4096 Jan 3 23:33 .local
                      drwx------ 5 iobroker iobroker 4096 Jan 4 14:34 .mozilla
                      drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Musik
                      drwxr-xr-x 2 iobroker iobroker 4096 Jan 12 20:24 .nano
                      drwxr-xr-x 3 iobroker iobroker 4096 Jan 19 22:49 .node-gyp
                      drwxr-xr-x 5 iobroker iobroker 4096 Jan 25 13:01 node_modules
                      drwxr-xr-x 6 iobroker iobroker 4096 Jan 25 13:49 .npm
                      drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Öffentlich
                      -rw-r--r-- 1 iobroker iobroker 921 Jan 19 22:49 package-lock.json
                      drwx------ 3 iobroker iobroker 4096 Jan 5 18:08 .pki
                      -rw-r--r-- 1 iobroker iobroker 675 Jan 3 23:32 .profile
                      drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Schreibtisch
                      -rw-r--r-- 1 iobroker iobroker 66 Jan 12 20:24 .selected_editor
                      drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Videos
                      drwxr-xr-x 2 iobroker iobroker 4096 Jan 3 23:33 Vorlagen
                      Gruß René
                        enemy2003 last edited by
                        @arteck:
                        @Smarti2019:
                        hi,
                        devices:
                        retain: false
                        garnicht..wir nutzen nur den converter… `
                        sry dass ich so unwissend nachfragen muss :oops: aber ich finde es einfach nicht. Wo kann man das mit dem converter nachlesen? Braucht man dann zusätzlich zigbee2mqtt oder wie ist das? Wäre so toll dieses Gerät zum laufen zu bekommen 🙂
                        Vielen Dank!
                        // Update… mit Browser Cache leeren, Gerät nochmal löschen (auch aus der shepherd.db) und neu verbinden ist es nun zu sehen. Die Buttons wurden als Objekte angelegt. Leider ohne Funktion. Was fehlt noch?
                          @rewe9:
                          @gosund:
                          ls -la
                          anzeigen lassen.
                          chmod -R ugo+rwX *
                          insgesamt 900
                          Gruß René `
                          sorry,die konsole im iobroker gibt folgendes aus:
                          insgesamt 268
                          4 drwxrwxrwx 2 iobroker root 4096 Jan 25 18:06 backups
                          4 drwxrwxrwx 2 iobroker root 4096 Jan 21 08:12 cache
                          4 drwxrwxrwx 2 iobroker root 4096 Mär 30 2018 etc
                          4 drwxr-xr-x 5 iobroker root 4096 Jan 5 18:16 install
                          4 -rwxrwxrwx 1 iobroker root 297 Apr 1 2018 install.sh
                          4 -rwxr-xr-x 1 iobroker root 67 Jan 4 14:52 iob
                          4 -rwxr-xr-x 1 iobroker root 67 Apr 1 2018 iobroker
                          4 drwxrwxrwx 8 iobroker root 4096 Jan 27 18:05 iobroker-data
                          4 -rwxrwxrwx 1 iobroker root 92 Nov 9 14:35 killall.sh
                          4 drwxr-xr-x 2 iobroker root 4096 Jan 5 18:16 lib
                          4 -rw-r–r-- 1 iobroker root 1137 Jan 5 18:16 LICENSE
                          4 drwxrwxrwx 2 iobroker root 4096 Jan 30 01:29 log
                          24 drwxrwxrwx 661 iobroker root 20480 Jan 30 10:54 node_modules
                          16 -rw-r--r-- 1 iobroker root 16177 Jan 4 00:27 npm-debug.log
                          4 -rwxrwxrwx 1 iobroker iobroker 841 Jan 30 10:54 package.json
                          164 -rw-r--r-- 1 iobroker root 164479 Jan 4 14:52 package-lock.json
                          8 -rw-r--r-- 1 iobroker root 6101 Jan 5 18:16 README.md
                          4 -rwxrwxrwx 1 iobroker root 709 Nov 9 14:35 reinstall.sh
                            Mordrad last edited by
                            @enemy2003:
                            @arteck:
                            @Smarti2019:
                            hi,
                            devices:
                            retain: false
                            Vielen Dank!
                            // Update… mit Browser Cache leeren, Gerät nochmal löschen (auch aus der shepherd.db) und neu verbinden ist es nun zu sehen. Die Buttons wurden als Objekte angelegt. Leider ohne Funktion. Was fehlt noch? `
                            An die Frage würde ich mich auch gerne anschließen. Anmelden der Remote war erfolgreich, allerdings ändern sich die States nicht. Beim Ersten ButtonPress hatte ich folgende Zeile im Log: "Zigbee publish to '0x000b57fffe3089cc', genBasic - 0 - [{"attrId":16384},{"attrId":3}] - 1 failed with error Error: AF data request fails, status code: 183. APS no ack."
                              Smarti2019 last edited by
                              @Smarti2019:
                              hi,
                              devices:
                              retain: false
                              hier aktuell gelöst:
                              https://github.com/ioBroker/ioBroker.zigbee/issues/178
                              funktioniert danach 1A, kann jetzt meine Tradfri Leuchten oder andere Dinge per Remote FB zumindest an und ausschalten.
                              Es werden aber alle Tasten unter den Objekten aufgeführt und es kommt auch treffend eine Reaktion
                              gruss
                              Blacksoul87 created this issue in ioBroker/ioBroker.zigbee
                              closed How can i find configuration.yaml file :( #178
                                @Smarti2019:
                                @Smarti2019:
                                hi,
                                devices:
                                retain: false
                                gruss `
                                Wo sind die Gruppen? Den Tab gibt es bei mir nicht <emoji seq="1f648">🙈</emoji>
                                  du hast den aktuellen adapter zigbee installiert?
                                  0.9.1 ist aktuell !
                                  gruss
                                    Siegfried Forum Testing last edited by
                                    Nach update auf 0.9.0 geht der Xiaomi lumi.sensor_86sw2 nicht mehr
                                    Rest ok
                                    sg
                                    Edit: nach update auf 0.9.1 wieder alles super; danke für den super Adapter
                                      @Smarti2019:
                                      0.9.1 ist aktuell !
                                      gruss `
                                      Ja war schon installiert. Aber Adapter und Instanz sauber löschen und neu installieren dann klappt’s auch <emoji seq="1f44d-1f3fb">👍🏻</emoji> Danke
                                      Kann man die Group ohne 2. Stick auslesen?
                                        @enemy2003:
                                        Wie hast Du das gemacht?
                                          @gosund:
                                          @enemy2003:
                                          Wie hast Du das gemacht? `
                                          Na erst die Instanz löschen, dann den Adapter. Dann aus der git repo den Adapter neu installieren und daraus eine Instanz erzeugen <emoji seq="263a">☺️</emoji> Viel Erfolg
                                            Ok, Danke. Also nur über die Web-Oberfläche reicht.
                                            Aber wo finde ich die aktuelle 0.9.1?
                                            Nachdem ich eben alles entfernt habe und dann https://github.com/arteck/ioBroker.zigbee
                                            installiert habe, bin ich laut Version immer noch bei 0.9.0 - allerdings jetzt auf deutsch 🙂
                                            894
                                            228426
