    2. Русский
    3. ioBroker
    4. Скрипты
    5. node-red Скрипты (flows)
    6. Node-RED примеры, решения и и вопросы. Общая тема по Node-RED
      andryp last edited by
      Вот пример как определить расстояние от дома. Ставим адаптер Find my iphone, пишем такой скрипт в NR:
      ! [{"id":"1c09c50c.74d60b","type":"function","z":"99a1edcb.6bb1","name":"GetLocation","func":"\nvar home_long = 11.11111;\nvar home_alt = 22.22222;\n\n//var values = flow.get(["latitude", "longitude"]);\n \nvar long_target = 0; \nvar alt_target = 0;\n\nlong_target = parseFloat(flow.get('LO'));// values[1];\nalt_target = parseFloat(flow.get('LA'));\n//node.log(long_target);\n//node.log(alt_target);\n\n\nmsg.payload = 63711000Math.acos(Math.sin(Math.PIhome_alt/180)Math.sin(Math.PIalt_target/180)+Math.cos(Math.PIhome_alt/180)Math.cos(Math.PIalt_target/180)Math.cos(Math.PI(home_long-long_target)/180));\n// вывод в лог расстояния в метрах\nreturn msg;","outputs":1,"noerr":0,"x":690,"y":260,"wires":[["6b23990b.f116c8"]]},{"id":"6b23990b.f116c8","type":"debug","z":"99a1edcb.6bb1","name":"Расстояние","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":870,"y":260,"wires":[]},{"id":"282f31cf.40579e","type":"change","z":"99a1edcb.6bb1","name":"Set LA.","rules":[{"t":"set","p":"LA","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":240,"wires":[["1c09c50c.74d60b","642dcb16.a76cb4"]]},{"id":"eed8108f.ea0d9","type":"change","z":"99a1edcb.6bb1","name":"SET LO","rules":[{"t":"set","p":"LO","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":280,"wires":[["1c09c50c.74d60b","c013725a.bbb22"]]},{"id":"642dcb16.a76cb4","type":"debug","z":"99a1edcb.6bb1","name":"LA","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":510,"y":200,"wires":[]},{"id":"c013725a.bbb22","type":"debug","z":"99a1edcb.6bb1","name":"LO","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":510,"y":320,"wires":[]},{"id":"e7628b0a.cbcc18","type":"ioBroker get","z":"99a1edcb.6bb1","name":"latitude","topic":"find-my-iphone.0.iPhone_(TELE).latitude","attrname":"payload","payloadType":"value","x":340,"y":240,"wires":[["282f31cf.40579e"]]},{"id":"452ba365.3c988c","type":"ioBroker get","z":"99a1edcb.6bb1","name":"longitude","topic":"find-my-iphone.0.iPhone_(TELE).longitude","attrname":"payload","payloadType":"value","x":340,"y":280,"wires":[["eed8108f.ea0d9"]]},{"id":"5e3ac9eb.238b68","type":"trigger","z":"99a1edcb.6bb1","op1":"60","op2":"1","op1type":"num","op2type":"str","duration":"-1","extend":false,"units":"min","reset":"","bytopic":"all","name":"","x":170,"y":240,"wires":[["e7628b0a.cbcc18","452ba365.3c988c"]]},{"id":"1bc2b34.ef3094d","type":"inject","z":"99a1edcb.6bb1","name":"","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":150,"y":200,"wires":[["5e3ac9eb.238b68"]]}]
      P.S. Спасибо telegram @cahek2202 за код расчета расстояния по координатам.
        Smitkas last edited by
        Собрал схему для управления точечными светильниками philips zhirui downlight
        единственная проблема - слишком большая задержка (((
        Нужно установить
        php
        php-miio-master
        node-red-contrib-string
        включить/выключить
        php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_power","params":["on"]}'
        php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_power","params":["off"]}'
        переключить
        php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"toggle",,"params":[]}'
        яркость (от 1 до 100)
        php /home/pi/php-miio-master/miio-cli.php --ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_bright","params":[1]}'
        цветовая температура (1-желтый, 100 – белый)
        php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_cct","params":[100]}'
        сцены (от 1 до 4)
        php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"apply_fixed_scene","params":[1]}'
        статус (php miio-cli.php –ip ип лампы --token токен лампы --sendcmd '{"id":1,"method":"get_prop","params":["power","bright", ,"cct","snm","dv"]}')
        php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"get_prop","params":["power","bright", ,"cct","snm","dv"]}'
        ! "id": "8d7ab50b.086a48",
        ! "type": "tab",
        ! "label": "Flow 3",
        ! "disabled": false,
        ! "info": ""
        ! "id": "1199f0d9.331b1f",
        ! "type": "ioBroker in",
        ! "z": "8d7ab50b.086a48",
        ! "name": "First button pressed",
        ! "topic": "mihome.0.devices.86sw2_158d000233827e.channel_0",
        ! "payloadType": "value",
        ! "onlyack": "",
        ! "func": "all",
        ! "gap": "",
        ! "x": 170,
        ! "y": 180,
        ! "wires": [
        ! "82596561.899ce8"
        ! "id": "dc776a4c.fbd218",
        ! "type": "inject",
        ! "name": "Button",
        ! "topic": "",
        ! "payload": "true",
        ! "payloadType": "str",
        ! "repeat": "",
        ! "crontab": "",
        ! "once": false,
        ! "onceDelay": 0.1,
        ! "x": 150,
        ! "y": 400,
        ! "wires": [
        ! "345c5f57.38ca6"
        ! "id": "345c5f57.38ca6",
        ! "type": "switch",
        ! "name": "only true",
        ! "property": "payload",
        ! "propertyType": "msg",
        ! "rules": [
        ! "t": "eq",
        ! "v": "true",
        ! "vt": "str"
        ! "checkall": "true",
        ! "repair": false,
        ! "outputs": 1,
        ! "x": 280,
        ! "y": 320,
        ! "wires": [
        ! "b643cffa.5e1ac",
        ! "b1c46b43.e444d8"
        ! "id": "78dad649.35d498",
        ! "type": "switch",
        ! "name": "Is Light On?",
        ! "property": "STAT1",
        ! "propertyType": "flow",
        ! "rules": [
        ! "t": "eq",
        ! "v": "false",
        ! "vt": "str"
        ! "t": "eq",
        ! "v": "true",
        ! "vt": "str"
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 530,
        ! "y": 320,
        ! "wires": [
        ! "66ee6bc9.126594"
        ! "10645dc0.7ac9e2"
        ! "id": "66ee6bc9.126594",
        ! "type": "change",
        ! "name": "PowerOn Lamp",
        ! "rules": [
        ! "t": "set",
        ! "p": "payload",
        ! "pt": "msg",
        ! "to": "true",
        ! "tot": "bool"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 800,
        ! "y": 280,
        ! "wires": [
        ! "64e1cf4e.ec14a"
        ! "id": "10645dc0.7ac9e2",
        ! "type": "change",
        ! "name": "PowerOff Lamp",
        ! "rules": [
        ! "t": "set",
        ! "p": "payload",
        ! "pt": "msg",
        ! "to": "true",
        ! "tot": "bool"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 800,
        ! "y": 340,
        ! "wires": [
        ! "f262cc14.faa8e"
        ! "id": "9a8e714.224659",
        ! "type": "exec",
        ! "command": "php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_power","params":["off"]}'",
        ! "addpay": true,
        ! "append": "",
        ! "useSpawn": "false",
        ! "timer": "",
        ! "oldrc": false,
        ! "name": "",
        ! "x": 780,
        ! "y": 1080,
        ! "wires": [
        ! "id": "bec64fe2.71292",
        ! "type": "exec",
        ! "command": "php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"set_power","params":["on"]}'",
        ! "addpay": true,
        ! "append": "",
        ! "timer": "",
        ! "oldrc": false,
        ! "name": "power on",
        ! "x": 1060,
        ! "y": 260,
        ! "wires": [
        ! "id": "7c0af08b.0c659",
        ! "type": "switch",
        ! "name": "STAT1",
        ! "rules": [
        ! "t": "cont",
        ! "v": "true",
        ! "vt": "str"
        ! "t": "cont",
        ! "v": "false",
        ! "vt": "str"
        ! "checkall": "false",
        ! "repair": false,
        ! "outputs": 2,
        ! "x": 830,
        ! "y": 160,
        ! "wires": [
        ! "8a2dac90.3ca8c"
        ! "ed111c41.dcf5"
        ! "id": "8a2dac90.3ca8c",
        ! "type": "change",
        ! "name": "Light On",
        ! "rules": [
        ! "t": "set",
        ! "p": "STAT1",
        ! "pt": "flow",
        ! "to": "true",
        ! "tot": "str"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 1040,
        ! "y": 140,
        ! "wires": [
        ! "id": "ed111c41.dcf5",
        ! "type": "change",
        ! "name": "Light Off",
        ! "rules": [
        ! "t": "set",
        ! "p": "STAT1",
        ! "pt": "flow",
        ! "to": "false",
        ! "tot": "str"
        ! "action": "",
        ! "property": "",
        ! "from": "",
        ! "to": "",
        ! "reg": false,
        ! "x": 1040,
        ! "y": 200,
        ! "wires": [
        ! "id": "b643cffa.5e1ac",
        ! "type": "exec",
        ! "command": "php /home/pi/php-miio-master/miio-cli.php –ip 192.168.1.236 --token 57014f99f369ff772cad86955f44c17c --sendcmd '{"id":1,"method":"get_prop","params":["power"]}'",
        ! "addpay": false,
        ! "append": "",
        ! "timer": "",
        ! "oldrc": false,
        ! "name": "Lamp status?",
        ! "x": 480,
        ! "y": 160,
        ! "wires": [
        ! "c1d9f7ec.d097c8"
        ! "id": "81a1c26a.2224b",
        ! "type": "inject",
        ! "name": "Button",
        ! "topic": "",
        ! "repeat": "",
        ! "crontab": "",
        ! "once": false,
        ! "onceDelay": 0.1,
        ! "x": 150,
        ! "y": 120,
        ! "wires": [
        ! "b643cffa.5e1ac"
        ! "id": "c1d9f7ec.d097c8",
        ! "type": "string",
        ! "name": "",
        ! "methods": [
        ! "name": "toString",
        ! "params": []
        ! "name": "between",
        ! "params": [
        ! "type": "str",
        ! "value": "result":[""
        ! "type": "str",
        ! "value": ""],"id""
        ! "params": []
        ! "name": "toBoolean",
        ! "params": []
        ! "prop": "payload",
        ! "propout": "payload",
        ! "object": "msg",
        ! "objectout": "msg",
        ! "x": 690,
        ! "y": 160,
        ! "wires": [
        ! "7c0af08b.0c659"
        ! "id": "34ba9712.3e5b88",
        ! "type": "exec",
        ! "addpay": true,
        ! "append": "",
        ! "timer": "",
        ! "oldrc": false,
        ! "name": "power off",
        ! "x": 1060,
        ! "y": 340,
        ! "wires": [
        ! "id": "f262cc14.faa8e",
        ! "type": "delay",
        ! "name": "",
        ! "pauseType": "delay",
        ! "timeout": "1400",
        ! "timeoutUnits": "milliseconds",
        ! "rate": "1",
        ! "nbRateUnits": "1",
        ! "rateUnits": "second",
        ! "randomFirst": "1",
        ! "randomLast": "5",
        ! "randomUnits": "seconds",
        ! "drop": false,
        ! "x": 820,
        ! "y": 400,
        ! "wires": [
        ! "34ba9712.3e5b88"
        ! "id": "64e1cf4e.ec14a",
        ! "type": "delay",
        ! "name": "",
        ! "rate": "1",
        ! "drop": false,
        ! "x": 800,
        ! "y": 220,
        ! "wires": [
        ! "bec64fe2.71292"
        ! "id": "b1c46b43.e444d8",
        ! "type": "delay",
        ! "name": "",
        ! "rate": "1",
        ! "drop": false,
        ! "x": 540,
        ! "y": 240,
        ! "wires": [
        ! "78dad649.35d498"
        ! "id": "82596561.899ce8",
        ! "type": "trigger",
        ! "op1": "true",
        ! "op2": "",
        ! "op1type": "str",
        ! "op2type": "nul",
        ! "duration": "5300",
        ! "extend": false,
        ! "units": "ms",
        ! "reset": "",
        ! "bytopic": "all",
        ! "name": "",
        ! "x": 240,
        ! "y": 260,
        ! "wires": [
        ! "345c5f57.38ca6"
        • O
          OlegJktu last edited by
          @Smitkas:
          Собрал схему для управления точечными светильниками philips zhirui downlight `
          А вот все равно спасибо. А то отсутствие вариантов с miio уже начинает напрягать.
          Встречный вопрос. Пробовали кубики с miio (они должны быть на nodejs и быстрее и там есть general device)
          1. https://flows.nodered.org/node/node-red-contrib-mi-miio
          2. https://flows.nodered.org/node/node-red … iaomi-miio
          3. https://flows.nodered.org/node/node-red ... io-wrapper
          Я пробывал 2 и 3 в докер контейнере с iobroker и node-red и Node-red сдох, пришлось поднимать контейнер и бекапа. Так что перед экспериментами сохраняемся!
          Очень хотел попробовать с отдельного хоста/контейнера, но в итоге руки так и не дошли.
          UPD лампы еще должны затаскиваться в iobroker через драйвер HAM (там искать miio), но я HAM пока не победил.
            MihaNN52 last edited by
            Кто нибудь подключал датчик холла к малине с нодом для подсчета импульсов. а-ля прерывания как организовать и можно ли вообще?
              Sergey777 last edited by
              В Node-red есть блок function, в описании этого блока, в примерах, на сайте, есть счетчик, сколько раз функция была запущена. А как уж подключить датчик к малине и увидеть его в Node-RED - незнаю.
                Как запустить из нода что то понятно, а как сделать чтоб нод отреагировал не понимаю.
                  @MihaNN52:
                  Как запустить из нода что то понятно, а как сделать чтоб нод отреагировал не понимаю. `
                  Вы имеете в виду, как увидеть сигнал с пина малинки в Node-RED? Если Вы ставили образ iobroker, то в нем есть все необходимые плагины, в панели есть, вроде, эти элементы.
                  P.S.вот же:
                    ой…. и правда :lol:
                    • O
                      Вот здесь решили проблему с записью символов в файл в win
                      viewtopic.php?f=26&t=21288
                        @OlegJktu:
                        viewtopic.php?f=26&t=21288 `
                        Так не понятно, какую ноду дополнительно установили? Ссылку дадите, или полное название?
                          Привет всем! Я столнулся со схожей проблемой, что в сообщении выше.
                          Я тут приводил такой пример: viewtopic.php?f=48&t=11969#p152942 ,там всё работало, пока я не обновил iobroker.
                          Суть в чём:
                          Имею такую конструкцию
                          ! [ { "id": "58ad33b2.fabb1c", "type": "http request", "z": "f9e33a52.dacda8", "name": "", "method": "POST", "ret": "txt", "url": "http://192.168.1.2:5000/webapi/entry.cgi?api=SYNO.Chat.External&method=incoming&version=2&token=\"QERFWrtrg4t5\"&payload={\"text\": \"кирилица\"}", "tls": "", "x": 490, "y": 1200, "wires": [ [ "27422c15.fd50d4" ] ] }, { "id": "27422c15.fd50d4", "type": "debug", "z": "f9e33a52.dacda8", "name": "Door Sensor Status", "active": true, "tosidebar": true, "console": false, "tostatus": true, "complete": "payload", "x": 720, "y": 1200, "wires": [] }, { "id": "626ece3b.a16df", "type": "inject", "z": "f9e33a52.dacda8", "name": "", "topic": "", "payload": "true", "payloadType": "str", "repeat": "", "crontab": "", "once": false, "onceDelay": 0.1, "x": 290, "y": 1200, "wires": [ [ "58ad33b2.fabb1c" ] ] } ] !
                          Тут на сервер отправляется сообщение методом POST. Так вот, если в сообщении содержится кириллица, то вылетает ошибка, и ничего не отправляется.
                          log:
                          |node-red.0|2019-01-27 22:12:01.260|error|at processImmediate [as _immediateCallback] (timers.js:745:5)|
                          |node-red.0|2019-01-27 22:12:01.260|error|at tryOnImmediate (timers.js:768:5)|
                          |node-red.0|2019-01-27 22:12:01.260|error|at runCallback (timers.js:810:20)|
                          |node-red.0|2019-01-27 22:12:01.260|error|at Immediate. <anonymous>(/opt/iobroker/node_modules/request/request.js:578:7)|
                          |node-red.0|2019-01-27 22:12:01.260|error|at end (/opt/iobroker/node_modules/request/request.js:549:18)|
                          |node-red.0|2019-01-27 22:12:01.260|error|at Request.write (/opt/iobroker/node_modules/request/request.js:1497:10)|
                          |node-red.0|2019-01-27 22:12:01.260|error|at Request.start (/opt/iobroker/node_modules/request/request.js:751:32)|
                          |node-red.0|2019-01-27 22:12:01.260|error|at Object.request (http.js:39:10)|
                          |node-red.0|2019-01-27 22:12:01.260|error|at new ClientRequest (_http_client.js:137:13)|
                          |node-red.0|2019-01-27 22:12:01.260|error|27 Jan 22:12:01 - [error] [http request:TEST DOOR] TypeError: Request path contains unescaped characters|</anonymous>
                          Debug messages
                          msg : error
                          "TypeError: Request path contains unescaped characters"
                          msg.payload : string[247]
                          "TypeError: Request path contains unescaped characters : http://192.168.1.2:5000/webapi/entry.cgi?api=SYNO.Chat.External&method=incoming&version=2&token="QERFWrtrg4t5"&payload={"text": "кирилица"}"
                          Если писать латинскими символами, то всё работает.
                          P.S. ioBroker стоит на малине, раньше ставил образ 2017 года, на нём всё работало. Но система посыпалась, поставил новый образ, и теперь не работает с кириллицей. Мне кажется, что не хватает каких-то кодировок в системе и Node-RED тут не при чём.
                          Подкиньте идей, пожалуйста.
                          ****<size size="150">******************************************************</size>****
                          P.P.S.
                          Нашёл решение - предварительно перекодируем сообщение функцией encodeURIComponent()
                           ![5574_cyrillicmessage.png](/assets/uploads/files/5574_cyrillicmessage.png)
                          msg.CyrillicMessage = encodeURIComponent('Привет Мир');
                          return msg;
                          И "Привет Мир" превращается в "%D0%9F%D1%80%D0%B8%D0%B2%D0%B5%D1%82%20%D0%9C%D0%B8%D1%80", а это уже прокатывает, отправка сообщений кириллицей работает.
                          Вот полный код, url до сервера, естественно, изменён, каждый вбивает свой собственный:
                                  "id": "20b1742.e00da8c",
                                  "z": "64e8a21a.233f3c",
                                  "name": "",
                                  "method": "POST",
                                  "ret": "txt",
                                  "url": "http://192.168.1.2:5000/webapi/entry.cgi?api=SYNO.Chat.External&method=incoming&version=2&token=%22TvDtggrtGr%22&payload={\"text\": \"{{{CyrillicMessage}}}\"}",
                                  "tls": "",
                                  "x": 830,
                                  "y": 160,
                                  "wires": [
                                          "9039465f.edbf18"
                                  "id": "9039465f.edbf18",
                                  "type": "debug",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": true,
                                  "x": 1040,
                                  "y": 160,
                                  "wires": []
                                  "id": "ae787e2c.09a418",
                                  "type": "inject",
                                  "name": "",
                                  "topic": "",
                                  "payload": "true",
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "x": 450,
                                  "y": 160,
                                  "wires": [
                                          "8ec1277c.0cdf2"
                                  "id": "8ec1277c.0cdf2",
                                  "type": "function",
                                  "name": "Текст сообщения",
                                  "func": "msg.CyrillicMessage = encodeURIComponent('Привет Мир');\nreturn msg;",
                                  "outputs": 1,
                                  "noerr": 0,
                                  "x": 630,
                                  "y": 160,
                                  "wires": [
                                          "c6325ef1.f616b",
                                          "20b1742.e00da8c"
                                  "id": "c6325ef1.f616b",
                                  "type": "debug",
                                  "name": "",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": true,
                                  "complete": "CyrillicMessage",
                                  "x": 860,
                                  "y": 100,
                                  "wires": []
                            Anrikigai last edited by
                            Только начал осваивать Node-Red, и сразу вопросы:
                            1. Можно ли в функции определить исходную команду, а не только источник?
                              Скажем, при получении сигнала от кубика Rotate Left нужно некий параметр уменьшить, а по Rotate Right увеличить.
                              Сейчас у меня после ioBroker in с событием Rotate right идет Change, в котором true меняется на 1, и анаогично Rotate left -> Change, меняющий true на -1.
                              Оба этих события сходятся в одну функцию, которая соответственно меняет громкость, яркость, что угодно.
                              Но по идее промежуточные Change не очень нужны. Можно сразу с Rotate Left и Rotate Right на эту функцию сигнал подать. Да, в обоих случаях будет true, но наверняка же в этой функции можно определить, было это вызвано поворотм влево или вправо?
                              Собственно аналогично отделять одинарное нажатие кнопки от двойного и т.п....
                            2. Нажатие кнопки у меня приводит к последовательному приходу событий от нее true и сразу false.
                              Я придумал 2 способа очистки. Switch, который пропускает только true. И Delay, в котором при выборе Rate Limit | All messages появляется пункт drop intermediate messages.
                              Результат одинаковый. Что эффективнее? Может еще получше вариант есть?
                            3. Как использовать ioBroker get node? Расположена в группе function. Насколько я понимаю, в отличие от ioBroker in node, посылающей сообщение дальше, get позволяет узнать текущее состояние. Но как? Что подать ей на вход и что на выход?
                              Скажем, сейчас я In node направляю на сохранение переменной во flow (скажем, параметр dimmer), и потом его использую. Но лучше же опрашивать статус, когда понадобится, а не подписываться на него?
                              Ну или хотя бы в коде функции как опросить произвольный параметр...
                            4. Можно ли из функции на Node-Red пройтись по всем датчикам (в моем случае подключены через Xiaomi Gateway 2) и, к примеру, проверить заряд их батрейки?
                              Ну а дальше либо вывести "аварийные" датчики, либо записать 0/1 в дополнительное поле каждого сенсора (к примеру, BatteryStatus) и указывать его в Metro плитках (они автоматически перекрашиваются в зависимости от "ID статуса"
                            • O
                              OlegJktu last edited by OlegJktu
                              1. если в обьектах нет, то без вариантов. Можно еще конечно лог глянуть. Только дебаг нужно включить.
                                1.1) возможно через usb-zigbee свиток драйвер отдает больше.
                              2. Я думаю без разницы.
                              3. На JS такое видел. На Node-red по моему только руками (ну или js засунуть в кубик). js пример есть на форуме, но он тоже не идеальный - там отдает id объекта - это не человеко читаемо.
                              4. Нужно мне самому попробовать на выходных,
                                ioBroker get node - точно будет красиво попробовать засунуть в Node-red dash реле-выключатель (но визуализаций на iobroker больше пяти, так что...)
                              • No Name
                                No Name last edited by No Name
                                Управление broadlink кнопкой xiaomi (драйвер zigbee). Исправил flow выше. Здесь нужен таймер и switch должен быть таким:
                                "id": "cf416abd.c92158",
                                "type": "tab",
                                "label": "Broadlink_STATUS",
                                "disabled": false,
                                "info": ""
                                "id": "5dae1e2f.960c38",
                                "type": "ioBroker out",
                                "z": "cf416abd.c92158",
                                "name": "Sonoff_POW_2",
                                "topic": "sonoff.0.Sonoff_POW_2_A02EBD.POWER",
                                "ack": "false",
                                "autoCreate": "false",
                                "x": 1700,
                                "y": 880,
                                "wires": []
                                "id": "b8e33699.63a34",
                                "name": "Tap twice",
                                "topic": "zigbee.0.00158d00029bbb6c.tap",
                                "onlyack": "",
                                "func": "all",
                                "gap": "",
                                "x": 100,
                                "y": 460,
                                "wires": [
                                "864b8892.25f1a"
                                "id": "80c6e025.1825e8",
                                "type": "switch",
                                "name": "Broadlink включен?",
                                "property": "Broadlink_STATUS",
                                "rules": [
                                "t": "eq",
                                "v": "false",
                                "vt": "str"
                                "t": "eq",
                                "v": "true",
                                "vt": "str"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 540,
                                "y": 460,
                                "wires": [
                                "aff64449.5b9498"
                                "3b2d8770.0222c8"
                                "id": "aff64449.5b9498",
                                "type": "change",
                                "name": "Включаем Broadlink",
                                "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "true",
                                "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 860,
                                "y": 400,
                                "wires": [
                                "9ea4024f.45e7d",
                                "b50086c9.ce0408"
                                "id": "3b2d8770.0222c8",
                                "type": "change",
                                "name": "Отключаем Broadlink",
                                "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "false",
                                "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 820,
                                "y": 520,
                                "wires": [
                                "a4d8b0b.c5ed45",
                                "58937c89.b8335c"
                                "id": "9ea4024f.45e7d",
                                "type": "SP2",
                                "name": "Bathoom",
                                "device": "6a792cc8.2a6eac",
                                "action": "setState",
                                "state": "true",
                                "x": 1100,
                                "y": 440,
                                "wires": [
                                "id": "a4d8b0b.c5ed45",
                                "type": "SP2",
                                "name": "Bathoom",
                                "state": "false",
                                "x": 1100,
                                "y": 520,
                                "wires": [
                                "id": "864b8892.25f1a",
                                "type": "switch",
                                "name": "Берём только true",
                                "rules": [
                                "t": "eq",
                                "v": "true",
                                "vt": "str"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 1,
                                "x": 290,
                                "y": 460,
                                "wires": [
                                "80c6e025.1825e8"
                                "id": "58937c89.b8335c",
                                "type": "debug",
                                "name": "Отключаем",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "x": 1110,
                                "y": 600,
                                "wires": []
                                "id": "b50086c9.ce0408",
                                "type": "debug",
                                "name": "Включаем",
                                "active": true,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "x": 1190,
                                "y": 380,
                                "wires": []
                                "id": "ba2cb790.e57ee",
                                "type": "SP2",
                                "name": "Bathoom",
                                "action": "getState",
                                "state": "true",
                                "x": 380,
                                "y": 300,
                                "wires": [
                                "60e40fa1.b78738"
                                "id": "60e40fa1.b78738",
                                "type": "switch",
                                "name": "Передаём статус broadlink",
                                "property": "payload.state",
                                "rules": [
                                "t": "true"
                                "t": "false"
                                "repair": false,
                                "outputs": 2,
                                "x": 600,
                                "y": 300,
                                "wires": [
                                "1be7b90d.421cf7"
                                "6bb3ee18.8728d8"
                                "id": "1be7b90d.421cf7",
                                "type": "change",
                                "name": "Broadlink ON",
                                "rules": [
                                "t": "set",
                                "p": "Broadlink_STATUS",
                                "pt": "flow",
                                "to": "true",
                                "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 890,
                                "y": 220,
                                "wires": [
                                "id": "6bb3ee18.8728d8",
                                "type": "change",
                                "name": "Broadlink OFF",
                                "rules": [
                                "t": "set",
                                "pt": "flow",
                                "to": "false",
                                "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 960,
                                "y": 340,
                                "wires": [
                                "id": "12b779f5.16f1a6",
                                "type": "comment",
                                "name": "Тут логика работы",
                                "info": "",
                                "x": 450,
                                "y": 380,
                                "wires": []
                                "id": "74adb82d.c4c64",
                                "type": "comment",
                                "name": "Тут определяем состояние реле Broadlink",
                                "info": "",
                                "x": 490,
                                "y": 220,
                                "wires": []
                                "id": "eb30ea3d.afc17",
                                "type": "inject",
                                "name": "",
                                "topic": "",
                                "payload": "",
                                "payloadType": "date",
                                "repeat": "1",
                                "crontab": "",
                                "once": false,
                                "onceDelay": 0.1,
                                "x": 170,
                                "y": 300,
                                "wires": [
                                "ba2cb790.e57ee"
                                "id": "743f811.46788",
                                "type": "bigtimer",
                                "outtopic": "",
                                "outpayload1": "",
                                "outpayload2": "",
                                "name": "Big Timer",
                                "comment": "",
                                "lat": "",
                                "lon": "",
                                "starttime": 5001,
                                "endtime": 1425,
                                "starttime2": 0,
                                "endtime2": 0,
                                "startoff": 0,
                                "endoff": 0,
                                "startoff2": 0,
                                "endoff2": 0,
                                "offs": 0,
                                "outtext1": "",
                                "outtext2": "",
                                "timeout": 1440,
                                "sun": true,
                                "mon": true,
                                "tue": true,
                                "wed": true,
                                "thu": true,
                                "fri": true,
                                "sat": true,
                                "jan": true,
                                "feb": true,
                                "mar": true,
                                "apr": true,
                                "may": true,
                                "jun": true,
                                "jul": true,
                                "aug": true,
                                "sep": true,
                                "oct": true,
                                "nov": true,
                                "dec": true,
                                "day1": 0,
                                "month1": 0,
                                "day2": 0,
                                "month2": 0,
                                "day3": 0,
                                "month3": 0,
                                "day4": 0,
                                "month4": 0,
                                "day5": 0,
                                "month5": 0,
                                "day6": 0,
                                "month6": 0,
                                "d1": 0,
                                "w1": 0,
                                "d2": 0,
                                "w2": 0,
                                "d3": 0,
                                "w3": 0,
                                "d4": 0,
                                "w4": 0,
                                "d5": 0,
                                "w5": 0,
                                "d6": 0,
                                "w6": 0,
                                "xday1": 0,
                                "xmonth1": 0,
                                "xday2": 0,
                                "xmonth2": 0,
                                "xday3": 0,
                                "xmonth3": 0,
                                "xday4": 0,
                                "xmonth4": 0,
                                "xday5": 0,
                                "xmonth5": 0,
                                "xday6": 0,
                                "xmonth6": 0,
                                "xd1": 0,
                                "xw1": 0,
                                "xd2": 0,
                                "xw2": 0,
                                "xd3": 0,
                                "xw3": 0,
                                "xd4": 0,
                                "xw4": 0,
                                "xd5": 0,
                                "xw5": 0,
                                "xd6": 0,
                                "xw6": 0,
                                "suspend": false,
                                "random": false,
                                "repeat": true,
                                "atstart": true,
                                "odd": false,
                                "even": false,
                                "x": 80,
                                "y": 160,
                                "wires": [
                                "id": "6a792cc8.2a6eac",
                                "type": "sp2device",
                                "z": "",
                                "mac": "78-0F-77-17-8D-49",
                                "host": "192.168.1.5"
                                • N
                                  notturno last edited by
                                  Ребят, подскажите, кто знает, как можно решить такую проблемку.
                                  Работают схемы, сценарии в Node-red, включены выключатели, настроены ползунки, расписание и т.д.
                                  Но вот когда комп перезагружается, то все настройки сбиваются, и что бы вернуть все как было, нужно заново все нажимать.
                                  Как можно это исправить?
                                  • O
                                    Было такое выше обсуждалось.
                                    Нод-Ред не хранит значения, поэтому логика с переменными при старте может подвисать.
                                    1. можно задать логику при старте. Для этого нужно поставить доп кубик. Таких есть 2 или 3.
                                    Вот тут я добавил кубик задающий логику при старте
                                    https://forum.iobroker.net/post/149786
                                    1. можно хранить переменные этой логике где-то за пределами Нод-Ред.
                                      Я храню в переменных IoBroker.
                                    • O
                                      Важнач информация для всех использующих Node-red из под IoBroker.
                                      Дополнительные паллеты (кубики и пр) нужно устанавливать из вебморды IoBroker (а не из вебморды Node-red).
                                      Иначе возможны проблемы при обновлении.
                                      • O
                                        Wiki переведенная на русский язык
                                        (Если не пускает используйте режим инкогнито в браузере)
                                        http://146.185.179.211/wiki/Node-RED:Содержание
                                          Столкнулся с не тривиальной задачей. Нода onvif получает из IP камеры скриншот, этот скрин можно отобразить в ноде image. Мне нужно эту картинку отослать как webhook, для этого нужно картинку выгрузить в хранилище (на сервер) и потом дать http ссылку на неё. Как эту полученную в base64 картинку выгрузить на http сайт?
                                            romus last edited by
                                            Камрады, а можете дать простой примерчик с кнопкой Xiaomi и группой ламп Yeelight на одно короткое нажатие сделать вкл/выкл.
                                            Заранее спасибо!
                                            85
                                            73925
