    4. Neuer Adapter: SMA Wechselrichter mit sbfspot
      burningVweb.de last edited by
      Ich hab leider noch keinen Erfolg zu verbuchen.
      Sämtliche Versuche laufen immer wieder auf diese eine Ausgabe der Installation raus:
      pi@ioBroker-Raspi:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.sbfspot
      pi@ioBroker-Raspi:/opt/iobroker/node_modules/iobroker.sbfspot $ sudo npm install
      > sqlite3@3.1.7 install /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp info it worked if it ends with ok
      node-pre-gyp verb cli [ '/usr/bin/node',
      node-pre-gyp verb cli   '/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/node_modules/.bin/node-pre-gyp',
      node-pre-gyp verb cli   'install',
      node-pre-gyp verb cli   '--fallback-to-build' ]
      node-pre-gyp info using node-pre-gyp@0.6.31
      node-pre-gyp info using node@8.14.1 | linux | arm
      node-pre-gyp verb command install []
      node-pre-gyp info check checked for "/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" (not found)
      node-pre-gyp http GET https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.7/node-v57-linux-arm.tar.gz
      node-pre-gyp ERR! Tried to download(undefined): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.7/node-v57-linux-arm.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.7 and node@8.14.1 (node-v57 ABI) (falling back to source compile with node-gyp)
      node-pre-gyp http EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding'
      node-pre-gyp verb command build [ 'rebuild' ]
      node-pre-gyp http 403 https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.7/node-v57-linux-arm.tar.gz
      node-pre-gyp ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.7/node-v57-linux-arm.tar.gz
      node-pre-gyp http 403 status code downloading tarball https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.7/node-v57-linux-arm.tar.gz
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.14.1"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/.node-gyp"
      gyp WARN install got an error, rolling back install
      gyp ERR! configure error
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/.node-gyp'
      gyp ERR! System Linux 4.14.79-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm"
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3
      gyp ERR! node -v v8.14.1
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm' (1)
      node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
      node-pre-gyp ERR! System Linux 4.14.79-v7+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3
      node-pre-gyp ERR! node -v v8.14.1
      node-pre-gyp ERR! node-pre-gyp -v v0.6.31
      node-pre-gyp ERR! not ok
      gyp ERR! not ok
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sqlite3@3.1.7 (node_modules/sqlite3):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sqlite3@3.1.7 install: `node-pre-gyp install --fallback-to-build`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      audited 6695 packages in 27.189s
      found 17 vulnerabilities (2 low, 13 moderate, 2 high)
        run `npm audit fix` to fix them, or `npm audit` for details</anonymous>
      Nach verschiedenen Analysen musste ich feststellen, dass das Verzeichnis /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/ wo angeblich Rechte fehlen, gar nicht existiert.
      pi@ioBroker-Raspi:/opt/iobroker/node_modules/iobroker.sbfspot/node_modules $ cd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/
      -bash: cd: /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/: Datei oder Verzeichnis nicht gefunden
      So ganz langsam macht sich auch eine gewisse Resignation breit und ich überlege eine Alternative ohne den installierten Adapter.
      … oder vielleicht auch der Versuch auf die mySQL Variante umzusteigen, wobei ich mir in meinem Fall auch da nicht sicher bin ob der Adapter dann funktioniert.
      Ich werd jetzt auf jeden Fall erst mal alles wieder runter werfen...
      Viele Grüße
      • Rene_HM
        Rene_HM Developer last edited by
        Das Verzeichnis existiert nicht, da der Fehler bei mkdir (also beim Anlagen des Verzeichnisses) auftritt. Aus meiner Sicht fehlen die Rechte, das Verzeichnis entsprechend anzulegen…
        Ich würde dem gesamten iobroker-Verzeichis Vollzugriff gewähren:
        cd /opt/
        sudo chmod -R 777 iobroker
        René
          @burningV@web.de:
          So ganz langsam macht sich auch eine gewisse Resignation breit `
          Soll es nicht!
          Wir haben in letzter Zeit einiges am ioBroker umgebaut und benötigen daher dringend Informationen, wo es noch klemmt, damit wir das ausmerzen können.
          Eigentlich sollte es inzwischen wieder alles tun.
          Daher bitte folgende Fragen beantworten:
          Wie (genau) hast du ioBroker installiert?
          Wann war das ?
          Rainer
          • Rene_HM
            @Tottbeck:
            Wenn man das Datum im falschen Format eingibt geht übrigens auch nichts :oops:
            Die Anzeige mit 30 Tage/12 Monate/Jahre funktioniert, es fehlt dann aber immer die X-Achse, obwohl die natürlich aktiviert ist. `
            Kannst du mir dazu im https://github.com/rg-engineering/ioBroker.sbfspot/issues ein issue erstellen? (evtl. mit screenshots?)
              Tottbeck last edited by
              @Rene_HM:
              @Tottbeck:
              Kannst du mir dazu im https://github.com/rg-engineering/ioBroker.sbfspot/issues ein issue erstellen? (evtl. mit screenshots?) `
              Gerade geschehen
              https://github.com/rg-engineering/ioBro … /issues/11
                @Rene_HM:
                cd /opt/
                René `
                Hallo René
                Das ioBroker Verzeichnis hat Vollzugriff:
                pi@ioBroker-Raspi:~ $ cd /opt/
                pi@ioBroker-Raspi:/opt $ ls -al
                insgesamt 20
                drwxr-xr-x  5 root root 4096 Dez 26 11:23 .
                drwxr-xr-x 21 root root 4096 Jan 12 23:54 ..
                drwxrwxrwx  7 root root 4096 Jan 25 22:23 iobroker
                drwxr-xr-x  3 root root 4096 Nov 13 14:37 pigpio
                drwxr-xr-x  7 root root 4096 Nov 13 14:14 vc
                Trotzdem funktioniert die Installation nicht:
                pi@ioBroker-Raspi:/opt/iobroker $ sudo npm install
                > sqlite3@3.1.7 install /opt/iobroker/node_modules/sqlite3
                node-pre-gyp verb cli   '/opt/iobroker/node_modules/sqlite3/node_modules/.bin/node-pre-gyp',
                node-pre-gyp info check checked for "/opt/iobroker/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" (not found)
                node-pre-gyp http EACCES: permission denied, mkdir '/opt/iobroker/node_modules/sqlite3/lib/binding'
                gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/sqlite3/.node-gyp"
                gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/sqlite3/.node-gyp'
                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/opt/iobroker/node_modules/sqlite3/lib/binding/node-v57-linux-arm"
                gyp ERR! cwd /opt/iobroker/node_modules/sqlite3
                gyp ERR! not ok
                node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/opt/iobroker/node_modules/sqlite3/lib/binding/node-v57-linux-arm' (1)
                node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/sqlite3/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/sqlite3/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                node-pre-gyp ERR! cwd /opt/iobroker/node_modules/sqlite3
                gyp ERR! not ok
                npm WARN lifecycle iobroker.inst@1.3.1~install: cannot run in wd iobroker.inst@1.3.1 node lib/checkVersions.js (wd=/opt/iobroker)
                npm WARN lifecycle iobroker.inst@1.3.1~postinstall: cannot run in wd iobroker.inst@1.3.1 node lib/install.js (wd=/opt/iobroker)
                audited 2427 packages in 44.068s
                found 40 vulnerabilities (19 low, 13 moderate, 8 high)
                Mit den Pfadangaben habe ich das Gefühl er versucht sich ein Armbian-Paket zu laden obwohl er auf nem Raspberry läuft.
                Ich habe dann versucht das erste Verzeichnis bei dem der Zugriff scheitert manuell anzulegen (mkdir /opt/iobroker/node_modules/sqlite3/lib/binding) und die Installation nochmal laufen zu lassen. Mit dem selben Ergebnis.
                ` > Daher bitte folgende Fragen beantworten:
                Wie (genau) hast du ioBroker installiert? `
                1. Armbian Image für mein Cubieboard, danach ioBroker Installation über die Konsole nach dieser Anleitung:
                http://www.iobroker.net/docu/?page_id=8323&lang=de
                Die sah dort aber noch ein bißchen anders aus.
                2. Feste IP vergeben
                3. Multihostbetrieb als 'Master' aktivieren
                4. Update via Web-Interface
                5. Installation der ersten Adapter (DWD, vis, HomeMatic, …) über das Web Interface
                6. erste Scripts erstellt und getestet.
                7. Installation eines Raspberry 3b+ über das Image: http://www.iobroker.net/docu/?page_id=8038&lang=de
                8. Feste IP
                9. Raspberry Pi als Multihost 'Slave' mit dem Master verbinden
                10. Installation des KM200 Adapter auf dem Raps für die Heizung
                11. Installation von SBFspot und Verbindung via Bluetooth zu den Wechselrichtern
                12. Installation des SBFspot Adapters via Web Interface
                > Wann war das ?
                Die Installation hab ich Anfang Dezember 2018 durchgeführt.
                Bis auf den SBFspot Adapter läuft bis jetzt auch alles.
                Die Adapter sind auch auf dem richtigen Host installiert!
                Danke für eure Mühen
                Thorsten
                  Hallo, noch eine allgemeine Frage zum dem Adapter: Kann ich beim SBFspot-Widget auswählen, welche Wandler-Parameter ich ausgeben will ?
                  Ich möchte z.B. verschiedene Strings / Spannungen / Temperatur etc. anzeigen.
                  Ich habe jetzt auch die Datenpunkte eine Historie gesetzt und diese per flot angezeigt.
                  Aber das ist ja auch irgendwie doppelt weil ich die Messwert-Historie dann in der Datenbank und nochmal in der History-Modul habe.
                  Etwas Offtopic: Oder kann ich die sqlite3-Datenbank direkt abfragen? Der SQL-Adapter ist dafür ja nicht gedacht.
                  • Rene_HM
                    @Tottbeck:
                    Gerade geschehen
                    https://github.com/rg-engineering/ioBro … /issues/11 `
                    Den Fehler in der Tagesanzeige mit sqlite habe ich behoben. Neue Version liegt im github und npm…
                    War ein typo in der sql-Abfrage 😞
                    • Rene_HM
                      @Tottbeck:
                      Aber das ist ja auch irgendwie doppelt weil ich die Messwert-Historie dann in der Datenbank und nochmal in der History-Modul habe. `
                      nein, das geht (noch) nicht. sorry.
                      @Tottbeck:
                      Etwas Offtopic: Oder kann ich die sqlite3-Datenbank direkt abfragen? Der SQL-Adapter ist dafür ja nicht gedacht. `
                      Das weiß ich leider nicht, hab den Adapter noch nicht probiert…
                      • Rene_HM
                        @burningV@web.de:
                        Thorsten `
                        Irgendwie fehlt auf dem Raspi irgendetwas…
                        Musste bei der Installation der anderen Adapter auf dem Raspi etwas gebaut werden, oder ist der SBFspot Adapter der erste, der etwas baut? Ist auf dem Raspi das Linux-Paket "build-essentail" installiert?
                          @Rene_HM:
                          War ein typo in der sql-Abfrage 😞 `
                          Super, Danke.
                            @Rene_HM:
                            Musste bei der Installation der anderen Adapter auf dem Raspi etwas gebaut werden, oder ist der SBFspot Adapter der erste, der etwas baut? Ist auf dem Raspi das Linux-Paket "build-essentail" installiert? `
                            Nein, die anderen Adapter konnten direkt installiert werden. Der SBFspot ist der einzige der in die Build-Routine läuft.
                            "build-essential" müsste drauf sein… kann ich aber nochmal testen.
                              m76 @burningVweb.de last edited by
                              gibt es eine Anleitung wie man das Widget sbfspot einrichtet?
                              Hab sbfspot-Instanz und WR Seriennummer eingetragen, sehe aber nur
                              einen großen breiten gelben Balken? Muss ich hier noch sql historie einrichten?
                                martinschm last edited by
                                hab mir grade SBFspot auf meinem Rock64 (Debian Stretch) mit sqlite nach der Anleitung von SBFspot installiert.
                                Installation erfolte per SSH mit root user, iobroker hab ich per Installationsskript installiert.
                                Die Stelle der Anleitung mit
                                sudo chown -R pi:pi /var/log/sbfspot.3
                                habe ich angepasst
                                sudo chown -R root:root /var/log/sbfspot.3
                                Da es auf meiner Installation kein User pi gibt.
                                Der SBFspot Adapter ist installiert, aber ich sehe nirgendwo die Daten. SBFspot selber bekommt Daten, ich habe wie in der Anleitung beschrieben testweise ein Select auf die Datenbank gemacht und es wurden Daten angezeigt.
                                Muss ich das chown für den iobroker User machen, damit iobroker die Daten auch lesen darf?
                                ciao
                                Martin
                                • Rene_HM
                                  wie hast du den Adapter konfiguriert? Was sagt das log? evtl. den debug-Mode des Adapters noch einschalten...
                                  Gruß René
                                    martinschm @Rene_HM last edited by
                                    @Rene_HM said in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                                    Gruß René
                                    sbfspot.0	2019-06-29 21:00:01.806	error	Error while performing Query in GetInverter. Error: SQLITE_CANTOPEN: unable to open database file
                                    sbfspot.0	2019-06-29 21:00:01.805	debug	SELECT * from Inverters
                                    sbfspot.0	2019-06-29 21:00:01.805	debug	sqlite Database is connected ...
                                    sbfspot.0	2019-06-29 21:00:01.804	debug	--- connecting to /home/smadata/SBFspot.db
                                    sbfspot.0	2019-06-29 21:00:01.804	info	start with sqlite
                                    sbfspot.0	2019-06-29 21:00:01.802	info	starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.sbfspot, node: v8.16.0
                                    host.rock64	2019-06-29 21:00:00.037	info	instance system.adapter.sbfspot.0 started with pid 30394
                                    Ich habe bei dem chown Befehl jetzt mal den iobroker user eingefügt, weil ich dachte das evtl iobroker keine Leserechte auf die Datei hat. Hat leider keine Änderung gebracht.
                                    • Rene_HM
                                      Rene_HM Developer @martinschm last edited by
                                      @martinschm ich denke, da fehlen dann auch Schreibrechte, bin mir aber nicht sicher. Ich habe leider derzeit kein System mit sqlite um es auzuprobieren...
                                        martinschm @Rene_HM last edited by martinschm
                                        so war es auch. Habe mal ein chown für den gesamten Ordner smadata gemacht und alles an den user iobroker "übergeben". Jetzt scheint es laut log zu klappen.
                                          was muß ich denn machen um das Widget zum Laufen zu bekommen.
                                          Ich habe es in eine View eingefügt, bei sbfspot Instanz 0 eingetragen und bei der WR Seriennummer die Seriennummer meines WRs eingetragen.
                                          Bei OID steht jetzt die 0.meineSerienummer.history.today
                                          Angezeigt wird mir trotz Neuladen der VIS nichts.
                                          Hab ich was vergessen?
                                          • Rene_HM
                                            Du musst bei Instanz "sbfspot.0" eintragen ... Dann passt auch die OID...
                                            248
                                            40930
