    4. [Problem] Dream btw. Enigma2 Adapter
      A Former User last edited by
      Einstellungen
      Netzwerk
      Webinterface
      Ganz nach unten scrollen und die letzten 3 Einstellungen auf aus.
        Piwie last edited by
        Habe ich gerade gemacht… Trotzdem weiterhin diese Fehler, sobald die VU+ Solo4k in den Standby geschickt wird:
        host.Rasperry	2019-01-31 21:15:05.109	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
        host.Rasperry	2019-01-31 21:15:05.109	error	Caught by controller[0]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:322:31)
        host.Rasperry	2019-01-31 21:15:05.109	error	Caught by controller[0]: at SAXParser.write (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:1436:13)
        host.Rasperry	2019-01-31 21:15:05.109	error	Caught by controller[0]: at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:889:7)
        host.Rasperry	2019-01-31 21:15:05.109	error	Caught by controller[0]: at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:629:5)
        host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at emit (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:624:35)
        host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at SAXParser.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:261:26)
        host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at Parser.emit (events.js:188:13)
        host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:303:18)
        host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:314:7
        host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:410:95)
        host.Rasperry	2019-01-31 21:15:05.106	error	Caught by controller[0]: TypeError: Cannot read property 'e2eventlist' of undefined
        enigma2.0	2019-01-31 21:15:04.588	error	TypeError: Cannot read property 'e2eventlist' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:410:95) at /opt/iobroker/node_modules/iobroker.eni
        enigma2.0	2019-01-31 21:15:04.587	error	uncaught exception: Cannot read property 'e2eventlist' of undefined</anonymous>
        Ich denke deswegen wird auch das normale power toggle nicht funktionieren, da der adapter sich ja in dauerschleife neu startet… Also die meisten Zeit "tot" ist...?
        Vielleicht weiss ja noch jemand Rat... :shock:
        Greetz
        -Piwie-
        • Matten Matten
          Matten Matten last edited by
          Auch Mal ein Neustart vom Receiver gemacht?
          • haselchen
            haselchen Most Active last edited by
            @MattenMatten
            Möchte nochmal den Poll Intervall aufgreifen.
            Lässt der sich vielleicht mit dem nächsten Update manuell einstellen?
            • Matten Matten
              @haselchen:
              @MattenMatten
              Lässt der sich vielleicht mit dem nächsten Update manuell einstellen? `
              Du kannst bereits manuell Pollen lassen.
              Unter
              enigma2.0.enigma2.Update
              Matten Matten
                @Matten Matten:
                Auch Mal ein Neustart vom Receiver gemacht? `
                Ja… Leider immernoch der gleiche absturz des adapters wenn die box im standby ist... 😞
                Schade... denn so an sich ist es ein genialer adapter...
                Greetz
                -Piwie-
                • Matten Matten
                  Hast du Open webif drauf? Teste sonst Mal Webinterface vom vti Feed
                  Oder den Adapter erneut in iobroker laden, dann ein Upload durchführen und den Adapter starten.
                    @Matten Matten:
                    Hab auf meinen Kisten hier ruDREAM am laufen… Die nutzen ein erweitertes Open Webif Version: OWIF 0.4.0... Daher würde das webinterface vom vti feed nicht drauf laufen...
                    Mit dem Adapter nochmal neu reinladen werde ich morgen mal versuchen... Daumen drücken das es dann klappt...
                    Greetz
                    -Piwie-
                    • Matten Matten
                      @Piwie:
                      -Piwie- `
                      Ich habe da vielleicht eine Idee wie ich das Problem ausblenden kann. Damit es nicht zu diesen Fehlern kommt.
                      Ich melde mich sobald ich Erfolg hab.
                      Matten Matten
                      • Matten Matten
                        Version 1.1.9 auf GitHub
                        https://github.com/Matten-Matten/ioBrok … /README.md
                        (Matten-Matten) (#14) add enigma2.EVENTDURATION_MIN in Minute
                        (Matten-Matten) (#14) add enigma2.EVENTREMAINING_MIN in Minute
                        (Matten-Matten) Troubleshooting in standby toggle
                        (Matten-Matten) Troubleshooting in the "eventlist" query
                        Bitte testen und Feedback geben! Danke.
                        Matten Matten
                        • Steff
                          Steff last edited by
                          @Matten Matten:
                          Bitte testen und Feedback geben! Danke. `
                          Läuft bei mir! 😄
                          Gruß Steffen
                            dos1973 last edited by
                            @Matten Matten:
                            Start und endzeiten sind lange zahlen, kann ich aber auch noch Mal mit einpflegen. Das scheint ein "Unix Timecode" zu sein. Ich weiß aber noch nicht wie ich
                            den umcodiert bekomme. Hat jemand eine Idee?
                            Matten Matten `
                            du hast es ja inzwischen erfolgreich geschafft :lol:
                            hast du ggfs dafür ein script, oder Blocky. Ich habe an anderer Stelle jetzt einen Unit Timestamp und würde den gerne in H:m ausgeben - und dann fiel mir dieser Thread ein.
                            Matten Matten Stabilostick 2 Replies Last reply Reply Quote 0
                            • Matten Matten
                              Matten Matten @dos1973 last edited by Matten Matten
                              @dos1973 said in [Problem] Dream btw. Enigma2 Adapter:
                              @Matten Matten:
                              Matten Matten `
                              function sec2HMS(sec) {
                              	if (sec  === 0) {
                                      return '0';
                                  const sec_num = parseInt(sec, 10);
                                  let hours   = Math.floor(sec_num / 3600);
                                  let minutes = Math.floor((sec_num - (hours * 3600)) / 60);
                                  let seconds = sec_num - (hours * 3600) - (minutes * 60);
                                  if (minutes < 10) {minutes = '0' + minutes;}
                                  if (seconds < 10) {seconds = '0' + seconds;}
                                  if (hours === 0) {
                                      return minutes + ':' + seconds;
                                  if (hours < 10) {hours = '0' + hours;}
                                  return hours + ':' + minutes + ':' + seconds;
                              Das ist aus Apollon77's alexa2 adapter. hab ich auch nur von ihm abgeschaut.😌
                                was mach ich jetzt nur damit 🙂 das hatte ich mir in meinem naiven Kopfbild anders vorgestellt
                                ich habe einen DP
                                javascript.0.wetterimport.recordtime
                                und brauch den wert in
                                javascript.0.wetterimport.uhrzeit
                                Matten Matten 1 Reply Last reply Reply Quote 0
                                • Stabilostick
                                  Stabilostick @dos1973 last edited by Stabilostick
                                  @dos1973 sagte in [Problem] Dream btw. Enigma2 Adapter:
                                  Unit Timestamp
                                  Meinst Du Unix Timestamp?
                                  Also so etwas wie
                                  var s = new Date(meineUnixZeit).toLocaleDateString("de-DE")
                                  für das Datum. Und für den Zeitanteil:
                                  var s = new Date(meineUnixZeit).toLocaleTimeString("de-DE")
                                  Anleitung zu toLocaleTimeString:
                                  https://developer.mozilla.org/de/docs/Web/JavaScript/Reference/Global_Objects/Date/toLocaleDateString
                                    Ich habs anders gelöst.
                                    Ich sende ja unix timecode von einer php website, dort habe ich den formatieren können und schreiben den via simpleapi. Php verstehe ich irgendwie einfacher. In js verstehe leider nix
                                    • Stabilostick
                                      Stabilostick last edited by
                                      Prima, dass Du eine Lösung gefunden hast.
                                      Viele Grüße
                                      Thomas
                                      • Matten Matten
                                        ich habe einen DP
                                        on({id: "javascript.0.wetterimport.recordtime", change: "ne"}, function (obj) {
                                          var value = obj.state.val;
                                          setStateDelayed('javascript.0.wetterimport.uhrzeit', sec2HMS((obj.state ? obj.state.val : "")), true, parseInt(0, 10), false);
                                        	if (sec  === 0) {
                                                return '0';
                                            if (hours === 0) {
                                        könnte so aussehen.
                                        Matten Matten
                                          hi,
                                          kurze Frage, ich habe in Vis auch die sender logos visualisiert... also der aktuelle Kanal wird mir als Logo in Vis dargestellt mittels Servicereferenz
                                          enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE =
                                          1:0:1:B:2:85:FFFF0000:0:0:0: (Sky Cinema +1)
                                          wenn ich allerdings eine Film von der Festplatte schaue dann habe ich unter dem DP z.B folgendes:
                                          1:0:0:0:0:0:0:0:0:0:/media/net/DS218/Rampage - Big Meets Bigger.ts
                                          darauf kann ich nicht reagieren, wie macht ihr das mit dem Symbol bei einer Aufnahme?
                                          Für eine Idee oder Hinweis Vielen Danke
                                          • SBorg
                                            ich müsste endlich mal ein passendes Picon erstellen...
                                            Da ich externe Picons vom Web-Server nutze, brauche ich die SIDs ohne Doppelpunkte. Deswegen wandele ich sie mittels Javascript sowieso um. Da braucht es nur:
                                            if ( PICON == "1:0:0:0:0:0:0:0:0:0:" ) { PICON="&nbsp;" }
                                            Da könnte jetzt natürlich auch einfach ein Bild einer HDD rein 🙂
                                            739
                                            189557
