    4. [Vorstellung] Meine zweite Visualisierung
      Kuddel last edited by Kuddel
      @tiroler:
      Danke fürs bereitstellen,
      Hätte noch eine Frage wie hast das mit der Waschmaschine gelöst, kannst du das Script dafür auch bereitstellen. Danke `
      Status-Waschmaschine (Blockly):
       <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="o%),[!u9gGk_ZZyIIa:v" x="-155" y="45"><mutation items="1"></mutation>
        <value name="OID0"><shadow type="field_oid" id="T7ab,8_M8,BHbMdX^]!h"><field name="oid">hm-rpc.0.LEQ1272397.2.POWER</field></shadow></value>
        <statement name="STATEMENT"><block type="comment" id="1QB=V}FQL0d}#l+(QxJB"><field name="COMMENT">Aus</field>
            <next><block type="controls_if" id="dD#]Vc0pnz@,}#f{`eW="><value name="IF0"><block type="logic_operation" id="%a`(cn`m~t{|rdYc#+iS" inline="false"><field name="OP">AND</field>
                    <value name="A"><block type="logic_compare" id="4VKDm7AnA`T4ERO3PN,W"><field name="OP">NEQ</field>
                        <value name="A"><block type="get_value" id="`Yrk}!l*wt#Muy(wu:m3"><field name="ATTR">val</field>
                            <field name="OID">javascript.0.haushalt.waschmaschine</field></block></value>
                        <value name="B"><block type="math_number" id="~,Rn(x3i.pHq*!QnO?pI"><field name="NUM">0</field></block></value></block></value>
                    <value name="B"><block type="logic_compare" id="M3C^axU4Q:D`-G+VDGta"><field name="OP">LT</field>
                        <value name="A"><block type="get_value" id="Q.=+)xl0+dGQ;v;/*n9v"><field name="ATTR">val</field>
                            <field name="OID">hm-rpc.0.LEQ1272397.2.POWER</field></block></value>
                        <value name="B"><block type="math_number" id="Yc7C,cA)oJl}if0XFrqi"><field name="NUM">0.5</field></block></value></block></value></block></value>
                <statement name="DO0"><block type="timeouts_settimeout" id="3(oXDT4p`AX|](%[}pL("><field name="NAME">timeout2</field>
                    <field name="DELAY">1</field>
                    <statement name="STATEMENT"><block type="controls_if" id="VC39ip(2Y]`lk/X?ykj;"><value name="IF0"><block type="logic_operation" id="tOFb-,NZzjk!4K5@8tSb" inline="false"><field name="OP">AND</field>
                            <value name="A"><block type="logic_compare" id="Z8{Q![]D*Dm04Wzr/G|R"><field name="OP">NEQ</field>
                                <value name="A"><block type="get_value" id="0G*yY/TP5EW1}s}4nKZI"><field name="ATTR">val</field>
                                <value name="B"><block type="math_number" id="^6N|fJ`#]J*6.7r47%Kk"><field name="NUM">0</field></block></value></block></value>
                            <value name="B"><block type="logic_compare" id="UjiDdhQ,]W#MCpmMMxMj"><field name="OP">LT</field>
                                <value name="A"><block type="get_value" id="9p,-t~21w]Wmzfx?(f3P"><field name="ATTR">val</field>
                                <value name="B"><block type="math_number" id=":vB!/kTAi]dKF5+j!~W{"><field name="NUM">0.5</field></block></value></block></value></block></value>
                        <statement name="DO0"><block type="control" id="5Q)5v-.Aw^aZcAwY@]oc"><mutation delay_input="false"></mutation>
                            <value name="VALUE"><block type="math_number" id="ql(RVJ.2-IX}){cA(pd*"><field name="NUM">0</field></block></value></block></statement></block></statement></block></statement>
                <next><block type="comment" id="V[JvQyTj@U0KfZ,]1D@f"><field name="COMMENT">Läuft</field>
                    <next><block type="controls_if" id="Xi)LJAN:?)b`*ln/kKvD"><value name="IF0"><block type="logic_operation" id="yCx3KlI8^oo:-r@G3q;g" inline="false"><field name="OP">AND</field>
                            <value name="A"><block type="logic_compare" id="A!!DpNVjljp1cFY_P@+:"><field name="OP">NEQ</field>
                                <value name="A"><block type="get_value" id="obAcC67N*D2QX)x~OS%l"><field name="ATTR">val</field>
                                <value name="B"><block type="math_number" id="bmp+Xv4Kb(gbn5J/~h*H"><field name="NUM">1</field></block></value></block></value>
                            <value name="B"><block type="logic_compare" id="3K^Vl7hlx==y*Y8Pq2}9"><field name="OP">GT</field>
                                <value name="A"><block type="get_value" id="l)YY|DODI_s3r0J*WKW8"><field name="ATTR">val</field>
                                <value name="B"><block type="math_number" id="XF|!fj+/SrLI=k5S~g(F"><field name="NUM">140</field></block></value></block></value></block></value>
                        <statement name="DO0"><block type="control" id="J4~j2G8}C;Qw!)Pgv:pE"><mutation delay_input="false"></mutation>
                            <value name="VALUE"><block type="math_number" id="H0w:XuVjmqP~[|QoF#md"><field name="NUM">1</field></block></value></block></statement>
                        <next><block type="comment" id="xX[H0Gjr^+UdsAXj%Gv["><field name="COMMENT">Timer</field>
                            <next><block type="controls_if" id="i8AKxAJ2u0(K3+*n]Fsu"><value name="IF0"><block type="logic_operation" id=",`Ck;ys{}MOyTA5ty=v+" inline="false"><field name="OP">AND</field>
                                    <value name="A"><block type="logic_compare" id="5|(Ej)@Y2.AUcANeD(VO"><field name="OP">EQ</field>
                                        <value name="A"><block type="get_value" id="3OF:nKn0@]nT)]bRPM^U"><field name="ATTR">val</field>
                                        <value name="B"><block type="math_number" id="[%HI@1baQTW+0qHuO!BV"><field name="NUM">0</field></block></value></block></value>
                                    <value name="B"><block type="logic_operation" id="73ug28Rg:;zV`BaYK[bU" inline="false"><field name="OP">AND</field>
                                        <value name="A"><block type="logic_compare" id="HQ!Iv[2{YGocWe*/7FC@"><field name="OP">LT</field>
                                            <value name="A"><block type="get_value" id="s(l9}WXGx_A*8T%d;M,B"><field name="ATTR">val</field>
                                            <value name="B"><block type="math_number" id=")QOW1!?Uy7txa8h1(,Ff"><field name="NUM">6</field></block></value></block></value>
                                        <value name="B"><block type="logic_compare" id="*Z7o2%aCAC*uWTWcOdy^"><field name="OP">GT</field>
                                            <value name="A"><block type="get_value" id="96f(OrH_BciNrMS~v|%?"><field name="ATTR">val</field>
                                            <value name="B"><block type="math_number" id="E@RSATlh~G5t^qo)~%%p"><field name="NUM">5</field></block></value></block></value></block></value></block></value>
                                <statement name="DO0"><block type="control" id="2fX=L~mZf|~;4.`#m~9G"><mutation delay_input="false"></mutation>
                                    <value name="VALUE"><block type="math_number" id="%l9h-,8e[[~VS:sY)NaR"><field name="NUM">2</field></block></value></block></statement>
                                <next><block type="comment" id="Ca%7[kx7U(Y(v`h3vPLM"><field name="COMMENT">Fertig</field>
                                    <next><block type="controls_if" id="YgP%U~lLn*BC-?ZVZUiN"><value name="IF0"><block type="logic_operation" id="H?VMR#|..l%WDz=qRByb" inline="false"><field name="OP">AND</field>
                                            <value name="A"><block type="logic_compare" id="5w}Z?FR4c]HgSZ7g33Td"><field name="OP">NEQ</field>
                                                <value name="A"><block type="get_value" id="%.Pni:P2|2gg[[R-;#2("><field name="ATTR">val</field>
                                                <value name="B"><block type="math_number" id="NKpxyPQe:T`}kGk8vLh2"><field name="NUM">3</field></block></value></block></value>
                                            <value name="B"><block type="logic_operation" id="LS*dqzVf`b!VM2!ptks_" inline="false"><field name="OP">AND</field>
                                                <value name="A"><block type="logic_compare" id="W00wE^~/xd1SoLd+`Jhh"><field name="OP">LT</field>
                                                    <value name="A"><block type="get_value" id="hF_M:1;;f!7lMdVb^[sY"><field name="ATTR">val</field>
                                                    <value name="B"><block type="math_number" id="+.v;eO}:AHO~27Z%`q|T"><field name="NUM">4</field></block></value></block></value>
                                                <value name="B"><block type="logic_compare" id="Oz~3,:P7F:+Yr1m*d:%0"><field name="OP">GT</field>
                                                    <value name="A"><block type="get_value" id="-F}P;O7*y-DHtQ^/p+8w"><field name="ATTR">val</field>
                                                    <value name="B"><block type="math_number" id="M0FY#+wW3S(,v|dG*nzd"><field name="NUM">3</field></block></value></block></value></block></value></block></value>
                                        <statement name="DO0"><block type="timeouts_settimeout" id="GlR8m1w4;}?vaX^4a/pq"><field name="NAME">timeout</field>
                                            <field name="DELAY">10</field>
                                            <statement name="STATEMENT"><block type="controls_if" id="yk;n@H0Pt;*yE001/1Pv"><value name="IF0"><block type="logic_operation" id="!qEnJZd7!E#+({Fulj-f" inline="false"><field name="OP">AND</field>
                                                    <value name="A"><block type="logic_compare" id="X+,!iy9kv+LZK:6DNX/g"><field name="OP">NEQ</field>
                                                        <value name="A"><block type="get_value" id="^Z.j7ydE=:wIi4~gyj^u"><field name="ATTR">val</field>
                                                        <value name="B"><block type="math_number" id="X13P=,9Jp/TyaiNog9*S"><field name="NUM">3</field></block></value></block></value>
                                                    <value name="B"><block type="logic_operation" id="LD|=^/J?Ez=~sI31h]31" inline="false"><field name="OP">AND</field>
                                                        <value name="A"><block type="logic_compare" id="b/VP7=UZB7kB*%^t%CUX"><field name="OP">LT</field>
                                                            <value name="A"><block type="get_value" id="lwc,3wBc%o,PnzA[kV`("><field name="ATTR">val</field>
                                                            <value name="B"><block type="math_number" id="r,Rd+gGA0QLE/hO}@,]E"><field name="NUM">4</field></block></value></block></value>
                                                        <value name="B"><block type="logic_compare" id="?;xbf!?)D3}CY@f6by!*"><field name="OP">GT</field>
                                                            <value name="A"><block type="get_value" id="mOhdHKJN,@p!bZf0R1y*"><field name="ATTR">val</field>
                                                            <value name="B"><block type="math_number" id="UhvmXp.]Q#,85;O,d%6D"><field name="NUM">0.5</field></block></value></block></value></block></value></block></value>
                                                <statement name="DO0"><block type="control" id="NGtYSq12Y1I9M+tpzKcs"><mutation delay_input="false"></mutation>
                                                    <value name="VALUE"><block type="math_number" id="G=YD~ju7|b8ql}j0}w^n"><field name="NUM">3</field></block></value></block></statement></block></statement></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></statement></block>
      ```[/s]
        pi_noob15 last edited by
        mal ne Frage vom Anfänger…..wie kann ich diese echt geile Oberfläche in die eigene VIS übernehmen ?
        Bzw. der weitere Schritt wäre nur einzelne Bereiche daraus.....
          Ralf.Grum last edited by
          Hut ab! Da muß ich mir was klauen!!
          Was mich nur wundert , Du hast ja die selben fast die gleichen Tankstellen wie ich in der VIS!
          Ich tipp mal: Du kommst aus Buxte:?
          Gruß Ralf
            @pi_noob15:
            Bzw. der weitere Schritt wäre nur einzelne Bereiche daraus..... `
            Öffne deinen VIS Editor und klick auf Setup, dann auf Projekt-Export/import und dann auf import.
            In das Fenster ziehst du die Zip Datei von mir, gibst der VIS einen Namen klickst dann auf "import project".
            Jetzt kannst du meine VIS bearbeiten oder die Widgets exportieren
              @Ralf.Grum:
              Gruß Ralf `
              Korrekt, Buxtehude 🙂
              • Röstkartoffel
                Röstkartoffel last edited by
                Schönen Gruß aus Neu Wulmstorf.
                @ Kuddel: Klasse Views, die du da gemacht hast.
                  mehrwiedu last edited by
                  @Kuddel:
                  @tiroler:
                  <next><block type="controls_if" id="dD#]Vc0pnz@,}#f{eW="><value name="IF0"><block type="logic_operation" id="%a(cnm~t{|rdYc#+iS" inline="false"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="4VKDm7AnAT4ERO3PN,W"><field name="OP">NEQ</field>
                  <value name="A"><block type="get_value" id="Yrk}!l*wt#Muy(wu:m3"><field name="ATTR">val</field> <field name="OID">javascript.0.haushalt.waschmaschine</field></block></value> <value name="B"><block type="math_number" id="~,Rn(x3i.pHq*!QnO?pI"><field name="NUM">0</field></block></value></block></value> <value name="B"><block type="logic_compare" id="M3C^axU4Q:D-G+VDGta"><field name="OP">LT</field>
                  <value name="A"><block type="get_value" id="Q.=+)xl0+dGQ;v;/n9v"><field name="ATTR">val</field>
                  <statement name="DO0"><block type="timeouts_settimeout" id="3(oXDT4pAX|](%[}pL("><field name="NAME">timeout2</field> <field name="DELAY">1</field> <field name="UNIT">min</field> <statement name="STATEMENT"><block type="controls_if" id="VC39ip(2Y]lk/X?ykj;"><value name="IF0"><block type="logic_operation" id="tOFb-,NZzjk!4K5@8tSb" inline="false"><field name="OP">AND</field>
                  <value name="A"><block type="get_value" id="0GyY/TP5EW1}s}4nKZI"><field name="ATTR">val</field>
                  <value name="B"><block type="math_number" id="^6N|fJ#]J*6.7r47%Kk"><field name="NUM">0</field></block></value></block></value> <value name="B"><block type="logic_compare" id="UjiDdhQ,]W#MCpmMMxMj"><field name="OP">LT</field> <value name="A"><block type="get_value" id="9p,-t~21w]Wmzfx?(f3P"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.LEQ1272397.2.POWER</field></block></value> <value name="B"><block type="math_number" id=":vB!/kTAi]dKF5+j!~W{"><field name="NUM">0.5</field></block></value></block></value></block></value> <statement name="DO0"><block type="control" id="5Q)5v-.Aw^aZcAwY@]oc"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.haushalt.waschmaschine</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="ql(RVJ.2-IX}){cA(pd*"><field name="NUM">0</field></block></value></block></statement></block></statement></block></statement> <next><block type="comment" id="V[JvQyTj@U0KfZ,]1D@f"><field name="COMMENT">Läuft</field> <next><block type="controls_if" id="Xi)LJAN:?)bln/kKvD"><value name="IF0"><block type="logic_operation" id="yCx3KlI8^oo:-r@G3q;g" inline="false"><field name="OP">AND</field>
                  <value name="B"><block type="logic_compare" id="3K^Vl7hlx==yY8Pq2}9"><field name="OP">GT</field>
                  <next><block type="controls_if" id="i8AKxAJ2u0(K3+n]Fsu"><value name="IF0"><block type="logic_operation" id=",Ck;ys{}MOyTA5ty=v+" inline="false"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="5|(Ej)@Y2.AUcANeD(VO"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="3OF:nKn0@]nT)]bRPM^U"><field name="ATTR">val</field> <field name="OID">javascript.0.haushalt.waschmaschine</field></block></value> <value name="B"><block type="math_number" id="[%HI@1baQTW+0qHuO!BV"><field name="NUM">0</field></block></value></block></value> <value name="B"><block type="logic_operation" id="73ug28Rg:;zVBaYK[bU" inline="false"><field name="OP">AND</field>
                  <value name="A"><block type="get_value" id="s(l9}WXGx_A8T%d;M,B"><field name="ATTR">val</field>
                  <value name="B"><block type="logic_compare" id="Z7o2%aCACuWTWcOdy^"><field name="OP">GT</field>
                  <statement name="DO0"><block type="control" id="2fX=L~mZf|~;4.#m~9G"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.haushalt.waschmaschine</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="%l9h-,8e[[~VS:sY)NaR"><field name="NUM">2</field></block></value></block></statement> <next><block type="comment" id="Ca%7[kx7U(Y(vh3vPLM"><field name="COMMENT">Fertig</field>
                  <value name="B"><block type="math_number" id="NKpxyPQe:T}kGk8vLh2"><field name="NUM">3</field></block></value></block></value> <value name="B"><block type="logic_operation" id="LS*dqzVfb!VM2!ptks_" inline="false"><field name="OP">AND</field>
                  <value name="A"><block type="logic_compare" id="W00wE^~/xd1SoLd+Jhh"><field name="OP">LT</field> <value name="A"><block type="get_value" id="hF_M:1;;f!7lMdVb^[sY"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.LEQ1272397.2.POWER</field></block></value> <value name="B"><block type="math_number" id="+.v;eO}:AHO~27Z%q|T"><field name="NUM">4</field></block></value></block></value>
                  <value name="B"><block type="logic_compare" id="Oz~3,:P7F:+Yr1md:%0"><field name="OP">GT</field>
                  <value name="B"><block type="math_number" id="M0FY#+wW3S(,v|dGnzd"><field name="NUM">3</field></block></value></block></value></block></value></block></value>
                  <statement name="STATEMENT"><block type="controls_if" id="yk;n@H0Pt;yE001/1Pv"><value name="IF0"><block type="logic_operation" id="!qEnJZd7!E#+({Fulj-f" inline="false"><field name="OP">AND</field>
                  <value name="B"><block type="logic_compare" id="?;xbf!?)D3}CY@f6by!"><field name="OP">GT</field>
                  Ich habe mir das Script auch mal eingebunden um davon zu lernen. 🙂
                  Vielen Dank für die Bereitstellung. Allerdings habe ich direkt eine Frage. Was ist das für ein Objekt?
                    Mit dem Objekt stelle ich den aktuellen Status der Waschmaschine da;
                    0=aus
                    1=an
                    2=timer
                    3=fertig
                      @Kuddel:
                      0=aus
                      1=an
                      2=timer
                      3=fertig `
                      Wow, danke für die superschnelle Antwort.
                      Hab ein bisschen Nachsehen mit mir. 🙂 Ich erkenne die Logik jetzt dahinter im Script, aber ich wüsste nicht, wo ich das Objekt bei mir anlegen sollte und was es dann für einen Inhalt bekommt. Ist das einfach nur ein Infoobjekt, was dann später in der VIS Darstellung den gesetzten Wert wiedergibt? Oder steckt da noch weiterer Code hinter? Da bin ich wahrscheinlich noch viel zu weit am Anfang, als das ich das direkt verstehe. Sorry für die Fragen. Ich lerne halt noch. 😉
                        Die Werte sind zur Darstellung in VIS gedacht.
                        Das Datenobjekt kannst du unter Javascript.0 anlegen.
                        Überlege dir vorher am Besten eine Struktur, denn mit der Zeit werden es immer mehr Objekte und leider kann man die nicht verschieben
                        • Segway
                          Segway last edited by
                          Momentan nutze ich noch das schlechte Wetter um ebenso an meiner VIS zu basteln.
                          Anhand deiner Fotos sehe ich, dass du zB Ram, Speicher, Festplattenplatz anscheinend "dynamisch" anzeigen lässt, also wenn noch x von y MB frei sind (entspricht 50%) den Balken entsprechend lang machst.
                          Wie bekommt man sowas hin ? Macht das das Widget oder programmieren ?
                            mehrwiedu last edited by mehrwiedu
                            Ich müsste hier nochmal etwas nachfragen. Ich wühle mich gerade durch diese Visualisierung und lerne tatsächlich so einiges. Allerdings liegen auch noch viele Sachen im Dunkeln.
                            Das mit den Datenpunkten habe ich soweit verstanden. In der Darstellung Deiner Echo Geräte, nutzt Du auch einen "Status", der wahrscheinlich dazu dient, die Views entsprechend anzuzeigen (Spotify, Radio, Amazon Music). Das habe ich noch nicht verstanden, wie das funktioniert. Ich finde da in den Einstellungen auch nichts, wo ich das ableiten könnte. Regelst Du das ausschließlich im VIS Editor, oder liegt da ein Script hinter?
                            Ebenfalls sind in den Views für Spotify und Amazon Music "Vor" "Zurück" "Play" und "Pause" Button zu sehen, die ich als Widgets im Editor zwar auch finde, jedoch die Icons und die Datenpunkte dazu nicht. Ich bekomme die also bei mir erst gar nicht visuell angezeigt. Wie ist das geregelt?
                            Ich glaube, wenn ich die beiden Punkte verstanden habe, dass ich mit meiner VIS ein sehr großes Stückchen weiterkomme.
                            Danke Dir schonmal im Voraus für Deine Mühen.
                            /edit
                            Die Play, Pause, Vor und Zurückbuttons habe ich nun gefunden. Ich hatte nur die hqwidgets nicht installiert. 🙂
                            /edit2
                            Den Zusammenhang zwischen Statuswert und der Sichtbarkeit der Widgets habe ich nun auch rausgekriegt.
                            Stellt sich mir nur die Frage, warum ein eigener Status und nicht den des Gerätes verwenden?
                            Gibt es da noch Vorteile einen eigenen Status zu benutzen.
                              maxpd last edited by
                              Müsste er nicht so die Icons erkennen?
                              Wie bekomme ich denn Waschmaschine markiert? Er markiert mir immer nur Haushalt. Auch wenn ich 2019-02-10 21_27_03-Edit vis.png versuche den Rahmen in den Hintergrund zu schieben.!
                                Kuddel @Segway last edited by
                                @Segway said in [Vorstellung] Meine zweite Visualisierung:
                                Dafür gibt es extra ein Balken Widget. Iwas mit bar
                                  Kuddel @mehrwiedu last edited by
                                  @mehrwiedu said in [Vorstellung] Meine zweite Visualisierung:
                                  /edit
                                  /edit2
                                  -Den aktuellen Status meiner Echo geräte setzte ich per Skript.
                                  Ich ahbe das so eingestellt, dass die Radiosteuerung immer angezeigt werden soll, auch wenn die Geräte aus sind.
                                  Der Amazon / Spotify Player wird dann wenn aktiv über der Radiosteuerung angezigt.
                                  Wenn man das mit dem normalen Alexa Status macht, wird die Radio-Steuerung erstn angezeigt, wenn man das Radio gestatet hat
                                    Kuddel @maxpd last edited by
                                    @maxpd said in [Vorstellung] Meine zweite Visualisierung:
                                    Wenn du das Widget der Waschmaschine bearbeiten willst, muss du in den View Haushalt wechseln. Von der Startseite aus geht das nicht, da wird nur der View angezeigt
                                      mehrwiedu @Kuddel last edited by
                                      @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                                      Ich bin ja schon ein kleines bisschen weiter in der ganzen Sache. Ich habe nicht sooo viele Radiosender, die ich per Schalter aufrufen muss. Bei mir sind es eher Playlisten und so habe ich mir das für meine Geräte ganz individuell mit unterschiedlichen Playlisten gebaut, dank Deiner Vorlage. 🙂
                                      Habe am Wochenende echt viel lernen können daraus. So hab ich mir fürs Innenklima auch den kritischen Batteriestatus meiner Temperatursensoren in die Übersicht gebaut. Ab einem gewissen Wert (Volt oder Prozent) blinkt dann vor dem Sofasymbol eine rote Batterie. 😉
                                      Aber doch ein Script dahinter bei der Anzeige. 😉
                                      Allerdings sind bei mir die Echos nie aus. Es bleibt also immer der letzte Interpret oder der letzte Radiosender in den Player_Werten stehen. Du schaltest sie über die Stromzufuhr ab? Das habe ich natürlich bei mir nicht ausprobiert.
                                      Ich wäre aber noch an dem Script für den Mi Roboter (Behälterfüllstand und Historie/Start-Saugzeit-Fläche) und an den Windrichtungen unterhalb der Wetter-Tagesvorschau interessiert, wenn Du das preisgeben möchtest.
                                        Dirni last edited by
                                        Wie hast du das genau mit den Radio Icons umgesetzt, welcehs Widget hast du da genommen bzw. geht das mit Script ?
                                          mehrwiedu @Dirni last edited by
                                          @Dirni said in [Vorstellung] Meine zweite Visualisierung:
                                          Genau sagen, wie es der TE gemacht hat, kann ich nicht. Ich weiß nur, wie ich das für mich angeglichen habe.
                                          Die Buttons sind "ctrl - Icon State"
                                          In den Einstellungen habe ich die ObjectID vom entsprechenden Echo aus dem Alexa2 Adapter (Music Provider-TuneIn) genommen.
                                          und den auszuführenden Wert ans Objekt übergeben
                                          Das Bild habe ich mir bei laufendem Radiosender aus der URL im Objekt "Player" des Echos im Alexa2 Adapters geholt. Einfach kopieren und im Browser aufrufen, anschließend runterladen. 😉
                                          Und dieses png habe ich dann in den zwei Bedingungen des ctrl Icon State einmal bei "gleich" und "ungleich" eingefügt.
                                          So bleibt das Bild in VIS sichtbar, auch wenn der "current title" aus dem Player etwas anderes anzeigt.
                                          In VIS kann man dann auf die Button drücken und der Echo startet oder wechselt den Radiosender nach Wunsch.
                                          Muss natürlich für jeden Echo separat gemacht werden.
                                          P.S.
                                          Hey, ich konnte auch mal helfen. 😉
                                          @Kuddel
                                          Die Historie des Robos habe ich auch hingekriegt. War nur ein falscher Datenpunkt.
                                          Nun bin ich aber bei der Zonenreinigung angelangt. Das benötigt ja definitiv etwas Vorarbeit. Kannst Du mir dabei helfen, die passenden Infos zu finden?
                                            Kuddel @mehrwiedu last edited by Kuddel
                                            @mehrwiedu
                                            Meine Echos sind auch immer an, also stecken in der Steckdose. Nur blende ich Interpreten etc. aus, wenn nichts aktiv ist
                                            Die Hostorie vom Robo werden mit den Datenpunkten vom Adapter dargesellt. Da ist kein Script hinterlegt
                                            Script Mi Roboter Behälterfüllstand
                                            <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="ux3[8:o+:z*O,f{n0^yV" collapsed="true" x="-500" y="-260">
                                              <value name="OID0">
                                                <shadow type="field_oid" id="w}!oDUTU#9!?ub1p]FTy">
                                                  <field name="oid">mihome-vacuum.0.info.cleanedtime</field>
                                                <block type="controls_if" id="s~fmVH:blSc?}fwN54,u">
                                                    <block type="logic_compare" id="[j)B%Ms/ER3JLCYp{EX:">
                                                        <block type="get_value" id="dao9[6-Y=8,j1]DE/+{d">
                                                          <field name="OID">javascript.0.NoNo.Behaelter_Stand</field>
                                                        <block type="math_number" id="9UfD8GZNJy,y|AM(cw-y">
                                                          <field name="NUM">100</field>
                                                    <block type="update" id="3lbjOrzB!`h*np#Vd15V">
                                                        <block type="math_arithmetic" id="Zq4JbfdCDvKx.@Tr]W}e">
                                                          <field name="OP">ADD</field>
                                                            <shadow type="math_number" id="xaw|mh7/a~zXaV0Ol9~a">
                                                            <block type="get_value" id="9{rgch9BP;(.]^bDA](v">
                                                            <shadow type="math_number" id="FZ={FB`AQ7ABAeuvJybc">
                                            Script für die Windrichtungen
                                            <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="A,S__`h%ARwU~S]k!P*c" x="-437" y="-187">
                                              <value name="OID0">
                                                <shadow type="field_oid" id="PhCZInh`E}60H=qOD8UE">
                                                  <field name="oid">system.adapter.daswetter.0.alive</field>
                                                <block type="controls_if" id="TdW/C%WrCo.y1A*NM_{F">
                                                    <block type="logic_compare" id="?V^{l:G}^d#A]vDSf-*k">
                                                        <block type="get_value" id="%cO2VvY)%Ng3NS|82)ip">
                                                          <field name="OID">system.adapter.daswetter.0.alive</field>
                                                        <block type="logic_boolean" id="m0Pz0/GxBOIwgF.*C4_-">
                                                    <block type="comment" id="!Rv96?6CusFm,)Mph`N+">
                                                      <field name="COMMENT">Wind</field>
                                                        <block type="variables_set" id="JonV776pH7cVAcDeTz^b">
                                                          <field name="VAR">zusatz</field>
                                                            <block type="text" id="FwI7Jc5TL8[D*{^gub3y">
                                                              <field name="TEXT">http://192.168.4.30:8082</field>
                                                            <block type="control" id="V3vy?wO!D16r*!C3V!#?">
                                                              <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-1</field>
        <block type="text_join" id="u#dl2[xRLhytkg1^W@cZ" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="@05mokC~2Gq=:pX*5Y%K">
        <value name="ADD1">
        <block type="get_value" id="p(?Hd2v}(3KoHKj-]2j/">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_1.windIconURL</field>
        <block type="control" id="0Rv7(9m!Ah.}l2{5n(c7">
        <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-2</field>
        <block type="text_join" id="L_=J5_T9V]Dw}v-%ZWL0" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="M6{,XV1zX4lqPKO^5W^.">
        <value name="ADD1">
        <block type="get_value" id="r!?ZFzOsIv:t*n5LKnZ^">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_2.windIconURL</field>
        <block type="control" id="sJM#~Z?3KYr3Y4WIr-`O">
        <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-3</field>
        <block type="text_join" id="RZ6R2zC,DO25S|{%E~]c" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="Y1cA%r@n4AAggTYN{_7)">
        <value name="ADD1">
        <block type="get_value" id="{w]s)xW_Dycl81QED(Ep">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_3.windIconURL</field>
        <block type="control" id="L+wnoyaErCI5L?Ak`Kkg">
        <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-4</field>
        <block type="text_join" id="Yi!~fb_#:%McPalL3s[N" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="uk_e0rBi8N!%Hjt{^uX.">
        <value name="ADD1">
        <block type="get_value" id="!fg23j11P[E#zpkm(6[q">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_4.windIconURL</field>
        <block type="control" id="ftu4[f{t]EuCqLJ]3riY">
        <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-5</field>
        <block type="text_join" id="O52RQzIb{uS-I.w/E*1d" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="{EeMJzc0{Q14X6F:R3_i">
        <value name="ADD1">
        <block type="get_value" id="VQA_UF1vhVt_E0(,|Biw">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_5.windIconURL</field>
                                            template vis
                                            148
                                            1324
                                            504610
