    4. Test Adapter SourceAnalytix v0.2.x
    • lobomau
      lobomau last edited by
      Ich wollte auch mal testen und hatte den 0.2.27 mit den Fehlern. Nun versuche ich den zu löschen um auf 0.2.26 zu kommen.
      Mit wenig Erfolg. Ein Rechteproblem?
      > user "root" does not have permission to access the dev dir "/home/iobroker/.node-gyp/8.15.0"gyp
      $ ./iobroker add sourceanalytix --host iobroker-ubuntu
      NPM version: 6.4.1
      npm install iobroker.sourceanalytix --production --save --prefix "/opt/iobroker" (System call)
      npm notice created a lockfile as package-lock.json. You should commit this file.
      node-pre-gyp
      WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v57-linux-x64.tar.gz node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
      ! gyp
      WARN EACCES user "root" does not have permission to access the dev dir "/home/iobroker/.node-gyp/8.15.0"gyp
      WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
      make: *** No rule to make target '../.node-gyp/8.15.0/include/node/common.gypi', needed by 'Makefile'. Stop.
      gyp
      ERR! build error
      gyp ERR!
      stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack at emitTwo (events.js:126:13)
      ! gyp ERR! stack at ChildProcess.emit (events.js:214:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
      gyp
      ERR! System Linux 4.15.0-45-genericgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
      ! gyp ERR! cwd /opt/iobroker/node_modules/usbgyp ERR! node -v v8.15.0
      ! gyp ERR! node-gyp -v v3.8.0gyp ERR! not ok
      ! node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      at emitTwo (events.js:126:13)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
      node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
      node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
      ! node-pre-gyp ERR!
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp
      ERR! cwd /opt/iobroker/node_modules/usbnode-pre-gyp ERR! node -v v8.15.0
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      ! node-pre-gyp
      node-pre-gyp
      WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v57-linux-x64.tar.gz node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
      ! gyp
      WARN EACCES user "root" does not have permission to access the dev dir "/home/iobroker/.node-gyp/8.15.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/.node-gyp"
      ! make: *** No rule to make target '../.node-gyp/8.15.0/include/node/common.gypi', needed by 'Makefile'. Stop.
      gyp
      ERR! build error
      gyp
      ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp
      gyp ERR! System Linux 4.15.0-45-generic
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" "--module_name=binding" "--module_path=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"gyp ERR! cwd
      /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socketgyp ERR! node -v v8.15.0
      gyp
      ERR! not ok
      node-pre-gyp ERR!
      stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node --module_name=binding --module_path=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
      node-pre-gyp
      ERR! stack at ChildProcess.emit (events.js:214:7)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
      ! node-pre-gyp
      ERR! System Linux 4.15.0-45-genericnode-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      ! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socketnode-pre-gyp ERR! node -v v8.15.0
      node-pre-gyp
      ERR! node-pre-gyp -v v0.12.0node-pre-gyp ERR! not ok
      ! npm
      WARN onvif-snapshot@1.0.2 requires a peer of onvif@^0.5.5 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm
      WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 (node_modules/usb):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 install: node-pre-gyp install --fallback-to-build
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1npm WARN optional
      SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 install: node-pre-gyp install --fallback-to-build
      ! host.iobroker-ubuntu install adapter sourceanalytix
      got /opt/iobroker/node_modules/iobroker.sourceanalytix/admin
      upload [17] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/words.js words.js application/javascript
      upload [16] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/tsconfig.json tsconfig.json application/json
      upload [15] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/style.css style.css text/css
      upload [14] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/sourceanalytix.png sourceanalytix.png image/png
      upload [13] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_open.png settings_open.png image/png
      upload [12] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_details.png settings_details.png image/png
      upload [11] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/index_m.html index_m.html text/html
      upload [10] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [9] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [8] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [7] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [4] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [3] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [2] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [1] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/custom_m.html custom_m.html text/html
      ERROR: /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:805 if (adapter.substring(0, appName.length + 1) === appName + '.') {
      ! TypeError: Cannot read property 'substring' of undefined
      at Object.getAdapterDir (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:805:17)
      at Install.createInstance (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:672:34)
      at Socket.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:522:34)
      at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
      at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      ! ERROR: process exited with code 1</anonymous></anonymous></anonymous></anonymous>
      • Dutchman
        Probier Mal bitte aus Admin anstatt Konsole zu installieren.
        Hoffentlich finde ich heute Zeit weiter zu machen…
          f0rd42 last edited by
          Hi
          mir sind gerade ein paar Logs aufgefallen:
          sourceanalytix.0	2019-02-06 12:24:00.200	info	Object array of trigger : {"type":"state","common":{"name":"Letzte Regeneration Über","type":"number","role":"number","desc":"Letzte Regeneration Über","read":true,"write":true,"def":0,"min":0,"unit"
          sourceanalytix.0	2019-02-06 12:24:00.200	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
          sourceanalytix.0	2019-02-06 12:24:00.200	info	Object array of trigger : {"type":"state","common":{"name":"Letzte Regeneration","type":"string","role":"string","desc":"Letzte Regeneration vor x h","read":true,"write":true,"def":0,"min":0,"unit":"
          sourceanalytix.0	2019-02-06 12:24:00.199	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
          sourceanalytix.0	2019-02-06 12:24:00.199	info	Object array of trigger : {"type":"state","common":{"name":"Restzeit/-menge Reg.Schritt","type":"number","role":"number","desc":"Restzeit/-menge Reg.Schritt","read":true,"write":true,"def":0,"min":0,
          sourceanalytix.0	2019-02-06 12:24:00.199	info	Object array of trigger : {"type":"state","common":{"name":"Kapazitätszahl","type":"number","role":"number","desc":"Kapazitätszahl","read":true,"write":true,"def":0,"min":0,"unit":"m³*°dH"},"from":"s
          sourceanalytix.0	2019-02-06 12:24:00.197	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
          sourceanalytix.0	2019-02-06 12:24:00.197	info	Object array of trigger : {"type":"state","common":{"name":"Restkapazität","type":"number","role":"number","desc":"Restkapazität","read":true,"write":true,"def":0,"min":0,"unit":"m³*°dH"},"from":"sys
          sourceanalytix.0	2019-02-06 12:24:00.197	info	Object array of trigger : {"type":"state","common":{"name":"Aktueller Durchfluss","type":"number","role":"number","desc":"Aktueller Durchfluss","read":true,"write":true,"def":0,"min":0,"unit":"m³/h",
          sourceanalytix.0	2019-02-06 12:24:00.196	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
          sourceanalytix.0	2019-02-06 12:24:00.196	info	Object array of trigger : {"type":"state","common":{"name":"Regeneration aktiv","type":"number","role":"number","desc":"Regeneration aktiv","read":true,"write":true,"def":0,"min":0,"unit":""},"from":
          sourceanalytix.0	2019-02-06 12:24:00.193	info	Object array of trigger : {"type":"state","common":{"name":"Voraussichtliche nächste Regeneration","type":"string","role":"string","desc":"Voraussichtliche nächste Regeneration","read":true,"write":t
          sourceanalytix.0	2019-02-06 12:24:00.192	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
          sourceanalytix.0	2019-02-06 12:24:00.192	info	Object array of trigger : {"type":"state","common":{"name":"0= Austauscher gestört/in Regeneration 1= Austauscher in Betrieb","type":"number","role":"number","desc":"0= Austauscher gestört/in Regener
          sourceanalytix.0	2019-02-06 12:24:00.192	info	Object array of trigger : {"type":"state","common":{"name":"Aktuelle Restkapazität Austauscher","type":"number","role":"number","desc":"Aktuelle Restkapazität Austauscher","read":true,"write":true,"d
          sourceanalytix.0	2019-02-06 12:24:00.192	info	Object array of trigger : {"type":"state","common":{"name":"Ergebnis letzter E-Mail Versand 0=keine Mail versandt 1=Mail erfolgreich versandt 2=Benutzerdaten fehlerhaft 3= kein Internetzugang/Server
          sourceanalytix.0	2019-02-06 12:24:00.191	info	Object array from trigger : ["smartmeter.0.1-0:1_8_0_255.value","smartmeter.1.1_8_1.value"]
          warum "vergreift" sich denn sourceanalytix an meiner Wasserenthärtungsanlage?
          Eigestellt ist bei den Datenpunkten nichts
          • lobomau
            @Dutchman:
            Sent from my iPhone using Tapatalk `
            Ich habe es immer per Admin gemacht. Ich bekomme es nur nicht vernünftig de- und installiert. Er sagt unter "latest", Version 2.2.26 verfügbar.
            Nach der Installation steht aber 2.2.27. installiert. Aber richtig zuende installieren tut er auch nicht mehr. Ich glaube ich bekomme 2.2.27 nicht richtig deinstalliert.
            Beim Versuch zu installieren:
            cloud.0 2019-02-06 12:51:06.133 warn Unknown command: cmdExit
            cloud.0 2019-02-06 12:51:05.137 warn Unknown command: cmdExit
            cloud.0 2019-02-06 12:51:05.136 warn Unknown command: cmdStderr
            iobroker 2019-02-06 12:51:05.129 info exit 1
            iobroker 2019-02-06 12:51:05.125 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
            iobroker 2019-02-06 12:51:05.125 error at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
            iobroker 2019-02-06 12:51:05.125 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
            iobroker 2019-02-06 12:51:05.125 error at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
            iobroker 2019-02-06 12:51:05.125 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
            iobroker 2019-02-06 12:51:05.125 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
            iobroker 2019-02-06 12:51:05.125 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
            iobroker 2019-02-06 12:51:05.125 error at Socket.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:522:34)
            iobroker 2019-02-06 12:51:05.125 error at Install.createInstance (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:672:34)
            iobroker 2019-02-06 12:51:05.125 error at Object.getAdapterDir (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:805:17)
            iobroker 2019-02-06 12:51:05.125 error TypeError: Cannot read property 'substring' of undefined
            iobroker 2019-02-06 12:51:05.125 error ^
            iobroker 2019-02-06 12:51:05.125 error /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:805 if (adapter.substring(0, appName.length + 1) === appName + '.') {
            cloud.0 2019-02-06 12:51:04.830 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.828 info upload [0] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/custom_m.html custom_m.html text/html
            cloud.0 2019-02-06 12:51:04.769 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.766 info upload [1] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/de/translations.json i18n/de/translations.json application/json
            cloud.0 2019-02-06 12:51:04.708 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.706 info upload [2] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/en/translations.json i18n/en/translations.json application/json
            cloud.0 2019-02-06 12:51:04.649 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.647 info upload [3] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/es/translations.json i18n/es/translations.json application/json
            cloud.0 2019-02-06 12:51:04.586 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.583 info upload [4] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            cloud.0 2019-02-06 12:51:04.527 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.525 info upload [5] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/it/translations.json i18n/it/translations.json application/json
            cloud.0 2019-02-06 12:51:04.454 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.451 info upload [6] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            cloud.0 2019-02-06 12:51:04.393 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.390 info upload [7] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            cloud.0 2019-02-06 12:51:04.331 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.329 info upload [8] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            cloud.0 2019-02-06 12:51:04.242 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:04.239 info upload [9] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            cloud.0 2019-02-06 12:51:03.989 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.986 info upload [10] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            cloud.0 2019-02-06 12:51:03.916 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.914 info upload [11] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/index_m.html index_m.html text/html
            cloud.0 2019-02-06 12:51:03.812 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.810 info upload [12] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_details.png settings_details.png image/png
            cloud.0 2019-02-06 12:51:03.748 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.745 info upload [13] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_open.png settings_open.png image/png
            cloud.0 2019-02-06 12:51:03.672 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.670 info upload [14] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/sourceanalytix.png sourceanalytix.png image/png
            cloud.0 2019-02-06 12:51:03.613 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.611 info upload [15] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/style.css style.css text/css
            cloud.0 2019-02-06 12:51:03.554 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.551 info upload [16] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/tsconfig.json tsconfig.json application/json
            cloud.0 2019-02-06 12:51:03.462 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.458 info upload [17] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/words.js words.js application/javascript
            cloud.0 2019-02-06 12:51:03.434 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.431 info got /opt/iobroker/node_modules/iobroker.sourceanalytix/admin
            cloud.0 2019-02-06 12:51:03.406 warn Unknown command: cmdStdout
            iobroker 2019-02-06 12:51:03.404 info host.iobroker-ubuntu install adapter sourceanalytix
            iobroker 2019-02-06 12:51:02.476 info add sourceanalytix --host iobroker-ubuntu</anonymous></anonymous>
            Installationsdialog zeigt aber keine Einträge, als wenn nicths passieren würde. ABer log zeigt, dass etwas passiert.
            Dann beim Versuch zu deinstallieren:
            cloud.0	2019-02-06 12:59:56.365	warn	Unknown command: cmdStdout
            iobroker	2019-02-06 12:59:56.362	info	path: '/home/iobroker/.npm/_logs' }
            iobroker	2019-02-06 12:59:56.362	info	syscall: 'scandir',
            iobroker	2019-02-06 12:59:56.362	info	code: 'EACCES',
            iobroker	2019-02-06 12:59:56.362	info	errno: -13,
            iobroker	2019-02-06 12:59:56.362	info	glob error { Error: EACCES: permission denied, scandir '/home/iobroker/.npm/_logs' stack: 'Error: EACCES: permission denied, scandir \'/home/iobroker/.npm/_logs\'',
            host.iobroker-ubuntu	2019-02-06 12:58:51.796	error	Cannot write files: /opt/iobroker/iobroker-data/files/sourceanalytix.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/sourceanalytix.admin/_data.json'
            cloud.0	2019-02-06 12:58:51.457	warn	Unknown command: cmdStdout
            iobroker	2019-02-06 12:58:51.454	info	npm uninstall iobroker.sourceanalytix --silent --save --prefix "/opt/iobroker" (System call)
            cloud.0	2019-02-06 12:58:50.833	warn	Unknown command: cmdStdout
            iobroker	2019-02-06 12:58:50.816	info	host.iobroker-ubuntu Deleting 1 state(s).
            cloud.0	2019-02-06 12:58:50.812	warn	Unknown command: cmdStdout
            iobroker	2019-02-06 12:58:50.807	info	host.iobroker-ubuntu Deleting 1 object(s).
            cloud.0	2019-02-06 12:58:50.785	warn	Unknown command: cmdStdout
            iobroker	2019-02-06 12:58:50.778	info	host.iobroker-ubuntu Counted 1 states (system.adapter.sourceanalytix.*) from states
            cloud.0	2019-02-06 12:58:50.652	warn	Unknown command: cmdStdout
            iobroker	2019-02-06 12:58:50.649	info	host.iobroker-ubuntu Counted 1 states of sourceanalytix
            cloud.0	2019-02-06 12:58:48.441	warn	Unknown command: cmdStdout
            iobroker	2019-02-06 12:58:48.438	info	host.iobroker-ubuntu no instances of adapter sourceanalytix found
            cloud.0	2019-02-06 12:58:48.415	warn	Unknown command: cmdStdout
            iobroker	2019-02-06 12:58:48.412	info	Delete adapter "sourceanalytix"
            iobroker	2019-02-06 12:58:47.559	info	del sourceanalytix
            Edit: habe scheinbar allgemein einen bug. Oder ist es normal, dass sich über cloud iobroker.pro das Dialogfeld beim Installieren sich nicht aktualisiert? Habe eben anderen Adapter installiert und es kommt nix. Es steht einfach: Gestartet… $ ./iobroker upgrade "Adaptername"
            • U
              UncleB last edited by
              Mal ne blöde Fragen..
              Welchen Datenpunkt muss ich loggen um eine Tägliche / Monatliche /Jährliche Auswertung zu erhalten?
              Vermutlich ENERGY_TODAY?
              Oder passiert das Live mit Current?
              ![](</s><URL url=)https://i.postimg.cc/xTktVh29/Download.png" />
              • Homer.J.
                Homer.J. last edited by
                @UncleB:
                ![](</s><URL url=)https://i.postimg.cc/xTktVh29/Download.png" /> ` Energy total Rest geht von alleine.
                  Creator last edited by
                  So ich habe auch mal den Adapter installiert.
                  Ich vertstehe gerade nicht wie ich dafür sorgen kann, dass die Berechnung bei 0 anfängt.
                  Es ist egal ob ich beim Startwert 0 oder den aktuellen Zählerstand hinterlege, der aktuelle Monat war echt teuer...
                  Dazu wäre es für viele glaube ich ich super, wenn in der Oberfläche bei den Einstellungen eine erklärung stehen würde. 🙂 Als Tooltipp oder so.
                  a200 1 Reply Last reply Reply Quote 0
                  • a200
                    a200 @Creator last edited by a200
                    @Creator said in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                    Aber wie hast du das gemacht? Der Adapter (0.2.27) ist nicht im IoBroker und wenn ich den über git installieren will, dann bekomme ich Fehlermeldung beim erzeugen der Instanz.
                      sigi234 Forum Testing Most Active @a200 last edited by
                      @a200
                      Über die Katze...
                      • a200
                        a200 @sigi234 last edited by
                        @sigi234
                        ja, aber dann wird die 0.2.27er Version geladen und die macht bei der Erstellung einer Instanz Probleme!!002.PNG.
                        Welches os hast du denn und wann hast du die 0.2.26 Version Installiert?
                          sigi234 Forum Testing Most Active @a200 last edited by sigi234
                          @a200
                          Windows 10, bin wieder auf die 0.2.26 gegangen.
                          • a200
                            a200 @sigi234 last edited by a200
                            @sigi234 said in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                            @a200
                            ok. ich bin auf der qnap. aber wie kannst du auf 0.2.26 gegangen. Bei der Katz kriege ich automatisch die 0.2.27.
                            • hg6806
                              hg6806 Most Active last edited by
                              Sag mal Dutchman, wann gibt es denn eine neue Version?
                              Besonders das todo
                              "add object states for previous [x]day, [x]week, [x]month, [x]quarter, [x]year configurable in adapter settings"
                              ist für mich interessant, da ich immer die letzten Tage/Wochen per Balkengrafik anzeigen lasse.
                              • Negalein
                                Negalein Global Moderator @a200 last edited by
                                @a200 said in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                                Du musst den Expertenmodus einschalten. Dann siehst du ganz rechts (neben dem Papierkorb) ein neues Symbol. Mit dem kannst du dann die Version auswählen.
                                • a200
                                  a200 @Negalein last edited by
                                  @Negalein said in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                                  Vielen Dank, wenn du Screenshots von oben siehst, dann wirst du merken, dass dieses Icon bei dem Adapter bei mir nicht angezeigt wird. Allerdings habe ich mir Dutchmans Hilfe das Problem gelöst. Ich habe das latest-repo als default angemeldet und dann wurde die 0.2.26 gezogen. Danach die Respos wieder aus Standard gesetzt. Also alles gut jetzt! vielen Dank an alle!
                                  porty 1 Reply Last reply Reply Quote 0
                                    Treep77 last edited by Treep77
                                    Hab die 0.2.26 Version installiert. Muss man die Objektordner (Tage/Woche---) selbst erstellen?? Bekomme bei den Objekten keine Unterordner angezeigt.
                                    EDIT: Fehler gefunden....hab 2 Häckchen vergessen.
                                    • Dutchman
                                      Dieses Wochenende wird weiter gehen in der Entwicklung dieses Adapters hatte bissl zuviel tun letzten Wochen 😉
                                      • hg6806
                                        Klasse !!!
                                        • SmarthomeMF
                                          SmarthomeMF last edited by
                                          Ich lese wieder mit
                                            burncolonia last edited by
                                            Ein freundliches Hallo in die Runde. Auch ich habe mich sehr über diesen Adapter gefreut, kann ich doch damit perfekt meinen Stromverbrauch messen bzw mitloggen.
                                            Ich habe ein ganz anderes Problem. Ich wollte aus Performance-Gründen den Raspi gegen einen NUC mit 8GB RAM austauschen. Der Umzug klappt auch soweit gut nur werden leider keine Daten von sourceanalytix übernommen. Weder über iobroker backup / restore noch über den kopierten History Ordner.
                                            Könnte mir jemand sagen wo die Daten liegen?
                                            Freundliche Grüße
                                            vom BuRn
                                            adapter test
                                            103
                                            958
                                            285308
