    4. [Vorstellung] Meine zweite Visualisierung
      mehrwiedu last edited by
      @Kuddel:
      @tiroler:
      Danke fürs bereitstellen,
      Hätte noch eine Frage wie hast das mit der Waschmaschine gelöst, kannst du das Script dafür auch bereitstellen. Danke `
      Status-Waschmaschine (Blockly):
      <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="o%),[!u9gGk_ZZyIIa:v" x="-155" y="45"><mutation items="1"></mutation>
      <value name="OID0"><shadow type="field_oid" id="T7ab,8_M8,BHbMdX^]!h"><field name="oid">hm-rpc.0.LEQ1272397.2.POWER</field></shadow></value>
      <statement name="STATEMENT"><block type="comment" id="1QB=V}FQL0d}#l+(QxJB"><field name="COMMENT">Aus</field>
      <next><block type="controls_if" id="dD#]Vc0pnz@,}#f{eW="><value name="IF0"><block type="logic_operation" id="%a(cnm~t{|rdYc#+iS" inline="false"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="4VKDm7AnAT4ERO3PN,W"><field name="OP">NEQ</field>
      <value name="A"><block type="get_value" id="Yrk}!l*wt#Muy(wu:m3"><field name="ATTR">val</field> <field name="OID">javascript.0.haushalt.waschmaschine</field></block></value> <value name="B"><block type="math_number" id="~,Rn(x3i.pHq*!QnO?pI"><field name="NUM">0</field></block></value></block></value> <value name="B"><block type="logic_compare" id="M3C^axU4Q:D-G+VDGta"><field name="OP">LT</field>
      <value name="A"><block type="get_value" id="Q.=+)xl0+dGQ;v;/n9v"><field name="ATTR">val</field>
      <field name="OID">hm-rpc.0.LEQ1272397.2.POWER</field></block></value>
      <value name="B"><block type="math_number" id="Yc7C,cA)oJl}if0XFrqi"><field name="NUM">0.5</field></block></value></block></value></block></value>
      <statement name="DO0"><block type="timeouts_settimeout" id="3(oXDT4pAX|](%[}pL("><field name="NAME">timeout2</field> <field name="DELAY">1</field> <field name="UNIT">min</field> <statement name="STATEMENT"><block type="controls_if" id="VC39ip(2Y]lk/X?ykj;"><value name="IF0"><block type="logic_operation" id="tOFb-,NZzjk!4K5@8tSb" inline="false"><field name="OP">AND</field>
      <value name="A"><block type="logic_compare" id="Z8{Q![]D
      Dm04Wzr/G|R"><field name="OP">NEQ</field>
      <value name="A"><block type="get_value" id="0GyY/TP5EW1}s}4nKZI"><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id="^6N|fJ#]J*6.7r47%Kk"><field name="NUM">0</field></block></value></block></value> <value name="B"><block type="logic_compare" id="UjiDdhQ,]W#MCpmMMxMj"><field name="OP">LT</field> <value name="A"><block type="get_value" id="9p,-t~21w]Wmzfx?(f3P"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.LEQ1272397.2.POWER</field></block></value> <value name="B"><block type="math_number" id=":vB!/kTAi]dKF5+j!~W{"><field name="NUM">0.5</field></block></value></block></value></block></value> <statement name="DO0"><block type="control" id="5Q)5v-.Aw^aZcAwY@]oc"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.haushalt.waschmaschine</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="ql(RVJ.2-IX}){cA(pd*"><field name="NUM">0</field></block></value></block></statement></block></statement></block></statement> <next><block type="comment" id="V[JvQyTj@U0KfZ,]1D@f"><field name="COMMENT">Läuft</field> <next><block type="controls_if" id="Xi)LJAN:?)bln/kKvD"><value name="IF0"><block type="logic_operation" id="yCx3KlI8^oo:-r@G3q;g" inline="false"><field name="OP">AND</field>
      <value name="A"><block type="logic_compare" id="A!!DpNVjljp1cFY_P@+:"><field name="OP">NEQ</field>
      <value name="A"><block type="get_value" id="obAcC67N
      D2QX)x~OS%l"><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id="bmp+Xv4Kb(gbn5J/~h
      H"><field name="NUM">1</field></block></value></block></value>
      <value name="B"><block type="logic_compare" id="3K^Vl7hlx==yY8Pq2}9"><field name="OP">GT</field>
      <value name="A"><block type="get_value" id="l)YY|DODI_s3r0J
      WKW8"><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id="XF|!fj+/SrLI=k5S~g(F"><field name="NUM">140</field></block></value></block></value></block></value>
      <statement name="DO0"><block type="control" id="J4~j2G8}C;Qw!)Pgv:pE"><mutation delay_input="false"></mutation>
      <value name="VALUE"><block type="math_number" id="H0w:XuVjmqP~[|QoF#md"><field name="NUM">1</field></block></value></block></statement>
      <next><block type="comment" id="xX[H0Gjr^+UdsAXj%Gv["><field name="COMMENT">Timer</field>
      <next><block type="controls_if" id="i8AKxAJ2u0(K3+n]Fsu"><value name="IF0"><block type="logic_operation" id=",Ck;ys{}MOyTA5ty=v+" inline="false"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="5|(Ej)@Y2.AUcANeD(VO"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="3OF:nKn0@]nT)]bRPM^U"><field name="ATTR">val</field> <field name="OID">javascript.0.haushalt.waschmaschine</field></block></value> <value name="B"><block type="math_number" id="[%HI@1baQTW+0qHuO!BV"><field name="NUM">0</field></block></value></block></value> <value name="B"><block type="logic_operation" id="73ug28Rg:;zVBaYK[bU" inline="false"><field name="OP">AND</field>
      <value name="A"><block type="logic_compare" id="HQ!Iv[2{YGocWe
      /7FC@"><field name="OP">LT</field>
      <value name="A"><block type="get_value" id="s(l9}WXGx_A8T%d;M,B"><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id=")QOW1!?Uy7txa8h1(,Ff"><field name="NUM">6</field></block></value></block></value>
      <value name="B"><block type="logic_compare" id="Z7o2%aCACuWTWcOdy^"><field name="OP">GT</field>
      <value name="A"><block type="get_value" id="96f(OrH_BciNrMS~v|%?"><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id="E@RSATlh~G5t^qo)~%%p"><field name="NUM">5</field></block></value></block></value></block></value></block></value>
      <statement name="DO0"><block type="control" id="2fX=L~mZf|~;4.#m~9G"><mutation delay_input="false"></mutation> <field name="OID">javascript.0.haushalt.waschmaschine</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block type="math_number" id="%l9h-,8e[[~VS:sY)NaR"><field name="NUM">2</field></block></value></block></statement> <next><block type="comment" id="Ca%7[kx7U(Y(vh3vPLM"><field name="COMMENT">Fertig</field>
      <next><block type="controls_if" id="YgP%U~lLn
      BC-?ZVZUiN"><value name="IF0"><block type="logic_operation" id="H?VMR#|..l%WDz=qRByb" inline="false"><field name="OP">AND</field>
      <value name="A"><block type="logic_compare" id="5w}Z?FR4c]HgSZ7g33Td"><field name="OP">NEQ</field>
      <value name="A"><block type="get_value" id="%.Pni:P2|2gg[[R-;#2("><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id="NKpxyPQe:T}kGk8vLh2"><field name="NUM">3</field></block></value></block></value> <value name="B"><block type="logic_operation" id="LS*dqzVfb!VM2!ptks_" inline="false"><field name="OP">AND</field>
      <value name="A"><block type="logic_compare" id="W00wE^~/xd1SoLd+Jhh"><field name="OP">LT</field> <value name="A"><block type="get_value" id="hF_M:1;;f!7lMdVb^[sY"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.LEQ1272397.2.POWER</field></block></value> <value name="B"><block type="math_number" id="+.v;eO}:AHO~27Z%q|T"><field name="NUM">4</field></block></value></block></value>
      <value name="B"><block type="logic_compare" id="Oz~3,:P7F:+Yr1md:%0"><field name="OP">GT</field>
      <value name="A"><block type="get_value" id="-F}P;O7
      y-DHtQ^/p+8w"><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id="M0FY#+wW3S(,v|dGnzd"><field name="NUM">3</field></block></value></block></value></block></value></block></value>
      <statement name="DO0"><block type="timeouts_settimeout" id="GlR8m1w4;}?vaX^4a/pq"><field name="NAME">timeout</field>
      <field name="DELAY">10</field>
      <statement name="STATEMENT"><block type="controls_if" id="yk;n@H0Pt;yE001/1Pv"><value name="IF0"><block type="logic_operation" id="!qEnJZd7!E#+({Fulj-f" inline="false"><field name="OP">AND</field>
      <value name="A"><block type="logic_compare" id="X+,!iy9kv+LZK:6DNX/g"><field name="OP">NEQ</field>
      <value name="A"><block type="get_value" id="^Z.j7ydE=:wIi4~gyj^u"><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id="X13P=,9Jp/TyaiNog9
      S"><field name="NUM">3</field></block></value></block></value>
      <value name="B"><block type="logic_operation" id="LD|=^/J?Ez=~sI31h]31" inline="false"><field name="OP">AND</field>
      <value name="A"><block type="logic_compare" id="b/VP7=UZB7kB
      %^t%CUX"><field name="OP">LT</field>
      <value name="A"><block type="get_value" id="lwc,3wBc%o,PnzA[kV`("><field name="ATTR">val</field>
      <value name="B"><block type="math_number" id="r,Rd+gGA0QLE/hO}@,]E"><field name="NUM">4</field></block></value></block></value>
      <value name="B"><block type="logic_compare" id="?;xbf!?)D3}CY@f6by!"><field name="OP">GT</field>
      <value name="A"><block type="get_value" id="mOhdHKJN,@p!bZf0R1y
      <value name="B"><block type="math_number" id="UhvmXp.]Q#,85;O,d%6D"><field name="NUM">0.5</field></block></value></block></value></block></value></block></value>
      <statement name="DO0"><block type="control" id="NGtYSq12Y1I9M+tpzKcs"><mutation delay_input="false"></mutation>
      <value name="VALUE"><block type="math_number" id="G=YD~ju7|b8ql}j0}w^n"><field name="NUM">3</field></block></value></block></statement></block></statement></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></statement></block>
      Ich habe mir das Script auch mal eingebunden um davon zu lernen. 🙂
      Vielen Dank für die Bereitstellung. Allerdings habe ich direkt eine Frage. Was ist das für ein Objekt?
        Kuddel last edited by
        Mit dem Objekt stelle ich den aktuellen Status der Waschmaschine da;
        0=aus
        1=an
        2=timer
        3=fertig
          @Kuddel:
          0=aus
          1=an
          2=timer
          3=fertig `
          Wow, danke für die superschnelle Antwort.
          Hab ein bisschen Nachsehen mit mir. 🙂 Ich erkenne die Logik jetzt dahinter im Script, aber ich wüsste nicht, wo ich das Objekt bei mir anlegen sollte und was es dann für einen Inhalt bekommt. Ist das einfach nur ein Infoobjekt, was dann später in der VIS Darstellung den gesetzten Wert wiedergibt? Oder steckt da noch weiterer Code hinter? Da bin ich wahrscheinlich noch viel zu weit am Anfang, als das ich das direkt verstehe. Sorry für die Fragen. Ich lerne halt noch. 😉
            Die Werte sind zur Darstellung in VIS gedacht.
            Das Datenobjekt kannst du unter Javascript.0 anlegen.
            Überlege dir vorher am Besten eine Struktur, denn mit der Zeit werden es immer mehr Objekte und leider kann man die nicht verschieben
            • Segway
              Segway last edited by
              Momentan nutze ich noch das schlechte Wetter um ebenso an meiner VIS zu basteln.
              Anhand deiner Fotos sehe ich, dass du zB Ram, Speicher, Festplattenplatz anscheinend "dynamisch" anzeigen lässt, also wenn noch x von y MB frei sind (entspricht 50%) den Balken entsprechend lang machst.
              Wie bekommt man sowas hin ? Macht das das Widget oder programmieren ?
                mehrwiedu last edited by mehrwiedu
                Ich müsste hier nochmal etwas nachfragen. Ich wühle mich gerade durch diese Visualisierung und lerne tatsächlich so einiges. Allerdings liegen auch noch viele Sachen im Dunkeln.
                Das mit den Datenpunkten habe ich soweit verstanden. In der Darstellung Deiner Echo Geräte, nutzt Du auch einen "Status", der wahrscheinlich dazu dient, die Views entsprechend anzuzeigen (Spotify, Radio, Amazon Music). Das habe ich noch nicht verstanden, wie das funktioniert. Ich finde da in den Einstellungen auch nichts, wo ich das ableiten könnte. Regelst Du das ausschließlich im VIS Editor, oder liegt da ein Script hinter?
                Ebenfalls sind in den Views für Spotify und Amazon Music "Vor" "Zurück" "Play" und "Pause" Button zu sehen, die ich als Widgets im Editor zwar auch finde, jedoch die Icons und die Datenpunkte dazu nicht. Ich bekomme die also bei mir erst gar nicht visuell angezeigt. Wie ist das geregelt?
                Ich glaube, wenn ich die beiden Punkte verstanden habe, dass ich mit meiner VIS ein sehr großes Stückchen weiterkomme.
                Danke Dir schonmal im Voraus für Deine Mühen.
                /edit
                Die Play, Pause, Vor und Zurückbuttons habe ich nun gefunden. Ich hatte nur die hqwidgets nicht installiert. 🙂
                /edit2
                Den Zusammenhang zwischen Statuswert und der Sichtbarkeit der Widgets habe ich nun auch rausgekriegt.
                Stellt sich mir nur die Frage, warum ein eigener Status und nicht den des Gerätes verwenden?
                Gibt es da noch Vorteile einen eigenen Status zu benutzen.
                  maxpd last edited by
                  Müsste er nicht so die Icons erkennen?
                  Wie bekomme ich denn Waschmaschine markiert? Er markiert mir immer nur Haushalt. Auch wenn ich 2019-02-10 21_27_03-Edit vis.png versuche den Rahmen in den Hintergrund zu schieben.!
                    Kuddel @Segway last edited by
                    @Segway said in [Vorstellung] Meine zweite Visualisierung:
                    Dafür gibt es extra ein Balken Widget. Iwas mit bar
                      Kuddel @mehrwiedu last edited by
                      @mehrwiedu said in [Vorstellung] Meine zweite Visualisierung:
                      /edit
                      /edit2
                      -Den aktuellen Status meiner Echo geräte setzte ich per Skript.
                      Ich ahbe das so eingestellt, dass die Radiosteuerung immer angezeigt werden soll, auch wenn die Geräte aus sind.
                      Der Amazon / Spotify Player wird dann wenn aktiv über der Radiosteuerung angezigt.
                      Wenn man das mit dem normalen Alexa Status macht, wird die Radio-Steuerung erstn angezeigt, wenn man das Radio gestatet hat
                        Kuddel @maxpd last edited by
                        @maxpd said in [Vorstellung] Meine zweite Visualisierung:
                        Wenn du das Widget der Waschmaschine bearbeiten willst, muss du in den View Haushalt wechseln. Von der Startseite aus geht das nicht, da wird nur der View angezeigt
                          mehrwiedu @Kuddel last edited by
                          @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                          Ich bin ja schon ein kleines bisschen weiter in der ganzen Sache. Ich habe nicht sooo viele Radiosender, die ich per Schalter aufrufen muss. Bei mir sind es eher Playlisten und so habe ich mir das für meine Geräte ganz individuell mit unterschiedlichen Playlisten gebaut, dank Deiner Vorlage. 🙂
                          Habe am Wochenende echt viel lernen können daraus. So hab ich mir fürs Innenklima auch den kritischen Batteriestatus meiner Temperatursensoren in die Übersicht gebaut. Ab einem gewissen Wert (Volt oder Prozent) blinkt dann vor dem Sofasymbol eine rote Batterie. 😉
                          Aber doch ein Script dahinter bei der Anzeige. 😉
                          Allerdings sind bei mir die Echos nie aus. Es bleibt also immer der letzte Interpret oder der letzte Radiosender in den Player_Werten stehen. Du schaltest sie über die Stromzufuhr ab? Das habe ich natürlich bei mir nicht ausprobiert.
                          Ich wäre aber noch an dem Script für den Mi Roboter (Behälterfüllstand und Historie/Start-Saugzeit-Fläche) und an den Windrichtungen unterhalb der Wetter-Tagesvorschau interessiert, wenn Du das preisgeben möchtest.
                            Dirni last edited by
                            Wie hast du das genau mit den Radio Icons umgesetzt, welcehs Widget hast du da genommen bzw. geht das mit Script ?
                              mehrwiedu @Dirni last edited by
                              @Dirni said in [Vorstellung] Meine zweite Visualisierung:
                              Genau sagen, wie es der TE gemacht hat, kann ich nicht. Ich weiß nur, wie ich das für mich angeglichen habe.
                              Die Buttons sind "ctrl - Icon State"
                              In den Einstellungen habe ich die ObjectID vom entsprechenden Echo aus dem Alexa2 Adapter (Music Provider-TuneIn) genommen.
                              und den auszuführenden Wert ans Objekt übergeben
                              Das Bild habe ich mir bei laufendem Radiosender aus der URL im Objekt "Player" des Echos im Alexa2 Adapters geholt. Einfach kopieren und im Browser aufrufen, anschließend runterladen. 😉
                              Und dieses png habe ich dann in den zwei Bedingungen des ctrl Icon State einmal bei "gleich" und "ungleich" eingefügt.
                              So bleibt das Bild in VIS sichtbar, auch wenn der "current title" aus dem Player etwas anderes anzeigt.
                              In VIS kann man dann auf die Button drücken und der Echo startet oder wechselt den Radiosender nach Wunsch.
                              Muss natürlich für jeden Echo separat gemacht werden.
                              P.S.
                              Hey, ich konnte auch mal helfen. 😉
                              @Kuddel
                              Die Historie des Robos habe ich auch hingekriegt. War nur ein falscher Datenpunkt.
                              Nun bin ich aber bei der Zonenreinigung angelangt. Das benötigt ja definitiv etwas Vorarbeit. Kannst Du mir dabei helfen, die passenden Infos zu finden?
                                Kuddel @mehrwiedu last edited by Kuddel
                                @mehrwiedu
                                Meine Echos sind auch immer an, also stecken in der Steckdose. Nur blende ich Interpreten etc. aus, wenn nichts aktiv ist
                                Die Hostorie vom Robo werden mit den Datenpunkten vom Adapter dargesellt. Da ist kein Script hinterlegt
                                Script Mi Roboter Behälterfüllstand
                                <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="ux3[8:o+:z*O,f{n0^yV" collapsed="true" x="-500" y="-260">
                                  <value name="OID0">
                                    <shadow type="field_oid" id="w}!oDUTU#9!?ub1p]FTy">
                                      <field name="oid">mihome-vacuum.0.info.cleanedtime</field>
                                    <block type="controls_if" id="s~fmVH:blSc?}fwN54,u">
                                        <block type="logic_compare" id="[j)B%Ms/ER3JLCYp{EX:">
                                            <block type="get_value" id="dao9[6-Y=8,j1]DE/+{d">
                                              <field name="OID">javascript.0.NoNo.Behaelter_Stand</field>
                                            <block type="math_number" id="9UfD8GZNJy,y|AM(cw-y">
                                              <field name="NUM">100</field>
                                        <block type="update" id="3lbjOrzB!`h*np#Vd15V">
                                            <block type="math_arithmetic" id="Zq4JbfdCDvKx.@Tr]W}e">
                                              <field name="OP">ADD</field>
                                                <shadow type="math_number" id="xaw|mh7/a~zXaV0Ol9~a">
                                                <block type="get_value" id="9{rgch9BP;(.]^bDA](v">
                                                <shadow type="math_number" id="FZ={FB`AQ7ABAeuvJybc">
                                Script für die Windrichtungen
                                <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="A,S__`h%ARwU~S]k!P*c" x="-437" y="-187">
                                  <value name="OID0">
                                    <shadow type="field_oid" id="PhCZInh`E}60H=qOD8UE">
                                      <field name="oid">system.adapter.daswetter.0.alive</field>
                                    <block type="controls_if" id="TdW/C%WrCo.y1A*NM_{F">
                                        <block type="logic_compare" id="?V^{l:G}^d#A]vDSf-*k">
                                            <block type="get_value" id="%cO2VvY)%Ng3NS|82)ip">
                                              <field name="OID">system.adapter.daswetter.0.alive</field>
                                            <block type="logic_boolean" id="m0Pz0/GxBOIwgF.*C4_-">
                                        <block type="comment" id="!Rv96?6CusFm,)Mph`N+">
                                          <field name="COMMENT">Wind</field>
                                            <block type="variables_set" id="JonV776pH7cVAcDeTz^b">
                                              <field name="VAR">zusatz</field>
                                                <block type="text" id="FwI7Jc5TL8[D*{^gub3y">
                                                  <field name="TEXT">http://192.168.4.30:8082</field>
                                                <block type="control" id="V3vy?wO!D16r*!C3V!#?">
                                                  <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-1</field>
                                                    <block type="text_join" id="u#dl2[xRLhytkg1^W@cZ" inline="true">
                                                      <value name="ADD0">
                                                        <block type="variables_get" id="@05mokC~2Gq=:pX*5Y%K">
                                                      <value name="ADD1">
                                                        <block type="get_value" id="p(?Hd2v}(3KoHKj-]2j/">
                                                          <field name="OID">daswetter.0.NextDays.Location_1.Day_1.windIconURL</field>
                                                    <block type="control" id="0Rv7(9m!Ah.}l2{5n(c7">
                                                      <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-2</field>
                                                        <block type="text_join" id="L_=J5_T9V]Dw}v-%ZWL0" inline="true">
                                                          <value name="ADD0">
                                                            <block type="variables_get" id="M6{,XV1zX4lqPKO^5W^.">
                                                          <value name="ADD1">
                                                            <block type="get_value" id="r!?ZFzOsIv:t*n5LKnZ^">
                                                              <field name="OID">daswetter.0.NextDays.Location_1.Day_2.windIconURL</field>
                                                        <block type="control" id="sJM#~Z?3KYr3Y4WIr-`O">
                                                          <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-3</field>
                                                            <block type="text_join" id="RZ6R2zC,DO25S|{%E~]c" inline="true">
                                                              <value name="ADD0">
        <block type="variables_get" id="Y1cA%r@n4AAggTYN{_7)">
                                                              <value name="ADD1">
        <block type="get_value" id="{w]s)xW_Dycl81QED(Ep">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_3.windIconURL</field>
                                                            <block type="control" id="L+wnoyaErCI5L?Ak`Kkg">
                                                              <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-4</field>
        <block type="text_join" id="Yi!~fb_#:%McPalL3s[N" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="uk_e0rBi8N!%Hjt{^uX.">
        <value name="ADD1">
        <block type="get_value" id="!fg23j11P[E#zpkm(6[q">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_4.windIconURL</field>
        <block type="control" id="ftu4[f{t]EuCqLJ]3riY">
        <field name="OID">javascript.0.DasWetter.Wind-Symbol-Tag-5</field>
        <block type="text_join" id="O52RQzIb{uS-I.w/E*1d" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="{EeMJzc0{Q14X6F:R3_i">
        <value name="ADD1">
        <block type="get_value" id="VQA_UF1vhVt_E0(,|Biw">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_5.windIconURL</field>
                                  @mehrwiedu
                                  Mein Robo hat gerade einen neuen Standort bekommen, so dass ich die Koordinaten neu auslesen muss.
                                  Leider habe ich noch keinen Weg gefunden, wie das funktioniert.
                                  Der alte weg über die App "FloleVac" funktioniert nicht mehr
                                    Ich bin ganz froh darüber, dass der letzte Interpret, wie auch der letzte Titel angezeigt wird. Trotz Log, lass ich das glaube ich so, denn so sieht man auf einen Blick, was aus der Kiste dröhnt, wenn man "Alexa, weiter!" sagt. 😉
                                    Ich habe drei Kinder und die füttern insgesamt 6 Echos hier im Haus mit allem möglichen Mist. Da gab es schon die eine oder andere Überraschung Samstags, wenn ich kurz meine BuLi pausiert habe und in der Halbzeitpause kurz weg war und mich dann genüsslich mit einem "Alexa, weiter!" auf die Couch fallen ließ. Hehe....
                                    Und vielen Dank für die Skripte. 🙂
                                    Lass mir noch ein paar Wochen, dann kann ich hoffentlich auch welche schreiben, bzw. zusammenklicken.
                                    Das mit den Zonen ist auch nicht lebensnotwendig. Da kann ich dann selbst auch mal schauen, wie das geht. Obwohl ich mir damals auch fast die Finger beim Token auslesen gebrochen hätte. Aber ich müsste bei meinem Roboter auch erst die Firmware updaten. Das habe ich bisher seit ich ihn habe, noch nicht gemacht aus Angst, dass ich den Token dann verliere und ihn nicht wieder ausgelesen bekomme.
                                      Ceel last edited by Ceel
                                      Hallo
                                      Super vis, gefällt mir echt gut
                                      Könntest du alle Scripte Posten oder mir per PN schicken die mit Alexa zu tun haben?
                                        Saschag last edited by
                                        Super Vis.
                                        wie machst du dass mit denn Systeminfos (npm, nodejs...)
                                        Hast du da ein Script oder so??
                                        Danke und Grüße
                                          dtp last edited by
                                          Schön gemacht. Mir persönlich wären aber viele Seiten zu überladen. Ich mag lieber weniger Informationen, die ich mit einem Blick aus gewisser Entfernung überschauen kann. Zudem benutze ich meine Visualisierung eher nicht zum Steuern. Das mache ich lieber per Siri oder über die Automatismen.
                                          liv-in-sky 1 Reply Last reply Reply Quote 1
                                            Kuddel @Ceel last edited by
                                            @Ceel
                                            Für Alexa habe ich nur ein SKript, welches den aktuellen Status bestimmt:
                                            <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="ZTJ#4Ya@!gKB*[R;.n9K" x="-20" y="-504">
                                              <mutation items="10"></mutation>
                                              <value name="OID0">
                                                <shadow type="field_oid" id="8rbV~8Dmy04hS8wxbc9E">
                                                  <field name="oid">alexa2.0.Echo-Devices.G090LF11819608MX.Player.currentState</field>
                                              <value name="OID1">
                                                <shadow type="field_oid" id="OF#L~s+~2#7~@qfAsYB3">
                                                  <field name="oid">alexa2.0.Echo-Devices.G090LF1184250DT2.Player.currentState</field>
                                              <value name="OID2">
                                                <shadow type="field_oid" id="+RxGgYoe^IuMs%oKq0tt">
                                                  <field name="oid">alexa2.0.Echo-Devices.G2A0P30883260826.Player.currentState</field>
                                              <value name="OID3">
                                                <shadow type="field_oid" id="^egt:EJF2}@|v*Fb:hf#">
                                                  <field name="oid">alexa2.0.Echo-Devices.b0ccd53c13cc4ec0a03f192efd76abb1.Player.currentState</field>
                                              <value name="OID4">
                                                <shadow type="field_oid" id=":KsDi]OJNRF^U9mQg~-{">
                                                  <field name="oid">alexa2.0.Echo-Devices.5e4f60f0dd7a414f9972e59f4fa85bf4.Player.currentState</field>
                                              <value name="OID5">
                                                <shadow type="field_oid" id="3uVs2OO9%M6pDJ7[?lYk">
                                                  <field name="oid">alexa2.0.Echo-Devices.G090LF11819608MX.Player.providerName</field>
                                              <value name="OID6">
                                                <shadow type="field_oid" id="wvmIx[t{4d*s)!u;=9iy">
                                                  <field name="oid">alexa2.0.Echo-Devices.G090LF1184250DT2.Player.providerName</field>
                                              <value name="OID7">
                                                <shadow type="field_oid" id="MvCt1ATyx;zA!qLBPG3m">
                                                  <field name="oid">alexa2.0.Echo-Devices.G2A0P30883260826.Player.providerName</field>
                                              <value name="OID8">
                                                <shadow type="field_oid" id="+V{AgUL?MbLT1_XJ#yg*">
                                              <value name="OID9">
                                                <shadow type="field_oid" id="M#G/?-LA5!;iY!ZCma=]">
                                                  <field name="oid">alexa2.0.Echo-Devices.5e4f60f0dd7a414f9972e59f4fa85bf4.Player.providerName</field>
                                                <block type="comment" id="4FYP`p#Do8g=ABY;@%2)">
                                                  <field name="COMMENT">Wohnzimmer</field>
                                                    <block type="controls_if" id="ha((-fbS7gbfR:y61GUs">
                                                        <block type="logic_compare" id="BEw(%b~a7AK@l,Klw{__">
                                                            <block type="get_value" id="~[+E!^yYZoCt=:-hB[Xg">
                                                              <field name="OID">alexa2.0.Echo-Devices.G090LF11819608MX.Player.currentState</field>
                                                            <block type="logic_boolean" id="f4SnD/ystx74h/*R|rTh">
                                                        <block type="control" id="bTZ%XPLm].wNpA;ntJJl">
                                                          <field name="OID">javascript.0.echo.wohnzimmer_status</field>
                                                            <block type="get_value" id="94%ts|GSV*3notwkh]4|">
                                                              <field name="OID">alexa2.0.Echo-Devices.G090LF11819608MX.Player.providerName</field>
                                                      <statement name="ELSE">
                                                        <block type="control" id="Gw+l[YjS2-K?@Xq2sP7:">
                                                            <block type="text" id="X;(9KwG!6ZS{8(,QoKxp">
                                                              <field name="TEXT">Stopped</field>
                                                        <block type="comment" id="De2U]!`e=RVv!@iIy1AE">
                                                          <field name="COMMENT">Küche</field>
                                                            <block type="controls_if" id="J.(Z./0%(yW[W0c!#aLD">
        <block type="logic_compare" id="AO]n*Ns;nKWyUnPUHlTt">
        <block type="get_value" id=".vAl8S-]hb/]xc?fm?/W">
        <field name="OID">alexa2.0.Echo-Devices.G090LF1184250DT2.Player.currentState</field>
        <block type="logic_boolean" id="7a/#TTrAwYJvEz?bc{N!">
        <block type="control" id="m1l0nsWk75ZT_`UGHxKG">
        <field name="OID">javascript.0.echo.kueche_status</field>
        <block type="get_value" id="D%CV7^NA7VC:4|X./M*R">
        <field name="OID">alexa2.0.Echo-Devices.G090LF1184250DT2.Player.providerName</field>
        <block type="control" id="dQW2~,9.wt_!kZhYyIXe">
        <block type="text" id="Pg7%R9Lf:Au)SYo-l*-N">
        <block type="comment" id=";_6M6CXp[Ez1@~Mor)/u">
        <field name="COMMENT">Badezimmer</field>
        <block type="controls_if" id="#7.Vq+4*xn+QEI=L_sN(">
        <block type="logic_compare" id="F@O*5^DH8:NeM|T:2@O!">
        <block type="get_value" id="B2{HHbV)l`5XIM2l}/Zj">
        <field name="OID">alexa2.0.Echo-Devices.G2A0P30883260826.Player.currentState</field>
        <block type="logic_boolean" id="pm=nAdF^`:U_!f/K#rGU">
        <block type="control" id="vmS)9?#]~)7o!8mOW*+Q">
        <field name="OID">javascript.0.echo.badezimmer_status</field>
        <block type="get_value" id="jZ^:u?Z)2k#7f^1itM4m">
        <field name="OID">alexa2.0.Echo-Devices.G2A0P30883260826.Player.providerName</field>
        <block type="control" id="vM,fDXd|DgoddElII,z!">
        <block type="text" id="~;@iyS~Rb[K]/#gQwebA">
        <block type="comment" id="Rj]bvfphCDPIGyX=)hRL">
        <field name="COMMENT">Erdgeschoss</field>
        <block type="controls_if" id="vkF%+Y!)m,D6#Kf?JSzN">
        <block type="logic_compare" id="fd1|gq({-:{gLTcLgoPn">
        <block type="get_value" id="cN(^N[_d@{et%oU^AT.~">
        <field name="OID">alexa2.0.Echo-Devices.b0ccd53c13cc4ec0a03f192efd76abb1.Player.currentState</field>
        <block type="logic_boolean" id="W?I!1fvifm)WYmLgGl][">
        <block type="control" id="cjI8o9(bue=M=]adkp=v">
        <field name="OID">javascript.0.echo.erdgeschoss_status</field>
        <block type="get_value" id="[LM#=Le{ImP{;^iq5`v*">
        <field name="OID">alexa2.0.Echo-Devices.b0ccd53c13cc4ec0a03f192efd76abb1.Player.providerName</field>
        <block type="control" id="!gw{F{W5/Dz,si1c-[b*">
        <block type="text" id="d`*`:_LIK8C)y03iDBFO">
        <block type="comment" id="}C=}fnySgU2)}FpJJ0oE">
        <field name="COMMENT">Haus</field>
        <block type="controls_if" id="g-hLJ9*(SO/4DuR48r5?">
        <block type="logic_compare" id="EPe#-.p6.^E?}/v~Cm]z">
        <block type="get_value" id="W/o]R6m}`|J:4U)2SM:)">
        <field name="OID">alexa2.0.Echo-Devices.5e4f60f0dd7a414f9972e59f4fa85bf4.Player.currentState</field>
        <block type="logic_boolean" id="KX#KI.-n.DT|u(Wf(rf4">
        <block type="control" id="(4bnk4=h|nik,)okp894">
        <field name="OID">javascript.0.echo.haus_status</field>
        <block type="get_value" id="`3iLsM^bqCJCFvY@gKR)">
        <field name="OID">alexa2.0.Echo-Devices.5e4f60f0dd7a414f9972e59f4fa85bf4.Player.providerName</field>
        <block type="control" id="|*^UqMwLIo~)P)D,QwPS">
        <block type="text" id="hT1,[QfGjA8-1ls}WgR=">
                                            template vis
                                            148
                                            1324
                                            505000
