    4. Shelly Adapter
    SOLVED Shelly Adapter
      Rocket85 @Stabilostick last edited by
      @Stabilostick
      Mal wieder auf dem Schlauch gestanden.
        apollon77 last edited by
        äääähm ... alos Stündlicher restart muss das erste * eine 0 sein ... ansonsten: warum denn überhaupt? Und auch der Default ist nur * * * * * sondern "leer" weil an sich kein Restart beim Shelly Adapter nötig ist
        Stuebi H 2 Replies Last reply Reply Quote 0
          @Stabilostick
          host.raspberrypi 2019-02-12 01:00:11.740 info Restart adapter system.adapter.shelly.0 because enabled
          host.raspberrypi 2019-02-12 01:00:11.739 error instance system.adapter.shelly.0 terminated with code 0 (OK)
          shelly.0 2019-02-12 01:00:11.686 info Starting shelly.0 in version 2.1.0
          shelly.0 2019-02-12 01:00:11.674 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
          shelly.0 2019-02-12 01:00:11.552 debug statesDB connected
          shelly.0 2019-02-12 01:00:11.490 debug objectDB connected
          host.raspberrypi 2019-02-12 01:00:10.328 info instance system.adapter.shelly.0 started with pid 5729
          host.raspberrypi 2019-02-12 00:59:40.303 info Restart adapter system.adapter.shelly.0 because enabled
          host.raspberrypi 2019-02-12 00:59:40.303 error instance system.adapter.shelly.0 terminated with code 0 (OK)
          shelly.0 2019-02-12 00:59:40.252 info Starting shelly.0 in version 2.1.0
          shelly.0 2019-02-12 00:59:40.242 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
          shelly.0 2019-02-12 00:59:40.124 debug statesDB connected
          shelly.0 2019-02-12 00:59:40.061 debug objectDB connected
          host.raspberrypi 2019-02-12 00:59:38.909 info instance system.adapter.shelly.0 started with pid 5707
          host.raspberrypi 2019-02-12 00:59:08.878 info Restart adapter system.adapter.shelly.0 because enabled
          host.raspberrypi 2019-02-12 00:59:08.878 error instance system.adapter.shelly.0 terminated with code 0 (OK)
          shelly.0 2019-02-12 00:59:08.815 info Starting shelly.0 in version 2.1.0
          shelly.0 2019-02-12 00:59:08.806 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
          shelly.0 2019-02-12 00:59:08.688 debug statesDB connected
          shelly.0 2019-02-12 00:59:08.623 debug objectDB connected
          host.raspberrypi 2019-02-12 00:59:07.436 info instance system.adapter.shelly.0 started with pid 5685
          host.raspberrypi 2019-02-12 00:59:04.958 info instance system.adapter.shelly.0 terminated with code 0 (OK)
          host.raspberrypi 2019-02-12 00:59:04.894 info stopInstance system.adapter.shelly.0 killing pid 4699
            Rocket85 @Rocket85 last edited by
            @Rocket85 said in Shelly Adapter:
            @Stabilostick
            Da werd ich leider nicht schlau drauß, aber irgendwas stimmt mit dem Adapter glaube ich nicht!
            • Stabilostick
              Stabilostick last edited by Stabilostick
              Drei mal gestopp worden und Du hattest ihn ein mal gestartet?
              Ist der Adapter konfigurierbar und Du hast ihn richtig konfiguriert?
              Leichtet die Ampel vor der Instanz immer grün?
                @Stabilostick
                Ich hab leider nichts gemacht, kam alles automatisch. Ich habe lediglich einmal versucht einen Shelly von fals auf true zu schalten
                  @Stabilostick said in Shelly Adapter:
                  Normal schon.
                  Hab jetzt mal komplett gelöscht und neu installiert. Bis jetzt ist er noch nicht grün
                  host.raspberrypi 2019-02-12 01:05:17.769 info Restart adapter system.adapter.shelly.0 because enabled
                  host.raspberrypi 2019-02-12 01:05:17.766 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                  host.raspberrypi 2019-02-12 01:05:16.336 info instance system.adapter.shelly.0 started with pid 6050
                  host.raspberrypi 2019-02-12 01:05:16.308 info object change system.adapter.shelly.0
                  host.raspberrypi 2019-02-12 01:04:47.951 info Restart adapter system.adapter.shelly.0 because enabled
                  host.raspberrypi 2019-02-12 01:04:47.950 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                  shelly.0 2019-02-12 01:04:47.897 info Starting shelly.0 in version 2.1.0
                  shelly.0 2019-02-12 01:04:47.887 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                  shelly.0 2019-02-12 01:04:47.771 debug statesDB connected
                  shelly.0 2019-02-12 01:04:47.700 debug objectDB connected
                  host.raspberrypi 2019-02-12 01:04:46.520 info instance system.adapter.shelly.0 started with pid 6027
                  host.raspberrypi 2019-02-12 01:04:46.492 info object change system.adapter.shelly.0
                  host.raspberrypi 2019-02-12 01:04:39.260 info Restart adapter system.adapter.shelly.0 because enabled
                  host.raspberrypi 2019-02-12 01:04:39.259 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                  shelly.0 2019-02-12 01:04:39.205 info Starting shelly.0 in version 2.1.0
                  shelly.0 2019-02-12 01:04:39.193 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                  shelly.0 2019-02-12 01:04:39.074 debug statesDB connected
                  shelly.0 2019-02-12 01:04:39.010 debug objectDB connected
                    geht leider immer in Dauerschleife so weiter!
                    host.raspberrypi 2019-02-12 01:08:13.531 info Restart adapter system.adapter.shelly.0 because enabled
                    host.raspberrypi 2019-02-12 01:08:13.531 error instance system.adapter.shelly.0 terminated with code 0 (OK)
                    shelly.0 2019-02-12 01:08:13.471 info Starting shelly.0 in version 2.1.0
                    shelly.0 2019-02-12 01:08:13.456 info starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                    shelly.0 2019-02-12 01:08:13.328 debug statesDB connected
                    shelly.0 2019-02-12 01:08:13.264 debug objectDB connected
                      Jetzt wird der Shelly Adapter leider nicht mehr grün
                      • Stabilostick
                        Kannst Du bitte das in dem folgendem Posting beschriebene ausprobieren und das Ergebnis hier posten?
                        https://forum.iobroker.net/topic/18687/shelly-adapter-funktioniert-nicht-error-log/2
                          @Stabilostick
                          Anbei das Ergebnis. Schon mal vielen DANK für deine Mühe.
                          Exception: TypeError: xmlserializer.Builder is not a constructor/TypeError: xmlserializer.Builder is not a constructor
                          • Stabilostick
                            Kannst Du bitte den Shelly-Adapter mit der zugehörigen Instanz noch einmal löschen, wieder installieren und das Log der Installation hier posten (wenn er wieder nicht grün wird)?
                              Rocket85 @Stabilostick last edited by Negalein
                              @Stabilostick
                              $ ./iobroker add shelly  --host raspberrypi
                              host.raspberrypi create instance shelly
                              host.raspberrypi object shelly.0.info.connection created
                              host.raspberrypi object shelly.0.info created
                              host.raspberrypi object system.adapter.shelly.0.outputCount created
                              host.raspberrypi object system.adapter.shelly.0.inputCount created
                              host.raspberrypi object system.adapter.shelly.0.uptime created
                              host.raspberrypi object system.adapter.shelly.0.memRss created
                              host.raspberrypi object system.adapter.shelly.0.memHeapTotal created
                              host.raspberrypi object system.adapter.shelly.0.memHeapUsed created
                              host.raspberrypi object system.adapter.shelly.0.connected created
                              host.raspberrypi object system.adapter.shelly.0.alive created
                              host.raspberrypi object system.adapter.shelly.0 created
                              process exited with code 0
                              • Stabilostick
                                Kann es sein, dass Du nur die Instanz aber nicht den Adapter gelöscht hast?
                                  @Stabilostick
                                  Eigentlich habe ich den Adapter gelöscht, allerdings habe ich eben mal den Haken bei - schließen wenn fertig - weg gemacht und da ist mir etwas aufgefallen.
                                  $ ./iobroker del shelly
                                  Delete adapter "shelly"
                                  host.raspberrypi no instances of adapter shelly found
                                  npm uninstall iobroker.shelly --silent --save --prefix "/opt/iobroker" (System call)
                                  ERROR: Error deleting adapter shelly from disk: Error: host.raspberrypi: Cannot uninstall iobroker.shelly: 243
                                  ERROR: You might have to delete it yourself!
                                  • Stabilostick
                                    Vorschlag:
                                    1. Beende iobroker mit
                                      iobroker stop
                                      ausgeführt im iobroker-Ordner.
                                    2. Lösche manuell den node_modules/iobroker.shelly-Ordner (habe ich aus dem Gedächtnis so geschrieben)
                                    Dann wieder den ioBroker starten.
                                      @Stabilostick
                                      Rückmeldung:
                                      rm: das entfernen von ´node_modules/iobroker.shelly´ ist nicht möglich. Keine Berechtigung
                                      • Stabilostick
                                        Dann mit etwas mehr Rechten. Stelle bitte den Befehl „sudo“ vor Deinen rm-Befehl
                                          @Stabilostick
                                          Hab ich schon gemacht. DANKE....Moment Shelly ist weg, ich installiere neu!
                                            Rocket85 last edited by Negalein
                                            So langsam fehlen mir die Worte. Anbei das Log der Neuinstallation. Leider immer noch auf ROT.
                                            NPM version: 6.5.0
                                            npm install iobroker.shelly --production --save --prefix "/opt/iobroker" (System call)
                                            host.raspberrypi install adapter shelly
                                            got /opt/iobroker/node_modules/iobroker.shelly/admin
                                            upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
                                            upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
                                            upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
                                            host.raspberrypi object system.adapter.shelly created
                                              host.raspberrypi	2019-02-12 16:59:51.548	error	instance system.adapter.shelly.0 terminated with code 0 (OK)
                                              host.raspberrypi	2019-02-12 16:59:50.074	info	instance system.adapter.shelly.0 started with pid 10547
                                              host.raspberrypi	2019-02-12 16:59:50.061	info	object change system.adapter.shelly.0
                                              host.raspberrypi	2019-02-12 16:59:49.979	info	Restart adapter system.adapter.shelly.0 because enabled
                                              host.raspberrypi	2019-02-12 16:59:49.979	error	instance system.adapter.shelly.0 terminated with code 0 (OK)
                                              shelly.0	2019-02-12 16:59:49.918	info	Starting shelly.0 in version 2.1.0
                                              shelly.0	2019-02-12 16:59:49.905	info	starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
                                              shelly.0	2019-02-12 16:59:49.785	debug	statesDB connected
                                              shelly.0	2019-02-12 16:59:49.714	debug	objectDB connected
                                              6423
