    4. [Vorstellung] Meine zweite Visualisierung
      Kuddel @Ceel last edited by
      @Ceel
      Für Alexa habe ich nur ein SKript, welches den aktuellen Status bestimmt:
      <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="ZTJ#4Ya@!gKB*[R;.n9K" x="-20" y="-504">
        <mutation items="10"></mutation>
        <value name="OID0">
          <shadow type="field_oid" id="8rbV~8Dmy04hS8wxbc9E">
            <field name="oid">alexa2.0.Echo-Devices.G090LF11819608MX.Player.currentState</field>
        <value name="OID1">
          <shadow type="field_oid" id="OF#L~s+~2#7~@qfAsYB3">
            <field name="oid">alexa2.0.Echo-Devices.G090LF1184250DT2.Player.currentState</field>
        <value name="OID2">
          <shadow type="field_oid" id="+RxGgYoe^IuMs%oKq0tt">
            <field name="oid">alexa2.0.Echo-Devices.G2A0P30883260826.Player.currentState</field>
        <value name="OID3">
          <shadow type="field_oid" id="^egt:EJF2}@|v*Fb:hf#">
            <field name="oid">alexa2.0.Echo-Devices.b0ccd53c13cc4ec0a03f192efd76abb1.Player.currentState</field>
        <value name="OID4">
          <shadow type="field_oid" id=":KsDi]OJNRF^U9mQg~-{">
            <field name="oid">alexa2.0.Echo-Devices.5e4f60f0dd7a414f9972e59f4fa85bf4.Player.currentState</field>
        <value name="OID5">
          <shadow type="field_oid" id="3uVs2OO9%M6pDJ7[?lYk">
            <field name="oid">alexa2.0.Echo-Devices.G090LF11819608MX.Player.providerName</field>
        <value name="OID6">
          <shadow type="field_oid" id="wvmIx[t{4d*s)!u;=9iy">
            <field name="oid">alexa2.0.Echo-Devices.G090LF1184250DT2.Player.providerName</field>
        <value name="OID7">
          <shadow type="field_oid" id="MvCt1ATyx;zA!qLBPG3m">
            <field name="oid">alexa2.0.Echo-Devices.G2A0P30883260826.Player.providerName</field>
        <value name="OID8">
          <shadow type="field_oid" id="+V{AgUL?MbLT1_XJ#yg*">
        <value name="OID9">
          <shadow type="field_oid" id="M#G/?-LA5!;iY!ZCma=]">
            <field name="oid">alexa2.0.Echo-Devices.5e4f60f0dd7a414f9972e59f4fa85bf4.Player.providerName</field>
          <block type="comment" id="4FYP`p#Do8g=ABY;@%2)">
            <field name="COMMENT">Wohnzimmer</field>
              <block type="controls_if" id="ha((-fbS7gbfR:y61GUs">
                  <block type="logic_compare" id="BEw(%b~a7AK@l,Klw{__">
                    <field name="OP">EQ</field>
                      <block type="get_value" id="~[+E!^yYZoCt=:-hB[Xg">
                        <field name="OID">alexa2.0.Echo-Devices.G090LF11819608MX.Player.currentState</field>
                      <block type="logic_boolean" id="f4SnD/ystx74h/*R|rTh">
                  <block type="control" id="bTZ%XPLm].wNpA;ntJJl">
                    <field name="OID">javascript.0.echo.wohnzimmer_status</field>
                      <block type="get_value" id="94%ts|GSV*3notwkh]4|">
                        <field name="OID">alexa2.0.Echo-Devices.G090LF11819608MX.Player.providerName</field>
                <statement name="ELSE">
                  <block type="control" id="Gw+l[YjS2-K?@Xq2sP7:">
                      <block type="text" id="X;(9KwG!6ZS{8(,QoKxp">
                        <field name="TEXT">Stopped</field>
                  <block type="comment" id="De2U]!`e=RVv!@iIy1AE">
                    <field name="COMMENT">Küche</field>
                      <block type="controls_if" id="J.(Z./0%(yW[W0c!#aLD">
                          <block type="logic_compare" id="AO]n*Ns;nKWyUnPUHlTt">
                              <block type="get_value" id=".vAl8S-]hb/]xc?fm?/W">
                                <field name="OID">alexa2.0.Echo-Devices.G090LF1184250DT2.Player.currentState</field>
                              <block type="logic_boolean" id="7a/#TTrAwYJvEz?bc{N!">
                          <block type="control" id="m1l0nsWk75ZT_`UGHxKG">
                            <field name="OID">javascript.0.echo.kueche_status</field>
                              <block type="get_value" id="D%CV7^NA7VC:4|X./M*R">
                                <field name="OID">alexa2.0.Echo-Devices.G090LF1184250DT2.Player.providerName</field>
                          <block type="control" id="dQW2~,9.wt_!kZhYyIXe">
                              <block type="text" id="Pg7%R9Lf:Au)SYo-l*-N">
                          <block type="comment" id=";_6M6CXp[Ez1@~Mor)/u">
                            <field name="COMMENT">Badezimmer</field>
                              <block type="controls_if" id="#7.Vq+4*xn+QEI=L_sN(">
                                  <block type="logic_compare" id="F@O*5^DH8:NeM|T:2@O!">
                                      <block type="get_value" id="B2{HHbV)l`5XIM2l}/Zj">
                                        <field name="OID">alexa2.0.Echo-Devices.G2A0P30883260826.Player.currentState</field>
                                      <block type="logic_boolean" id="pm=nAdF^`:U_!f/K#rGU">
                                  <block type="control" id="vmS)9?#]~)7o!8mOW*+Q">
                                    <field name="OID">javascript.0.echo.badezimmer_status</field>
                                      <block type="get_value" id="jZ^:u?Z)2k#7f^1itM4m">
                                        <field name="OID">alexa2.0.Echo-Devices.G2A0P30883260826.Player.providerName</field>
                                  <block type="control" id="vM,fDXd|DgoddElII,z!">
                                      <block type="text" id="~;@iyS~Rb[K]/#gQwebA">
                                  <block type="comment" id="Rj]bvfphCDPIGyX=)hRL">
                                    <field name="COMMENT">Erdgeschoss</field>
                                      <block type="controls_if" id="vkF%+Y!)m,D6#Kf?JSzN">
                                          <block type="logic_compare" id="fd1|gq({-:{gLTcLgoPn">
                                              <block type="get_value" id="cN(^N[_d@{et%oU^AT.~">
                                                <field name="OID">alexa2.0.Echo-Devices.b0ccd53c13cc4ec0a03f192efd76abb1.Player.currentState</field>
                                              <block type="logic_boolean" id="W?I!1fvifm)WYmLgGl][">
                                          <block type="control" id="cjI8o9(bue=M=]adkp=v">
                                            <field name="OID">javascript.0.echo.erdgeschoss_status</field>
                                              <block type="get_value" id="[LM#=Le{ImP{;^iq5`v*">
                                                <field name="OID">alexa2.0.Echo-Devices.b0ccd53c13cc4ec0a03f192efd76abb1.Player.providerName</field>
                                          <block type="control" id="!gw{F{W5/Dz,si1c-[b*">
                                              <block type="text" id="d`*`:_LIK8C)y03iDBFO">
                                          <block type="comment" id="}C=}fnySgU2)}FpJJ0oE">
                                            <field name="COMMENT">Haus</field>
                                              <block type="controls_if" id="g-hLJ9*(SO/4DuR48r5?">
                                                  <block type="logic_compare" id="EPe#-.p6.^E?}/v~Cm]z">
                                                      <block type="get_value" id="W/o]R6m}`|J:4U)2SM:)">
                                                        <field name="OID">alexa2.0.Echo-Devices.5e4f60f0dd7a414f9972e59f4fa85bf4.Player.currentState</field>
                                                      <block type="logic_boolean" id="KX#KI.-n.DT|u(Wf(rf4">
                                                  <block type="control" id="(4bnk4=h|nik,)okp894">
                                                    <field name="OID">javascript.0.echo.haus_status</field>
                                                      <block type="get_value" id="`3iLsM^bqCJCFvY@gKR)">
                                                        <field name="OID">alexa2.0.Echo-Devices.5e4f60f0dd7a414f9972e59f4fa85bf4.Player.providerName</field>
                                                  <block type="control" id="|*^UqMwLIo~)P)D,QwPS">
                                                      <block type="text" id="hT1,[QfGjA8-1ls}WgR=">
        Kuddel @Saschag last edited by
        @Saschag
        In der Debian VM läuft ein Shell-Skript, welches ich per Crontab laufen lasse.
        Versionen abfragen:
        #ioBroker Version
        iobroker=$(iobroker version)
        iobroker state set javascript.0.Versionen.JS-Controller $iobroker
        #Node Version
        node=$(node -v)
        iobroker state set javascript.0.Versionen.Node $node
        #NPM Version
        npm=$(npm -v)
        iobroker state set javascript.0.Versionen.NPM $npm
        Crontab Eintrag
        #Abfrage der Versionen von ioBroker, Node und NPM
        * * * * * sudo /opt/iobroker/skripts/iobroker_versionen.sh
        S Glasfaser 2 Replies Last reply Reply Quote 0
          liv-in-sky @dtp last edited by
          @dtp said in [Vorstellung] Meine zweite Visualisierung:
          Schön gemacht. Mir persönlich wären aber viele Seiten zu überladen. Ich mag lieber weniger Informationen, die ich mit einem Blick aus gewisser Entfernung überschauen kann. Zudem benutze ich meine Visualisierung eher nicht zum Steuern. Das mache ich lieber per Siri oder über die Automatismen.
          das wollte ich ursprünglich auch so machen (nur zur visualisierung) - das änderte sich, als alexa mal für eine weile weg war ! mittlerweile kann meine vis auch viel mehr steuern - sieht leider nicht so toll aus wie hier gezeigt
          tolles vis und danke fürs vorstellen
            Gerni @Kuddel last edited by
            @Kuddel Wozu hast Du denn ein Skript zur Müllabfuhr? Wie sieht das aus und was macht es?
              Kuddel @Gerni last edited by
              @Gerni
              Das Skript rechnet aus, in wie vielen Tagen z.b. der Hausmüll abgeholt wird.
              Ist ein reines Javascript, dass ich hier aus dem Forum habe.
              Die Resttage bis zur Abholung werden auf meiner Startseite dargestellt
                Jukabroker last edited by
                ich habe mir das mit den Radio-Icons auch nachgebaut. Danke für die Vorstellung . Muss sagen es funktioniert einwandfrei.
                Die Icon-Bilder der Sender bietet die "imageURL" ja schon an. Diese URL habe ich kopiert und bei Bild [0] und bei Bild [1] eingesetzt. Somit spart man sich das downloaden der Icons.
                Ansonsten tolle Anleitung.
                Gruß Jukabroker
                @mehrwiedu said in [Vorstellung] Meine zweite Visualisierung:
                In VIS kann man dann auf die Button drücken und der Echo startet oder wechselt den Radiosender nach Wunsch.
                Muss natürlich für jeden Echo separat gemacht werden.
                  Find ich bisher auch super, zumindest am Smartphone. Auch wenn es nicht dafür optimiert ist.
                  Mein Tablet hingegen geht allein schon beim Laden in die Knie...
                    Mallet last edited by
                    Hi Knuddel,
                    erst mal großes Lob von meiner Seite, ich finde deine VIS absolut gelungen, hast du wirklich gut gemacht... Toll. Eine Frage hätte ich, du hast einiges an Scripten laufen... Sei es Müll, oder Spritpreise, wäre es zu viel verlangt wenn du kurz auflisten könntest welche Scripts du am laufen hast? Das wäre richtig cool von dir.
                    Danke für deine Müehe und das zur Verfügung stellen deiner Arbeit.
                      Kuddel @Mallet last edited by
                      @Mallet
                      Mittlerwiele habe ich für alles mögliche Skripte am laufen (an der Zahl 56).
                      Die aufzulisten ist nicht mal eben schnell gemacht.
                      Wenn du spezielle Fragen zu Skripten hast, die evtl. für meine VIS wichtig sein könnte, schieß los.
                        Saschag @Kuddel last edited by
                        @Kuddel
                        Vielen Dank!!
                        • haschel
                          haschel last edited by haschel
                          Servus Kuddel,
                          wirklich super Visualisierung die du da gebastelt hast, hilft mir bei der wenigen Zeit die ich habe wirklich sehr weiter. Bin schon gut am basteln. Falls ich Scripte-Mangel haben sollte, werde ich bestimmt noch auf dich zurückkommen. Aber wirklich gute Arbeit.
                          Mir ist direkt noch was aufgefallen. Wahrscheinlich total easy, nur hab ich wohl ein Brett vorm Kopp.
                          Die Uptime Scripte für die verschiedenen Geräte - wie hast du die realisiert?
                          Beste Grüße.
                            Dirni last edited by
                            Hallo
                            Könntest mir noch sagen warum das Fenster in deinen Screenshots angezeigt wird ? Sind alle Gruppen in einem eigenen Fenster ?
                            Wie heist dieses Widget wenn es eines ist ?
                              Kuddel @Dirni last edited by
                              @Dirni
                              Auf Grund von Platzmangel in der Spalte "Wohnzimmer" habe ich für die Steckdose nur ein Widget was das extra Fenster öffnet.
                              Die Steckdosen selber sind auf der Seite "2411_EG_Steckdosen_Wohnzimmer".
                              Genau so habe ich es für die Rolladen im Wohnzimmer auch gemacht.
                                Kuddel @haschel last edited by
                                @haschel
                                Ja das ist ein bisschen komplexer.
                                Uptime ioBroker = Uptime im RPI Adapter. Wird dann von Sekunden entsprechend umgewandelt
                                Uptime CCU = Wird per Skript auf der CCU ausgelesen und auf der CCU in eine Variable geschieben
                                Uptime ESX-NUC = Auf meiner WIn10 VM läuft ein Powershell Skript, was doe Uptime per PowerCLI ausgelesen und an den ioBroker übergeibt
                                Uptime Win10 = Wird ebenfalls per Skitpt auf der VM ausgelesen und übergeben (per API)
                                Uptime Unifi = Wird per Shell Skript auf der ioBroker VM per SSH ausgelesen und formatiert
                                Uptime Sophos = Wird per Shell Skript auf der ioBroker VM per SSH ausgelesen und formatiert
                                Uptime QNAP-B = Auswetung der SNMP Adapter
                                Wenn du ein bestimmtes Skript brauchst, gib Bescheid, dann poste ich das eben
                                haschel 1 Reply Last reply Reply Quote 0
                                  gfrene last edited by
                                  @Kuddel könntest du die Scripte zur Verfügung stellen wie du die Zonenreinigung umgesetzt hast 🙂
                                  Danke dir und 1a VIS
                                    Kuddel @gfrene last edited by
                                    @gfrene
                                    Skript für die Zonenreinung:
                                    <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="A3mcx,(O{KZ0SAwINJkl" x="-362.00000000000057" y="10037.5">
                                      <value name="OID0">
                                        <shadow type="field_oid" id="=^9T:bBq#a4Q,Nh;+#c=">
                                          <field name="oid">javascript.0.NoNo.Zonen_Reinigung</field>
                                        <block type="variables_set" id="?Vkt^R1:a?ZRu{JyI(Vh">
                                          <field name="VAR">Buero</field>
                                            <block type="text" id="a=(?PpOyB5iGBLjQ6Aap">
                                              <field name="TEXT">app_zoned_clean;[[18471,19907,22571,23007,1]]</field>
                                            <block type="variables_set" id="sYCBkY(T4jb-]X+2Eak,">
                                              <field name="VAR">Flur</field>
                                                <block type="text" id="%-KCb~RlSSjV6q_]/?j*">
                                                  <field name="TEXT">app_zoned_clean;[[22637,19580,29787,25130,2]]</field>
                                                <block type="variables_set" id=";M*u(QADG3GbZdCgq8GG">
                                                  <field name="VAR">GaesteWC</field>
                                                    <block type="text" id="lS%?^.}[p`XS/bXa8f#g">
                                                      <field name="TEXT">app_zoned_clean;[[28009,25008,29709,26458,2]]</field>
                                                    <block type="variables_set" id="H#[grBDiKs9O6?Cx9J4#">
                                                      <field name="VAR">Kueche</field>
                                                        <block type="text" id="qSyl{KE}K,}iq}DCvI!1">
                                                          <field name="TEXT">app_zoned_clean;[[26727,25000,29777,29250,2]]</field>
                                                        <block type="variables_set" id="q[mk=w]QG/B:uT%rh)%7">
                                                          <field name="VAR">Wohnzimmer</field>
                                                            <block type="text" id="Qd0=lq+^}-*HGJNu^hHE">
                                                              <field name="TEXT">app_zoned_clean;[[18626,25160,25976,29110,2],[18569,23306,22519,25106,2]]</field>
                                                            <block type="controls_if" id="lH-2B:yzLcZ]@Mk~(nc]">
        <block type="logic_compare" id="Bp2=TLQfL3|kHV=a:vvq">
        <block type="get_value" id="Hmzyi5vAP`/`|r8fEf=T">
        <field name="OID">javascript.0.NoNo.Zonen_Reinigung</field>
        <block type="math_number" id="=ef#+88ApoWQv2F(soI)">
        <field name="NUM">1</field>
        <block type="control" id="rvU:D+8+T0=}aFHB4Y_,">
        <field name="OID">mihome-vacuum.0.control.X_send_command</field>
        <block type="variables_get" id="OrN{Ji``zx:c+,GIQ%V~">
        <block type="controls_if" id="p@4RtG#w?*ZfeQh-DhW=">
        <block type="logic_compare" id="]ML3dK+K%Ss*PP1C6}.I">
        <block type="get_value" id="A[L@C_egi[F/oVMQW^_/">
        <block type="math_number" id=":t3k=z={gtWBjX9%+oDY">
        <field name="NUM">2</field>
        <block type="control" id="Fj!_{m.PvLy[ZCTt69Ai">
        <block type="variables_get" id="cs^jf5ppROjO7t=DIc:W">
        <block type="controls_if" id="522b~?+NAKvD,dErnt,l">
        <block type="logic_compare" id="b3T-%fupbfET7[^%D{gz">
        <block type="get_value" id="DciAT#,TJm)AFKPl,ZKU">
        <block type="math_number" id="Mtrun}#MK=5#js?MQLDP">
        <field name="NUM">3</field>
        <block type="control" id="hP#DYCrpD6@t+ZCj4K}t">
        <block type="variables_get" id="d6tpE4/.-l@yw(k6Op:h">
        <block type="controls_if" id="wSNWFV(=oe3*Wq;f*@BI">
        <block type="logic_compare" id="Amc2r/~*m=c94}A/ex2x">
        <block type="get_value" id="^2CFEG{SfmYy#-cI{L{a">
        <block type="math_number" id="@{Af3%,R_U}B/_]Qnf!j">
        <field name="NUM">4</field>
        <block type="control" id="2OX9HjBTIzS|;/.x7Evs">
        <block type="variables_get" id="!aKr!M;)d[~lIFQEW:Rv">
        <block type="controls_if" id="sFsn,FsK/.lHM#d!zPu{">
        <block type="logic_compare" id="sV!{?%?M[3~@{WX[desv">
        <block type="get_value" id="jUehj--)Ra/*Fa_!-kBh">
        <block type="math_number" id="KC(quv,.gF*^p+@UY[f/">
        <field name="NUM">5</field>
        <block type="control" id="YO.z!X!:4Bz}]iBb(jhf">
        <block type="variables_get" id="hhG2Xi:Ge;lTOZ`k]ta-">
                                    Ausgelöst wird das ganze durch den entsprechenden Wert im Datenpunkt javascript.0.NoNo.Zonen_Reiningung
                                    0 = Aus
                                    1 = Raum 1
                                    2 = Raum 2
                                    ect.
                                    G 2 Replies Last reply Reply Quote 1
                                      Mallet @Kuddel last edited by
                                      @Kuddel Hi Knuddel,
                                      das es nicht blos ein oder 2 sind dachte ich mir schon... 🙂 habe akutell keine direkte frage... aber wenn schreib ich... Danke 🙂 Wirklich toll die VIS
                                      • haschel
                                        haschel @Kuddel last edited by
                                        @Kuddel hört sich sehr gut an. bin gerade am fummeln, wie ich mir die Uptime per Script speicher. Das auslesen ist soweit kein Problem. Würde mich freuen wenn du mir die für das Windws-System und für Unifi geben könntest.
                                        Also, Interesse hätte ich an:
                                        Win 10 Uptime
                                        Unifi Uptime
                                        Festplattenspeicher NAS
                                        WOL (Win Server)
                                        Vielen Dank an dich - wirklich super Arbeit - das Verständnis wird meinerseits immer besser. 🙂
                                          gfrene @Kuddel last edited by
                                          @Kuddel Dickes danke 🙂 wegen dem javascript.0.NoNo.Zonen_Reiningung steht in diesen Datenpukt was ? ist das noch ein JAVA-Srcipt ? Gruß und danke für deine Hilfe.
                                            @haschel
                                            Uptime WIndows 10 (Powershell):
                                            windows_10_uptime_umwandeln.txt windows_10_uptime_abfrage.txt
                                            Uptime Unifi-Controller (Shell):
                                            Voraussetzung: auf dem ioBroker einen SSH Key erstellen und auf den Unifi-Controller kopieren, sonst funktioniert die Abfrage nicht ohne PW
                                            unifi_uptime_umwandelntxt.txt unifi_uptime_abfrage.txt
                                            Festplattensepicher WinNAS (Powershell):
                                            WinNAS_Festplattenauslastung.txt
                                            WOL WinNAS (JavaScript):
                                            WinNAS_WOL.txt
                                            template vis
                                            148
                                            1324
                                            504716
