    4. ioBroker.js-controller 1.5.6
      e-i-k-e last edited by
      Auf einen ioBroker Slave mit 1.5.5 habe ich den Javascript Adapter nicht auf grün bekommen.
      Nach einem downgrade auf 1.4.2 wurde dieser sofort weider grün.
      Bluefox 1 Reply Last reply Reply Quote 0
        Marty56 last edited by
        Hab es mal versucht, sieht nicht so gut aus.
        root@ioBroker-OPi2E:~# iobroker stop
        Stopping iobroker controller daemon...
        iobroker controller daemon stopped.
        Exit code for "killall.sh": 0
        root@ioBroker-OPi2E:~# cd ..
        root@ioBroker-OPi2E:/# cd opt
        root@ioBroker-OPi2E:/opt# cd iobroker
        root@ioBroker-OPi2E:/opt/iobroker# npm i iobroker.js-controller@1.5.5
        npm WARN lifecycle iobroker.js-controller@1.5.5~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@1.5.5 node lib/preinstallCheck.js /opt/iobroker/node_modules/.staging/iobroker.js-controller-a76002ca
        > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/authenticate-pam/build'
          CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
        ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: No such file or directory
        compilation terminated.
        authenticate_pam.target.mk:92: recipe for target 'Release/obj.target/authenticate_pam/authenticate_pam.o' failed
        make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
        make: Leaving directory '/opt/iobroker/node_modules/authenticate-pam/build'
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
        gyp ERR! stack     at emitTwo (events.js:106:13)
        gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
        gyp ERR! System Linux 4.14.70-sunxi
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
        gyp ERR! node -v v6.14.4
        gyp ERR! node-gyp -v v3.4.0
        gyp ERR! not ok
        > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
        > node rebuild.js
        > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
          CXX(target) Release/obj.target/diskusage/src/main.o
          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          SOLINK_MODULE(target) Release/obj.target/diskusage.node
          COPY Release/diskusage.node
        make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
        > iobroker.js-controller@1.5.5 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        > rsa-compat@1.9.2 postinstall /opt/iobroker/node_modules/acme-v2/node_modules/rsa-compat
        > node lib/telemetry.js event:install
        > rsa-compat@1.9.2 postinstall /opt/iobroker/node_modules/greenlock/node_modules/rsa-compat
        - asn1js@1.2.12 node_modules/asn1js
        - buffer-v6-polyfill@1.0.5 node_modules/buffer-v6-polyfill
        - node.extend@1.1.6 node_modules/certpem/node_modules/node.extend
        cliui@4.1.0 node_modules/iobroker.js-controller/node_modules/cliui -> node_modules/cliui
        - node.extend@1.1.6 node_modules/greenlock/node_modules/node.extend
        - arraybuffer.slice@0.0.7 node_modules/iobroker.js-controller/node_modules/arraybuffer.slice
        - camelcase@4.1.0 node_modules/iobroker.js-controller/node_modules/camelcase
        - component-emitter@1.2.1 node_modules/iobroker.js-controller/node_modules/component-emitter
        - debug@3.1.0 node_modules/iobroker.js-controller/node_modules/debug
        - engine.io-parser@2.1.2 node_modules/iobroker.js-controller/node_modules/engine.io-parser
        - isarray@2.0.1 node_modules/iobroker.js-controller/node_modules/isarray
        - socket.io-adapter@1.1.1 node_modules/iobroker.js-controller/node_modules/socket.io-adapter
        - socket.io-parser@3.2.0 node_modules/iobroker.js-controller/node_modules/socket.io-parser
        - ultron@1.1.1 node_modules/iobroker.js-controller/node_modules/ultron
        - ws@3.3.3 node_modules/iobroker.js-controller/node_modules/ws
        - engine.io@3.2.0 node_modules/iobroker.js-controller/node_modules/engine.io
        - xmlhttprequest-ssl@1.5.5 node_modules/iobroker.js-controller/node_modules/xmlhttprequest-ssl
        - engine.io-client@3.2.1 node_modules/iobroker.js-controller/node_modules/engine.io-client
        - socket.io-client@2.1.1 node_modules/iobroker.js-controller/node_modules/socket.io-client
        - socket.io@2.1.1 node_modules/iobroker.js-controller/node_modules/socket.io
        - yargs-parser@9.0.2 node_modules/iobroker.js-controller/node_modules/yargs/node_modules/yargs-parser
        - pkijs@1.3.33 node_modules/pkijs
        - certpem@1.0.1 node_modules/certpem
        - glob@7.1.2 node_modules/rimraf/node_modules/glob
        - bindings@1.1.1 node_modules/unix-dgram/node_modules/bindings
        - yargs-parser@4.2.1 node_modules/iobroker.js-controller/node_modules/yargs-parser
        yargs@11.1.0 node_modules/iobroker.js-controller/node_modules/yargs -> node_modules/yargs
        iobroker@1.0.0 /opt/iobroker
        └─┬ iobroker.js-controller@1.5.5
          ├─┬ diskusage@0.2.6
          │ └── nan@2.12.1
          ├─┬ greenlock@2.6.7
          │ ├── acme@1.2.0
          │ ├─┬ acme-v2@1.5.2
          │ │ └─┬ rsa-compat@1.9.2
          │ │   └── node-forge@0.7.6
          │ ├── cert-info@1.5.0
          │ ├── le-store-certbot@2.2.1
          │   ├── node-forge@0.7.6
          │   └─┬ ursa-optional@0.9.10
          │     ├─┬ bindings@1.4.0
          │     │ └── file-uri-to-path@1.0.0
          │     └── nan@2.12.1
          ├─┬ jsonwebtoken@8.4.0
          │ └─┬ jws@3.2.1
          │   └── jwa@1.2.0
          ├─┬ jszip@3.1.5
          │ └── pako@1.0.8
          ├── le-acme-core@2.1.4
          ├── le-sni-auto@2.1.6
          ├─┬ loadavg-windows@1.0.2
          │ └── weak-daemon@1.0.3
          ├─┬ node-schedule@1.3.1
          │ └─┬ cron-parser@2.7.3
          │   └── moment-timezone@0.5.23
          ├─┬ node.extend@2.0.2
          │ ├── has@1.0.3
          │ └── is@3.3.0
          ├─┬ pidusage@2.0.17
          │ └── safe-buffer@5.1.2
          ├─┬ prompt@1.0.0
          │ └─┬ utile@0.3.0
          │   └─┬ rimraf@2.6.3
          │     └── glob@7.1.3
          ├── pyconf@1.1.6
          ├─┬ redis@2.8.0
          │ └── redis-commands@1.4.0
          ├── safe-replace@1.1.0
          ├─┬ tar@4.4.8
          │ ├── chownr@1.1.1
          │ ├── minipass@2.3.5
          │ ├── minizlib@1.2.1
          │ └── yallist@3.0.3
          └── winston@2.4.4
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mymodule/package.json'
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        Bluefox apollon77 2 Replies Last reply Reply Quote 0
          Zu meinem Erstaunen konnte ich iobroker starten und das UI und auch VIS scheint zu funktionieren.
          • Bluefox
            Bluefox @Marty56 last edited by
            @Marty56 said in ioBroker.js-controller 1.5.4:
            > node-gyp rebuild
            gyp ERR! not ok
            > node rebuild.js
            > node-gyp rebuild
              ├─┬ diskusage@0.2.6
              │ └── nan@2.12.1
              ├─┬ greenlock@2.6.7
              │ ├── acme@1.2.0
              │ ├─┬ acme-v2@1.5.2
              │     └── nan@2.12.1
              │ └─┬ jws@3.2.1
              │   └── jwa@1.2.0
              ├─┬ jszip@3.1.5
              │ └── pako@1.0.8
              │ ├── has@1.0.3
              │ └── is@3.3.0
              ├─┬ pidusage@2.0.17
              ├─┬ prompt@1.0.0
              │ └─┬ utile@0.3.0
              │   └─┬ rimraf@2.6.3
              │     └── glob@7.1.3
              ├── pyconf@1.1.6
              ├─┬ redis@2.8.0
              ├─┬ tar@4.4.8
              │ ├── chownr@1.1.1
              │ └── yallist@3.0.3
              └── winston@2.4.4
            Es sind nur Warnungen.
            • Bluefox
              Bluefox @e-i-k-e last edited by
              @e-i-k-e said in ioBroker.js-controller 1.5.4:
              Ich brauche logs, so kann ich nicht mal vermuten, was nicht ging
                Marty56 last edited by Marty56
                Es scheint alles zu laufen.
                Scheinbar habe ich noch irgendwo einen undefinierten State, der vorher aber nicht bemerkt wurde.
                Jetzt bekomme ich eine minütliche Fehlermeldung
                javascript.0	2019-02-13 07:48:00.596	error	Error in callback: TypeError: Cannot read property 'common' of undefined
                Ich habe schon alle Scripts durchgesucht, ob ich irgendwo einen Minuten Timer habe. Aber ich habe leider nach 30 Minuten Suche nichts gefunden.
                  Ich konnte es jetzt einkreisen.
                  javascript.0	2019-02-13 07:56:00.209	error	Error in callback: TypeError: Cannot read property 'common' of undefined
                  javascript.0	2019-02-13 07:55:38.422	error	Error in callback: TypeError: Cannot read property 'common' of undefined
                  javascript.0	2019-02-13 07:55:38.248	error	TypeError: Cannot read property 'common' of undefined
                  javascript.0	2019-02-13 07:55:38.248	error	^
                  javascript.0	2019-02-13 07:55:38.247	error	if (!language || !dayOfWeeksFull[language]) language = objects['system.config'].common.language;
                  javascript.0	2019-02-13 07:55:38.247	error	script.js.common.Tagescharacteristik: /opt/iobroker/node_modules/iobroker.javascript/javascript.js:2712
                  Es ist das Kommando formatDate(new Date(), "W hh:mm").
                  Liegt nicht an meinen Scripts sondern wohl an der neuen js-controller Version
                  Was funktioniert ist: formatDate(new Date(), "hh:mm")
                  update:
                  • WW, НН(cyrillic) - full week day as text
                  • W, Н(cyrillic) - short week day as text
                  funktionieren alle nicht mehr
                  Bluefox 2 Replies Last reply Reply Quote 1
                  • Bluefox
                    @Marty56 was für JS Version hast du?
                      Marty56 @Bluefox last edited by Marty56
                      @Bluefox javascript 3.6.4
                      Ich habe alles sonst auf default als repro.
                      Also die Versionen, die unter http://download.iobroker.net/sources-dist.json liegen
                        apollon77 @Marty56 last edited by
                        @Marty56 Hier wäre (rechtebedingt) noch ein --unsafe-perm anzuhängen, aber das preinstall script ist bei nem update nicht so nötig, also alles ok ie BF schon gesagt hat
                        • Bluefox
                          @Marty56 said in ioBroker.js-controller 1.5.4/1.5.5:
                          Ich kann diesen Fehler nicht erklären. Reproduzieren kann ich auch nicht, aber ich habe js-controller@1.5.6 und javascript@3.6.5 gemacht.
                          Kannst du ausprobieren? Erst javascript updaten und dann js-controller.
                          cd /optOderHomeVerzeichnis/iobroker
                          iobroker stop
                          npm i iobroker.javascript@3.6.5 --production
                          npm i iobroker.js-controller@1.5.6 --production
                          iobroker u javascript
                          iobroker start
                          M sigi234 2 Replies Last reply Reply Quote 0
                          • simatec
                            Bei einer Iobroker Installation mit neuen Installer ist auf die korrekte Rechtevergabe zu achten.
                            Der Befehl
                            kann nicht einfach als anderer User ausgeführt werden, da sonst der User iobroker nicht alle Recht hat.
                            R apollon77 2 Replies Last reply Reply Quote 0
                              js-controller 1.5.5 läuft hier einwandfrei.
                              iobroker.admin - aktuell aus git
                              iobroker.web - aktuell aus git
                              iobroker.iot - aktuell aus git
                              iobroker.javascript - aktuell aus git
                              Node 8.15, NPM 6.7, Linux mint 18.3. in ner VM unter proxmox.
                              ( Hauptsystem, 170 Netzwerkdevices und 88 MiHome - es wird genug traffic erzeugt.. ;-))
                              Auf den Raspi's mit gleichen Versionen unter ARM auch keine Probleme.
                              js-controller 1.5.5 wirkt im admin schneller. ( er aktualisiert die Seite sehr schnell )
                              Testsystem frisch aufgesetzt und auf latest gestellt, auch Node 8.15, NPM6.7, Linux Mint 19.1, keine Fehler.
                              ( hier sind nur ein paar Skripts am laufen)
                              Ansonsten klasse, weiter so! Das neue Forum ist auch viel besser.
                              Frage: auf 1.5.6 kann ich nicht updaten, npm findet die Version nicht?
                              npm ERR! notarget No matching version found for iobroker.js-controller@1.5.6
                              npm ERR! notarget In most cases you or one of your dependencies are requesting
                              npm ERR! notarget a package version that doesn't exist.
                              • frankjoke
                                frankjoke last edited by
                                @Bluefox sagte in ioBroker.js-controller 1.5.6:
                                Hab's versucht aber
                                npm ERR! code ETARGET
                                npm ERR!     /home/iobroker/.npm/_logs/2019-02-13T15_37_04_235Z-debug.log
                                erhalten!
                                p.s.: ich mach solche Sachen unter der neuen iobroker-Installation immer mit vorher:
                                sudo -u iobroker sh
                                  @Bluefox damit geht es wieder.
                                  • Bluefox
                                    Ich habe jetzt 1.5.6 auf npm gepuscht (war noch nicht und ich habe nicht bemerkt)
                                    M ? 2 Replies Last reply Reply Quote 1
                                      @Bluefox
                                      mit js-controller 1.5.5 und javscript 3.65 kein Problem
                                      Bluefox 1 Reply Last reply Reply Quote 1
                                      • Bluefox
                                        @Marty56 Und dein Script zeigt auch Wochentag richtig?
                                          @Bluefox
                                          log(formatDate(new Date(), "W hh:mm"));
                                          Mi 17:16
                                          sieht gut aus.
                                            A Former User @Bluefox last edited by
                                            @Bluefox Danke, funktioniert !
                                            call for action test
                                            31
                                            150
                                            19841
