    4. ioBroker.js-controller 1.5.6
      A Former User @Bluefox last edited by
      @Bluefox Danke, funktioniert !
      • Matzebhv
        Matzebhv last edited by
        Moin,
        hier fliegt der iobroker mit der Version alle 30sec. auseinander. Habe die 1.5.5 probiert und auch die 1.5.6.
        admin.0	2019-02-13 18:19:16.539	info	terminating http server on port 8081
        cloud.0	2019-02-13 18:19:10.594	info	Connection changed: connect
        cloud.0	2019-02-13 18:19:10.437	info	Trying to connect as system.user.admin
        host.raspberry	2019-02-13 18:19:05.979	info	instance system.adapter.upnp.0 terminated with code 0 (OK)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.emit (events.js:214:7)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at emitTwo (events.js:126:13)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
        host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: RangeError: Maximum call stack size exceeded
        host.raspberry	2019-02-13 18:19:05.660	info	iobroker exit 0
        host.raspberry	2019-02-13 18:19:05.659	info	iobroker Starting node restart.js
        host.raspberry	2019-02-13 18:19:05.539	info	iobroker _restart
        host.raspberry	2019-02-13 18:19:05.539	error	RangeError: Maximum call stack size exceeded at Buffer.write (buffer.js:855:34) at fromString (buffer.js:319:20) at Function.Buffer.from (buffer.js:177:12) at new Buffer (buffer.js:158
        host.raspberry	2019-02-13 18:19:05.538	error	uncaught exception: Maximum call stack size exceeded
        iot.0	2019-02-13 18:19:04.819	info	Connection changed: connect
        Matze
        Bluefox 1 Reply Last reply Reply Quote 0
        • Bluefox
          Bluefox @Matzebhv last edited by Bluefox
          @Matzebhv Was sagt npm ls socket.io ?
          • Matzebhv
            @Bluefox : ich bin schon wieder auf 1.4.2 zurück. Kannst du dann damit noch was anfangen?
            Und noch als Hinweis, Usern mit neuerer Version ( neuer Installer ) haut es beim Update die Berechtigungen auseinander. Da hast du dann Ordner mit Besitzer "root" dazwischen.
            Matze
              RappiRN Most Active @simatec last edited by
              @simatec sagte in ioBroker.js-controller 1.5.6:
              Bei einer Iobroker Installation mit neuen Installer ist auf die korrekte Rechtevergabe zu achten.
              Der Befehl
              npm i iobroker.js-controller@1.5.6
              kann nicht einfach als anderer User ausgeführt werden, da sonst der User iobroker nicht alle Recht hat.
              Hier steht schon ein Hinweis darauf, das sollte natürlich auch im ioBroker-Admin angezeigt werden, als deutlichen Hinweis darauf, dass es zwei unterschiedliche Installationsvarianten gibt. Nicht dass es da noch große Diskussionen gibt!
              Enrico
                mirK last edited by
                wie kommt man wieder zurück auf die 1.4.6 ?
                Vis funktioniert nicht - bekomme nur eine weiße seite nach dem laden angzeigt.
                Homer.J. 1 Reply Last reply Reply Quote 0
                • Homer.J.
                  Homer.J. last edited by eric2905
                  Hallo Bluefox,
                  nach Update auf 1.5.6 funktioniert der Das Wetter Adapter nicht mehr steht dann das im Log.
                  2019-02-13 16:45:15.828  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                  zurück auf 1.4.2 und es geht wieder alles.
                  Edit by eric2905, Logs & Co. bitte immer in Code-Tags setzen
                  Bluefox P 2 Replies Last reply Reply Quote 0
                  • Homer.J.
                    Homer.J. @mirK last edited by
                    @mirK
                    cd /opt/iobroker
                    iobroker stop
                    npm i iobroker.js-controller@1.4.2 --production
                    iobroker start
                    • Bluefox
                      Участник @Matzebhv написал в ioBroker.js-controller 1.5.6:
                      Natürlich..... nicht
                        sigi234 Forum Testing Most Active @Bluefox last edited by sigi234
                        @Bluefox sagte in ioBroker.js-controller 1.5.6:
                        javascript@3.6.5 --production
                        npm i iobroker.js-controller@1.5.6 --production
                        Installiert, derzeit keine Probleme..............
                        Platform: Windows
                        Architecture: x64
                        CPUs: 4
                        Speed: 3912 MHz
                        Model: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
                        RAM: 7.9 GB
                        System uptime: 23:07:29
                        Node.js: v8.15.0
                        NPM: 6.4.1
                        Disk size: 232.3 GiB
                        Disk free: 172.9 GiB
                        adapters count: 253
                        Uptime: 00:19:54
                        Active instances: 39
                        • Bluefox
                          Bluefox @Homer.J. last edited by
                          @Homer1976 Eigentlich DasWetter läuft alle 15 Minuten und stoppt sich.
                          Code 11 ist genau das.
                            Bei mit kommt jetzt auch ein Fehler:
                            daswetter.0	2019-02-13 20:30:02.224	error	at WS.Transport.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\transport.js:145:8)
                            daswetter.0	2019-02-13 20:30:02.224	error	at WS.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                            daswetter.0	2019-02-13 20:30:02.224	error	at WS.<anonymous> (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:268:10)
                            daswetter.0	2019-02-13 20:30:02.224	error	at Socket.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:451:14)
                            daswetter.0	2019-02-13 20:30:02.224	error	at Socket.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                            daswetter.0	2019-02-13 20:30:02.224	error	at Socket.<anonymous> (C:\ioBroker\node_modules\component-bind\index.js:21:15)
                            daswetter.0	2019-02-13 20:30:02.224	error	at Manager.ondata (C:\ioBroker\node_modules\socket.io-client\lib\manager.js:322:16)
                            daswetter.0	2019-02-13 20:30:02.224	error	at Decoder.add (C:\ioBroker\node_modules\socket.io-parser\index.js:237:14)
                            daswetter.0	2019-02-13 20:30:02.224	error	at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
                            daswetter.0	2019-02-13 20:30:02.224	error	at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12)
                            daswetter.0	2019-02-13 20:30:02.224	error	RangeError: Maximum call stack size exceeded
                            daswetter.0	2019-02-13 20:30:02.224	error	uncaught exception: Maximum call stack size exceeded
                            Bluefox 2 Replies Last reply Reply Quote 0
                            • Bluefox
                              Bluefox @sigi234 last edited by
                              @sigi234 npm ls socket.io ?
                                +-- iobroker.admin@3.6.0
                                | `-- socket.io@1.7.2
                                +-- iobroker.js-controller@1.5.6
                                | `-- socket.io@1.7.2
                                `-- iobroker.socketio@2.1.1
                                  `-- socket.io@1.7.2
                                Bluefox 1 Reply Last reply Reply Quote 1
                                • Bluefox
                                  @sigi234 Ist das nur DasWetter oder auch andere Adapter?
                                    nur DasWetter
                                    Korrektur:
                                    iot.0	2019-02-13 22:55:09.962	error	Cannot report device state: null
                                    iot.0	2019-02-13 22:55:09.576	error	Cannot report device state: null
                                    iot.0	2019-02-13 22:55:09.563	error	Cannot report device state: null
                                    • Bluefox
                                      @sigi234 node.js version ? npm ?
                                        Node.js: v8.15.0
                                        NPM: 6.4.1
                                          PrinzEisenherz1 @Homer.J. last edited by
                                          @Homer1976 sagte in ioBroker.js-controller 1.5.6:
                                          Hallo Bluefox,
                                          Nach der Installation hat erstmal der Shelly-Adapter tewas verrückt gespielt, sich aber nach m Neustart beruhigt.
                                          Jetzt hab ich derzeit nur die gleichen Fehlermeldungen vom dasWetter wie Homer 1976
                                          Ich bleibe jetzt aber mal auf Version 1.5.6 und schau mir das mal ne weile an was sich noch so alles tut
                                          Johnny
                                          • lobomau
                                            lobomau last edited by
                                            Gestern hatte ich ohne Erfolg 1.5.4. versucht, heute 1.5.6.
                                            Ich denke ich habe woanders Probleme. Irgendwie habe ich neben opt/iobroker auch home/iobroker... im zweiten habe ich aber keine Rechte... sudo cd /home/iobroker geht auch nicht.
                                            NPM version: 6.4.1
                                            npm version >= 5: disabling package-lock
                                            Could not check npm version: Error: EACCES: permission denied, open '/opt/iobroker/.npmrc'
                                            Assuming that correct version is installed.
                                            > node-bluetooth@1.2.5 install /opt/iobroker/node_modules/node-bluetooth
                                            > node-gyp configure build
                                            gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/iobroker/.node-gyp/8.15.0"
                                            gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/node-bluetooth/.node-gyp"
                                            gyp WARN install got an error, rolling back install
                                            gyp ERR! configure error
                                            gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/node-bluetooth/.node-gyp'
                                            gyp ERR! System Linux 4.15.0-45-generic
                                            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
                                            gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
                                            gyp ERR! node -v v8.15.0
                                            gyp ERR! node-gyp -v v3.8.0
                                            gyp ERR! not ok
                                            > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                                            > node rebuild.js
                                            ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                                            fs.js:646
                                              return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
                                            Error: EACCES: permission denied, open './stdout.log'
                                                at Object.fs.openSync (fs.js:646:18)
                                                at Object.fs.writeFileSync (fs.js:1299:33)
                                                at Object.<anonymous> (/opt/iobroker/node_modules/ursa-optional/rebuild.js:13:10)
                                                at Module._compile (module.js:653:30)
                                                at Object.Module._extensions..js (module.js:664:10)
                                                at Module.load (module.js:566:32)
                                                at tryModuleLoad (module.js:506:12)
                                                at Function.Module._load (module.js:498:3)
                                                at Function.Module.runMain (module.js:694:10)
                                                at startup (bootstrap_node.js:204:16)
                                            > usb@1.5.0 install /opt/iobroker/node_modules/usb
                                            > node-pre-gyp install --fallback-to-build
                                            node-pre-gyp WARN Using request for node-pre-gyp https download
                                            node-pre-gyp WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v57-linux-x64.tar.gz
                                            node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
                                            gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
                                            gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/usb/.node-gyp'
                                            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
                                            gyp ERR! cwd /opt/iobroker/node_modules/usb
                                            gyp ERR! not ok
                                            node-pre-gyp ERR! build error
                                            node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                                            node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                            node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
                                            node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                                            node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
                                            node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                                            node-pre-gyp ERR! System Linux 4.15.0-45-generic
                                            node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                            node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
                                            node-pre-gyp ERR! node -v v8.15.0
                                            node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                            node-pre-gyp ERR! not ok
                                            > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
                                            > node-gyp rebuild
                                            gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/diskusage/.node-gyp"
                                            gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/diskusage/.node-gyp'
                                            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                            gyp ERR! cwd /opt/iobroker/node_modules/diskusage
                                            gyp ERR! not ok
                                            > iobroker.js-controller@1.5.6 install /opt/iobroker/node_modules/iobroker.js-controller
                                            > node iobroker.js setup first
                                            Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                                            Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                                            fs.js:885
                                              return binding.mkdir(pathModule._makeLong(path),
                                            Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                                at Object.fs.mkdirSync (fs.js:885:18)
                                                at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:157:58)
                                                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:634:27
                                                at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:664:15)
                                                at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3159:5)
                                                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
                                            npm WARN onvif-snapshot@1.0.2 requires a peer of onvif@^0.5.5 but none is installed. You must install peer dependencies yourself.
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: `npm install node-pre-gyp`
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 243
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 (node_modules/node-bluetooth):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 install: `node-gyp configure build`
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 (node_modules/ursa-optional):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 install: `node rebuild.js`
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 (node_modules/usb):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 install: `node-pre-gyp install --fallback-to-build`
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 (node_modules/diskusage):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 install: `node-gyp rebuild`
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! errno 1
                                            npm ERR! iobroker.js-controller@1.5.6 install: `node iobroker.js setup first`
                                            npm ERR! Exit status 1
                                            npm ERR!
                                            npm ERR! Failed at the iobroker.js-controller@1.5.6 install script.
                                            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                            npm ERR!     /home/iobroker/.npm/_logs/2019-02-13T19_51_21_042Z-debug.log
                                            iobroker@iobroker-ubuntu:/opt/iobroker$
                                            call for action test
                                            31
                                            150
                                            19842
