    2. Русский
    3. ioBroker
    4. ioBroker установка и конфигурация
    5. Инсталляция под Linux
    • I
      IZUM last edited by
      @vtec:
      Попробуй так, что напишет
      cd /opt/iobroker
      sudo npm install iobroker.js-controller
      izum@izum-eM350:/opt/iobroker$ sudo npm cache clean
      izum@izum-eM350:/opt/iobroker$ sudo npm install iobroker.js-controller
      > ws@0.5.0 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws
      > (node-gyp rebuild 2> builderror.log) || (exit 0)
      npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
      npm WARN engine sntp@0.1.4: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
      npm WARN engine cryptiles@0.1.3: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
      npm WARN engine boom@0.3.8: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
      npm WARN engine hoek@0.7.6: wanted: {"node":"0.8.x"} (current: {"node":"0.10.25","npm":"1.4.21"})
      > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
      npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
      > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
      > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
      > iobroker.js-controller@0.5.15 install /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/setup.js setup first
      sh: 1: node: not found
      npm WARN This failure might be due to the use of legacy binary "node"
      npm WARN For further explanations, please read
      /usr/share/doc/nodejs/README.Debian
      npm ERR! iobroker.js-controller@0.5.15 install: `node lib/setup.js setup first`
      npm ERR! Exit status 127
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@0.5.15 install script.
      npm ERR! This is most likely a problem with the iobroker.js-controller package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node lib/setup.js setup first
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.
      npm ERR! System Linux 3.16.0-23-generic
      npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller"
      npm ERR! cwd /opt/iobroker
      npm ERR! node -v v0.10.25
      npm ERR! npm -v 1.4.21
      npm ERR! code ELIFECYCLE
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /opt/iobroker/npm-debug.log
      npm ERR! not ok code 0
      • Bluefox
        Bluefox last edited by
        node.js не доступен по команде "node"
        Что происходит если в консоли написать?
        izum@izum-eM350:/opt$ node
        • I
          IZUM last edited by
          @Bluefox:
          izum@izum-eM350:~$ izum@izum-eM350:/opt$ node
          bash: izum@izum-eM350:/opt$: Нет такого файла или каталога
          izum@izum-eM350:~$ /opt$ node
          bash: /opt$: Нет такого файла или каталога
          izum@izum-eM350:~$
          • V
            vtec last edited by
            Создай ссылку на "node" с помощью команды "sudo ln -s /usr/bin/nodejs /usr/bin/node"
            • I
              IZUM last edited by
              @vtec:
              Создай ссылку на "node" с помощью команды "sudo ln -s /usr/bin/nodejs /usr/bin/node" `
              make: вход в каталог «/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build»
                CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
                COPY Release/bufferutil.node
                CXX(target) Release/obj.target/validation/src/validation.o
                SOLINK_MODULE(target) Release/obj.target/validation.node
                SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
                COPY Release/validation.node
              make: выход из каталога «/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build»
              make: вход в каталог «/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build»
              make: выход из каталога «/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build»
              creating conf/iobroker.json
              object system.certificates created
              object system.repositories created
              object system.config created
              object enum.rooms created
              object system.group.user created
              object system.group.administrator created
              object _design/system created
              object system.user.admin created
              object system.meta.uuid created
              install adapter admin
              object system.adapter.admin created
              create instance admin
              object system.adapter.admin.0.uptime created
              object system.adapter.admin.0.memRss created
              object system.adapter.admin.0.memHeapTotal created
              object system.adapter.admin.0.memHeapUsed created
              object system.adapter.admin.0.connected created
              object system.adapter.admin.0.alive created
              object system.adapter.admin.0 created
              iobroker.js-controller@0.5.15 node_modules/iobroker.js-controller
              ├── daemonize2@0.4.2
              ├── mime@1.2.11
              ├── node-schedule@0.1.13
              ├── ncp@0.6.0
              ├── node.extend@1.0.10 (is@0.3.0)
              ├── adm-zip@0.4.7
              ├── yargs@1.2.6 (minimist@0.1.0)
              ├── request@2.38.0 (json-stringify-safe@5.0.0, forever-agent@0.5.2, aws-sign2@0.5.0, qs@0.6.6, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, node-uuid@1.4.3, mime-types@1.0.2, form-data@0.1.4, http-signature@0.10.1, tough-cookie@0.12.1, hawk@1.1.1)
              ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31)
              ├── socket.io@1.2.1 (debug@0.7.4, has-binary-data@0.1.3, socket.io-adapter@0.3.1, socket.io-parser@2.2.2, engine.io@1.4.3)
              ├── winston@0.7.3 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, colors@0.6.2, async@0.2.10, pkginfo@0.3.0, request@2.16.6)
              ├── socket.io-client@1.2.1 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.5, parseuri@0.0.2, socket.io-parser@2.2.2, engine.io-client@1.4.3)
              └── npm@2.3.0
              Вроде ошибок нет ,но http://localhost:8081/ не открывается.
              • Bluefox
                node iobroker start
                • I
                  IZUM last edited by
                  @Bluefox:
                  node iobroker start
                  izum@izum-eM350:/opt/iobroker$ node iobroker start
                  /opt/iobroker/iobroker:1
                  (function (exports, require, module, __filename, __dirname) { node node_module
                  SyntaxError: Unexpected identifier
                      at Module._compile (module.js:439:25)
                      at Object.Module._extensions..js (module.js:474:10)
                      at Module.load (module.js:356:32)
                      at Function.Module._load (module.js:312:12)
                      at Function.Module.runMain (module.js:497:10)
                      at startup (node.js:119:16)
                      at node.js:902:3
                  izum@izum-eM350:/opt/iobroker$ cd
                  izum@izum-eM350:~$ node iobroker start
                  /home/izum/iobroker:1
                      at node.js:902:3
                  izum@izum-eM350:~$ node --version
                  v0.10.25
                  • Bluefox
                    node /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js start
                    • I
                      IZUM last edited by
                      @Bluefox:
                      node /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js start `
                      Ура, все завелось! Спасибо вам за ваше терпение и отзывчивость))
                      • V
                        vtec last edited by
                        Изюм установил js-controller
                        Дай еще команду
                        sudo nmp install iobroker
                        После успешной установки
                        sudo init 6
                        • I
                          IZUM last edited by
                          @vtec:
                          Дай еще команду
                          sudo init 6 `
                          Не получилось….
                          npm ERR! not a package /tmp/npm-2695-nnDOKRW5/1426781950654-0.42539166775532067/tmp.tgz
                          > iobroker@0.5.1 install /opt/iobroker/node_modules/iobroker
                          > node lib/setup.js
                          npm install iobroker.js-controller --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
                          npm install iobroker.admin --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
                          Write "./iobroker start" to start the ioBroker
                          Non-critical error: EACCES, permission denied '/usr/bin/iobroker'
                          iobroker@0.5.1 node_modules/iobroker
                          └── yargs@1.2.6 (minimist@0.1.0)
                          • Bluefox
                            "npm install iobroker" выполнится только если не существует папка "/opt/iobroker/iobroker-data". То есть устанавливается только на чистую систему.
                            • I
                              IZUM last edited by
                              @Bluefox:
                              "npm install iobroker" выполнится только если не существует папка "/opt/iobroker/iobroker-data". То есть устанавливается только на чистую систему. `
                              То есть у меня сейчас не до конца установленный iobroker??
                              • Bluefox
                                @IZUM:
                                @Bluefox:
                                "npm install iobroker" выполнится только если не существует папка "/opt/iobroker/iobroker-data". То есть устанавливается только на чистую систему. То есть у меня сейчас не до конца установленный iobroker??
                                Он не запустится сам при перезагрузке.
                                  Andrei34 last edited by
                                  Что-то у меня не ролучается установить ioBroker . Такое пишет
                                  root@xbmc:/opt/iobroker# npm install iobroker
                                  npm WARN cannot run in wd iobroker@0.5.5 node lib/setup.js (wd=/opt/iobroker/node_modules/iobroker)
                                  iobroker@0.5.5 node_modules/iobroker
                                  root@xbmc:/opt/iobroker# init 6
                                  • V
                                    vtec last edited by
                                    А что такое WD? Название машины?
                                    4733_dok_1_meta_ordner.docx
                                    4733_daten_neq1512381.docx
                                      @vtec:
                                      А что такое WD? Название машины? `
                                      Да нет , это что-то от nodejs . Хотя когда делаю : root@xbmc:/opt/iobroker# npm install iobroker.js-controller
                                      устанавливается ,но в конце пишет ошибки :
                                      npm ERR! Linux 3.2.0-4-686-pae
                                      npm ERR! argv "node" "/usr/local/bin/npm" "install" "iobroker.js-controller"
                                      npm ERR! node v0.12.7
                                      npm ERR! npm  v2.14.0
                                      npm ERR! iobroker.js-controller@0.7.9 install: `node lib/setup.js setup first`
                                      npm ERR!
                                      npm ERR! Failed at the iobroker.js-controller@0.7.9 install script 'node lib/setup.js setup first'.
                                      npm ERR! Please include the following file with any support request:
                                      546_npm-debug.log
                                        electric69 last edited by
                                        @Andrei34:
                                        устанавливается ,но в конце пишет ошибки `
                                        У меня тоже при установке ошибки:
                                        > iobroker@0.5.5 install /opt/iobroker/node_modules/iobroker
                                        > node lib/setup.js
                                        npm install iobroker.js-controller --production --prefix /opt/iobroker
                                        /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:121
                                                    objects.getObject(obj._id, function (err, _obj) {
                                        TypeError: Cannot read property 'getObject' of undefined
                                            at dbSetup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:121:20)
                                            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:189:13
                                            at Object.States.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2095:82)
                                            at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:179:26)
                                            at Timer.listOnTimeout (timers.js:119:15)
                                        npm ERR! Linux 3.4.108-bananapi
                                        npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" "/opt/iobroker"
                                        npm ERR! npm  v2.11.3
                                        npm ERR!
                                        npm ERR!     /opt/iobroker/node_modules/iobroker/npm-debug.log
                                        Cannot install as normal user. Try sudo...
                                        sudo npm install iobroker.js-controller --production --prefix /opt/iobroker
                                        npm install iobroker.admin --production --prefix /opt/iobroker
                                        Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                                        iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                                        root@bananapi:/opt/iobroker#
                                        Только файла /opt/iobroker/node_modules/iobroker/npm-debug.log не нашел…
                                        Видимо появление этой ошибки - нормально при установке на линукс...
                                        Все таки система "криво" устанавливается, не запускается админка, в логе ошибки:
                                        ! 2015-08-22 11:31:42.603 - info: host.bananapi ioBroker.js-controller version 0.7.9 js-controller starting 2015-08-22 11:31:42.632 - info: host.bananapi Copyright (c) 2014-2015 bluefox, hobbyquaker 2015-08-22 11:31:42.637 - info: host.bananapi hostname: bananapi 2015-08-22 11:31:42.638 - info: host.bananapi ip addresses: 192.168.69.20 fe80::17:5ff:fe01:d974 2015-08-22 11:31:42.722 - info: inMem-states listening on port 9000 2015-08-22 11:31:42.786 - info: inMem-objects listening on port 9001 2015-08-22 11:31:42.819 - info: host.bananapi InMemoryDB connected 2015-08-22 11:31:42.860 - error: host.bananapi _design/system missing - call node iobroker.js setup !
                                        Попытка запустить вручную, ругается на конфиг admin.0
                                        root@bananapi:~# nodejs /opt/iobroker/node_modules/iobroker.admin/admin.js
                                        2015-08-22 12:16:00.184  - error: admin.0 invalid config
                                        root@bananapi:~#
                                        Запустился только io.js-controller:
                                          ford7 last edited by
                                          Подскажите, как починить?
                                          После пропадания питания вкладка "драйвера" пустая.
                                          upd:
                                          вкладка "сервера" тоже пустая.
                                          А в настройках все штатно:
                                            Спасибо , вроде исправили 😄 , как то установил . Но теперь адаптеры почему-то ставятся не в папку /opt/iobroker/node_modules ,
                                            а в /opt/iobroker/node_modules/node_modules и ioBroker их не видит.
                                            256
                                            92508
