    4. ioBroker.js-controller 1.5.6
    • lobomau
      lobomau last edited by
      Gestern hatte ich ohne Erfolg 1.5.4. versucht, heute 1.5.6.
      Ich denke ich habe woanders Probleme. Irgendwie habe ich neben opt/iobroker auch home/iobroker... im zweiten habe ich aber keine Rechte... sudo cd /home/iobroker geht auch nicht.
      NPM version: 6.4.1
      npm version >= 5: disabling package-lock
      Could not check npm version: Error: EACCES: permission denied, open '/opt/iobroker/.npmrc'
      Assuming that correct version is installed.
      > node-bluetooth@1.2.5 install /opt/iobroker/node_modules/node-bluetooth
      > node-gyp configure build
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/iobroker/.node-gyp/8.15.0"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/node-bluetooth/.node-gyp"
      gyp WARN install got an error, rolling back install
      gyp ERR! configure error
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/node-bluetooth/.node-gyp'
      gyp ERR! System Linux 4.15.0-45-generic
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
      gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
      gyp ERR! node -v v8.15.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
      > node rebuild.js
      ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
      fs.js:646
        return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      Error: EACCES: permission denied, open './stdout.log'
          at Object.fs.openSync (fs.js:646:18)
          at Object.fs.writeFileSync (fs.js:1299:33)
          at Object.<anonymous> (/opt/iobroker/node_modules/ursa-optional/rebuild.js:13:10)
          at Module._compile (module.js:653:30)
          at Object.Module._extensions..js (module.js:664:10)
          at Module.load (module.js:566:32)
          at tryModuleLoad (module.js:506:12)
          at Function.Module._load (module.js:498:3)
          at Function.Module.runMain (module.js:694:10)
          at startup (bootstrap_node.js:204:16)
      > usb@1.5.0 install /opt/iobroker/node_modules/usb
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v57-linux-x64.tar.gz
      node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/usb/.node-gyp'
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
      gyp ERR! cwd /opt/iobroker/node_modules/usb
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
      node-pre-gyp ERR! System Linux 4.15.0-45-generic
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
      node-pre-gyp ERR! node -v v8.15.0
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
      > node-gyp rebuild
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/diskusage/.node-gyp"
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/diskusage/.node-gyp'
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/diskusage
      gyp ERR! not ok
      > iobroker.js-controller@1.5.6 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
      fs.js:885
        return binding.mkdir(pathModule._makeLong(path),
      Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
          at Object.fs.mkdirSync (fs.js:885:18)
          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:157:58)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:634:27
          at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:664:15)
          at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3159:5)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
      npm WARN onvif-snapshot@1.0.2 requires a peer of onvif@^0.5.5 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: `npm install node-pre-gyp`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 243
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 (node_modules/node-bluetooth):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 install: `node-gyp configure build`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 (node_modules/ursa-optional):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 install: `node rebuild.js`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 (node_modules/usb):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 install: `node-pre-gyp install --fallback-to-build`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 (node_modules/diskusage):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 install: `node-gyp rebuild`
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@1.5.6 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@1.5.6 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2019-02-13T19_51_21_042Z-debug.log
      iobroker@iobroker-ubuntu:/opt/iobroker$
      Bluefox 1 Reply Last reply Reply Quote 0
        PrinzEisenherz1 last edited by
        jetzt hab ich den shedule von daswetter geändert und nun kommt dauernd folgender Fehler
        host.ioBroker-VM	2019-02-13 21:00:38.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:37.002	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:36.001	warn	instance system.adapter.daswetter.0 already running with pid 4461
        host.ioBroker-VM	2019-02-13 21:00:35.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:34.010	info	instance system.adapter.daswetter.0 started with pid 4461
        host.ioBroker-VM	2019-02-13 21:00:33.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:32.829	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
        host.ioBroker-VM	2019-02-13 21:00:32.002	warn	instance system.adapter.daswetter.0 already running with pid 4447
        host.ioBroker-VM	2019-02-13 21:00:31.003	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:30.001	warn	instance system.adapter.daswetter.0 already running with pid 4447
        host.ioBroker-VM	2019-02-13 21:00:29.002	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:28.003	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:27.274	warn	instance system.adapter.daswetter.0 already running with pid 4447
        host.ioBroker-VM	2019-02-13 21:00:26.002	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:25.010	info	instance system.adapter.daswetter.0 started with pid 4447
        host.ioBroker-VM	2019-02-13 21:00:24.457	info	instance scheduled system.adapter.daswetter.0 * */16 * * * *
        host.ioBroker-VM	2019-02-13 21:00:21.952	warn	stopInstance system.adapter.daswetter.0 not scheduled
        host.ioBroker-VM	2019-02-13 21:00:21.952	info	stopInstance system.adapter.daswetter.0
        host.ioBroker-VM	2019-02-13 21:00:21.952	info	object change system.adapter.daswetter.0
        host.ioBroker-VM	2019-02-13 21:00:19.497	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
        host.ioBroker-VM	2019-02-13 21:00:18.238	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
        host.ioBroker-VM	2019-02-13 21:00:15.723	info	stopInstance canceled schedule system.adapter.daswetter.0
        host.ioBroker-VM	2019-02-13 21:00:15.723	info	stopInstance system.adapter.daswetter.0
        host.ioBroker-VM	2019-02-13 21:00:15.722	info	object change system.adapter.daswetter.0
        host.ioBroker-VM	2019-02-13 21:00:15.005	warn	instance system.adapter.daswetter.0 already running with pid 4418
        host.ioBroker-VM	2019-02-13 21:00:14.063	info	instance system.adapter.ical.0 terminated with code 0 (OK)
        host.ioBroker-VM	2019-02-13 21:00:14.059	info	instance system.adapter.weatherunderground.0 started with pid 4433
        host.ioBroker-VM	2019-02-13 21:00:14.039	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:13.000	warn	instance system.adapter.daswetter.0 already running with pid 4418
        host.ioBroker-VM	2019-02-13 21:00:12.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:11.043	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:10.008	info	instance system.adapter.daswetter.0 started with pid 4418
        host.ioBroker-VM	2019-02-13 21:00:09.837	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
        host.ioBroker-VM	2019-02-13 21:00:09.000	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:08.000	warn	instance system.adapter.daswetter.0 already running with pid 4306
        host.ioBroker-VM	2019-02-13 21:00:07.016	info	instance system.adapter.yr.0 terminated with code 0 (OK)
        host.ioBroker-VM	2019-02-13 21:00:07.000	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:06.000	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:05.001	warn	instance system.adapter.daswetter.0 already running with pid 4306
        host.ioBroker-VM	2019-02-13 21:00:04.628	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
        host.ioBroker-VM	2019-02-13 21:00:04.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:03.013	warn	instance system.adapter.daswetter.0 does not started, because just executed
        host.ioBroker-VM	2019-02-13 21:00:02.037	warn	instance system.adapter.daswetter.0 already running with pid 4306
        • Bluefox
          Bluefox @PrinzEisenherz1 last edited by Bluefox
          Участник @PrinzEisenherz1 написал в ioBroker.js-controller 1.5.6:
          • */16 * * * *
          Kannst du auf "*/16 * * * *" ändern? Sonst wird es jede Sekunde ausgeführt
          • coyote
            coyote Most Active last edited by
            Gerade auch Javascript und js-controller auf neueste Version hochgezogen.
            Bisher alles unauffällig, Vis "Empty ID" Fehler s ist weg. 👍
            Bisher keine Fehler im Log von DasWetter . Behalte es mal im Auge😉
            Bluefox sigi234 2 Replies Last reply Reply Quote 0
            • Bluefox
              Bluefox @coyote last edited by
              Участник @coyote написал в ioBroker.js-controller 1.5.6:
              DasWetter
              Restarte mal DasWetter
                sigi234 Forum Testing Most Active @coyote last edited by
                @coyote sagte in ioBroker.js-controller 1.5.6:
                War bei mir auch so, der kommt erst später.....
                  PrinzEisenherz1 @Bluefox last edited by
                  @Bluefox sagte in ioBroker.js-controller 1.5.6:
                  */16 * * * *
                  Ah, auch gerade den Fehler gemerkt.
                  • coyote
                    Nach neustart alles gut.
                    repetier.0	2019-02-13 21:05:24.548	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.repetier, node: v8.12.0
                    host.debian	2019-02-13 21:05:24.013	info	instance system.adapter.repetier.0 started with pid 31337
                    host.debian	2019-02-13 21:05:21.150	info	instance system.adapter.repetier.0 terminated with code 0 (OK)
                    host.debian	2019-02-13 21:05:18.227	info	instance scheduled system.adapter.daswetter.0 */15 * * * *
                    repetier.0	2019-02-13 21:05:16.608	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.repetier, node: v8.12.0
                    host.debian	2019-02-13 21:05:16.013	info	instance system.adapter.repetier.0 started with pid 31323
                    host.debian	2019-02-13 21:05:15.722	warn	stopInstance system.adapter.daswetter.0 not scheduled
                    host.debian	2019-02-13 21:05:15.722	info	stopInstance system.adapter.daswetter.0
                    host.debian	2019-02-13 21:05:15.721	info	object change system.adapter.daswetter.0
                    Schätze, dass der Fehler erst nach dem ersten Schedule kommt
                    • Issi
                      Issi Developer last edited by
                      hab die v.1.5.6 jetzt seit gestern am laufen und bisher keine Error abgesehen von DasWetter mit dem code 11 aber der war auch schon vorher da
                      • Bluefox
                        Bluefox @lobomau last edited by
                        @lobomau da kann ich leider jetzt nicht helfen. Man muss sauber alles trennen. Da ist was mit der Installation kaputt
                        lobomau 1 Reply Last reply Reply Quote 0
                        • Bluefox
                          Bluefox @sigi234 last edited by Bluefox
                          @sigi234 Welche DasWetter Version hast du?
                          kannst du so was probieren ?:
                          node C:\ioBroker\node_modules\iobroker.daswetter\main.js --logs
                          • lobomau
                            lobomau @Bluefox last edited by
                            Ja, alles klar. Danke. Eben snapshot zurück und gut. Neu mache ich irgendwann in Ruhe.
                              sigi234 Forum Testing Most Active @Bluefox last edited by
                              starting. Version 2.6.1 in C:/ioBroker/node_modules/iobroker.daswetter, node: v8.15.0
                              set timeout to 300 sec
                              checking data structures
                              deleting unused dataset, reset to true
                              using new datastructure
                              calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxxx&affiliate_id=xxxxxxx=2.05 days forecast done, objects in list 947
                              objects in list: 947
                              calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxx&affiliate_id=xxxxxx&v=2.0&h=1
                              got 148 channels
                              RangeError: Maximum call stack size exceeded
                                  at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12)
                                  at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
                                  at Decoder.add (C:\ioBroker\node_modules\socket.io-parser\index.js:237:14)
                                  at Manager.ondata (C:\ioBroker\node_modules\socket.io-client\lib\manager.js:322:16)
                                  at Socket.<anonymous> (C:\ioBroker\node_modules\component-bind\index.js:21:15)
                                  at Socket.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                                  at Socket.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:451:14)
                                  at WS.<anonymous> (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:268:10)
                                  at WS.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                                  at WS.Transport.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\transport.js:145:8)
                              hourly forecast done, objects in list 2581
                              update already running
                              terminating
                                Hi Bluefox, also bei mir kommt folgendes
                                oot@ioBroker-VM:~# node /opt/iobroker/node_modules/iobroker.daswetter/main.js --logs
                                starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.15.0
                                set timeout to 80 sec
                                calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz
                                7 days forecast done, objects in list 107
                                objects in list: 107
                                calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz&v=2.0&h=1
                                got 150 channels
                                got 2875 states
                                hourly forecast done, objects in list 1699
                                nothing to do
                                exit, all done
                                root@ioBroker-VM:~#
                                Ich hab die Version 2.6.1
                                  Kann ich bestätigen.
                                  • Bluefox
                                    @PrinzEisenherz1 Hier ist alles OK.
                                      apollon77 @simatec last edited by
                                      @simatec Nach Rücksprache mit @AlCalzone ist das nicht ganz korrek t- zumindestens nicht mit den Installern seit 20.1. glaube ich.
                                      Dafpr ind die Default ACLs da die vom Instller gesetzt werden
                                      Dann gehören die Dateien zwar dem aktuellen user, iobroker behält trotzdem die Berechtigungen
                                      simatec 2 Replies Last reply Reply Quote 0
                                      • simatec
                                        simatec Developer Most Active @apollon77 last edited by simatec
                                        @apollon77
                                        OK dann teste ich das noch einmal mit einer neu aufgesetzten Installation.
                                        Meine aktuelle mit den manuellen Patch, den ich dann als PR für den Installer gepusht hatte, ging es nicht.
                                        Aber ich werde das nochmal reproduzieren und berichten 😉
                                        • coyote
                                          coyote Most Active @sigi234 last edited by
                                          @sigi234 sagte in ioBroker.js-controller 1.5.6:
                                          Also bei mir alles ok, kein Fehler im Log von DasWetter. Sind ja jetzt schon mehrere Zyklen durchgelaufen ohne Probleme....
                                            Hm........... da wären deine Einstellungen vom Adapter interessant.
                                            call for action test
                                            31
                                            150
                                            19842
