    4. ioBroker.js-controller 1.5.6
      PrinzEisenherz1 last edited by
      jetzt hab ich den shedule von daswetter geändert und nun kommt dauernd folgender Fehler
      host.ioBroker-VM	2019-02-13 21:00:38.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:37.002	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:36.001	warn	instance system.adapter.daswetter.0 already running with pid 4461
      host.ioBroker-VM	2019-02-13 21:00:35.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:34.010	info	instance system.adapter.daswetter.0 started with pid 4461
      host.ioBroker-VM	2019-02-13 21:00:33.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:32.829	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
      host.ioBroker-VM	2019-02-13 21:00:32.002	warn	instance system.adapter.daswetter.0 already running with pid 4447
      host.ioBroker-VM	2019-02-13 21:00:31.003	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:30.001	warn	instance system.adapter.daswetter.0 already running with pid 4447
      host.ioBroker-VM	2019-02-13 21:00:29.002	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:28.003	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:27.274	warn	instance system.adapter.daswetter.0 already running with pid 4447
      host.ioBroker-VM	2019-02-13 21:00:26.002	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:25.010	info	instance system.adapter.daswetter.0 started with pid 4447
      host.ioBroker-VM	2019-02-13 21:00:24.457	info	instance scheduled system.adapter.daswetter.0 * */16 * * * *
      host.ioBroker-VM	2019-02-13 21:00:21.952	warn	stopInstance system.adapter.daswetter.0 not scheduled
      host.ioBroker-VM	2019-02-13 21:00:21.952	info	stopInstance system.adapter.daswetter.0
      host.ioBroker-VM	2019-02-13 21:00:21.952	info	object change system.adapter.daswetter.0
      host.ioBroker-VM	2019-02-13 21:00:19.497	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
      host.ioBroker-VM	2019-02-13 21:00:18.238	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
      host.ioBroker-VM	2019-02-13 21:00:15.723	info	stopInstance canceled schedule system.adapter.daswetter.0
      host.ioBroker-VM	2019-02-13 21:00:15.723	info	stopInstance system.adapter.daswetter.0
      host.ioBroker-VM	2019-02-13 21:00:15.722	info	object change system.adapter.daswetter.0
      host.ioBroker-VM	2019-02-13 21:00:15.005	warn	instance system.adapter.daswetter.0 already running with pid 4418
      host.ioBroker-VM	2019-02-13 21:00:14.063	info	instance system.adapter.ical.0 terminated with code 0 (OK)
      host.ioBroker-VM	2019-02-13 21:00:14.059	info	instance system.adapter.weatherunderground.0 started with pid 4433
      host.ioBroker-VM	2019-02-13 21:00:14.039	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:13.000	warn	instance system.adapter.daswetter.0 already running with pid 4418
      host.ioBroker-VM	2019-02-13 21:00:12.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:11.043	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:10.008	info	instance system.adapter.daswetter.0 started with pid 4418
      host.ioBroker-VM	2019-02-13 21:00:09.837	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
      host.ioBroker-VM	2019-02-13 21:00:09.000	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:08.000	warn	instance system.adapter.daswetter.0 already running with pid 4306
      host.ioBroker-VM	2019-02-13 21:00:07.016	info	instance system.adapter.yr.0 terminated with code 0 (OK)
      host.ioBroker-VM	2019-02-13 21:00:07.000	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:06.000	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:05.001	warn	instance system.adapter.daswetter.0 already running with pid 4306
      host.ioBroker-VM	2019-02-13 21:00:04.628	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
      host.ioBroker-VM	2019-02-13 21:00:04.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:03.013	warn	instance system.adapter.daswetter.0 does not started, because just executed
      host.ioBroker-VM	2019-02-13 21:00:02.037	warn	instance system.adapter.daswetter.0 already running with pid 4306
      Bluefox 1 Reply Last reply Reply Quote 0
      • Bluefox
        Bluefox @PrinzEisenherz1 last edited by Bluefox
        Участник @PrinzEisenherz1 написал в ioBroker.js-controller 1.5.6:
        • */16 * * * *
        Kannst du auf "*/16 * * * *" ändern? Sonst wird es jede Sekunde ausgeführt
        • coyote
          coyote Most Active last edited by
          Gerade auch Javascript und js-controller auf neueste Version hochgezogen.
          Bisher alles unauffällig, Vis "Empty ID" Fehler s ist weg. 👍
          Bisher keine Fehler im Log von DasWetter . Behalte es mal im Auge😉
          Bluefox sigi234 2 Replies Last reply Reply Quote 0
          • Bluefox
            Bluefox @coyote last edited by
            Участник @coyote написал в ioBroker.js-controller 1.5.6:
            DasWetter
            Restarte mal DasWetter
              sigi234 Forum Testing Most Active @coyote last edited by
              @coyote sagte in ioBroker.js-controller 1.5.6:
              War bei mir auch so, der kommt erst später.....
                PrinzEisenherz1 @Bluefox last edited by
                @Bluefox sagte in ioBroker.js-controller 1.5.6:
                */16 * * * *
                Ah, auch gerade den Fehler gemerkt.
                • coyote
                  Nach neustart alles gut.
                  repetier.0	2019-02-13 21:05:24.548	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.repetier, node: v8.12.0
                  host.debian	2019-02-13 21:05:24.013	info	instance system.adapter.repetier.0 started with pid 31337
                  host.debian	2019-02-13 21:05:21.150	info	instance system.adapter.repetier.0 terminated with code 0 (OK)
                  host.debian	2019-02-13 21:05:18.227	info	instance scheduled system.adapter.daswetter.0 */15 * * * *
                  repetier.0	2019-02-13 21:05:16.608	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.repetier, node: v8.12.0
                  host.debian	2019-02-13 21:05:16.013	info	instance system.adapter.repetier.0 started with pid 31323
                  host.debian	2019-02-13 21:05:15.722	warn	stopInstance system.adapter.daswetter.0 not scheduled
                  host.debian	2019-02-13 21:05:15.722	info	stopInstance system.adapter.daswetter.0
                  host.debian	2019-02-13 21:05:15.721	info	object change system.adapter.daswetter.0
                  Schätze, dass der Fehler erst nach dem ersten Schedule kommt
                  • Issi
                    Issi Developer last edited by
                    hab die v.1.5.6 jetzt seit gestern am laufen und bisher keine Error abgesehen von DasWetter mit dem code 11 aber der war auch schon vorher da
                    • Bluefox
                      Bluefox @lobomau last edited by
                      @lobomau da kann ich leider jetzt nicht helfen. Man muss sauber alles trennen. Da ist was mit der Installation kaputt
                      lobomau 1 Reply Last reply Reply Quote 0
                      • Bluefox
                        Bluefox @sigi234 last edited by Bluefox
                        @sigi234 Welche DasWetter Version hast du?
                        kannst du so was probieren ?:
                        node C:\ioBroker\node_modules\iobroker.daswetter\main.js --logs
                        • lobomau
                          lobomau @Bluefox last edited by
                          Ja, alles klar. Danke. Eben snapshot zurück und gut. Neu mache ich irgendwann in Ruhe.
                            sigi234 Forum Testing Most Active @Bluefox last edited by
                            starting. Version 2.6.1 in C:/ioBroker/node_modules/iobroker.daswetter, node: v8.15.0
                            set timeout to 300 sec
                            checking data structures
                            deleting unused dataset, reset to true
                            using new datastructure
                            calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxxx&affiliate_id=xxxxxxx=2.05 days forecast done, objects in list 947
                            objects in list: 947
                            calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxx&affiliate_id=xxxxxx&v=2.0&h=1
                            got 148 channels
                            RangeError: Maximum call stack size exceeded
                                at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12)
                                at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
                                at Decoder.add (C:\ioBroker\node_modules\socket.io-parser\index.js:237:14)
                                at Manager.ondata (C:\ioBroker\node_modules\socket.io-client\lib\manager.js:322:16)
                                at Socket.<anonymous> (C:\ioBroker\node_modules\component-bind\index.js:21:15)
                                at Socket.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                                at Socket.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:451:14)
                                at WS.<anonymous> (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:268:10)
                                at WS.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                                at WS.Transport.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\transport.js:145:8)
                            hourly forecast done, objects in list 2581
                            update already running
                            terminating
                              Hi Bluefox, also bei mir kommt folgendes
                              oot@ioBroker-VM:~# node /opt/iobroker/node_modules/iobroker.daswetter/main.js --logs
                              starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.15.0
                              set timeout to 80 sec
                              calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz
                              7 days forecast done, objects in list 107
                              objects in list: 107
                              calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz&v=2.0&h=1
                              got 150 channels
                              got 2875 states
                              hourly forecast done, objects in list 1699
                              nothing to do
                              exit, all done
                              root@ioBroker-VM:~#
                              Ich hab die Version 2.6.1
                                Kann ich bestätigen.
                                • Bluefox
                                  @PrinzEisenherz1 Hier ist alles OK.
                                    apollon77 @simatec last edited by
                                    @simatec Nach Rücksprache mit @AlCalzone ist das nicht ganz korrek t- zumindestens nicht mit den Installern seit 20.1. glaube ich.
                                    Dafpr ind die Default ACLs da die vom Instller gesetzt werden
                                    Dann gehören die Dateien zwar dem aktuellen user, iobroker behält trotzdem die Berechtigungen
                                    simatec 2 Replies Last reply Reply Quote 0
                                    • simatec
                                      simatec Developer Most Active @apollon77 last edited by simatec
                                      @apollon77
                                      OK dann teste ich das noch einmal mit einer neu aufgesetzten Installation.
                                      Meine aktuelle mit den manuellen Patch, den ich dann als PR für den Installer gepusht hatte, ging es nicht.
                                      Aber ich werde das nochmal reproduzieren und berichten 😉
                                      • coyote
                                        coyote Most Active @sigi234 last edited by
                                        @sigi234 sagte in ioBroker.js-controller 1.5.6:
                                        Also bei mir alles ok, kein Fehler im Log von DasWetter. Sind ja jetzt schon mehrere Zyklen durchgelaufen ohne Probleme....
                                          Hm........... da wären deine Einstellungen vom Adapter interessant.
                                            Ich habe folgendes Verhalten beobachtet:
                                            Beim laden wird immer auf 127.0.0.1 gefiltert, wenn ich das Rote X Drücke geht es.
                                            call for action test
                                            31
                                            150
                                            19841
