    4. [Aufruf] Plex connect testen
    • X
      x-ess last edited by
      2019-02-05 19:00:31.099 - debug: plexconnect.0 objectDB connected
      2019-02-05 19:00:31.177 - debug: plexconnect.0 statesDB connected
      2019-02-05 19:00:31.190 - info: plexconnect.0 States connected to redis: 127.0.0.1:6379
      2019-02-05 19:00:32.094 - info: plexconnect.0 starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.plexconnect, node: v8.15.0
      2019-02-05 19:00:32.105 - info: plexconnect.0 function ready
      2019-02-05 19:00:32.139 - info: plexconnect.0 function main
      2019-02-05 19:00:32.143 - info: plexconnect.0 Server listening on port:10000
      2019-02-05 19:00:32.144 - info: plexconnect.0 PMS:192.168.1.206
      2019-02-05 19:00:50.376 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1549389650346,"q":0,"from":"system.adapter.admin.0","lc":1549389650346}
      2019-02-05 19:00:50.382 - debug: plexconnect.0 system.adapter.admin.0: logging true
      2019-02-05 19:02:08.237 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1549389728235,"q":0,"from":"system.adapter.admin.0","lc":1549389728235}
      2019-02-05 19:02:08.238 - debug: plexconnect.0 system.adapter.admin.0: logging false
      2019-02-05 19:03:29.305 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1549389809303,"q":0,"from":"system.adapter.admin.0","lc":1549389809303}
      2019-02-05 19:03:29.306 - debug: plexconnect.0 system.adapter.admin.0: logging true
      2019-02-05 19:04:57.887 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1549389897884,"q":0,"from":"system.adapter.admin.0","lc":1549389897884}
      2019-02-05 19:04:57.889 - debug: plexconnect.0 system.adapter.admin.0: logging false
      2019-02-05 19:04:59.143 - info: host.ioBroker-RasPi object change system.adapter.plexconnect.0
      2019-02-05 19:04:59.147 - info: host.ioBroker-RasPi stopInstance system.adapter.plexconnect.0
      2019-02-05 19:04:59.148 - info: host.ioBroker-RasPi stopInstance system.adapter.plexconnect.0 killing pid 898
      2019-02-05 19:04:59.679 - info: host.ioBroker-RasPi instance system.adapter.plexconnect.0 terminated with code 0 (OK)
      2019-02-05 19:05:01.674 - info: host.ioBroker-RasPi instance system.adapter.plexconnect.0 started with pid 1187
      2019-02-05 19:05:04.918 - info: plexconnect.0 States connected to redis: 127.0.0.1:6379
      2019-02-05 19:05:05.234 - info: plexconnect.0 starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.plexconnect, node: v8.15.0
      2019-02-05 19:05:05.252 - info: plexconnect.0 function ready
      2019-02-05 19:05:05.274 - info: plexconnect.0 function main
      2019-02-05 19:05:05.279 - info: plexconnect.0 Server listening on port:10000
      2019-02-05 19:05:05.280 - info: plexconnect.0 PMS:192.168.1.206
      2019-02-05 19:05:43.512 - info: host.ioBroker-RasPi object change system.adapter.plexconnect.0
      2019-02-05 19:05:43.513 - info: host.ioBroker-RasPi stopInstance system.adapter.plexconnect.0
      2019-02-05 19:05:43.514 - info: host.ioBroker-RasPi stopInstance system.adapter.plexconnect.0 killing pid 1187
      2019-02-05 19:05:44.045 - info: host.ioBroker-RasPi instance system.adapter.plexconnect.0 terminated with code 0 (OK)
      2019-02-05 19:05:46.039 - info: host.ioBroker-RasPi instance system.adapter.plexconnect.0 started with pid 1254
      2019-02-05 19:05:49.403 - debug: plexconnect.0 objectDB connected
      2019-02-05 19:05:49.486 - debug: plexconnect.0 statesDB connected
      2019-02-05 19:05:49.502 - info: plexconnect.0 States connected to redis: 127.0.0.1:6379
      2019-02-05 19:05:49.822 - info: plexconnect.0 starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.plexconnect, node: v8.15.0
      2019-02-05 19:05:49.834 - info: plexconnect.0 function ready
      2019-02-05 19:05:49.864 - info: plexconnect.0 function main
      2019-02-05 19:05:49.869 - info: plexconnect.0 Server listening on port:10000
      2019-02-05 19:05:49.870 - info: plexconnect.0 PMS:192.168.1.206
      • X
        2019-02-05 19:19:58.231 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1549390798229,"q":0,"from":"system.adapter.admin.0","lc":1549390798229}
        2019-02-05 19:19:58.238 - debug: plexconnect.0 system.adapter.admin.0: logging false
        2019-02-05 19:20:08.196 - debug: plexconnect.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1549390808194,"q":0,"from":"system.adapter.admin.0","lc":1549390808194}
        2019-02-05 19:20:08.197 - debug: plexconnect.0 system.adapter.admin.0: logging true
        • Eisbaeeer
          Eisbaeeer Developer last edited by
          Hmm, dein Adapter startet immer wieder neu. Oder hast du das angestoßen?
          Kann es sein, dass du in das RAM Problem läufst?
          Dein iobroker läuft auf einem RPi. Beobachte mal bitte deinen RAM.
          Es läuft gerade eine Umstellung von iobroker, mit der die Adapter keinen separaten Prozess mehr starten, also weniger RAM benötigen. Nachteil ist aber, dass wenn ein Adapter ein Problem hat, es alle anderen mit auf die Bretter zieht.
          Schau mal mit top auf dem rpi, wie der RAM ausgelastet ist.
          Grüße Eisbaeeer
          • X
            Danke für Deine Antwort.
            so weit ich weis stoße ich nichts an.
            Habe das mit dem Top probiert, aber für mich sieht das ok aus.
            • X
              Wenn ich die IP Adresse im plex webhooks neu speichere funktioniert es sofort.
              • Eisbaeeer
                Dann wird die Socket Verbindung nicht wieder hergestellt. Ich schau mir das beim nächsten Update an.
                Gruß Eisbaeeer
                Gesendet von meinem SM-G950F mit Tapatalk
                • X
                  Vielen herzlichen dank.
                  Danke für deine mühe.
                  Lg x-ess
                    wizzardking last edited by
                    Vielen Dank für dieses Tool!
                    ... aber leider bekomme ich es einfach nicht zum laufen.
                    Ich wäre sehr dankbar, wenn mir einer sagen könnte, wo evtl. bei mir der Fehler liegen könnte. Vermutlich habe ich irgend was mit den Einstellungen falsch gemacht.
                    PMS
                    Plex Media Server läuft (Mit Lifetime Plexpass) auf meinem QNAP NAS mit der IP 192.168.1.214
                    Webhooks wurde aktiviert und folgendes hinzugefügt: http://192.168.1.220:10000
                    In den Einstellungen ist "Webhooks: Diese Funktion erlaubt deinem Server, Ereignisse an externe Dienste zu senden." ebenfalls aktiviert.
                    ioBroker läuft auf dem selben NAS, allerdings in einem Docker Container und hat daher eine andere IP: 192.168.1.220
                    RAM Probleme habe ich sicher nicht.
                    Die Ampel von Plexconnect ist Grün und die Logs zeigen mir keine Fehler an:
                    unter Objekte zeigt mir Plexconnect aber keine Werte an:
                      Strange... aber nach Plex-Neustart gehts nun 😀
                        Wie sieht es bei euch mit der Reaktionszeit aus?
                        Habe ein Script geschrieben, welches bei der Wiedergabe die Lichtwerte zwischenspeichert und alle Lampen (welche angeschalten sind) dimmt. Sobald die Wiedergabe pausiert oder beendet wird, schalten sich die Lichter auf den vorherigen Wert zurück.
                        Funktioniert soweit sehr gut, ausser das es beim Pausieren/Beenden bis 10 Sekunden dauern kann, bis sich die Lichter wieder hochschalten, bzw. bis sich der Status in Plexconnect ändert.
                        Wird der Status hier vom PMS an Plexconnect gesendet, oder fragt Plexconnect regelmässig den Status beim Plex-Server ab? Falls ersteres... Pech gehabt, da Plex ohnehin nicht auf Anfragen/Feature Requests eingeht. Falls letzteres, wäre es super, wenn der Intervall selber eingestellt werden könnte.
                        • Zefau
                          Zefau last edited by
                          ich habe einen neuen Adapter für Plex geschrieben: ioBroker.plex.
                          Dieser nutzt die Plex API, um Server, Libraries und Settings zu laden (ohne Plex Pass). Weiterhin wird (wie im Plexconnect Adapter) der Plex Webhook (nur für Plex Pass) unterstützt, um die aktuelle Medien-Wiedergabe zu laden. Ohne Plex Pass ist es möglich mit Tautulli (Zusatzsoftware für Plex Statistiken, siehe hier) einen Webhook zu setzen und die aktuelle Wiedergabe in ioBroker zu laden.
                          Über Tests würde ich mich freuen. Einfach per SSH installieren:
                          iobroker url https://github.com/Zefau/ioBroker.plex
                          iobroker upload plex
                          Cheers,
                          Zefau
                            el_malto @Zefau last edited by
                            @Zefau sagte in [Aufruf] Plex connect testen:
                            Cheers,
                            Zefau
                            Magst du dafür einen eigenen Thread anlegen? Ich würde den am WE vielleicht mal testen. Dann hat man einen eigenen Thread um sich auszutauschen.
                            • Zefau
                              Zefau @el_malto last edited by
                              @el_malto sagte in [Aufruf] Plex connect testen:
                              Jo, ist sinnig. Habe einen neuen Thread aufgemacht: https://forum.iobroker.net/topic/22027/aufruf-neuer-adapter-iobroker-plex
                              31.7k
                              79.8k
                              66
                              9015
