    4. ioBroker.js-controller 1.5.6
    • Bluefox
      Bluefox @lobomau last edited by
      @lobomau da kann ich leider jetzt nicht helfen. Man muss sauber alles trennen. Da ist was mit der Installation kaputt
      lobomau 1 Reply Last reply Reply Quote 0
      • Bluefox
        Bluefox @sigi234 last edited by Bluefox
        @sigi234 Welche DasWetter Version hast du?
        kannst du so was probieren ?:
        node C:\ioBroker\node_modules\iobroker.daswetter\main.js --logs
        • lobomau
          lobomau @Bluefox last edited by
          @Bluefox sagte in ioBroker.js-controller 1.5.6:
          Ja, alles klar. Danke. Eben snapshot zurück und gut. Neu mache ich irgendwann in Ruhe.
            sigi234 Forum Testing Most Active @Bluefox last edited by
            starting. Version 2.6.1 in C:/ioBroker/node_modules/iobroker.daswetter, node: v8.15.0
            set timeout to 300 sec
            checking data structures
            deleting unused dataset, reset to true
            using new datastructure
            calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxxx&affiliate_id=xxxxxxx=2.05 days forecast done, objects in list 947
            objects in list: 947
            calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxx&affiliate_id=xxxxxx&v=2.0&h=1
            got 148 channels
            RangeError: Maximum call stack size exceeded
                at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12)
                at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
                at Decoder.add (C:\ioBroker\node_modules\socket.io-parser\index.js:237:14)
                at Manager.ondata (C:\ioBroker\node_modules\socket.io-client\lib\manager.js:322:16)
                at Socket.<anonymous> (C:\ioBroker\node_modules\component-bind\index.js:21:15)
                at Socket.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                at Socket.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:451:14)
                at WS.<anonymous> (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:268:10)
                at WS.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                at WS.Transport.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\transport.js:145:8)
            hourly forecast done, objects in list 2581
            update already running
            terminating
              PrinzEisenherz1 last edited by
              Hi Bluefox, also bei mir kommt folgendes
              oot@ioBroker-VM:~# node /opt/iobroker/node_modules/iobroker.daswetter/main.js --logs
              starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.15.0
              set timeout to 80 sec
              calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz
              7 days forecast done, objects in list 107
              objects in list: 107
              calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz&v=2.0&h=1
              got 150 channels
              got 2875 states
              hourly forecast done, objects in list 1699
              nothing to do
              exit, all done
              root@ioBroker-VM:~#
              Ich hab die Version 2.6.1
              Bluefox 1 Reply Last reply Reply Quote 0
                sigi234 Forum Testing Most Active @coyote last edited by
                @coyote sagte in ioBroker.js-controller 1.5.6:
                Schätze, dass der Fehler erst nach dem ersten Schedule kommt
                Kann ich bestätigen.
                • Bluefox
                  Bluefox @PrinzEisenherz1 last edited by
                  @PrinzEisenherz1 Hier ist alles OK.
                    apollon77 @simatec last edited by
                    @simatec Nach Rücksprache mit @AlCalzone ist das nicht ganz korrek t- zumindestens nicht mit den Installern seit 20.1. glaube ich.
                    Dafpr ind die Default ACLs da die vom Instller gesetzt werden
                    Dann gehören die Dateien zwar dem aktuellen user, iobroker behält trotzdem die Berechtigungen
                    simatec 2 Replies Last reply Reply Quote 0
                    • simatec
                      simatec Developer Most Active @apollon77 last edited by simatec
                      @apollon77
                      OK dann teste ich das noch einmal mit einer neu aufgesetzten Installation.
                      Meine aktuelle mit den manuellen Patch, den ich dann als PR für den Installer gepusht hatte, ging es nicht.
                      Aber ich werde das nochmal reproduzieren und berichten 😉
                      • coyote
                        coyote Most Active @sigi234 last edited by
                        @sigi234 sagte in ioBroker.js-controller 1.5.6:
                        Also bei mir alles ok, kein Fehler im Log von DasWetter. Sind ja jetzt schon mehrere Zyklen durchgelaufen ohne Probleme....
                          Hm........... da wären deine Einstellungen vom Adapter interessant.
                            Ich habe folgendes Verhalten beobachtet:
                            Beim laden wird immer auf 127.0.0.1 gefiltert, wenn ich das Rote X Drücke geht es.
                            • coyote
                              coyote Most Active last edited by
                              Ist nur "neue Datenstruktur" angewählt, Pfad 1-4 ausgefüllt, 60Sek Zeitlimit und Iconset 6
                              Das war's auch schon
                                Aha, ich habe nur Pfad 2+3 drinnen.
                                • coyote
                                  coyote Most Active last edited by coyote
                                  Hm ok, hab 1 und 4 mal raus genommen und schedule auf 2 min, mal sehen ob ein Fehler kommt.
                                  Edit: Alles gut, kein Fehler 🤷
                                    @coyote
                                    daswetter.0	2019-02-14 00:02:01.516	error	RangeError: Maximum call stack size exceeded at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12) at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
                                    daswetter.0	2019-02-14 00:02:01.516	error	uncaught exception: Maximum call stack size exceeded
                                    • coyote
                                      Zur Info:
                                      Socket.io 2.1.1
                                      npm 6.4.1
                                      nodejs 8.12.0
                                      Also hab ich nur eine andere nodejs Version
                                      • cvidal
                                        Seit 1.5.6 wird bei mir auch gefiltert, entweder steht da mal meine Email Adresse oder ne 2323...
                                        Kann mir das überhaupt nicht erklären...
                                        Holger76 sigi234 2 Replies Last reply Reply Quote 0
                                        • Homer.J.
                                          Homer.J. last edited by
                                          Morgen,
                                          2019-02-14 05:15:03.312 - error: daswetter.0 uncaught exception: Maximum call stack size exceeded
                                          2019-02-14 05:15:03.313 - error: daswetter.0 RangeError: Maximum call stack size exceeded
                                          • Bluefox
                                            @sigi234 hat nichts mit js-controller zu tun.
                                            call for action test
                                            31
                                            150
                                            19841
