    4. ioBroker.js-controller 1.5.6
    • lobomau
      lobomau @Bluefox last edited by
      @Bluefox sagte in ioBroker.js-controller 1.5.6:
      @lobomau da kann ich leider jetzt nicht helfen. Man muss sauber alles trennen. Da ist was mit der Installation kaputt
      Ja, alles klar. Danke. Eben snapshot zurück und gut. Neu mache ich irgendwann in Ruhe.
        sigi234 Forum Testing Most Active @Bluefox last edited by
        @sigi234 Welche DasWetter Version hast du?
        kannst du so was probieren ?:
        node C:\ioBroker\node_modules\iobroker.daswetter\main.js --logs
        starting. Version 2.6.1 in C:/ioBroker/node_modules/iobroker.daswetter, node: v8.15.0
        set timeout to 300 sec
        checking data structures
        deleting unused dataset, reset to true
        using new datastructure
        calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxxx&affiliate_id=xxxxxxx=2.05 days forecast done, objects in list 947
        objects in list: 947
        calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=xxxx&affiliate_id=xxxxxx&v=2.0&h=1
        got 148 channels
        RangeError: Maximum call stack size exceeded
            at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12)
            at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
            at Decoder.add (C:\ioBroker\node_modules\socket.io-parser\index.js:237:14)
            at Manager.ondata (C:\ioBroker\node_modules\socket.io-client\lib\manager.js:322:16)
            at Socket.<anonymous> (C:\ioBroker\node_modules\component-bind\index.js:21:15)
            at Socket.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
            at Socket.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:451:14)
            at WS.<anonymous> (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:268:10)
            at WS.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
            at WS.Transport.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\transport.js:145:8)
        hourly forecast done, objects in list 2581
        update already running
        terminating
          PrinzEisenherz1 last edited by
          Hi Bluefox, also bei mir kommt folgendes
          oot@ioBroker-VM:~# node /opt/iobroker/node_modules/iobroker.daswetter/main.js --logs
          starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.15.0
          set timeout to 80 sec
          calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz
          7 days forecast done, objects in list 107
          objects in list: 107
          calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=100557&affiliate_id=1h42khm1qqjz&v=2.0&h=1
          got 150 channels
          got 2875 states
          hourly forecast done, objects in list 1699
          nothing to do
          exit, all done
          root@ioBroker-VM:~#
          Ich hab die Version 2.6.1
          Bluefox 1 Reply Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @coyote last edited by
            @coyote sagte in ioBroker.js-controller 1.5.6:
            Schätze, dass der Fehler erst nach dem ersten Schedule kommt
            Kann ich bestätigen.
            • Bluefox
              Bluefox @PrinzEisenherz1 last edited by
              @PrinzEisenherz1 Hier ist alles OK.
                apollon77 @simatec last edited by
                @simatec Nach Rücksprache mit @AlCalzone ist das nicht ganz korrek t- zumindestens nicht mit den Installern seit 20.1. glaube ich.
                Dafpr ind die Default ACLs da die vom Instller gesetzt werden
                Dann gehören die Dateien zwar dem aktuellen user, iobroker behält trotzdem die Berechtigungen
                simatec 2 Replies Last reply Reply Quote 0
                • simatec
                  simatec Developer Most Active @apollon77 last edited by simatec
                  @apollon77
                  OK dann teste ich das noch einmal mit einer neu aufgesetzten Installation.
                  Meine aktuelle mit den manuellen Patch, den ich dann als PR für den Installer gepusht hatte, ging es nicht.
                  Aber ich werde das nochmal reproduzieren und berichten 😉
                  • coyote
                    coyote Most Active @sigi234 last edited by
                    @sigi234 sagte in ioBroker.js-controller 1.5.6:
                    Also bei mir alles ok, kein Fehler im Log von DasWetter. Sind ja jetzt schon mehrere Zyklen durchgelaufen ohne Probleme....
                      Hm........... da wären deine Einstellungen vom Adapter interessant.
                        Ich habe folgendes Verhalten beobachtet:
                        Beim laden wird immer auf 127.0.0.1 gefiltert, wenn ich das Rote X Drücke geht es.
                        • coyote
                          coyote Most Active last edited by
                          Ist nur "neue Datenstruktur" angewählt, Pfad 1-4 ausgefüllt, 60Sek Zeitlimit und Iconset 6
                          Das war's auch schon
                            Aha, ich habe nur Pfad 2+3 drinnen.
                            • coyote
                              coyote Most Active last edited by coyote
                              Hm ok, hab 1 und 4 mal raus genommen und schedule auf 2 min, mal sehen ob ein Fehler kommt.
                              Edit: Alles gut, kein Fehler 🤷
                                @coyote
                                daswetter.0	2019-02-14 00:02:01.516	error	RangeError: Maximum call stack size exceeded at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12) at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
                                daswetter.0	2019-02-14 00:02:01.516	error	uncaught exception: Maximum call stack size exceeded
                                • coyote
                                  Zur Info:
                                  Socket.io 2.1.1
                                  npm 6.4.1
                                  nodejs 8.12.0
                                  Also hab ich nur eine andere nodejs Version
                                  • cvidal
                                    Seit 1.5.6 wird bei mir auch gefiltert, entweder steht da mal meine Email Adresse oder ne 2323...
                                    Kann mir das überhaupt nicht erklären...
                                    Holger76 sigi234 2 Replies Last reply Reply Quote 0
                                    • Homer.J.
                                      Homer.J. last edited by
                                      Morgen,
                                      2019-02-14 05:15:03.312 - error: daswetter.0 uncaught exception: Maximum call stack size exceeded
                                      2019-02-14 05:15:03.313 - error: daswetter.0 RangeError: Maximum call stack size exceeded
                                      • Bluefox
                                        Bluefox @sigi234 last edited by
                                        @sigi234 hat nichts mit js-controller zu tun.
                                        • Bluefox
                                          Bluefox @Homer.J. last edited by
                                          @Homer1976 hat jemand meine git Version ausprobiert?
                                          Homer.J. 1 Reply Last reply Reply Quote 1
                                          • Matzebhv
                                            Matzebhv last edited by
                                            Moin,
                                            nachdem die 1.5.6 bei mir ja nicht lief und ich wieder zurück auf die 1.4.2 bin habe ich mir ( scheinbar ) wieder ein altes Problem mit Cron eingefangen. Mein Weckerscript wirft bei Cron und Astro einen Fehler:
                                            javascript.0	2019-02-14 08:24:57.808	error	at ContextifyScript.Script.runInContext (vm.js:59:29)
                                            javascript.0	2019-02-14 08:24:57.808	error	at script.js.Funktionen.Wecker:10:1
                                            javascript.0	2019-02-14 08:24:57.808	error	TypeError: schedule is not a function
                                            javascript.0	2019-02-14 08:24:57.808	error	^
                                            javascript.0	2019-02-14 08:24:57.808	error	schedule("30 30 6 * * 1-5", function () {
                                            javascript.0	2019-02-14 08:24:57.808	error	script.js.Funktionen.Wecker: script.js.Funktionen.Wecker:10
                                            javascript.0	2019-02-14 08:27:24.979	error	at ContextifyScript.Script.runInContext (vm.js:59:29)
                                            javascript.0	2019-02-14 08:27:24.979	error	at script.js.Funktionen.Wecker:22:1
                                            javascript.0	2019-02-14 08:27:24.979	error	TypeError: schedule is not a function
                                            javascript.0	2019-02-14 08:27:24.979	error	^
                                            javascript.0	2019-02-14 08:27:24.979	error	schedule({astro: "sunriseEnd", shift: 0}, function () {
                                            javascript.0	2019-02-14 08:27:24.979	error	script.js.Funktionen.Wecker: script.js.Funktionen.Wecker:22
                                            Konnte das noch jemand beobachten?
                                            Matze
                                            Bluefox BBTown 2 Replies Last reply Reply Quote 0
                                            call for action test
                                            31
                                            150
                                            19840
